[Linux] Okmx6ul 自制底板音频驱动DMA不能中断响应
楼主| yiyun1009 发表于 2021-6-28 16:33:25 | 显示全部楼层
[   32.269233] [531] snd_soc_write:2296: wm8960 1-001a: write 7 = 42
这是我的输出
R7 (07h)        8         ALRSWAP                  0                  Left/Right ADC Channel Swap                                  Audio Inte**ce
    Audio        1 = Swap left and right ADC data in audio                    Control
    Inte**ce                                                             inte**ce
        0 = Output left and right data as normal
                    7         BCLKINV                   0                 BCLK invert bit (for master and slave modes)                 Audio Inte**ce
        0 = BCLK not inverted                                         Control
        1 = BCLK inverted
                    6         MS                        0                 Master / Slave Mode Control                                  Audio Inte**ce
        0 = Enable slave mode                                         Control
        1 = Enable master mode
                    5         DLRSWAP                   0                 Left/Right DAC Channel Swap                                  Audio Inte**ce
        0 = Output left and right data as normal                      Control
        1 = Swap left and right DAC data in audio
        inte**ce
                    4         LRP                      0                  Right, left and I S modes – LRCLK polarity                   Audio Inte**ce
        0 = normal LRCLK polarity                                     Control
        1 = invert LRCLK polarity
        DSP Mode – mode A/B select
        0 = MSB is available on 2nd BCLK rising edge
        after LRC rising edge (mode A)
        1 = MSB is available on 1st BCLK rising edge
        after LRC rising edge (mode B)
                    3:2       WL[1:0]                   10                Audio Data Word Length                                       Audio Inte**ce
        00 = 16 bits                                                  Control
        01 = 20 bits
        10 = 24 bits
        11 = 32 bits (see Note)
