- 28
贡献155
飞刀44 FD
注册时间2021-6-18
在线时间6 小时
平台:OKA40i-c V1.2
编译环境:OKA40i-VM_15_1_0-ubuntu18.04说明:
1.源码解码md5均验证无误
2.make menuconfig ARCH=arm修改了nfs配置
操作步骤:1.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# pwd
/root/workspace/allwinner/A40i/bsp/lichee
root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh config
2.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh
build buidroot-201611...
xgnueabihf
sun8iw11p1_hf_defconfig
INFO: ----------------------------------------
INFO: build lichee ...
INFO: chip: sun8iw11p1
INFO: platform: linux
INFO: kernel: linux-3.10
INFO: board: OKA40i_C
INFO: output: out/sun8iw11p1/linux/OKA40i_C
INFO: build buildroot ...
make: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
>>> libglib2 2.50.1 Building
PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" /usr/bin/make -j5 -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/
make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile
Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936.
Makefile:862: recipe for target 'Makefile.in' failed
make[1]: *** [Makefile.in] Error 255
make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1'
package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed
make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2
make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
ERROR: build buildroot Failed
望帮助解答,感谢!
