查看: 75015|回复: 2
[Linux] 请问,LVDS显示分辨率为1280*1024,屏幕黑屏没有任何显示
A40i\T3\T507\T527通行证RK3568通行证RK3399通行证
loog340 发表于 2021-5-7 22:39:01 | 显示全部楼层 |阅读模式
在A40i开发板适配1280*1024 lvds液晶屏,但是一直没成功,没有任何内容显示。
下面是我配置的部分参数,不知道哪里配置错误了。请教大神们给指导一下。
这是屏幕的参数
这是配置文件的设置参数。
[lcd0]
lcd_used            = 1
lcd_driver_name     = "default_lcd"
lcd_backlight       = 255
lcd_if              = 3
lcd_x               = 1280
lcd_y               = 1024
lcd_width           =
lcd_height          =
lcd_dclk_freq       = 54
lcd_pwm_used        = 1
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 0
lcd_pwm_max_limit   = 255
lcd_hbp             = 40
lcd_ht              = 844
lcd_hspw            = 80
lcd_vbp             = 10
lcd_vt              = 1066
lcd_vspw            = 10
lcd_lvds_if         = 0
lcd_lvds_colordepth = 1
lcd_lvds_mode       = 0
lcd_frm             = 1
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 0
lcd_cmap_en         = 0
deu_mode            = 1
lcdgamma4iep        = 22
smart_color         = 90
lcd_bl_en           = port:PB09<1><0><default><1>
lcd_power           = "vcc-lcd"
lcdd0                   = port:PD00<3><0><default><default>
lcdd1                   = port:PD01<3><0><default><default>
lcdd2                   = port:PD02<3><0><default><default>
lcdd3                   = port:PD03<3><0><default><default>
lcdd4                   = port:PD04<3><0><default><default>
lcdd5                   = port:PD05<3><0><default><default>
lcdd6                   = port:PD06<3><0><default><default>
lcdd7                   = port:PD07<3><0><default><default>
lcdd8                   = port:PD08<3><0><default><default>
lcdd9                   = port:PD09<3><0><default><default>
;lcdd10                  = port:PD10<2><0><default><default>
;lcdd11                  = port:PD11<2><0><default><default>
;lcdd12                  = port:PD12<2><0><default><default>
;lcdd13                  = port:PD13<2><0><default><default>
;lcdd14                  = port:PD14<2><0><default><default>
;lcdd15                  = port:PD15<2><0><default><default>
;lcdd16                  = port:PD16<2><0><default><default>
;lcdd17                  = port:PD17<2><0><default><default>
;lcdd18                  = port:PD18<2><0><default><default>
;lcdd19                  = port:PD19<2><0><default><default>
;lcdd20                  = port:PD20<2><0><default><default>
;lcdd21                  = port:PD21<2><0><default><default>
;lcdd22                  = port:PD22<2><0><default><default>
;lcdd23                  = port:PD23<2><0><default><default>
;lcdclk                  = port:PD24<2><0><default><default>
;lcdde                   = port:PD25<2><0><default><default>
;lcdhsync                = port:PD26<2><0><default><default>
;lcdvsync                = port:PD27<2><0><default><default>
楼主| loog340 发表于 2021-5-7 22:43:11 | 显示全部楼层
屏幕的参数是
vertical Section   Tv  1066
Horizontal Section Th 844
Clock    54
zhichao 发表于 2021-5-10 09:18:52 | 显示全部楼层
您改的配置文件是1280x600的配置文件吗,lcd_ht 是横向总长,lcd_hspw 是左边前间,lcd_vt是纵向总长,lcd_vspw是上边间距,您的参数肯定有问题, 844还没1280大呢,您再看看吧,先了解一下这些参数是啥
