[Linux] 按照A40i-linuxSDK手册进行自动编译时出现了一个报错
A40i\T3\T507\T527通行证
pulice 发表于 2021-8-18 18:07:12 | 显示全部楼层
zhichao 发表于 2021-6-24 11:59
源码路径/root/workspace/allwinner/A40i/bsp/lichee
  1. configure.ac:39: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
  2. ../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
  3. ../../lib/autoconf/general.m4:2661: _AC_LINK_IFELSE is expanded from...
  4. ../../lib/autoconf/general.m4:2678: AC_LINK_IFELSE is expanded from...
  5. ../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
  6. ../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
  7. ../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
  8. m4/attributes.m4:87: CC_CHECK_LDFLAGS is expanded from...
  9. m4/attributes.m4:104: CC_NOUNDEFINED is expanded from...
  10. configure.ac:39: the top level
  11. Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake line 3936.
  12. autoreconf: /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake failed with exit status: 255
  13. make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/alsa-lib-1.1.2/.stamp_configured] Error 1
  14. make: Leaving directory `/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
  15. ERROR: build buildroot Failed
  16. root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# pwd
  17. /root/workspace/allwinner/A40i/bsp/lichee
复制代码
我已经按照文档做了还是报错
Forlinx-Niuzc 发表于 2021-8-19 09:07:32 | 显示全部楼层
您使用的ubuntu18.04开发环境是吗,开发环境下载的时候提供了patch包,按照readme文档操作一下
pulice 发表于 2021-8-19 11:07:38 | 显示全部楼层
文档中没有描述怎么用PATCH包呀
Forlinx-Niuzc 发表于 2021-8-19 11:50:50 | 显示全部楼层
开发环境下载时带的文件里有,您看错文件了吧
