查看: 103332|回复: 14
[Linux] 全源码编译失败
A40i\T3\T507\T527通行证i.MX6UL通行证
merak 发表于 2021-3-23 11:03:50 | 显示全部楼层 |阅读模式
根据用户手册的附录四全源码编译: clipboard.png
报错:
configure: error: Package requirements (libffi >= 3.0.0) were not met:
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
Package 'libffi', required by 'world', not found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables LIBFFI_CFLAGS
and LIBFFI_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
package/pkg-generic.mk:206: recipe for target '/home/merak/build/OKA40i/linux/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_configured' failed
make[1]: *** [/home/merak/build/OKA40i/linux/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_configured] Error 1
Makefile:76: recipe for target '_all' failed
make: *** [_all] Error 2
make: Leaving directory '/home/merak/build/OKA40i/linux/bsp/lichee/buildroot-201611'
ERROR: build buildroot Failed
请问如何解决?
A40i\T3\T507\T527通行证RK3568通行证FCU2401通行证
Jafy_Chan 发表于 2021-3-23 11:12:49 | 显示全部楼层
你先查看一下libffi-dev的版本,输入
#sudo apt-cache show libffi-dev
如果显示的version低于编译的版本要求,那就重新安装一下libffi-dev
#sudo apt-get --reinstall install libffi-dev
试一试
看这个版本,是满足条件的 Package: libffi-dev Priority: extra Section: libdevel Installed-Size: 356 Maintainer: Ubuntu Developers Original-Maintainer: Debian GCC Maintainers Architecture: amd6  详情 回复 发表于 2021-3-23 13:13
楼主| merak 发表于 2021-3-23 13:13:39 | 显示全部楼层
看这个版本,是满足条件的
Package: libffi-dev
Priority: extra
Section: libdevel
Installed-Size: 356
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Debian GCC Maintainers <debian-gcc@lists.debian.org>
Architecture: amd64
Source: libffi
Version: 3.2.1-4
Depends: libffi6 (= 3.2.1-4), dpkg (>= 1.15.4) | install-info
Conflicts: libffi4-dev
Filename: pool/main/libf/libffi/libffi-dev_3.2.1-4_amd64.deb
MD5sum: 91b6348af83ddaf01ca719302b93c75a
SHA1: 799a373e16da7a911c8e86d8f553ac1ad361df75
SHA256: 6cd62ec1a361bb6a6cb01e9a7fca343b9cb0934e1aedb7d6557606d7e32b020c
Description-en: Foreign Function Inte**ce library (development files)
This package contains the headers and static library files necessary for
building programs which use libffi.
A foreign function inte**ce is the popular name for the inte**ce that
allows code written in one language to call code written in another
language.
Description-md5: cb5b8c2fd242772cae1be91db134642c
Multi-Arch: same
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Origin: Ubuntu
Supported: 9m
tweet 发表于 2021-5-29 23:02:55 | 显示全部楼层
请问这个问题解决了么?我在编译rootfs的时候也遇到了相同的问题,unbuntu下安装了最新的libffi-dev照样提示说“configure: error: Package requirements (libffi >= 3.0.0) were not met:”
我后来从头开始重新试了一遍,放置的目录和文档里说的一致就正常了,和5楼所说一致  详情 回复 发表于 2021-5-31 09:01
tanglu 发表于 2021-5-31 08:47:02 | 显示全部楼层
您看一下您文件放置的路径是否和软件用户手册上的路径一致?因为全志平台环境变量设置的都是绝对路径,文件放置位置和软件用户手册不一致会出现这种问题。
楼主| merak 发表于 2021-5-31 09:01:26 | 显示全部楼层
请问这个问题解决了么?我在编译rootfs的时候也遇到了相同的问题,unbuntu下安装了最新的libffi-dev照样提 ...
我的想法是,如何创建一个buildroot环境,让里面的执行程序依赖的动态库为自定义本地目录。 例如,官方提供的rootfs中,host上的执行程序bison依赖的动态库为绝对路径:/root/workspace/allwinner/A40i/bsp/lichee/  详情 回复 发表于 2021-5-31 23:42
tweet 发表于 2021-5-31 23:42:00 | 显示全部楼层
例如,官方提供的rootfs中,host上的执行程序bison依赖的动态库为绝对路径:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/lib 2021-5-31 23-29-02.jpg
如果不符合/root/workspace/.....这样的目录结构,就会导致编译失败。该方法的问题是:总是需要使用root权限来编译,很不方便。
能不能生成自定义的rootfs,其中的执行程序依赖类似/home/tweet/out/.....呢?这样就可以使用其它用户来编译。而就是因为我没有按照用户手册提供的目录结构来编译生成新的buildroot,导致了libffi这个问题。@tanglu
tanglu 发表于 2021-6-3 08:40:30 | 显示全部楼层
现在论坛中最新的那版开发环境就可以使用普通用户进行编译,不过您编译时可能会报错,您将lichee这个路径下的out目录删掉再重新编译就可以了。
tweet 发表于 2021-7-2 17:49:34 来自手机 | 显示全部楼层
你好,我按照你说的,把out目录删除了重新使用./build.sh编译,还是没有成功,后来总是在编译default/librpc/gen_ndr目录下停止,还导致主机会死机,请问怎么才能继续编译?
Forlinx-Niuzc 发表于 2021-7-3 10:11:17 | 显示全部楼层
您用的是我们提供的18.04的开发环境吗,您按照开发环境的readme文档里的方法操作一下,里边有全编译需要修改的内容
