查看: 53581|回复: 4
[Linux] SD 烧写出现问题,无法烧录
14
i.MX8MM通行证i.MX6UL通行证i.MX6Q通行证
Augustus007 发表于 2020-11-28 09:13:16 | 显示全部楼层 |阅读模式
  1. U-Boot SPL 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
  2. power_bd71837_init
  3. DRAM PHY training for 2400MTS
  4. check ddr4_pmu_train_imem code
  5. check ddr4_pmu_train_imem code pass
  6. check ddr4_pmu_train_dmem code
  7. check ddr4_pmu_train_dmem code pass
  8. Training PASS
  9. DRAM PHY training for 400MTS
  10. check ddr4_pmu_train_imem code
  11. check ddr4_pmu_train_imem code pass
  12. check ddr4_pmu_train_dmem code
  13. check ddr4_pmu_train_dmem code pass
  14. Training PASS
  15. DRAM PHY training for 100MTS
  16. check ddr4_pmu_train_imem code
  17. check ddr4_pmu_train_imem code pass
  18. check ddr4_pmu_train_dmem code
  19. check ddr4_pmu_train_dmem code pass
  20. Training PASS
  21. DRAM PHY training for 2400MTS
  22. check ddr4_pmu_train_imem code
  23. check ddr4_pmu_train_imem code pass
  24. check ddr4_pmu_train_dmem code
  25. check ddr4_pmu_train_dmem code pass
  26. Training PASS
  27. WARNING:Please contact Forlinx
  28. WARNING:Please contact Forlinx
  29. WARNING:Please contact Forlinx
复制代码
SD 烧写出现问题,无法烧录,出现“WARNING:Please contact Forlinx”
djh 发表于 2020-12-1 08:45:38 | 显示全部楼层
您是怎么操作的啊?您拨码开关拨到TF模式了吗?
djh 发表于 2020-12-3 09:29:45 | 显示全部楼层
你用的是我们的底板吗?在我们的底板上面能否正常烧写呢?
楼主| Augustus007 发表于 2020-12-24 16:00:57 | 显示全部楼层
你们的软件,烧录到我们的底板,因为没有那个加密芯片,就报了这个错误。自己编译的uboot就没有这个问题了,能够烧录。你们uboot又不给开源。买了这么多板子,就没见你们开源uboot过,恼火!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
djh
加密芯片是在核心板上的,挂载到IIC1上了,您的底板上IIC1上挂载了其他的设备了吗?地址是多少呢?  详情 回复 发表于 2020-12-24 17:06
djh 发表于 2020-12-24 17:06:40 | 显示全部楼层
你们的软件,烧录到我们的底板,因为没有那个加密芯片,就报了这个错误。自己编译的uboot就没有这个问题了 ...
