查看: 9329|回复: 2
[Linux] imx6q使用官方的mfgtool刷机后启动黑屏
i.MX6Q通行证
SamuelXing 发表于 2020-6-28 19:55:55 | 显示全部楼层 |阅读模式
尝试过mfgtool下的原版文件,也尝试过资料中【镜像】文件下的预编译文件;
调试口信息能够正常输出;能正常登入后台;
启动过程中屏幕也会亮,但啥东西都没有显示;
设置过DISPLAY=:0.0;
手动后台运行一个qt例程,界面上也无任何显示;
启动信息如下
  1. [    0.000000] Booting Linux on physical CPU 0x0
  2. [    0.000000] Linux version 4.1.15-dirty (lixinguo@developer-RH2485-V2) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Wed Apr 22 09:14:33 CST 2020
  3. [    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
  4. [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  5. [    0.000000] Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
  6. [    0.000000] Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
  7. [    0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
  8. [    0.000000] Memory policy: Data cache writealloc
  9. [    0.000000] On node 0 totalpages: 524288
  10. [    0.000000] free_area_init_node: node 0, pgdat 80c52200, node_mem_map ee757000
  11. [    0.000000]   Normal zone: 3568 pages used for memmap
  12. [    0.000000]   Normal zone: 0 pages reserved
  13. [    0.000000]   Normal zone: 456704 pages, LIFO batch:31
  14. [    0.000000]   HighMem zone: 67584 pages, LIFO batch:15
  15. [    0.000000] PERCPU: Embedded 12 pages/cpu @ee6fc000 s17420 r8192 d23540 u49152
  16. [    0.000000] pcpu-alloc: s17420 r8192 d23540 u49152 alloc=12*4096
  17. [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  18. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520720
  19. [    0.000000] Kernel command line: console=ttymxc0,115200 video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB24,bpp=16,int_clk video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=16 ldb=sin0 root=/dev/mmcblk3p2 rootwait rw fec.macaddr=9E:AA:95:61:00:A5
  20. [    0.000000] Booting kernel: `9E:AA:95:61:00:A5' invalid for parameter `fec.macaddr'
  21. [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
  22. [    0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
  23. [    0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
  24. [    0.000000] Memory: 1737376K/2097152K available (8553K kernel code, 500K rwdata, 3092K rodata, 440K init, 458K bss, 32096K reserved, 327680K cma-reserved, 270336K highmem)
  25. [    0.000000] Virtual kernel memory layout:
  26.                    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  27.                    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
  28.                    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
  29.                    lowmem  : 0x80000000 - 0xef800000   (1784 MB)
  30.                    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
  31.                    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
  32.                      .text : 0x80008000 - 0x80b678b8   (11647 kB)
  33.                      .init : 0x80b68000 - 0x80bd6000   ( 440 kB)
  34.                      .data : 0x80bd6000 - 0x80c533e0   ( 501 kB)
  35.                       .bss : 0x80c56000 - 0x80cc8828   ( 459 kB)
  36. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  37. [    0.000000] Preemptible hierarchical RCU implementation.
  38. [    0.000000]         Additional per-CPU info printed with stalls.
  39. [    0.000000] NR_IRQS:16 nr_irqs:16 16
  40. [    0.000000] L2C-310 erratum 769419 enabled
  41. [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
  42. [    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
  43. [    0.000000] L2C-310 ID prefetch enabled, offset 16 lines
  44. [    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
  45. [    0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
  46. [    0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
  47. [    0.000000] mxc_clocksource_init 3000000
  48. [    0.000000] Switching to timer-based delay loop, resolution 333ns
  49. [    0.000006] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
  50. [    0.000024] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
  51. [    0.001189] Console: colour dummy device 80x30
  52. [    0.001209] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
  53. [    0.001224] pid_max: default: 32768 minimum: 301
  54. [    0.001326] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
  55. [    0.001340] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
  56. [    0.001979] CPU: Testing write buffer coherency: ok
  57. [    0.002276] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  58. [    0.002367] Setting up static identity map for 0x10008280 - 0x100082d8
  59. [    0.060119] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  60. [    0.080119] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  61. [    0.100122] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  62. [    0.100186] Brought up 4 CPUs
  63. [    0.100210] SMP: Total of 4 processors activated (24.00 BogoMIPS).
  64. [    0.100219] CPU: All CPU(s) started in SVC mode.
  65. [    0.100708] devtmpfs: initialized
  66. [    0.113306] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
  67. [    0.113704] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
  68. [    0.131202] pinctrl core: initialized pinctrl subsystem
  69. [    0.132460] NET: Registered protocol family 16
  70. [    0.141422] DMA: preallocated 256 KiB pool for atomic coherent allocations
  71. [    0.169665] cpuidle: using governor ladder
  72. [    0.199661] cpuidle: using governor menu
  73. [    0.199867] CPU identified as i.MX6Q, silicon rev 1.5
  74. [    0.211734] anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid default voltage selector.
  75. [    0.211759] anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with error -22
  76. [    0.212419] anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid default voltage selector.
  77. [    0.212440] anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with error -22
  78. [    0.226153] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
  79. [    0.226165] hw-breakpoint: maximum watchpoint size is 4 bytes.
  80. [    0.227427] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
  81. [    0.272483] mxs-dma 110000.dma-apbh: initialized
  82. [    0.277060] SCSI subsystem initialized
  83. [    0.277257] libata version 3.00 loaded.
  84. [    0.277565] usbcore: registered new inte**ce driver usbfs
  85. [    0.277638] usbcore: registered new inte**ce driver hub
  86. [    0.277730] usbcore: registered new device driver usb
  87. [    0.277921] 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
  88. [    0.278064] 2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
  89. [    0.278930] i2c-gpio i2c-ft5326: using pins 35 (SDA) and 169 (SCL)
  90. [    0.280045] i2c i2c-0: IMX I2C adapter registered
  91. [    0.280066] i2c i2c-0: can't use DMA
  92. [    0.280714] i2c i2c-1: IMX I2C adapter registered
  93. [    0.280732] i2c i2c-1: can't use DMA
  94. [    0.281995] i2c i2c-2: IMX I2C adapter registered
  95. [    0.282011] i2c i2c-2: can't use DMA
  96. [    0.282167] Linux video capture inte**ce: v2.00
  97. [    0.282261] pps_core: LinuxPPS API ver. 1 registered
  98. [    0.282271] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  99. [    0.282305] PTP clock support registered
  100. [    0.299712] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  101. [    0.319705] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  102. [    0.321048] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
  103. [    0.321063] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
  104. [    0.321157] MIPI CSI2 driver module loaded
  105. [    0.321433] Advanced Linux Sound Architecture Driver Initialized.
  106. [    0.323619] Switched to clocksource mxc_timer1
  107. [    0.334864] NET: Registered protocol family 2
  108. [    0.335552] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
  109. [    0.335714] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
  110. [    0.336002] TCP: Hash tables configured (established 16384 bind 16384)
  111. [    0.336191] UDP hash table entries: 1024 (order: 3, 32768 bytes)
  112. [    0.336269] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
  113. [    0.336543] NET: Registered protocol family 1
  114. [    0.336922] RPC: Registered named UNIX socket transport module.
  115. [    0.336934] RPC: Registered udp transport module.
  116. [    0.336944] RPC: Registered tcp transport module.
  117. [    0.336951] RPC: Registered tcp NFSv4.1 backchannel transport module.
  118. [    0.337605] CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
  119. [    0.337655] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
  120. [    0.338909] imx rpmsg driver is registered.
  121. [    0.339926] Bus freq driver module loaded
  122. [    0.341097] futex hash table entries: 1024 (order: 4, 65536 bytes)
  123. [    0.348330] VFS: Disk quotas dquot_6.6.0
  124. [    0.348524] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  125. [    0.350625] NFS: Registering the id_resolver key type
  126. [    0.350662] Key type id_resolver registered
  127. [    0.350671] Key type id_legacy registered
  128. [    0.350773] jffs2: version 2.2. (NAND) \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
  129. [    0.351514] fuse init (API version 7.23)
  130. [    0.355657] bounce: pool size: 64 pages
  131. [    0.355677] io scheduler noop registered
  132. [    0.355693] io scheduler deadline registered
  133. [    0.355881] io scheduler cfq registered (default)
  134. [    0.356473] imx-weim 21b8000.weim: Driver registered.
  135. [    0.358726] mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
  136. [    0.358848] MIPI DSI driver module loaded
  137. [    0.359098] MIPI DSI driver module loaded
  138. [    0.361973] mxc_sdc_fb fb@0: registered mxc display driver lcd
  139. [    0.437698] Console: switching to colour frame buffer device 100x30
  140. [    0.474361] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
  141. [    0.474387] fbcvt: 1920x1080@60: CVT Name - 2.073M9
  142. [    0.474527] mxc_sdc_fb fb@1: registered mxc display driver hdmi
  143. [    0.500366] imx-sdma 20ec000.sdma: no iram assigned, using external mem
  144. [    0.500779] imx-sdma 20ec000.sdma: no event needs to be remapped
  145. [    0.501039] imx-sdma 20ec000.sdma: loaded firmware 3.3
  146. [    0.503990] imx-sdma 20ec000.sdma: initialized
  147. [    0.505713] pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
  148. [    0.506328] pfuze100-regulator 1-0008: FAB: 0, FIN: 0
  149. [    0.506343] pfuze100-regulator 1-0008: pfuze100 found.
  150. [    0.521857] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 25, base_baud = 5000000) is a IMX
  151. [    1.376625] console [ttymxc0] enabled
  152. [    1.381048] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 302, base_baud = 5000000) is a IMX
  153. [    1.390267] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 303, base_baud = 5000000) is a IMX
  154. [    1.399512] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 304, base_baud = 5000000) is a IMX
  155. [    1.409025] usbcore: registered new inte**ce driver cdc_xr_usb_serial
  156. [    1.415586] xr_usb_serial_common: Exar USB UART (serial port) driver
  157. [    1.423931] imx sema4 driver is registered.
  158. [    1.428214] [drm] Initialized drm 1.1.0 20060810
  159. [    1.433350] [drm] Initialized vivante 1.0.0 20120216 on minor 0
  160. [    1.449048] brd: module loaded
  161. [    1.458559] loop: module loaded
  162. [    1.463238] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
  163. [    1.471213] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
  164. [    1.479251] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
  165. [    1.487465] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
  166. [    1.499168] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
  167. [    1.506187] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
  168. [    1.515008] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
  169. [    1.525647] scsi host0: ahci-imx
  170. [    1.529234] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 314
  171. [    1.541243] spi_imx 200c000.ecspi: probed
  172. [    1.546296] CAN device driver inte**ce
  173. [    1.551590] flexcan 2090000.flexcan: device registered (reg_base=f02e8000, irq=32)
  174. [    1.560423] 2188000.ethernet supply phy not found, using dummy regulator
  175. [    1.584079] pps pps0: new PPS source ptp0
  176. [    1.593456] libphy: fec_enet_mii_bus: probed
  177. [    1.598363] fec 2188000.ethernet eth0: registered PHC device 0
  178. [    1.605119] PPP generic driver version 2.4.2
  179. [    1.609609] PPP BSD Compression module registered
  180. [    1.614350] PPP Deflate Compression module registered
  181. [    1.619437] PPP MPPE Compression module registered
  182. [    1.624262] NET: Registered protocol family 24
  183. [    1.628823] usbcore: registered new inte**ce driver asix
  184. [    1.634323] usbcore: registered new inte**ce driver cdc_ether
  185. [    1.640223] usbcore: registered new inte**ce driver cdc_subset
  186. [    1.646272] usbcore: registered new inte**ce driver cdc_ncm
  187. [    1.651975] GobiNet: Quectel_WCDMA<E_Linux&Android_GobiNet_Driver_V1.3.0
  188. [    1.658944] usbcore: registered new inte**ce driver GobiNet
  189. [    1.664635] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  190. [    1.671178] ehci-mxc: Freescale On-Chip EHCI Host driver
  191. [    1.676711] usbcore: registered new inte**ce driver usb-storage
  192. [    1.682918] usbcore: registered new inte**ce driver usbserial
  193. [    1.688837] usbcore: registered new inte**ce driver option
  194. [    1.694481] usbserial: USB Serial support registered for GSM modem (1-port)
  195. [    1.701512] usbcore: registered new inte**ce driver pl2303
  196. [    1.707154] usbserial: USB Serial support registered for pl2303
  197. [    1.713148] usbcore: registered new inte**ce driver usb_ehset_test
  198. [    1.720759] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
  199. [    1.729067] usb_otg_vbus: supplied by SWBST
  200. [    1.738794] usb_h1_vbus: supplied by SWBST
  201. [    1.746248] ci_hdrc ci_hdrc.1: EHCI Host Controller
  202. [    1.751163] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
  203. [    1.773655] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
  204. [    1.779953] hub 1-0:1.0: USB hub found
  205. [    1.783793] hub 1-0:1.0: 1 port detected
  206. [    1.788889] mousedev: PS/2 mouse device common for all mice
  207. [    1.795376] edt_ft5x06 2-0038: touchscreen probe failed
  208. [    1.800630] edt_ft5x06: probe of 2-0038 failed with error -5
  209. [    1.813111] input: EP0790M09 as /devices/soc0/i2c-ft5326/i2c-3/3-0038/input/input1
  210. [    1.821223] <<-GTP-INFO->> GTP driver installing...
  211. [    1.826411] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
  212. [    1.832343] <<-GTP-INFO->> GTP I2C Address: 0x14
  213. [    1.838026] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  214. [    1.844925] <<-GTP-ERROR->> GTP i2c test failed time 1.
  215. [    1.864670] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  216. [    1.871553] <<-GTP-ERROR->> GTP i2c test failed time 2.
  217. [    1.883724] ata1: SATA link down (SStatus 0 SControl 300)
  218. [    1.889170] ahci-imx 2200000.sata: no device found, disabling link.
  219. [    1.894686] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  220. [    1.894690] <<-GTP-ERROR->> GTP i2c test failed time 3.
  221. [    1.907607] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
  222. [    1.914672] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  223. [    1.914676] <<-GTP-ERROR->> GTP i2c test failed time 4.
  224. [    1.934669] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  225. [    1.941552] <<-GTP-ERROR->> GTP i2c test failed time 5.
  226. [    1.963639] <<-GTP-ERROR->> I2C read failed.
  227. [    1.967989] <<-GTP-INFO->> GTP driver installing...
  228. [    1.973276] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
  229. [    1.979228] <<-GTP-INFO->> GTP I2C Address: 0x5d
  230. [    1.984941] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  231. [    1.991824] <<-GTP-ERROR->> GTP i2c test failed time 1.
  232. [    2.014668] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  233. [    2.021551] <<-GTP-ERROR->> GTP i2c test failed time 2.
  234. [    2.044704] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  235. [    2.051588] <<-GTP-ERROR->> GTP i2c test failed time 3.
  236. [    2.074668] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  237. [    2.081551] <<-GTP-ERROR->> GTP i2c test failed time 4.
  238. [    2.104666] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  239. [    2.111549] <<-GTP-ERROR->> GTP i2c test failed time 5.
  240. [    2.123648] usb 1-1: new high-speed USB device number 2 using ci_hdrc
  241. [    2.133640] <<-GTP-ERROR->> I2C read failed.
  242. [    2.138117] usbcore: registered new inte**ce driver usbtouchscreen
  243. [    2.144983] input: TSC2007 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a8000.i2c/i2c-2/2-0048/input/input2
  244. [    2.159849] rtc-rx8010 2-0032: Update timer was detected
  245. [    2.172321] rtc-rx8010 2-0032: rtc core: registered rx8010 as rtc0
  246. [    2.178541] rtc-rx8010 2-0032: IRQ 74 supplied
  247. [    2.184042] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
  248. [    2.192910] i2c /dev entries driver
  249. [    2.198047] IR NEC protocol handler initialized
  250. [    2.202597] IR RC5(x/sz) protocol handler initialized
  251. [    2.207688] IR RC6 protocol handler initialized
  252. [    2.212234] IR JVC protocol handler initialized
  253. [    2.216796] IR Sony protocol handler initialized
  254. [    2.221428] IR SANYO protocol handler initialized
  255. [    2.226164] IR Sharp protocol handler initialized
  256. [    2.230884] IR MCE Keyboard/mouse protocol handler initialized
  257. [    2.236748] IR XMP protocol handler initialized
  258. [    2.274832] hub 1-1:1.0: USB hub found
  259. [    2.278788] hub 1-1:1.0: 4 ports detected
  260. [    2.333853] ov5640_read_reg:write reg error:reg=300a
  261. [    2.338829] camera ov5640 is not found
  262. [    2.523851] ov5640_read_reg:write reg error:reg=300a
  263. [    2.528833] camera ov5640_mipi is not found
  264. [    2.534356] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
  265. [    2.541135] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
  266. [    2.547938] mxc_v4l2_output v4l2_out: V4L2 device registered as video18
  267. [    2.554990] usbcore: registered new inte**ce driver uvcvideo
  268. [    2.560746] USB Video Class driver (1.1.1)
  269. [    2.564888] usb 1-1.3: new high-speed USB device number 3 using ci_hdrc
  270. [    2.573231] mma8451 0-001c: read chip ID 0x1 is not equal to 0x1a or 0x2a!
  271. [    2.580287] mma8451: probe of 0-001c failed with error -22
  272. [    2.586765] imx2-wdt 20c0000.wdog: use WDOG_B to reboot.
  273. [    2.592425] imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
  274. [    2.598878] sdhci: Secure Digital Host Controller Inte**ce driver
  275. [    2.605122] sdhci: Copyright(c) Pierre Ossman
  276. [    2.609526] sdhci-pltfm: SDHCI platform and OF driver helper
  277. [    2.616059] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
  278. [    2.623240] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
  279. [    2.629767] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
  280. [    2.635988] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
  281. [    2.683786] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
  282. [    2.691492] /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
  283. [    2.698677] sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
  284. [    2.703895] sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
  285. [    2.710420] sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
  286. [    2.716699] sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
  287. [    2.773806] mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
  288. [    2.781637] /soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
  289. [    2.789138] sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
  290. [    2.795354] sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
  291. [    2.843650] mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
  292. [    2.852536] mxc_vpu 2040000.vpu_fsl: VPU initialized
  293. [    2.858136] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
  294. [    2.866390] mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
  295. [    2.873914] Galcore version 5.0.11.41671
  296. [    2.920117] mmc3: MAN_BKOPS_EN bit is not set
  297. [    2.945779] mmc3: new DDR MMC card at address 0001
  298. [    2.951542] mmcblk3: mmc3:0001 DG4008 7.28 GiB
  299. [    2.956591] mmcblk3boot0: mmc3:0001 DG4008 partition 1 4.00 MiB
  300. [    2.962959] mmcblk3boot1: mmc3:0001 DG4008 partition 2 4.00 MiB
  301. [    2.969393] mmcblk3rpmb: mmc3:0001 DG4008 partition 3 4.00 MiB
  302. [    2.977015]  mmcblk3: p1 p2
  303. [    3.559869] caam 2100000.caam: Entropy delay = 3200
  304. [    3.625577] caam 2100000.caam: Instantiated RNG4 SH0
  305. [    3.686340] caam 2100000.caam: Instantiated RNG4 SH1
  306. [    3.691321] caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
  307. [    3.698050] caam 2100000.caam: job rings = 2, qi = 0
  308. [    3.769422] caam algorithms registered in /proc/crypto
  309. [    3.778697] caam_jr 2101000.jr0: registering rng-caam
  310. [    3.784730] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
  311. [    3.790718] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
  312. [    3.799506] usbcore: registered new inte**ce driver usbhid
  313. [    3.805117] usbhid: USB HID core driver
  314. [    3.818347] fsl-asrc 2034000.asrc: driver registered
  315. [    3.832502] imx-wm8960 sound: wm8960-hifi <-> 202c000.ssi mapping ok
  316. [    3.844202] imx-wm8960 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
  317. [    3.851293] imx-wm8960 sound: wm8960-hifi <-> 202c000.ssi mapping ok
  318. [    3.970980] imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
  319. [    3.979850] NET: Registered protocol family 26
  320. [    3.984352] Netfilter messages via NETLINK v0.30.
  321. [    3.989150] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
  322. [    3.995975] ctnetlink v0.93: registering with nfnetlink.
  323. [    4.002040] xt_time: kernel timezone is -0000
  324. [    4.006854] ip_tables: (C) 2000-2006 Netfilter Core Team
  325. [    4.012385] arp_tables: (C) 2002 David S. Miller
  326. [    4.017776] NET: Registered protocol family 10
  327. [    4.023352] sit: IPv6 over IPv4 tunneling driver
  328. [    4.028752] NET: Registered protocol family 17
  329. [    4.033249] NET: Registered protocol family 15
  330. [    4.037734] can: controller area network core (rev 20120528 abi 9)
  331. [    4.044030] NET: Registered protocol family 29
  332. [    4.048532] can: raw protocol (rev 20120528)
  333. [    4.052821] can: broadcast manager protocol (rev 20120528 t)
  334. [    4.058528] can: netlink gateway (rev 20130117) max_hops=1
  335. [    4.064280] 8021q: 802.1Q VLAN Support v1.8
  336. [    4.068525] Key type dns_resolver registered
  337. [    4.077541] pwm-backlight supply power not found, using dummy regulator
  338. [    4.085472] backlight supply power not found, using dummy regulator
  339. [    4.095042] dhd_module_init in
  340. [    4.099062] input: gpio-keys as /devices/soc0/gpio-keys/input/input5
  341. [    4.107068] rtc-rx8010 2-0032: setting system clock to 2020-06-28 19:44:43 UTC (1593373483)
  342. [    4.126459] SW4: disabling
  343. [    4.129191] SATA_EN: disabling
  344. [    4.132252] CAN XCVR: disabling
  345. [    4.135451] usb_otg_vbus: disabling
  346. [    4.139161] ALSA device list:
  347. [    4.142135]   #0: wm8960-audio
  348. [    4.145215]   #1: imx-hdmi-soc
  349. [    4.209453] kjournald starting.  Commit interval 5 seconds
  350. [    4.209921] EXT3-fs (mmcblk3p2): using internal journal
  351. [    4.210283] EXT3-fs (mmcblk3p2): recovery complete
  352. [    4.210288] EXT3-fs (mmcblk3p2): mounted filesystem with ordered data mode
  353. [    4.210325] VFS: Mounted root (ext3 filesystem) on device 179:2.
  354. [    4.211220] devtmpfs: mounted
  355. [    4.212074] Freeing unused kernel memory: 440K (80b68000 - 80bd6000)
  356. [    4.743278] udevd[210]: starting version 3.1.5
  357. [    4.759059] random: udevd urandom read with 22 bits of entropy available
  358. [    5.076722] tsc2007 2-0048: i2c io error: -5
  359. [    5.106564] ERROR: v4l2 capture: slave not found!
  360. [    5.108108] ERROR: v4l2 capture: slave not found!
  361. [    5.761765] FAT-fs (mmcblk3p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
  362. [    5.773340] usbcore: registered new inte**ce driver rtl8723bu
  363. [    6.984529] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
  364. [    7.033839] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  365. [    8.287137] tsc2007 2-0048: i2c io error: -5
  366. [   10.984336] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
  367. [   10.992066] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  368. [   12.985671] fec 2188000.ethernet eth0: Link is Down
  369. [   13.076217] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  370. [   13.984355] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
  371. [   13.992235] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  372. [   24.474857] random: nonblocking pool is initialized
  373. [  132.364240] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
复制代码
ps -aux 信息如下
  1. USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
  2. root         1  1.1  0.0   1712  1124 ?        Ss   19:44   0:03 init [5]
  3. root         2  0.0  0.0      0     0 ?        S    19:44   0:00 [kthreadd]
  4. root         3  0.0  0.0      0     0 ?        S    19:44   0:00 [ksoftirqd/0]
  5. root         4  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/0:0]
  6. root         5  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/0:0H]
  7. root         6  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/u8:0]
  8. root         7  0.0  0.0      0     0 ?        S    19:44   0:00 [rcu_preempt]
  9. root         8  0.0  0.0      0     0 ?        S    19:44   0:00 [rcu_sched]
  10. root         9  0.0  0.0      0     0 ?        S    19:44   0:00 [rcu_bh]
  11. root        10  0.0  0.0      0     0 ?        S    19:44   0:00 [migration/0]
  12. root        11  0.0  0.0      0     0 ?        S    19:44   0:00 [migration/1]
  13. root        12  0.0  0.0      0     0 ?        S    19:44   0:00 [ksoftirqd/1]
  14. root        13  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/1:0]
  15. root        14  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/1:0H]
  16. root        15  0.0  0.0      0     0 ?        S    19:44   0:00 [migration/2]
  17. root        16  0.0  0.0      0     0 ?        S    19:44   0:00 [ksoftirqd/2]
  18. root        17  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/2:0]
  19. root        18  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/2:0H]
  20. root        19  0.0  0.0      0     0 ?        S    19:44   0:00 [migration/3]
  21. root        20  0.0  0.0      0     0 ?        S    19:44   0:00 [ksoftirqd/3]
  22. root        21  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/3:0]
  23. root        22  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/3:0H]
  24. root        23  0.0  0.0      0     0 ?        S<   19:44   0:00 [khelper]
  25. root        24  0.0  0.0      0     0 ?        S    19:44   0:00 [kdevtmpfs]
  26. root        25  0.0  0.0      0     0 ?        S<   19:44   0:00 [perf]
  27. root        26  0.0  0.0      0     0 ?        S<   19:44   0:00 [writeback]
  28. root        27  0.0  0.0      0     0 ?        S<   19:44   0:00 [crypto]
  29. root        28  0.0  0.0      0     0 ?        S<   19:44   0:00 [bioset]
  30. root        29  0.0  0.0      0     0 ?        S<   19:44   0:00 [kblockd]
  31. root        30  0.0  0.0      0     0 ?        S<   19:44   0:00 [ata_sff]
  32. root        31  0.0  0.0      0     0 ?        S    19:44   0:00 [ipu1_task]
  33. root        32  0.0  0.0      0     0 ?        S    19:44   0:00 [ipu1_task]
  34. root        33  0.0  0.0      0     0 ?        S    19:44   0:00 [ipu2_task]
  35. root        34  0.0  0.0      0     0 ?        S    19:44   0:00 [ipu2_task]
  36. root        35  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/0:1]
  37. root        36  0.0  0.0      0     0 ?        S<   19:44   0:00 [cfg80211]
  38. root        37  0.0  0.0      0     0 ?        S<   19:44   0:00 [rpciod]
  39. root        38  0.0  0.0      0     0 ?        S    19:44   0:00 [kswapd0]
  40. root        39  0.0  0.0      0     0 ?        S    19:44   0:00 [fsnotify_mark]
  41. root        40  0.0  0.0      0     0 ?        S<   19:44   0:00 [nfsiod]
  42. root        77  0.0  0.0      0     0 ?        S    19:44   0:00 [scsi_eh_0]
  43. root        78  0.0  0.0      0     0 ?        S<   19:44   0:00 [scsi_tmf_0]
  44. root        79  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/u8:1]
  45. root        80  0.0  0.0      0     0 ?        S    19:44   0:00 [spi1]
  46. root        81  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/u8:2]
  47. root        84  0.0  0.0      0     0 ?        S<   19:44   0:00 [ci_otg]
  48. root        85  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/1:1]
  49. root        86  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/76-edt-ft53]
  50. root        87  0.0  0.0      0     0 ?        S<   19:44   0:00 [goodix_wq]
  51. root        88  0.0  0.0      0     0 ?        S<   19:44   0:00 [gtp_esd_check]
  52. root        89  0.0  0.0      0     0 ?        S<   19:44   0:00 [goodix_wq]
  53. root        90  0.0  0.0      0     0 ?        S<   19:44   0:00 [gtp_esd_check]
  54. root        91  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/1:2]
  55. root        92  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/2:1]
  56. root        93  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/123-tsc2007]
  57. root        94  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/74-rx8010]
  58. root        95  0.0  0.0      0     0 ?        S    19:44   0:00 [cfinteractive]
  59. root        96  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/291-mmc1]
  60. root        97  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/71-2194000.]
  61. root        98  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/292-mmc2]
  62. root        99  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/69-2198000.]
  63. root       100  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/293-mmc3]
  64. root       101  0.0  0.0      0     0 ?        S<   19:44   0:00 [vpu_wq]
  65. root       102  0.0  0.0      0     0 ?        S<   19:44   0:00 [galcore workque]
  66. root       103  0.0  0.0      0     0 ?        S    19:44   0:00 [Vivante Kernel ]
  67. root       104  0.3  0.0      0     0 ?        S    19:44   0:00 [mmcqd/3]
  68. root       105  0.0  0.0      0     0 ?        S    19:44   0:00 [mmcqd/3boot0]
  69. root       106  0.0  0.0      0     0 ?        S    19:44   0:00 [mmcqd/3boot1]
  70. root       107  0.0  0.0      0     0 ?        S    19:44   0:00 [mmcqd/3rpmb]
  71. root       108  0.0  0.0      0     0 ?        S    19:44   0:00 [galcore daemon ]
  72. root       109  0.0  0.0      0     0 ?        S    19:44   0:00 [galcore daemon ]
  73. root       110  0.0  0.0      0     0 ?        S    19:44   0:00 [galcore daemon ]
  74. root       173  0.0  0.0      0     0 ?        S<   19:44   0:00 [ipv6_addrconf]
  75. root       174  0.0  0.0      0     0 ?        S<   19:44   0:00 [deferwq]
  76. root       175  0.0  0.0      0     0 ?        S    19:44   0:00 [irq/274-imx_the]
  77. root       176  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/0:1H]
  78. root       177  0.0  0.0      0     0 ?        S    19:44   0:00 [kjournald]
  79. root       178  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/1:1H]
  80. root       182  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/3:1H]
  81. root       183  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/3:1]
  82. root       194  0.0  0.0      0     0 ?        S<   19:44   0:00 [kworker/2:1H]
  83. root       211  0.1  0.1   3500  2328 ?        Ss   19:44   0:00 /sbin/udevd -d
  84. root       570  0.0  0.0    844    40 ?        S    19:44   0:00 /usr/bin/stupid-ftpd.Linux6 -f /etc/stupid-ftpd.conf
  85. root       600  0.0  0.1   2768  2132 ?        S    19:44   0:00 /bin/sh /etc/rc5.d/S01xserver-nodm start background
  86. root       602  0.0  0.0      0     0 ?        S    19:44   0:00 [kworker/0:2]
  87. message+   630  0.0  0.0   3260  1840 ?        Ss   19:44   0:00 /usr/bin/dbus-daemon --system
  88. root       635  0.0  0.0   3212   540 ?        S    19:44   0:00 xinit /etc/X11/Xsession -- /usr/bin/Xorg -br -pn -nolisten tcp +iglx
  89. root       636  0.2  0.5 165740 11888 ?        S<s  19:44   0:00 /usr/bin/Xorg :0 -br -pn -nolisten tcp +iglx
  90. root       637  0.0  0.1   7348  3860 ?        Ss   19:44   0:00 /usr/sbin/connmand
  91. rpc        648  0.0  0.0   2204  1440 ?        Ss   19:44   0:00 /usr/sbin/rpcbind
  92. root       661  0.0  0.0   2904  2024 ?        Ss   19:44   0:00 /usr/sbin/rpc.statd
  93. root       670  0.0  0.0   2168  1424 ?        S    19:44   0:00 /usr/sbin/atd -f
  94. root       685  0.0  0.0   1952  1328 ?        Ss   19:44   0:00 /sbin/syslogd
  95. root       687  0.1  0.2   4932  4332 ?        Ss   19:44   0:00 /sbin/klogd
  96. root       691  0.0  0.2   7196  4340 ?        S    19:44   0:00 matchbox-window-manager -theme Sato -use_desktop_mode decorated -use_cursor yes
  97. root       701  0.0  0.0   4172  1644 ?        S    19:44   0:00 /usr/bin/dbus-launch --auto-syntax --exit-with-session
  98. root       703  0.0  0.0   3152  1584 ?        Ss   19:44   0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
  99. avahi      705  0.4  0.1   3700  2108 ?        S    19:44   0:01 avahi-daemon: running [imx6qsabresd.local]
  100. avahi      707  0.0  0.0   3700   172 ?        S    19:44   0:00 avahi-daemon: chroot helper
  101. root       735  0.0  0.1   4920  2884 ?        Ss   19:44   0:00 /usr/sbin/ofonod
  102. root       754  0.0  0.0   3088  1860 ?        Ss   19:44   0:00 /usr/sbin/crond
  103. root       757  0.0  0.0   3328   628 ?        S    19:44   0:00 autohdmi
  104. root       767  0.0  0.0   4964  1880 ?        Ss   19:44   0:00 /usr/local/sbin/sshd
  105. root       776  0.0  0.0   2772   536 ?        Ss   19:44   0:00 /bin/bash /etc/init.d/rc_mxc.S
  106. root       777  0.0  0.0   2728   436 tty1     Ss+  19:44   0:00 /sbin/getty 38400 tty1
  107. root       779  0.2  0.1   3748  3028 ttymxc0  Ss+  19:44   0:00 -sh
  108. root       785  0.0  0.0   2768  1348 ?        S    19:45   0:00 /bin/sh /etc/X11/Xsession
  109. root       790  0.0  0.2  34788  4480 ?        Sl   19:45   0:00 /usr/libexec/at-spi-bus-launcher --launch-immediately
  110. root       794  0.0  0.5  21776 11144 ?        S    19:45   0:00 connman-applet
  111. root       813  0.0  0.1   3152  2160 ?        S    19:45   0:00 /usr/bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
  112. root       820  0.3  0.7  23444 15020 ?        S    19:45   0:00 matchbox-desktop
  113. root       822  0.1  0.6  22956 12940 ?        S    19:45   0:00 matchbox-panel --titlebar --start-applets showdesktop,windowselector --end-applets clock,battery,keyboard,systray,startup-notify,notify
  114. root       825  0.0  0.1   6960  3576 ?        S    19:45   0:00 /usr/libexec/gconfd-2
  115. root       827  0.0  0.1  16944  3424 ?        S    19:45   0:00 /usr/bin/settings-daemon
  116. root       831  0.0  0.1   6324  2976 ?        S    19:45   0:00 matchbox-keyboard -d
  117. root       833  0.0  0.0      0     0 ?        S    19:45   0:00 [kworker/u8:3]
  118. root       870  0.7  0.1   4964  3576 ?        Ss   19:48   0:00 sshd: root@pts/0
  119. root       872  0.5  0.1   3744  3028 pts/0    Ss   19:48   0:00 -sh
  120. root       878  0.9  0.1   4964  3380 ?        Ss   19:48   0:00 sshd: root@notty
  121. root       880  0.0  0.1   4432  2144 ?        Ss   19:48   0:00 /usr/local/libexec/sftp-server
  122. root       881  0.1  0.1   4432  2120 ?        Ss   19:48   0:00 /usr/local/libexec/sftp-server
  123. root       884  0.0  0.0   3028  1664 pts/0    R+   19:48   0:00 ps -aux
复制代码
i.MX6Q通行证
楼主| SamuelXing 发表于 2020-6-28 19:58:08 | 显示全部楼层
采用的时4.1.15+QT5.6的资料
Forlinx-Niuzc 发表于 2020-6-29 08:49:22 | 显示全部楼层
您用的屏是我们提供的吗,您看看您屏幕的分辨率和开发板选择的一致吗
