查看: 27660|回复: 2
[Ubuntu] 修改设备树后无法进入kernel
LS1043A\46A通行证
东风十二 发表于 2020-8-19 09:17:19 | 显示全部楼层 |阅读模式
U-Boot SPL 2018.03 (Jul 16 2020 - 11:00:13 +0800)
Initialzing DDR using fixed setting
Configuring DDR for 2100 MT/s data rate
Trying to boot from MMC1
U-Boot 2018.03 (Jul 16 2020 - 10:47:34 +0800)
SoC:  LS1046AE Rev1.0 (0x87070010)
Clock Configuration:
       CPU0(A72):1800 MHz  CPU1(A72):1800 MHz  CPU2(A72):1800 MHz
       CPU3(A72):1800 MHz
       Bus:      700  MHz  DDR:      2100 MT/s  FMAN:     800  MHz
       00000000: 0e150012 10000000 00000000 00000000
       00000010: 11335a59 40005012 40025000 c1000000
       00000020: 00000000 00000000 00000000 00238996
       00000030: 20044500 00001002 00000096 00000001
Model: OK1046-C
Board: LS1046ARDB, boot from SD/eMMC
SERDES Reference Clocks:
SD1_CLK1 = 100.00MHZ, SD1_CLK2 = 156.25MHZ
SD2_CLK1 = 100.00MHZ, SD2_CLK2 = 100.00MHZ
I2C:   ready
DRAM:  1.9 GiB (DDR4, 32-bit, CL=15, ECC off)
SEC0: RNG instantiated
FSL_SDHC: 0
PPA Firmware: Version LSDK-18.06-Forlinx
SEC Firmware: 'loadables' present in config
loadables: 'trustedOS@1'
DS2460 OK
Using SERDES1 Protocol: 4403 (0x1133)
Using SERDES2 Protocol: 23129 (0x5a59)
MMC:   Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
Target spinup took 0 ms.
AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Found 1 device(s).
SCSI:  Net:
MMC read: dev # 0, block # 18432, count 128 ...
Fman1: Uploading microcode version 106.4.18
PCIe0: pcie@3400000 Root Complex: no link
PCIe1: pcie@3500000 disabled
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC2, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1, FM1@TGEC2
starting USB...
USB0:   Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   Register 200017f NbrPorts 2
USB XHCI 1.00
USB2:   Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Device 0: device type unknown
switch to partitions #0, OK
mmc0(part 0) is current device
** Unrecognized filesystem type **
Scanning mmc 0:2...
Found U-Boot script /boot/ls1046ardb_boot.scr
926 bytes read in 17 ms (52.7 KiB/s)
## Executing script at 80000000
** Unable to read file /boot/uEnv.txt **
21590528 bytes read in 1101 ms (18.7 MiB/s)
** Unable to read file /boot/fsl-ls1046a-rdb-sdk-1133-5a59.dtb **
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
Scanning mmc 0:3...
Trying load from SD ..
Device: FSL_SDHC
Manufacturer ID: 13
OEM: 14e
Bus Speed: 52000000
Mode : MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
MMC read: dev # 0, block # 32768, count 81920 ... 81920 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
log如上所示,遇到这种情况,如何能快速的进入kernrl?
LS1043A\46A通行证
distance369 发表于 2020-9-23 17:30:41 | 显示全部楼层
把你编译后的image 替换进去啊
