- 33
贡献162
飞刀43 FD
注册时间2020-8-11
在线时间4 小时
按照OKA40i-C&OKT3-C-Linux-软件用户手册-V1.5-20201218 手册操作全源码编译成功了,但是在打包烧写镜像的时候失败了。下面是全源码编译和打包镜像时的log
- manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh config
- Welcome to mkscript setup progress
- All available chips:
- 0. sun8iw11p1
- Choice: 0
- All available platforms:
- 0. android
- 1. dragonboard
- 2. linux
- 3. camdroid
- Choice: 2
- All available kernel:
- 0. linux-3.10
- Choice: 0
- All available boards:
- 0. OKA40i_C
- 1. OKT3_C
- 2. a40i-p3
- Choice: 0
- All available buildroot:
- 0. buildroot
- 1. buildroot-201611
- Choice: 1
- select buildroot-201611
- All available float:
- 0. gnueabi
- 1. gnueabihf
- Choice: 1
- select gnueabihf
- All available qt version:
- 0. 5.9.0
- Choice: 0
- select 5.9.0
- create misc_config gnueabihf
- All available lcd resolutions:
- 0. 480x272
- 1. 800x480
- 2. 800x600
- 3. 1024x600
- 4. 1024x600mipi
- 5. 1280x800
- 6. 800x480_v1
- 7. 800x600_v1
- 8. 1024x600_v1
- 9. 1024x600mipi_v1
- 10. 1280x800_v1
- Choice: 5
- build buidroot-201611...
- xgnueabihf
- sun8iw11p1_hf_defconfig
- INFO: ----------------------------------------
- INFO: build lichee ...
- INFO: chip: sun8iw11p1
- INFO: platform: linux
- INFO: kernel: linux-3.10
- INFO: board: OKA40i_C
- INFO: output: out/sun8iw11p1/linux/OKA40i_C
- INFO: build buildroot ...
- make: Entering directory '/home/manyi/work/lichee/buildroot-201611'
- >>> Finalizing target directory
- rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.xml /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.dtd
- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/glib-compile-schemas /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/glib-2.0/schemas --targetdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas
- PYTHONPATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/sysconfigdata/:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/site-packages/" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/python2.7 support/scripts/pycompile.py /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.py' -print0 | xargs -0 --no-run-if-empty rm -f
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.pyo' -print0 | xargs -0 --no-run-if-empty rm -f
- mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
- echo "A40i" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hostname
- /bin/sed -i -e '$a \127.0.1.1\tA40i' -e '/^127.0.1.1/d' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hosts
- echo "Welcome to Allwinner A40i Linux Platform V1.3" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/issue
- mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/
- ( echo "# inte**ce file auto-generated by buildroot"; echo ; echo "auto lo"; echo "iface lo inet loopback"; echo ; echo "allow-hotplug eth0"; echo "iface eth0 inet dhcp"; ) > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/inte**ces
- /bin/sed -i -e s,^root:[^:]*:,root::, /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/shadow
- ln -sf bash /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/bin/sh
- /bin/sed -i -e '/# GENERIC_SERIAL$/s~^.*#~ttyS0::respawn:/sbin/getty -L ttyS0 115200 vt100 #~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
- /bin/sed -i -e '/^#.*-o remount,rw \/$/s~^#\+~~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
- rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge
- for i in C en_US locale-archive; do echo $i >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge; done
- for dir in /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/locale; do for langdir in $dir/*; do if [ -e "${langdir}" ]; then grep -qx "${langdir##*/}" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge || rm -rf $langdir; fi done; done
- if [ -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale ]; then for lang in C en_US; do if [ -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/locale.dir; fi
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/include /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/aclocal \
- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/pkgconfig /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/pkgconfig \
- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/cmake /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/cmake
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/{lib,share}/ -name '*.cmake' -print0 | xargs -0 rm -f
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/libexec/ \
- \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/zsh
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/man /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/man
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/info /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/info
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/doc /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/doc
- rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/gtk-doc
- rmdir /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share 2>/dev/null
- make[1]: [Makefile:648: target-finalize] Error 1 (ignored)
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*' \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' | \
- xargs -r /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
- find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
- test -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf && \
- { echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
- test -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf.d && \
- { echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
- echo "NAME=Buildroot"; \
- echo "VERSION=2016.11"; \
- echo "ID=buildroot"; \
- echo "VERSION_ID=2016.11"; \
- echo "PRETTY_NAME="Buildroot 2016.11"" \
- ) > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/os-release
- >>> Executing post-build script target/user_rootfs_build.sh
- run user rootfs build script------------genrootfs =
- not genrootfs DO NOT compile sdk lib
- >>> Generating root filesystem image rootfs.tar
- rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
- rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
- echo '#!/bin/sh' > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- echo "set -e" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- echo "chown -h -R 0:0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- printf ' dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n - - docker -1 * - - - Docker Application Container Framework\n - - input -1 * - - - Input device group\n sshd -1 sshd -1 * - - - SSH drop priv user\n ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 417: [: -ge: unary operator expected
- /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 426: [: -eq: unary operator expected
- cat system/device_table.txt > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
- printf ' /bin/busybox f 4755 0 0 - - - - -\n /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
- echo "/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- printf ' tar -cf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar --numeric-owner -C /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target .\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- chmod a+x /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- rootdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target
- table='/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt'
- /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" gzip -9 -c /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar.gz
- make: Leaving directory '/home/manyi/work/lichee/buildroot-201611'
- INFO: build buildroot OK.
- INFO: build kernel ...
- INFO: prepare toolchain of sun8iw11p1...
- error format,file shoule end with gz or xz or none
- Building kernel
- /home/manyi/work/lichee/linux-3.10/output/lib/modules/3.10.65
- Copy rootfs for arm
- rootfs_32bit.cpio_buildroot_201611.gz
- CHK include/generated/uapi/linux/version.h
- CHK include/generated/utsrelease.h
- make[1]: “include/generated/mach-types.h”已是最新。
- CC scripts/mod/devicetable-offsets.s
- CALL scripts/checksyscalls.sh
- GEN scripts/mod/devicetable-offsets.h
- HOSTCC scripts/mod/file2alias.o
- HOSTLD scripts/mod/modpost
- CHK include/generated/compile.h
- CHK kernel/config_data.h
- CC drivers/soc/allwinner/pm/standby/common.o
- CC drivers/soc/allwinner/pm/standby/standby_twi.o
- CC drivers/soc/allwinner/pm/standby/power/axp_power.o
- CC drivers/soc/allwinner/pm/standby/power/axp15_power.o
- CC drivers/soc/allwinner/pm/standby/power/axp22_power.o
- CC drivers/soc/allwinner/pm/standby/power/axp20_power.o
- CC drivers/soc/allwinner/pm/standby/power/standby_power.o
- drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_voltage':
- drivers/soc/allwinner/pm/standby/power/standby_power.c:41:9: warning: implicit declaration of function 'axp20_get_volt' [-Wimplicit-function-declaration]
- ret = axp20_get_volt(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:44:9: warning: implicit declaration of function 'axp22_get_volt' [-Wimplicit-function-declaration]
- ret = axp22_get_volt(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:57:9: warning: implicit declaration of function 'axp15_get_volt' [-Wimplicit-function-declaration]
- ret = axp15_get_volt(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_voltage':
- drivers/soc/allwinner/pm/standby/power/standby_power.c:82:9: warning: implicit declaration of function 'axp20_set_volt' [-Wimplicit-function-declaration]
- ret = axp20_set_volt(tree, voltage);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:85:9: warning: implicit declaration of function 'axp22_set_volt' [-Wimplicit-function-declaration]
- ret = axp22_set_volt(tree, voltage);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:98:9: warning: implicit declaration of function 'axp15_set_volt' [-Wimplicit-function-declaration]
- ret = axp15_set_volt(tree, voltage);
- drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_state':
- drivers/soc/allwinner/pm/standby/power/standby_power.c:126:9: warning: implicit declaration of function 'axp20_get_state' [-Wimplicit-function-declaration]
- ret = axp20_get_state(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:129:9: warning: implicit declaration of function 'axp22_get_state' [-Wimplicit-function-declaration]
- ret = axp22_get_state(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:142:9: warning: implicit declaration of function 'axp15_get_state' [-Wimplicit-function-declaration]
- ret = axp15_get_state(tree);
- drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_state':
- drivers/soc/allwinner/pm/standby/power/standby_power.c:170:9: warning: implicit declaration of function 'axp20_set_state' [-Wimplicit-function-declaration]
- ret = axp20_set_state(tree, state);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:173:9: warning: implicit declaration of function 'axp22_set_state' [-Wimplicit-function-declaration]
- ret = axp22_set_state(tree, state);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:186:9: warning: implicit declaration of function 'axp15_set_state' [-Wimplicit-function-declaration]
- ret = axp15_set_state(tree, state);
- drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_suspend_calc':
- drivers/soc/allwinner/pm/standby/power/standby_power.c:215:9: warning: implicit declaration of function 'axp20_suspend_calc' [-Wimplicit-function-declaration]
- ret = axp20_suspend_calc(mask, func);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:219:9: warning: implicit declaration of function 'axp22_suspend_calc' [-Wimplicit-function-declaration]
- ret = axp22_suspend_calc(mask, func);
- drivers/soc/allwinner/pm/standby/power/standby_power.c:232:9: warning: implicit declaration of function 'axp15_suspend_calc' [-Wimplicit-function-declaration]
- ret = axp15_suspend_calc(mask, func);
- CC drivers/soc/allwinner/pm/standby/standby_clock.o
- CC drivers/soc/allwinner/pm/standby/standby_debug.o
- AS drivers/soc/allwinner/pm/standby/standby_divlib.o
- CC drivers/soc/allwinner/pm/standby/standby_dram.o
- AS drivers/soc/allwinner/pm/standby/./../mem_mmu_pc_asm.o
- CC drivers/soc/allwinner/pm/standby/./../mem_divlibc.o
- CC drivers/soc/allwinner/pm/standby/./../mem_clk.o
- CC drivers/soc/allwinner/pm/standby/./../mem_timing.o
- CC drivers/soc/allwinner/pm/standby/./../mem_serial.o
- CC drivers/soc/allwinner/pm/standby/./../mem_printk.o
- CC drivers/soc/allwinner/pm/standby/./../pm_debug.o
- CC drivers/soc/allwinner/pm/standby/main.o
- drivers/soc/allwinner/pm/standby/main.c: In function 'standby_main':
- drivers/soc/allwinner/pm/standby/main.c:135:3: warning: implicit declaration of function 'power_enter_super_calc' [-Wimplicit-function-declaration]
- power_enter_super_calc(&pm_info, &extended_standby_para_info,
- drivers/soc/allwinner/pm/standby/main.c:144:3: warning: implicit declaration of function 'standby_twi_init_losc' [-Wimplicit-function-declaration]
- standby_twi_init_losc(pm_info.pmu_arg.twi_port);
- drivers/soc/allwinner/pm/standby/main.c: In function 'bus_enter_lowfreq':
- drivers/soc/allwinner/pm/standby/main.c:332:3: warning: implicit declaration of function 'standby_clk_ldodisable' [-Wimplicit-function-declaration]
- standby_clk_ldodisable();
- drivers/soc/allwinner/pm/standby/main.c: In function 'bus_freq_resume':
- drivers/soc/allwinner/pm/standby/main.c:342:3: warning: implicit declaration of function 'standby_clk_ldoenable' [-Wimplicit-function-declaration]
- standby_clk_ldoenable();
- CC drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.o
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'dram_udelay':
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:30:2: warning: implicit declaration of function 'change_runtime_env' [-Wimplicit-function-declaration]
- change_runtime_env();
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:31:2: warning: implicit declaration of function 'delay_us' [-Wimplicit-function-declaration]
- delay_us(n);
- In file included from drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:18:0:
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'mctl_channel_init_standby':
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_hal-sun8iw11.h:77:35: warning: implicit declaration of function 'printk' [-Wimplicit-function-declaration]
- #define dram_dbg_0(fmt, args...) printk(fmt, ##args)
- drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:713:2: note: in expansion of macro 'dram_dbg_0'
- dram_dbg_0("mctl_channel_init_standby\n");
- AS drivers/soc/allwinner/pm/standby.o
- CC drivers/soc/allwinner/pm/mem_divlibc.o
- CC drivers/soc/allwinner/pm/mem_int.o
- CC drivers/soc/allwinner/pm/mem_clk.o
- CC drivers/soc/allwinner/pm/mem_gpio.o
- CC drivers/soc/allwinner/pm/mem_timing.o
- LD drivers/video/sunxi/disp2/hdmi/hdmi.o
- LD drivers/video/sunxi/disp2/hdmi/built-in.o
- LD drivers/video/sunxi/built-in.o
- CC drivers/soc/allwinner/pm/mem_serial.o
- LD drivers/video/built-in.o
- LD drivers/soc/allwinner/pm/pm_tmp.o
- LD drivers/soc/allwinner/pm/built-in.o
- LD drivers/soc/allwinner/built-in.o
- LD drivers/soc/built-in.o
- LD drivers/built-in.o
- LINK vmlinux
- LD vmlinux.o
- MODPOST vmlinux.o
- WARNING: modpost: Found 1 section mismatch(es).
- To see full details build your kernel with:
- 'make CONFIG_DEBUG_SECTION_MISMATCH=y'
- GEN .version
- UPD include/generated/compile.h
- CC init/version.o
- LD init/built-in.o
- KSYM .tmp_kallsyms1.o
- KSYM .tmp_kallsyms2.o
- LD vmlinux
- SORTEX vmlinux
- SYSMAP System.map
- OBJCOPY arch/arm/boot/Image
- Building modules, stage 2.
- MODPOST 23 modules
- Kernel: arch/arm/boot/Image is ready
- GZIP arch/arm/boot/compressed/piggy.gzip
- AS arch/arm/boot/compressed/piggy.gzip.o
- LD arch/arm/boot/compressed/vmlinux
- OBJCOPY arch/arm/boot/zImage
- Kernel: arch/arm/boot/zImage is ready
- UIMAGE arch/arm/boot/uImage
- Image Name: Linux-3.10.65
- Created: Sat Jun 19 15:29:59 2021
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 5159544 Bytes = 5038.62 KiB = 4.92 MiB
- Load Address: 40008000
- Entry Point: 40008000
- Image arch/arm/boot/uImage is ready
- 'arch/arm/boot/Image' -> 'output/bImage'
- 'arch/arm/boot/uImage' -> 'output/uImage'
- 'arch/arm/boot/zImage' -> 'output/zImage'
- Building modules
- build nand library /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/lib
- build nand with existing library
- make: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/nand'
- make -C /home/manyi/work/lichee/linux-3.10 M=/home/manyi/work/lichee/linux-3.10/modules/nand
- make[1]: Entering directory '/home/manyi/work/lichee/linux-3.10'
- LD [M] /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/nand.o
- MODPOST 1 modules
- LD [M] /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/nand.ko
- make[1]: Leaving directory '/home/manyi/work/lichee/linux-3.10'
- make: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/nand'
- [GPU]: Building mali400 device driver...
- make: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/gpu'
- make -j -C mali400/kernel_mode/driver/src/devicedrv/mali BUILD=release
- make[1]: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
- make ARCH=arm -C /home/manyi/work/lichee/linux-3.10 M=/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali modules
- make[2]: Entering directory '/home/manyi/work/lichee/linux-3.10'
- CC [M] /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/__malidrv_build_info.o
- LD [M] /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.o
- MODPOST 1 modules
- CC /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.mod.o
- LD [M] /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko
- make[2]: Leaving directory '/home/manyi/work/lichee/linux-3.10'
- make[1]: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
- 'mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko' -> '/home/manyi/work/lichee/linux-3.10/output/lib/modules/3.10.65/mali.ko'
- make: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/gpu'
- [GPU]: mali400 device driver has been built.
- regenerate rootfs cpio
- 4283 blocks
- 5004 blocks
- build_ramfs
- Copy boot.img to output directory ...
- Copy modules to target ...
- ./scripts/build.sh
- sun8iw11p1 compile Kernel successful
- INFO: build kernel OK.
- INFO: build rootfs ...
- run user rootfs build script------------genrootfs = y
- cp: target '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/target/bin/' is not a directory
- rm: cannot remove '*.a': No such file or directory
- rm: cannot remove '*.la': No such file or directory
- libsdk.so compile ok!!!
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libMemAdapter.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libMemAdapter.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libOmxVdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libOmxVdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libOmxVenc.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libOmxVenc.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libVE.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libVE.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libadecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libadecoder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaencoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaencoder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_aacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_aacdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_alacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_alacdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_amrdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_amrdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_apedec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_apedec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_atrcdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_atrcdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_cookdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_cookdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_dsddec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_dsddec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_flacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_flacdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_g729dec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_g729dec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_mp3dec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_mp3dec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_oggdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_oggdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_opusdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_opusdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_radec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_radec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_siprdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_siprdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_wavdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_wavdec.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawavs.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawavs.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawh264.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawh264.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawh265.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawh265.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmjpeg.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmjpeg.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmjpegplus.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmjpegplus.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg2.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg2.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4base.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4dx.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4dx.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4h263.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4h263.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4normal.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4normal.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4vp6.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4vp6.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawrecorder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawrecorder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawvp8.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawvp8.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawvp9Hw.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawvp9Hw.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawwmv3.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawwmv3.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdc_base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdc_base.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdc_omxil_core.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdc_omxil_core.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_base.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_common.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_common.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_muxer.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_muxer.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_parser.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_parser.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_playback.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_playback.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_stream.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_stream.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcrypto.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcrypto.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcrypto.so.1.0.0' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcrypto.so.1.0.0'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libsalsa.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libsalsa.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libssl.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libssl.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libssl.so.1.0.0' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libssl.so.1.0.0'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libsubdecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libsubdecoder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvdecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvdecoder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvencoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvencoder.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvideoengine.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvideoengine.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxmetadataretriever.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxmetadataretriever.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so.2' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so.2'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so.2.9.4' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so.2.9.4'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxplayer.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxplayer.so'
- '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libz.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libz.so'
- make[2]: Nothing to be done for 'all'.
- cp: cannot stat '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/sdktest/eve_module/classifier/*': No such file or directory
- make finish!!!
- echo ----------vproxy---------
- ----------vproxy---------
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./videoprosy.cpp -o ./videopro.o -rdynamic -fPIC -shared -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DCDX_V27 -DSUPPORT_NEW_DRIVER -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0 -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xplayer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/
- In file included from ./videoprosy.cpp:8:0:
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -o ./libvideoproxy.so ./videopro.o -rdynamic -fPIC -shared -L./cedarx// -Wl,--no-undefined -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter -lcdc_base -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs_hf -lsdk_compose -lsdk_disp -lsdk_g2d -lsdk_dvr -lsdk_player -lsdk_tr -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib -lsdk -ltinyalsa -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs -lawshm -lawcommediavideo -I../shm/ -I../dbusmedia/
- cp ./libvideoproxy.so /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs
- make[2]: Circular videoserv <- videoserv dependency dropped.
- echo -------------------
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./background_video_player.cpp -o ./background_video_player.o -g -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27 -DSUPPORT_NEW_DRIVER -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0 -DBGVIDEO_SER -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
- In file included from ./background_video_player.cpp:11:0:
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
- ./background_video_player.cpp: In static member function 'static int CBackGroundMediaVideo::handleShareMemControlCmd(int, int, char*, void*, void*)':
- ./background_video_player.cpp:410:21: warning: NULL used in arithmetic [-Wpointer-arith]
- if(pout->val0 != NULL)
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./bg_video_serv_warper.cpp -o ./bg_video_serv_warper.o -g -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27 -DSUPPORT_NEW_DRIVER -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0 -DBGVIDEO_SER -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
- In file included from ./bg_video_serv_warper.cpp:14:0:
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -o ./video_serv ./background_video_player.o ./bg_video_serv_warper.o -DBGVIDEO_SER -L./cedarx// -Wl,--no-undefined -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter -lcdc_base -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/libs_hf -lsdk_compose -lsdk_disp -lsdk_g2d -lsdk_dvr -lsdk_player -lsdk_tr -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib -lsdk -ltinyalsa -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/libs -lawshm -lawcommediavideo
- target/user_rootfs_build.sh: 152: [: -a: unexpected operator
- make[2]: Nothing to be done for 'first'.
- user apps build cmd begin
- make[3]: Nothing to be done for 'build'.
- watchdog.c: In function 'main':
- watchdog.c:18:6: warning: implicit declaration of function 'strcmp' [-Wimplicit-function-declaration]
- if(strcmp(argv[2],"settimeout") == 0){
- watchdog.c:30:7: warning: implicit declaration of function 'sleep' [-Wimplicit-function-declaration]
- sleep(2);
- /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/qt_demo/Launcher
- user apps build cmd finish
- user apps build qt5 begin
- make[4]: Nothing to be done for 'first'.
- user apps build qt5 finish
- build extean 3th apps begin
- build extean 3th apps finish
- run user rootfs build script---------done!
- >>> Generating root filesystem image rootfs.ext2
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- printf ' PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" mke2img -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target -G 4 -R 1 -B 1524000 -I 0 -l "rootfs" -o /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
- tune2fs 1.43.3 (04-Sep-2016)
- Please run e2fsck -f on the filesystem.
- Creating journal inode: done
- This filesystem will be automatically checked every 20 mounts or
- 0 days, whichever comes first. Use tune2fs -c or -i to override.
- mke2img: e2fsck was successfully run on '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2' (ext4)
- Setting maximal mount count to -1
- Setting interval between checks to 0 seconds
- ln -sf rootfs.ext2 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext4
- PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" gzip -9 -c /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar.gz
- INFO: build rootfs OK.
- INFO: ----------------------------------------
- INFO: build lichee OK.
- manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh -m pack_rootfs
- build buidroot-201611...
- xgnueabihf
- sun8iw11p1_hf_defconfig
- INFO: create ext4 rootfs ...
- table='/home/manyi/work/lichee/tools/pack/common/devices/_device_table.txt'
- tune2fs 1.45.5 (07-Jan-2020)
- INFO: create ext4 rootfs OK.
- manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh pack
- xgnueabihf
- INFO: packing firmware ...
- copying tools file
- copying configs file
- ./out/aultls32.fex
- ./out/aultools.fex
- ./out/boot_package.cfg
- ./out/boot_package.fex
- ./out/boot_package_nor.cfg
- ./out/cardscript.fex
- ./out/cardscript_secure.fex
- ./out/cardtool.fex
- ./out/diskfs.fex
- ./out/env.cfg
- ./out/env_burn.cfg
- ./out/image.cfg
- renamed './out/image_linux.cfg' -> './out/image.cfg'
- ./out/split_**x.fex
- ./out/sunxi.fex
- ./out/sys_config.fex
- ./out/sys_config1024x600.fex
- ./out/sys_config1024x600_100M.fex
- ./out/sys_config1024x600_pwm4.fex
- ./out/sys_config1024x600_v1.fex
- ./out/sys_config1024x600mipi-gt9xx.fex
- ./out/sys_config1024x600mipi.fex
- ./out/sys_config1024x600mipi_v1.fex
- ./out/sys_config1080p.fex
- ./out/sys_config1080p_v1.fex
- ./out/sys_config1280x800.fex
- ./out/sys_config1280x800_v1.fex
- ./out/sys_config800x480.fex
- ./out/sys_config800x480_v1.fex
- ./out/sys_configFCU2401.fex
- ./out/sys_configFCU2401_100M.fex
- ./out/sys_config_new_evb_lvds1024600.fex
- ./out/sys_partition_dump.fex
- renamed './out/sys_partition_linux.fex' -> './out/sys_partition.fex'
- ./out/sys_partition_linux_128M.fex
- ./out/sys_partition_linux_256M.fex
- ./out/sys_partition_linux_mmc.fex
- ./out/sys_partition_private.fex
- ./out/toc0.fex
- ./out/toc1.fex
- ./out/usbtool.fex
- ./out/usbtool_test.fex
- copying boot resource
- copying usr resource
- copying boot file
- p=soc c=product state=0
- p=soc c=platform state=0
- p=soc c=target state=0
- p=soc c=norflash state=0
- p=soc c=boot_init_gpio state=0
- p=soc c=power_sply state=0
- p=soc c=card_boot state=0
- p=soc c=pm_para state=0
- p=soc c=card0_boot_para state=0
- p=soc c=card2_boot_para state=0
- p=soc c=twi_para state=0
- p=soc c=uart_para state=0
- p=soc c=jtag_para state=0
- p=soc c=clock state=0
- p=soc c=dram state=0
- p=soc c=emac0 state=0
- p=soc c=gmac0 state=0
- p=soc c=can0 state=0
- p=soc c=can0 state=1
- p=soc c=twi0 state=0
- p=soc c=twi1 state=0
- p=soc c=twi2 state=0
- p=soc c=twi3 state=0
- p=soc c=twi4 state=0
- p=twi2 c=rx8010 state=0
- p=twi4 c=at24 state=0
- p=soc c=ir0 state=0
- p=soc c=uart0 state=0
- p=soc c=uart0 state=1
- p=soc c=uart1 state=0
- p=soc c=uart1 state=1
- p=soc c=uart2 state=0
- p=soc c=uart2 state=1
- p=soc c=uart3 state=0
- p=soc c=uart3 state=1
- p=soc c=uart4 state=0
- p=soc c=uart4 state=1
- p=soc c=uart5 state=0
- p=soc c=uart5 state=1
- p=soc c=uart6 state=0
- p=soc c=uart6 state=1
- p=soc c=uart7 state=0
- p=soc c=uart7 state=1
- p=soc c=spi0 state=0
- p=soc c=spi1 state=0
- p=soc c=spi2 state=0
- p=soc c=spi3 state=0
- p=soc c=rtp_para state=0
- p=soc c=ctp state=0
- p=soc c=ctp_list state=0
- p=soc c=tkey_para state=0
- p=soc c=motor_para state=0
- p=soc c=nand0 state=0
- p=soc c=sata state=0
- p=soc c=disp state=0
- p=soc c=tv0 state=0
- p=soc c=tv1 state=0
- p=soc c=tvd state=0
- p=soc c=tvd0 state=0
- p=soc c=tvd1 state=0
- p=soc c=tvd2 state=0
- p=soc c=tvd3 state=0
- p=soc c=lcd0 state=0
- p=soc c=lcd0 state=1
- p=soc c=pwm0 state=0
- p=soc c=pwm0 state=1
- p=soc c=car_reverse state=0
- p=soc c=Transmit_fm state=0
- p=soc c=hdmi state=0
- p=soc c=ak7601 state=0
- p=soc c=csi0 state=0
- p=csi0 c=csi0_dev0 state=0
- p=soc c=csi1 state=0
- p=csi1 c=csi1_dev0 state=0
- p=soc c=tvout_para state=0
- p=soc c=tvin_para state=0
- p=soc c=di state=0
- p=soc c=sdc0 state=0
- p=soc c=sdc1 state=0
- p=soc c=sdc2 state=0
- p=soc c=sdc3 state=0
- p=soc c=smc state=0
- p=soc c=gpio_para state=0
- p=soc c=usbc0 state=0
- p=soc c=usbc1 state=0
- p=soc c=usbc2 state=0
- p=soc c=gsensor_para state=0
- p=soc c=gps_para state=0
- p=soc c=ril_para state=0
- p=soc c=wlan state=0
- p=soc c=bt state=0
- p=soc c=btlpm state=0
- p=soc c=gy_para state=0
- p=soc c=ls_para state=0
- p=soc c=compass_para state=0
- p=soc c=spdif state=0
- p=soc c=sndspdif state=0
- p=soc c=audiohdmi state=0
- p=soc c=sndhdmi state=0
- p=soc c=snddaudio0 state=0
- p=soc c=daudio0 state=0
- p=soc c=snddaudio1 state=0
- p=soc c=daudio1 state=0
- p=soc c=sndcodec state=0
- p=soc c=codec state=0
- p=soc c=pmu0 state=0
- p=soc c=charger0 state=0
- p=soc c=powerkey0 state=0
- p=soc c=regulator0 state=0
- p=soc c=axp_gpio0 state=0
- p=soc c=dvfs_table state=0
- p=soc c=Vdevice state=0
- p=soc c=gpu_mali400_0 state=0
- Conver script to dts ok.
- dtbpath=/home/manyi/work/lichee/tools/pack/out/sunxi.fex
- update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
- ---0xd0, 0xd
- update_fdt: num 844384 randto1k
- update_fdt: num 155696 randto1k
- file1_len = ce400, file2_len = 28400
- dtb offset ce400,size 28400
- update_fdt:genrate /home/manyi/work/lichee/tools/pack/out/u-boot.fex ok
- pack boot package
- GetPrivateProfileSection read to end
- content_count=1
- packing for linux
- normal
- mbr count = 4
- partitation file Path=/home/manyi/work/lichee/tools/pack/out/sys_partition.bin
- mbr_name file Path=/home/manyi/work/lichee/tools/pack/out/sunxi_mbr.fex
- download_name file Path=/home/manyi/work/lichee/tools/pack/out/dlinfo.fex
- mbr size = 16384
- mbr magic softw411
- disk name=boot-resource
- filename = boot-resource.fex
- dl_file_size = 10682 sector
- part_size = 28672 sector
- disk name=env
- filename = env.fex
- dl_file_size = 256 sector
- part_size = 8192 sector
- disk name=boot
- filename = boot.fex
- dl_file_size = 26104 sector
- part_size = 32768 sector
- disk name=rootfs
- filename = rootfs.fex
- dl_file_size = 3873280 sector
- part_size = 4200000 sector
- disk name=private
- disk name=usr
- unable to open file usr-resource.fex
- dl file usr-resource.fex size too large
- update_for_part_info -1
- update mbr file fail
- ERROR: update_mbr failed
复制代码 usr-resource.fex 这个文件我在lichee目录下面搜了,根本就没有。
现在要怎么做才能完成打包烧写镜像啊。。。公司项目,很着急啊,求速回复。
