查看: 34728|回复: 2
[Linux] 网卡eth0无法启用
XX18通行证
XLTX 发表于 2021-5-26 15:24:54 | 显示全部楼层 |阅读模式
首先我查看网络信息发现eth0并未启动
# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:130 errors:0 dropped:0 overruns:0 frame:0
          TX packets:130 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:421536 (411.6 KiB)  TX bytes:421536 (411.6 KiB)
尝试查看所有的网卡信息
# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 1E:C6:7C:5C:64:25
          inet addr:192.168.1.163  Bcast:192.168.1.255  Mask:255.255.255.0
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:48
ip6tnl0   Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
          NOARP  MTU:1452  Metric:1
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
尝试启动eth0
# ifconfig eth0 up
[ 1715.953000] eth0: device MAC address 1e:c6:7c:5c:64:25
[ 1716.047000] nxpmac_hw_setup: DMA engine initialization failed
[ 1716.053000] stmmac_open: Hw setup failed
ifconfig: SIOCSIFFLAGS: Device or resource busy
@飞凌-chongzi @飞凌-peacelove
我应该如何解决?
倔强的土坷垃 发表于 2021-6-10 11:37:03 | 显示全部楼层
看信息是mac损坏了
XX18通行证
楼主| XLTX 发表于 2021-6-13 16:33:14 | 显示全部楼层
我送售后了,发现是核心板和底板接触不良
