查看: 14721|回复: 2
[Android] 编译错误_config.mk: No such file or directory
A40i\T3\T507\T527通行证
yogiHe 发表于 2021-3-19 18:06:56 | 显示全部楼层 |阅读模式
frameworks/av/media/libcedarc/base/../config.mk:5: "product file: "
frameworks/av/media/libcedarc/base/../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/library/../config.mk:5: "product file: "
frameworks/av/media/libcedarc/library/../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/library/Android.mk:28: "lib_32 is: "notdef"_32"
frameworks/av/media/libcedarc/library/Android.mk:31: aosp_arm config not found! Please check it!
frameworks/av/media/libcedarc/memory/../config.mk:5: "product file: "
frameworks/av/media/libcedarc/memory/../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/openmax/libstagefrighthw/../../config.mk:5: "product file: "
frameworks/av/media/libcedarc/openmax/libstagefrighthw/../../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/openmax/omxcore/../../config.mk:5: "product file: "
frameworks/av/media/libcedarc/openmax/omxcore/../../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/openmax/vdec/../../config.mk:5: "product file: "
frameworks/av/media/libcedarc/openmax/vdec/../../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/openmax/venc/../../config.mk:5: "product file: "
frameworks/av/media/libcedarc/openmax/venc/../../config.mk:85: "can not find coframeworks/av/media/libcedarc/base/../config.mk:5: "product file: "
frameworks/av/media/libcedarc/openmax/venc/../../config.mk:85: "can not find config_file: product=, androd_version=7"
frameworks/av/media/libcedarc/openmax/venc/Android.mk:22: 7
frameworks/av/media/libcedarc/vdecoder/../config.mk:5: "product file: "
frameworks/av/media/libcedarc/vdecoder/../config.mk:85: "can not find config_file: product=, androd_version=7"
including ./frameworks/av/media/libcedarx/Android.mk ...
frameworks/av/media/libcedarx/android_adapter/awplayer/../../config.mk:45: ./frameworks/av/media/libcedarx/config/_config.mk: No such file or directory
make: *** [out/build-aosp_arm.ninja] Error 1
config.mk:85: "can not find config_file: product=, androd_version=7"nfig_file: product=, androd_version=7"
tanglu 发表于 2021-3-20 10:13:07 | 显示全部楼层
您方便把您操作的全部的打印信息发过来吗?放到word文档中,您可以发到我们的邮箱中,邮箱为linux@forlinx.com
cas
我也遇到这样的问题,请问什么解决?  详情 回复 发表于 2021-5-13 16:03
cas 发表于 2021-5-13 16:03:37 | 显示全部楼层
我也遇到这样的问题,请问什么解决?
