- 142
贡献751
飞刀229 FD
注册时间2021-6-7
在线时间29 小时
forlinx@forlinx:~/workspace/allwinner/A40i/bsp/lichee$ ./build.sh
build buidroot-201611...
xgnueabihf
sun8iw11p1_hf_defconfig
INFO: ----------------------------------------
INFO: build lichee ...
INFO: chip: sun8iw11p1
INFO: platform: linux
INFO: kernel: linux-3.10
INFO: board: OKT3_C
INFO: output: out/sun8iw11p1/linux/OKT3_C
INFO: build buildroot ...
make: Entering directory '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
>>> alsa-lib 1.1.2 Configuring
>>> alsa-lib 1.1.2 Autoreconfiguring
configure.ac:39: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2661: _AC_LINK_IFELSE is expanded from...
../../lib/autoconf/general.m4:2678: AC_LINK_IFELSE is expanded from...
../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
m4/attributes.m4:87: CC_CHECK_LDFLAGS is expanded from...
m4/attributes.m4:104: CC_NOUNDEFINED is expanded from...
configure.ac:39: the top level
libtoolize: putting auxiliary files in '.'.
libtoolize: copying file './ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake line 3936.
autoreconf: /home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake failed with exit status: 255
package/pkg-generic.mk:206: recipe for target '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/alsa-lib-1.1.2/.stamp_configured' failed
make: *** [/home/forlinx/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/alsa-lib-1.1.2/.stamp_configured] Error 1
make: Leaving directory '/home/forlinx/workspace/allwinner/A40i/bsp/lichee/buildroot-201611'
ERROR: build buildroot Failed
编译时,出现问题,用的是官方的虚拟机linux环境,下载镜像,校验无误,其他未改动,直接全编译出现这个问题。是不能全编译吗?
