- 22
贡献70
飞刀18 FD
注册时间2016-9-26
在线时间11 小时
我用开发板自带的8723bu模块连接路由器热点后,尝试用scp或者ftp从开发板向PC机下载文件,文件大小400MB左右,传输大概3分钟时开发板的wifi模块自动断开连接,尝试rmmod后重新insmod后dmesg提示加载驱动失败,打印信息如下,此时再无法连接路由器热点,只有重启开发板才能再次正常使用wifi模块,此BUG使用开发板自带的镜像100%能复现
[ 483.379610] RTW: USB_SPEED_HIGH
[ 483.379619] RTW: CHIP TYPE: RTL8723BU
[ 483.892202] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:1
[ 484.412215] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:2
[ 484.932291] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:3
[ 485.452278] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:4
[ 485.972307] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:5
[ 485.972325] RTW: [dvobj:e2fdf000][ERROR] continual_io_error:5 > 4
[ 485.972338] RTW: rtw_hal_config_rftype RF_Type is 0 TotalTxPath is 1
[ 485.972349] RTW: Chip Version Info: CHIP_8723B_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[ 485.972360] RTW: _ConfigChipOutEP_8723 OutEpQueueSel(0x07), OutEpNumber(4)
[ 485.972369] RTW: EEPROM type is E-FUSE
[ 485.972378] RTW: Boot from EFUSE, Autoload Fail !
