查看: 60619|回复: 2
[Linux] 全志T3适配1920x720 lvds显示屏
A40i\T3\T507\T527通行证i.MX6Q通行证
dongsen 发表于 2020-8-4 13:56:58 | 显示全部楼层 |阅读模式
最近想在T3开发板适配1920x720 lvds液晶屏,但是一直没成功,背光正常,但是没有任何内容显示。
同样的方法,1920x1080 lvds的液晶屏就能够显示。
是1920 720的屏幕需要什么特殊设置吗?这块屏就是普通的双路 24bit 屏幕。
下面是我配置的部分参数。
[lcd0]
lcd_used            = 1
lcd_driver_name     = "default_lcd"
lcd_backlight       = 100
lcd_if              = 3
lcd_x               = 1920
lcd_y               = 720
lcd_width           =
lcd_height          =
lcd_dclk_freq       = 88
lcd_pwm_used        = 1
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 1
lcd_pwm_max_limit   = 255
lcd_hbp             = 16
lcd_ht              = 2004
lcd_hspw            = 12
lcd_vbp             = 5
lcd_vt              = 733
lcd_vspw            = 3
lcd_lvds_if         = 1
lcd_lvds_colordepth = 0
lcd_lvds_mode       = 0
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 0
lcd_cmap_en         = 0
deu_mode            = 0
lcdgamma4iep        = 22
smart_color         = 90
lcd_bl_en           = port:PB09<1><0><default><1>
lcd_power           = "vcc-lcd"
lcdd0                   = port:PD00<3><0><default><default>
lcdd1                   = port:PD01<3><0><default><default>
lcdd2                   = port:PD02<3><0><default><default>
lcdd3                   = port:PD03<3><0><default><default>
lcdd4                   = port:PD04<3><0><default><default>
lcdd5                   = port:PD05<3><0><default><default>
lcdd6                   = port:PD06<3><0><default><default>
lcdd7                   = port:PD07<3><0><default><default>
lcdd8                   = port:PD08<3><0><default><default>
lcdd9                   = port:PD09<3><0><default><default>
lcdd10                  = port:PD10<2><0><default><default>
lcdd11                  = port:PD11<2><0><default><default>
lcdd12                  = port:PD12<2><0><default><default>
lcdd13                  = port:PD13<2><0><default><default>
lcdd14                  = port:PD14<2><0><default><default>
lcdd15                  = port:PD15<2><0><default><default>
lcdd16                  = port:PD16<2><0><default><default>
lcdd17                  = port:PD17<2><0><default><default>
lcdd18                  = port:PD18<2><0><default><default>
lcdd19                  = port:PD19<2><0><default><default>
;lcdd20                  = port:PD20<2><0><default><default>
;lcdd21                  = port:PD21<2><0><default><default>
;lcdd22                  = port:PD22<2><0><default><default>
;lcdd23                  = port:PD23<2><0><default><default>
;lcdclk                  = port:PD24<2><0><default><default>
;lcdde                   = port:PD25<2><0><default><default>
;lcdhsync                = port:PD26<2><0><default><default>
;lcdvsync                = port:PD27<2><0><default><default>
[lcd0_suspend]
lcdd0               = port:PD00<7><0><default><default>
lcdd1               = port:PD01<7><0><default><default>
lcdd2               = port:PD02<7><0><default><default>
lcdd3               = port:PD03<7><0><default><default>
lcdd4               = port:PD04<7><0><default><default>
lcdd5               = port:PD05<7><0><default><default>
lcdd6               = port:PD06<7><0><default><default>
lcdd7               = port:PD07<7><0><default><default>
lcdd8               = port:PD08<7><0><default><default>
lcdd9               = port:PD09<7><0><default><default>
lcdd10                  = port:PD10<7><0><default><default>
lcdd11                  = port:PD11<7><0><default><default>
lcdd12                  = port:PD12<7><0><default><default>
lcdd13                  = port:PD13<7><0><default><default>
lcdd14                  = port:PD14<7><0><default><default>
lcdd15                  = port:PD15<7><0><default><default>
lcdd16                  = port:PD16<7><0><default><default>
lcdd17                  = port:PD17<7><0><default><default>
lcdd18                  = port:PD18<7><0><default><default>
lcdd19                  = port:PD19<7><0><default><default>
;lcdd20                  = port:PD20<7><0><default><default>
;lcdd21                  = port:PD21<7><0><default><default>
;lcdd22                  = port:PD22<7><0><default><default>
;lcdd23                  = port:PD23<7><0><default><default>
;lcdclk                  = port:PD24<7><0><default><default>
;lcdde                   = port:PD25<7><0><default><default>
;lcdhsync                = port:PD26<7><0><default><default>
;lcdvsync                = port:PD27<7><0><default><default>
楼主| dongsen 发表于 2020-8-4 15:54:02 | 显示全部楼层
已解决,默认引脚配置的是lcd
