查看: 35961|回复: 2
[硬件咨询] BootLoder IAP 方式烧写 失败
i.MX6Q通行证i.MX6UL通行证RK3588通行证i.MX RT通行证
weichushun 发表于 2020-10-24 16:41:04 | 显示全部楼层 |阅读模式
RT1052开发板,bootloader IAP感觉是文件已经100%传输下去了,但是提示Failed to receve the file,不知道是哪个步骤出问题了?
bootloader IAP工程编译和led_output工程都是用了MIMXRT1052**xx_flexspi_nor.scf
(1)bootloader IAP工程编译的MIMXRT1052**xx_flexspi_nor.scf
#define m_flash_config_start           0x60000000
#define m_flash_config_size            0x00001000
#define m_ivt_start                    0x60001000
#define m_ivt_size                     0x00001000
#define m_interrupts_start             0x60002000
#define m_interrupts_size              0x00000400
#define m_text_start                   0x60002400
#define m_text_size                    0x007FDC00
#define m_data_start                   0x20000000
#define m_data_size                    0x00020000
#define m_data2_start                  0x20200000
#define m_data2_size                   0x000C0000
(2)led_output工程编译的MIMXRT1052**xx_flexspi_nor.scf
;#define m_flash_config_start           0x60000000
;#define m_flash_config_size            0x00001000
;#define m_ivt_start                    0x60001000
;#define m_ivt_size                     0x00001000
;#define m_interrupts_start             0x60002000
#define m_interrupts_start             0x60008000
;#define m_text_start                   0x60002400
#define m_text_start                   0x60008400
#define m_text_size                    0x03FFDC00
#define m_data2_size                   0x00040000
楼主| weichushun 发表于 2020-10-24 16:43:57 | 显示全部楼层
Please slecet :
1: run app
2: update app
3: reboot
Waiting for the file to be sent ... (press 'a' to abort)
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
开始 ymodem 传输。  按 Ctrl+C 取消。
Transferring igpio_led_output.bin...
  100%       9 KB    4 KB/s 00:00:02       0 Errors
Failed to receive the file!
Please slecet :
1: run app
2: update app
3: reboot
i.MX RT通行证
rcc123 发表于 2021-5-14 09:22:53 | 显示全部楼层
你APP也是跑rt1052的?
