查看: 9167|回复: 0
[Ubuntu] OK1012A Openssl升级问题
LS1012A通行证
w_wengang 发表于 2020-7-15 18:15:42 | 显示全部楼层 |阅读模式
OK1012A Ubuntu自带的Openssl 1.0.2L,想升级为1.1.1d版本,但是在make的时候就报错,应该怎么升级?
root@localhost:~/source/openssl-1.1.1d# ./config no-asm shared
Operating system: aarch64-whatever-linux2
Configuring OpenSSL version 1.1.1d (0x1010104fL) for linux-aarch64
Using os-specific seed configuration
Creating configdata.pm
Creating Makefile
***   OpenSSL has been successfully configured                     ***
***   If you encounter a problem while building, please open an    ***
***   issue on GitHub <https://github.com/openssl/openssl/issues>  ***
***   and include the output from the following command:           ***
***       perl configdata.pm --dump                                ***
***   (If you are new to OpenSSL, you might want to consult the    ***
***   'Troubleshooting' section in the INSTALL file first)         ***
Creating Makefile
root@localhost:~/source/openssl-1.1.1d# make
make: Warning: File 'crypto/include/internal/bn_conf.h.in' has modification time 50949035 s in the future
Detected changed: Configure config Configurations/common0.tmpl Configurations/unix-Makefile.tmpl Configurations/common.tmpl build.info crypto/build.info ssl/build.info engines/build.info apps/build.info test/build.info util/build.info tools/build.info fuzz/build.info crypto/objects/build.info crypto/md4/build.info crypto/md5/build.info crypto/sha/build.info crypto/mdc2/build.info crypto/hmac/build.info crypto/ripemd/build.info crypto/whrlpool/build.info crypto/poly1305/build.info crypto/blake2/build.info crypto/siphash/build.info crypto/sm3/build.info crypto/des/build.info crypto/aes/build.info crypto/rc2/build.info crypto/rc4/build.info crypto/idea/build.info crypto/aria/build.info crypto/bf/build.info crypto/cast/build.info crypto/camellia/build.info crypto/seed/build.info crypto/sm4/build.info crypto/chacha/build.info crypto/modes/build.info crypto/bn/build.info crypto/ec/build.info crypto/rsa/build.info crypto/dsa/build.info crypto/dh/build.info crypto/sm2/build.info crypto/dso/build.info crypto/engine/build.info crypto/buffer/build.info crypto/bio/build.info crypto/stack/build.info crypto/lhash/build.info crypto/rand/build.info crypto/err/build.info crypto/evp/build.info crypto/asn1/build.info crypto/pem/build.info crypto/x509/build.info crypto/x509v3/build.info crypto/conf/build.info crypto/txt_db/build.info crypto/pkcs7/build.info crypto/pkcs12/build.info crypto/comp/build.info crypto/ocsp/build.info crypto/ui/build.info crypto/cms/build.info crypto/ts/build.info crypto/srp/build.info crypto/cmac/build.info crypto/ct/build.info crypto/async/build.info crypto/kdf/build.info crypto/store/build.info test/ossl_shim/build.info Configurations/00-base-templates.conf Configurations/10-main.conf
/usr/bin/perl configdata.pm -r
Creating Makefile
***   Please run the same make command again   ***
Makefile:682: recipe for target 'configdata.pm' failed
make: *** [configdata.pm] Error 1
