- 28
贡献118
飞刀25 FD
注册时间2021-7-21
在线时间4 小时
烧写原始镜像的提示
U-Boot SPL 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
power_bd71837_init
DRAM PHY training for 2400MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DS2460 OK
Normal Boot
Trying to boot from MMC1
U-Boot 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
CPU: Freescale i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU: Commercial temperature grade (0C to 95C) at 41C
Reset cause: POR
Model: FSL i.MX8MM EVK board
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
lt8912_check_dds: DDS:3b,57,1e
Display: MIPI2HDMI_1280x800 (1280x800)
Video: 1280x800x24
sec_mipi_dsim_bridge_mode_set: bitclk 498006 pixclk 83001 p 4 m 74 s 0
** Unable to read file logo.bmp **
Logo:
There is no valid bmp file at the given address
Error: no valid bmp image at 40480000
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF d6451cc
- U-Boot 2018.03-dirty
switch to partitions #0, OK
mmc0 is current device
flash target is MMC:0
Net: eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
17215124 bytes read in 735 ms (22.3 MiB/s)
## Loading kernel from FIT Image at 4a000000 ...
Using 'okmx8mm' configuration
Trying 'kernel' kernel subimage
Description: ARM64 Kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x4a0000d0
Data Size: 8940586 Bytes = 8.5 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x40480000
Entry Point: 0x40480000
Hash algo: crc32
Hash value: b2455a52
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 4a000000 ...
Trying 'initrd' ramdisk subimage
Description: initrd for arm64
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x4a886ddc
Data Size: 8229541 Bytes = 7.8 MiB
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 805c150e
## Loading fdt from FIT Image at 4a000000 ...
Trying 'okmx8mm-evk-dtb' fdt subimage
Description: ok8mm-evk-dtb
Type: Flat Device Tree
Data Start: 0x4b060168
Data Size: 42972 Bytes = 42 KiB
Load Address: 0x43000000
Hash algo: crc32
Hash value: 96a916de
Loading fdt from 0x4b060168 to 0x43000000
Booting using the fdt blob at 0x43000000
Uncompressing Kernel Image ... OK
reserving fdt memory region: addr=7f000000 size=1000000
Using Device Tree in place at 0000000043000000, end 000000004300d7db
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.78-g19c3169-dirty (forlinx@forlinx-Shangqi-N4610) (gcc version 7.3.0 (GCC)) #1 SMP P REEMPT Tue Aug 13 10:43:28 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Forlinx i.MX8MM EVK board
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000056000000, size 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xbffbed00-0xbffc0aff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8400000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80007ff59000 s57624 r8192 d32488 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515072
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 root=/dev/ram0 rw rootw ait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1360008K/2093056K available (12604K kernel code, 1172K rwdata, 4700K rodata, 768K init, 435K bs s, 77688K reserved, 655360K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008cd0000 ( 12608 KB)
[ 0.000000] .rodata : 0xffff000008cd0000 - 0xffff000009170000 ( 4736 KB)
[ 0.000000] .init SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MM clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 44079520212 0 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.008453] system counter timer init
[ 0.011766] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.019776] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.030934] Console: colour dummy device 80x25
[ 0.034631] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.044900] pid_max: default: 32768 minimum: 301
[ 0.049602] Security Framework initialized
[ 0.054272] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.061128] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.067930] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.074655] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.097894] ASID allocator initialised with 32768 entries
[ 0.105888] Hierarchical SRCU implementation.
[ 0.114438] Cannot find MU entry in device tree
[ 0.116244] CPU identified as i.MX8MM, silicon rev 1.0
[ 0.121369] EFI services will not be available.
[ 0.133862] smp: Bringing up secondary CPUs ...
[ 0.162002] Detected VIPT I-cache on CPU1
[ 0.162038] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.162078] CPU1: Booted secondary processor [410fd034]
[ 0.190037] Detected VIPT I-cache on CPU2
[ 0.190060] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.190077] CPU2: Booted secondary processor [410fd034]
[ 0.218092] Detected VIPT I-cache on CPU3
[ 0.218108] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.218123] CPU3: Booted secondary processor [410fd034]
[ 0.218179] smp: Brought up 1 node, 4 CPUs
[ 0.267992] SMP: Total of 4 processors activated.
[ 0.272718] CPU features: detected feature: GIC system register CPU inte**ce
[ 0.279893] CPU features: detected feature: 32-bit EL0 Support
[ 0.285755] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.298425] CPU: All CPU(s) started at EL2
[ 0.299679] alternatives: patching kernel code
[ 0.305506] devtmpfs: initialized
[ 0.312566] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.319055] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.328217] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.354267] pinctrl core: initialized pinctrl subsystem
[ 0.357757] DMI not present or invalid.
[ 0.360856] NET: Registered protocol family 16
[ 0.369043] cpuidle: using governor menu
[ 0.370947] vdso: 2 pages (1 code @ ffff000008cd6000, 1 data @ ffff000009234000)
[ 0.377659] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.394446] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.398404] Serial: AMBA PL011 UART driver
[ 0.404941] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.431347] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.444646] ACPI: Interpreter disabled.
[ 0.447452] vgaarb: loaded
[ 0.448626] SCSI subsystem initialized
[ 0.452670] usbcore: registered new inte**ce driver usbfs
[ 0.457682] usbcore: registered new inte**ce driver hub
[ 0.463158] usbcore: registered new device driver usb
[ 0.468502] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.477118] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.493561] bd71837 0-004b: Device ID=0xA1
[ 0.494812] bd71837 0-004b: gpio_intr = 3
[ 0.498958] bd71837 0-004b: chip_irq=54
[ 0.511078] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.531242] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.551261] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.563316] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.575317] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.587336] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.599368] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.611395] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.623426] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.643462] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.651484] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.671531] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.691569] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.699580] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.719636] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.739698] i2c i2c-0: IMX I2C adapter registered
[ 0.741563] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.747665] i2c i2c-1: IMX I2C adapter registered
[ 0.751643] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.757082] BD71837:bd71837_pmic_interrupt() in.
[ 0.757421] media: Linux media inte**ce: v0.10
[ 0.757466] Linux video capture inte**ce: v2.00
[ 0.757600] pps_core: LinuxPPS API ver. 1 registered
[ 0.757603] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.757625] PTP clock support registered
[ 0.757816] EDAC MC: Ver: 3.0.0
[ 0.758200] dmi: Firmware registration failed.
[ 0.759204] MU is ready for cross core communication!
[ 0.803408] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.805796] BD71837:IRQ_WDOG
[ 0.805798] BD71837:IRQ_ON_REQ
[ 0.813452] imx rpmsg driver is registered.
[ 0.817486] Advanced Linux Sound Architecture Driver Initialized.
[ 0.824004] Bluetooth: Core ver 2.22
[ 0.826986] NET: Registered protocol family 31
[ 0.831432] Bluetooth: HCI device and connection manager initialized
[ 0.837819] Bluetooth: HCI socket layer initialized
[ 0.842717] Bluetooth: L2CAP socket layer initialized
[ 0.847802] Bluetooth: SCO socket layer initialized
[ 0.853526] clocksource: Switched to clocksource arch_sys_counter
[ 0.858963] VFS: Disk quotas dquot_6.6.0
[ 0.862804] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.869811] pnp: PnP ACPI: disabled
[ 0.878941] NET: Registered protocol family 2
[ 0.881046] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.887894] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.894723] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.901218] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.907027] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.913637] NET: Registered protocol family 1
[ 0.918371] RPC: Registered named UNIX socket transport module.
[ 0.923779] RPC: Registered udp transport module.
[ 0.928501] RPC: Registered tcp transport module.
[ 0.933223] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.939885] Trying to unpack rootfs image as initramfs...
[ 0.945491] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 0.973269] Freeing initrd memory: 8036K
[ 0.975458] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.982624] kvm [1]: 8-bit VMID
[ 0.986126] kvm [1]: GICv3: no GICV resource entry
[ 0.990108] kvm [1]: disabling GICv2 emulation
[ 0.994597] kvm [1]: GIC system register CPU inte**ce enabled
[ 1.000500] kvm [1]: vgic interrupt IRQ1
[ 1.004466] kvm [1]: Hyp mode initialized successfully
[ 1.012085] audit: initializing netlink subsys (disabled)
[ 1.015100] audit: type=2000 audit(0.912:1): state=initialized audit_enabled=0 res=1
[ 1.015493] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 1.021164] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.021826] NFS: Registering the id_resolver key type
[ 1.021856] Key type id_resolver registered
[ 1.021859] Key type id_legacy registered
[ 1.021868] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.021898] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.022424] 9p: Installing v9fs 9p2000 file system support
[ 1.036417] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.036426] io scheduler noop registered
[ 1.036588] io scheduler cfq registered (default)
[ 1.036592] io scheduler mq-deadline registered
[ 1.036595] io scheduler kyber registered
[ 1.043717] pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
[ 1.046911] imx-sdma 30bd0000.dma-controller: no iram assigned, using external mem
[ 1.050942] imx-sdma 30bd0000.dma-controller: Falling back to user helper
[ 1.053889] imx-sdma 302c0000.dma-controller: no iram assigned, using external mem
[ 1.059202] imx-sdma 302b0000.dma-controller: no iram assigned, using external mem
[ 1.065603] mxs-dma 33000000.dma-apbh: initialized
[ 1.067204] Bus freq driver module loaded
[ 1.071223] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.073674] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 25, base_baud = 1500000) is a IMX
[ 1.156885] console [ttymxc1] enabled
[ 1.161356] bootconsole [ec_imx6q0] disabled
[ 1.177263] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.183929] [drm] No driver support for vblank timestamp query.
[ 1.189967] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.197727] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.204761] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.213040] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -19
[ 1.220760] ------------[ cut here ]------------
[ 1.225386] WARNING: CPU: 3 PID: 1 at drivers/gpu/drm/drm_bridge.c:155 drm_bridge_detach+0x50/0x60
[ 1.234342] Modules linked in:
[ 1.237403] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.14.78-g19c3169-dirty #1
[ 1.244710] Hardware name: Forlinx i.MX8MM EVK board (DT)
[ 1.250108] task: ffff80007a3b0000 task.stack: ffff000008078000
[ 1.256027] PC is at drm_bridge_detach+0x50/0x60
[ 1.260645] LR is at drm_encoder_cleanup+0x2c/0xa8
[ 1.265435] pc : [<ffff000008616068>] lr : [<ffff00000861965c>] pstate: 40000045
[ 1.272827] sp : ffff00000807ba50
[ 1.276140] x29: ffff00000807ba50 x28: ffff80007b43d018
[ 1.281454] x27: 0000000000000029 x26: ffff80007a737280
[ 1.286767] x25: ffff80007acbf000 x24: 00000000ffffffed
[ 1.292080] x23: ffff000008d91af8 x22: ffff000008d91000
[ 1.297393] x21: ffff80007acbf000 x20: 0000000000000000
[ 1.302706] x19: ffff80007b4ac018 x18: 0000000000000010
[ 1.308019] x17: 0000000000000001 x16: 0000000000000000
[ 1.313332] x15: ffffffffffffffff x14: ffff0000893635cf
[ 1.318644] x13: ffff0000093635dd x12: ffff000009238df8
[ 1.323957] x11: ffff0000085b6478 x10: ffff00000807b700
[ 1.329270] x9 : 0000000000000006 x8 : 206d697364206365
[ 1.334583] x7 : 7320646e6962206f x6 : 00000000000000ed
[ 1.339896] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.345209] x3 : ffffffffffffffff x2 : 0000000000000000
[ 1.350521] x1 : ffff80007a3b0000 x0 : ffff80007b4ac018
[ 1.355835] Call trace:
[ 1.358283] Exception stack(0xffff00000807b910 to 0xffff00000807ba50)
[ 1.364724] b900: ffff80007b4ac018 ffff80007a3b0000
[ 1.372553] b920: 0000000000000000 ffffffffffffffff 0000000000000000 0000000000000000
[ 1.380383] b940: 00000000000000ed 7320646e6962206f 206d697364206365 0000000000000006
[ 1.388212] b960: ffff00000807b700 ffff0000085b6478 ffff000009238df8 ffff0000093635dd
[ 1.396042] b980: ffff0000893635cf ffffffffffffffff 0000000000000000 0000000000000001
[ 1.403871] b9a0: 0000000000000010 ffff80007b4ac018 0000000000000000 ffff80007acbf000
[ 1.411701] b9c0: ffff000008d91000 ffff000008d91af8 00000000ffffffed ffff80007acbf000
[ 1.419530] b9e0: ffff80007a737280 0000000000000029 ffff80007b43d018 ffff00000807ba50
[ 1.427360] ba00: ffff00000861965c ffff00000807ba50 ffff000008616068 0000000040000045
[ 1.435189] ba20: ffff00000807ba30 ffff00000864f3ac ffffffffffffffff ffff0000086399ec
[ 1.443018] ba40: ffff00000807ba50 ffff000008616068
[ 1.447895] [<ffff000008616068>] drm_bridge_detach+0x50/0x60
[ 1.453555] [<ffff00000861965c>] drm_encoder_cleanup+0x2c/0xa8
[ 1.459392] [<ffff0000086399f4>] imx_sec_dsim_bind+0x1e4/0x228
[ 1.465226] [<ffff00000864da84>] component_bind_all+0xfc/0x280
[ 1.471059] [<ffff00000863410c>] imx_drm_bind+0x13c/0x288
[ 1.476458] [<ffff00000864d6d0>] try_to_bring_up_master+0x178/0x1d8
[ 1.482724] [<ffff00000864d7c8>] component_add+0x98/0x160
[ 1.488123] [<ffff000008649858>] lcdif_crtc_probe+0x20/0x40
[ 1.493697] [<ffff000008655648>] platform_drv_probe+0x58/0xb8
[ 1.499443] [<ffff000008653a28>] driver_probe_device+0x210/0x2d0
[ 1.505449] [<ffff000008653ba4>] __driver_attach+0xbc/0xc0
[ 1.510937] [<ffff000008651b84>] bus_for_each_dev+0x4c/0x98
[ 1.516508] [<ffff000008653340>] driver_attach+0x20/0x28
[ 1.521821] [<ffff000008652e90>] bus_add_driver+0x1b8/0x228
[ 1.527393] [<ffff000008654540>] driver_register+0x60/0xf8
[ 1.532878] [<ffff000008655598>] __platform_driver_register+0x40/0x48
[ 1.539324] [<ffff0000091ae038>] lcdif_crtc_driver_init+0x18/0x20
[ 1.545420] [<ffff000008083c90>] do_one_initcall+0x38/0x128
[ 1.550998] [<ffff000009170d0c>] kernel_init_freeable+0x188/0x22c
[ 1.557094] [<ffff000008cb33b8>] kernel_init+0x10/0x108
[ 1.562319] [<ffff000008084f60>] ret_from_fork+0x10/0x18
[ 1.567635] ---[ end trace 7cf49cb0fd16f5df ]---
[ 1.572306] imx-drm display-subsystem: failed to bind 32e10000.mipi_dsi (ops imx_sec_dsim_ops): -19
[ 1.581528] imx-drm display-subsystem: master bind failed: -19
[ 1.595170] brd: module loaded
[ 1.603640] loop: module loaded
[ 1.610165] random: fast init done
[ 1.618991] fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
[ 1.626058] slram: not enough parameters.
[ 1.631568] libphy: Fixed MDIO Bus: probed
[ 1.636163] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.642214] tun: Universal TUN/TAP device driver, 1.6
[ 1.647497] CAN device driver inte**ce
[ 1.652624] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.658478] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.664466] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.671443] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.677061] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.684948] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.691050] sky2: driver version 1.30
[ 1.696209] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.702771] ehci-pci: EHCI PCI platform driver
[ 1.707287] ehci-platform: EHCI generic platform driver
[ 1.712663] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.718880] ohci-pci: OHCI PCI platform driver
[ 1.723382] ohci-platform: OHCI generic platform driver
[ 1.729072] usbcore: registered new inte**ce driver usb-storage
[ 1.735131] usbcore: registered new inte**ce driver usb_ehset_test
[ 1.742427] usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.752853] usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.769887] imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using dummy regulator
[ 1.781227] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.786136] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.809584] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.815861] hub 1-0:1.0: USB hub found
[ 1.819662] hub 1-0:1.0: 1 port detected
[ 1.825326] input: InputEmulator as /devices/virtual/input/input0
[ 1.832312] i2c /dev entries driver
[ 1.850779] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.857979] sdhci: Secure Digital Host Controller Inte**ce driver
[ 1.864310] sdhci: Copyright(c) Pierre Ossman
[ 1.868797] Synopsys Designware ** Card Inte**ce Driver
[ 1.875207] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.929601] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.942669] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.994183] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.057562] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 2.067649] galcore: clk_get vg clock failed, disable vg!
[ 2.072367] mmc1: host does not support reading read-only switch, assuming write-enable
[ 2.081310] Galcore version 6.2.4.163672
[ 2.157620] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.187642] hantrodec 0 : module inserted. Major = 240
[ 2.193832] hantrodec 1 : module inserted. Major = 240
[ 2.200361] hx280enc: module inserted. Major <239>
[ 2.211612] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.215206] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.215956] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 2.217197] mmc2: new HS200 MMC card at address 0001
[ 2.217939] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[ 2.218419] mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
[ 2.218905] mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
[ 2.219377] mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
[ 2.223258] mmcblk1: p1
[ 2.224725] mmcblk2: p1 p2
[ 2.262555] caam 30900000.caam: ERA source: CCBVID.
[ 2.269804] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.276360] caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
[ 2.285574] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.290852] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.325167] hub 1-1:1.0: USB hub found
[ 2.329059] hub 1-1:1.0: 4 ports detected
[ 2.363737] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.431387] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.448840] caam algorithms registered in /proc/crypto
[ 2.457324] caam_jr 30901000.jr0: registering rng-caam
[ 2.462692] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.471399] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.477807] platform caam_sm: 64-bit clear key:
[ 2.482355] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.488028] platform caam_sm: 64-bit black key:
[ 2.492585] platform caam_sm: [0000] 78 a8 b0 30 67 85 3a 12
[ 2.498256] platform caam_sm: [0008] 43 29 3c 6d 46 da 37 69
[ 2.503924] platform caam_sm: 128-bit clear key:
[ 2.508553] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.514223] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.519892] platform caam_sm: 128-bit black key:
[ 2.524523] platform caam_sm: [0000] 17 a3 9e 03 fd fd 16 ee
[ 2.530195] platform caam_sm: [0008] 4d ad 62 dd 33 aa eb 89
[ 2.535864] platform caam_sm: 192-bit clear key:
[ 2.540493] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.546171] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.551842] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.557518] platform caam_sm: 192-bit black key:
[ 2.562147] platform caam_sm: [0000] 19 18 90 fb 7e 53 59 20
[ 2.567817] platform caam_sm: [0008] ef d9 37 fb 28 10 7d 53
[ 2.573490] platform caam_sm: [0016] f3 49 bf c4 d4 b4 fc 4e
[ 2.579162] platform caam_sm: [0024] e2 c4 86 8e 42 17 65 5a
[ 2.584833] platform caam_sm: 256-bit clear key:
[ 2.589462] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.595134] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.600806] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.606477] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.612145] platform caam_sm: 256-bit black key:
[ 2.616774] platform caam_sm: [0000] 43 a9 e9 2e 18 ab 81 88
[ 2.622445] platform caam_sm: [0008] d9 2e e8 2d 22 16 05 fa
[ 2.626047] usb 1-1.2: new full-speed USB device number 3 using ci_hdrc
[ 2.634737] platform caam_sm: [0016] 17 aa 47 03 6f 47 1f 34
[ 2.640408] platform caam_sm: [0024] 8b c8 7c 28 8a 8e 2a 79
[ 2.646077] platform caam_sm: 64-bit unwritten blob:
[ 2.651053] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.656725] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.662396] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.668068] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.673739] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.679410] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.685082] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.690752] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.696423] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.702097] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.707767] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.713440] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.719108] platform caam_sm: 128-bit unwritten blob:
[ 2.724173] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.729844] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.735513] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.741184] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.746857] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.752534] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.758207] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.763881] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.769553] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.775227] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.780898] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.786569] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.792243] platform caam_sm: 196-bit unwritten blob:
[ 2.797307] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.802982] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.808655] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.814325] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.819996] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.822069] usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
[ 2.832289] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.837960] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.843632] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.849303] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.854976] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.860647] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.866319] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.871988] platform caam_sm: 256-bit unwritten blob:
[ 2.877052] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.882722] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.888393] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.894063] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.899734] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.905404] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.911074] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.916773] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.922448] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.928119] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.933789] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.939464] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.945251] platform caam_sm: 64-bit black key in blob:
[ 2.950495] platform caam_sm: [0000] af 74 c7 73 33 0e 87 57
[ 2.956166] platform caam_sm: [0008] 69 bc e3 a7 2b 30 43 a9
[ 2.961848] platform caam_sm: [0016] 5c 66 c1 15 c8 0c 12 94
[ 2.967519] platform caam_sm: [0024] 82 4f ae b1 c2 c3 ae 2e
[ 2.973195] platform caam_sm: [0032] 66 c8 52 b7 d8 9f 5a 03
[ 2.978868] platform caam_sm: [0040] 07 9f c3 f2 d0 f9 f6 e3
[ 2.984543] platform caam_sm: [0048] 2d ec 58 50 c8 bb 00 39
[ 2.990216] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.995886] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.001557] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.007228] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.012898] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.018567] platform caam_sm: 128-bit black key in blob:
[ 3.023891] platform caam_sm: [0000] bf a1 15 34 96 fe 2c c0
[ 3.029562] platform caam_sm: [0008] 94 69 79 41 8a ab d6 13
[ 3.035233] platform caam_sm: [0016] cd 0d 57 9a fc 4b 6d 7f
[ 3.040903] platform caam_sm: [0024] de f6 40 a3 5f 7c e4 d5
[ 3.046574] platform caam_sm: [0032] 8f 59 a0 d8 60 53 29 fb
[ 3.052244] platform caam_sm: [0040] 44 e6 29 c0 64 84 81 d8
[ 3.057915] platform caam_sm: [0048] 6d 90 d7 91 a4 49 12 f3
[ 3.063585] platform caam_sm: [0056] 88 f9 e2 5f 4b b9 4f 19
[ 3.069256] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.074927] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.080597] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.086268] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.091936] platform caam_sm: 192-bit black key in blob:
[ 3.097260] platform caam_sm: [0000] 53 7a 9e 51 6d 25 a1 17
[ 3.102932] platform caam_sm: [0008] 94 a3 43 cc 2e 62 20 eb
[ 3.108603] platform caam_sm: [0016] d6 ad 96 5d 58 20 3c 23
[ 3.114274] platform caam_sm: [0024] b6 69 3c 03 e0 7e 37 b9
[ 3.119945] platform caam_sm: [0032] 97 75 29 50 6f 16 22 cd
[ 3.125615] platform caam_sm: [0040] 7a 42 78 11 c6 36 cf 9b
[ 3.131286] platform caam_sm: [0048] 29 9f 49 1d 34 ef 5c 8b
[ 3.136956] platform caam_sm: [0056] 09 5f 65 e6 75 e8 d2 38
[ 3.142627] platform caam_sm: [0064] 12 f5 32 81 e6 04 95 9a
[ 3.148298] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.153969] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.159639] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.165307] platform caam_sm: 256-bit black key in blob:
[ 3.170631] platform caam_sm: [0000] 86 07 58 19 eb 3c 5e ee
[ 3.176302] platform caam_sm: [0008] 41 73 5b ff de f8 d4 a3
[ 3.181972] platform caam_sm: [0016] a5 b5 a2 99 d8 b7 44 37
[ 3.187643] platform caam_sm: [0024] 84 a5 c8 0d 7f 0a be a8
[ 3.193313] platform caam_sm: [0032] 40 63 a2 9f 72 06 e8 b6
[ 3.198985] platform caam_sm: [0040] 06 b7 c2 1b 35 61 f5 a9
[ 3.204655] platform caam_sm: [0048] d6 b9 2a b0 e9 3e 2d 31
[ 3.210326] platform caam_sm: [0056] 4a 65 3a 42 1c 54 2b 73
[ 3.215997] platform caam_sm: [0064] da 6d ce 0e 66 01 1a 46
[ 3.221671] platform caam_sm: [0072] 83 03 0a 45 5a dd a5 e2
[ 3.227342] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.233013] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.240345] platform caam_sm: restored 64-bit black key:
[ 3.245672] platform caam_sm: [0000] 02 4f d2 17 f5 db 10 32
[ 3.251343] platform caam_sm: [0008] c9 d7 5e 8b 41 ec 32 5e
[ 3.257012] platform caam_sm: restored 128-bit black key:
[ 3.262422] platform caam_sm: [0000] 17 a3 9e 03 fd fd 16 ee
[ 3.268093] platform caam_sm: [0008] 4d ad 62 dd 33 aa eb 89
[ 3.273761] platform caam_sm: restored 192-bit black key:
[ 3.279172] platform caam_sm: [0000] 19 18 90 fb 7e 53 59 20
[ 3.284842] platform caam_sm: [0008] ef d9 37 fb 28 10 7d 53
[ 3.290513] platform caam_sm: [0016] 3f fc f2 8b ed d2 56 3e
[ 3.296183] platform caam_sm: [0024] 96 bb 37 d5 9c 6d 61 5a
[ 3.301852] platform caam_sm: restored 256-bit black key:
[ 3.307262] platform caam_sm: [0000] 43 a9 e9 2e 18 ab 81 88
[ 3.312933] platform caam_sm: [0008] d9 2e e8 2d 22 16 05 fa
[ 3.318603] platform caam_sm: [0016] 17 aa 47 03 6f 47 1f 34
[ 3.324274] platform caam_sm: [0024] 8b c8 7c 28 8a 8e 2a 79
[ 3.330657] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 3.336563] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 3.353986] input: eGalax Inc. eGalaxTouch P80H46 1592 vT1_M00 k4.10.142 as /devices/platform/32e50000.usb/ci_hdrc. 1/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:C002.0001/input/input1
[ 3.369761] hid-multitouch 0003:0EEF:C002.0001: input: USB HID v1.11 Pointer [eGalax Inc. eGalaxTouch P80H46 1592 v T1_M00 k4.10.142] on usb-ci_hdrc.1-1.2/input0
[ 3.384349] usbcore: registered new inte**ce driver usbhid
[ 3.389941] usbhid: USB HID core driver
[ 3.402797] imx-micfil sound-micfil: failed to find MICFIL platform device
[ 3.409724] imx-micfil: probe of sound-micfil failed with error -22
[ 3.416668] NET: Registered protocol family 26
[ 3.421642] NET: Registered protocol family 10
[ 3.426880] Segment Routing with IPv6
[ 3.430680] NET: Registered protocol family 17
[ 3.435142] can: controller area network core (rev 20170425 abi 9)
[ 3.441391] NET: Registered protocol family 29
[ 3.445851] can: raw protocol (rev 20170425)
[ 3.450137] can: broadcast manager protocol (rev 20170425 t)
[ 3.455814] can: netlink gateway (rev 20170425) max_hops=1
[ 3.461995] Bluetooth: RFCOMM TTY layer initialized
[ 3.466894] Bluetooth: RFCOMM socket layer initialized
[ 3.472062] Bluetooth: RFCOMM ver 1.11
[ 3.475849] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.481175] Bluetooth: BNEP filters: protocol multicast
[ 3.486414] Bluetooth: BNEP socket layer initialized
[ 3.491391] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[ 3.497323] Bluetooth: HIDP socket layer initialized
[ 3.502373] 9pnet: Installing 9P2000 support
[ 3.506731] Key type dns_resolver registered
[ 3.515771] registered taskstats version 1
[ 3.545566] cpu cpu0: registered imx8mq-cpufreq
[ 3.552630] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 3.560221] hctosys: unable to open rtc device (rtc0)
[ 3.569997] WLAN_EN: disabling
[ 3.573075] usb_otg1_vbus: disabling
[ 3.577968] ALSA device list:
[ 3.580941] No soundcards found.
[ 3.584676] RAMDISK: gzip image found at block 0
[ 3.953370] EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
[ 3.961116] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 3.967255] devtmpfs: mounted
[ 3.970557] Freeing unused kernel memory: 768K
Open /dev/fb0 failed, errno:2, error message:No such file or directory
[ 4.051605] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.893681] random: crng init done
[ 62.529615] imx-sdma 302c0000.dma-controller: external firmware not found, using ROM firmware
[ 62.529617] imx-sdma 302b0000.dma-controller: external firmware not found, using ROM firmware
[ 62.529721] imx-sdma 30bd0000.dma-controller: external firmware not found, using ROM firmware
[ 30x
power_bd71837_init
Training PASS
Training PASS
Training PASS
Training PASS
DS2460 OK
Normal Boot
Trying to boot from MMC2
CPU: Commercial temperature grade (0C to 95C) at 57C
Reset cause: POR
DRAM: 2 GiB
Loading Environment from MMC... *** Warning - bad CRC, using default environment
OK
use custom mode MIPI2HDMI_CUSTOM: 60, 1024, 600, 20000, 32, 20, 8, 4, 40, 1, 00000004, 00000000
Display: MIPI2HDMI_CUSTOM (1024x600)
Video: 1024x600x24
sec_mipi_dsim_bridge_mode_set: bitclk 300000 pixclk 50000 p 3 m 67 s 1
360054 bytes read in 13 ms (26.4 MiB/s)
Logo:
Image size : 400 x 300
Bits per pixel: 24
Compression : 0
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF d6451cc
mmc1(part 0) is current device
flash target is MMC:1
Net:
Warning: ethernet@30be0000 (eth0) using random MAC address - 6e:5f:91:50:47:a0
Saving Environment to MMC... Writing to MMC(1)... OK
Fastboot: Normal
Normal Boot
19749376 bytes read in 243 ms (77.5 MiB/s)
Booting from mmc ...
44118 bytes read in 9 ms (4.7 MiB/s)
## Flattened Device Tree blob at 43000000
Using Device Tree in place at 0000000043000000, end 000000004300dc55
Starting kernel ...
[ 0.000000] Linux version 4.14.78 (root@ubuntu) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Wed Jul 21 11:39:57 CST 2021
[ 0.000000] NUMA: NODE_DATA [mem 0xbffbc700-0xbffbe4ff]
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80007ff57000 s57624 r8192 d32488 u98304
[ 0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 root=/dev/mmcblk2p2 rootwait rw
[ 0.000000] Memory: 1368052K/2093056K available (12604K kernel code, 1174K rwdata, 4696K rodata, 768K init, 425K bss, 69644K reserved, 655360K cma-reserved)
[ 0.000000] .init : 0xffff000009170000 - 0xffff000009230000 ( 768 KB)
[ 0.000000] .data : 0xffff000009230000 - 0xffff000009355a00 ( 1175 KB)
[ 0.000000] .bss : 0xffff000009355a00 - 0xffff0000093bffb8 ( 426 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0002000000 ( 32 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff800080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000005] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.008457] system counter timer init
[ 0.011768] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.019775] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.030981] Console: colour dummy device 80x25
[ 0.034628] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.049598] Security Framework initialized
[ 0.054282] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.061123] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.067929] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.097893] ASID allocator initialised with 32768 entries
[ 0.114458] Cannot find MU entry in device tree
[ 0.116269] CPU identified as i.MX8MM, silicon rev 1.0
[ 0.121392] EFI services will not be available.
[ 0.133882] smp: Bringing up secondary CPUs ...
[ 0.162016] Detected VIPT I-cache on CPU1
[ 0.162052] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.162093] CPU1: Booted secondary processor [410fd034]
[ 0.190054] Detected VIPT I-cache on CPU2
[ 0.190073] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.190090] CPU2: Booted secondary processor [410fd034]
[ 0.218109] Detected VIPT I-cache on CPU3
[ 0.218126] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.218141] CPU3: Booted secondary processor [410fd034]
[ 0.218197] smp: Brought up 1 node, 4 CPUs
[ 0.268010] SMP: Total of 4 processors activated.
[ 0.272736] CPU features: detected feature: GIC system register CPU inte**ce
[ 0.279911] CPU features: detected feature: 32-bit EL0 Support
[ 0.285773] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.298441] CPU: All CPU(s) started at EL2
[ 0.299694] alternatives: patching kernel code
[ 0.305525] devtmpfs: initialized
[ 0.312764] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.319262] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.328415] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.354249] pinctrl core: initialized pinctrl subsystem
[ 0.357809] DMI not present or invalid.
[ 0.360831] NET: Registered protocol family 16
[ 0.369026] cpuidle: using governor menu
[ 0.370973] vdso: 2 pages (1 code @ ffff000008cd6000, 1 data @ ffff000009234000)
[ 0.377563] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.390469] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.394402] Serial: AMBA PL011 UART driver
[ 0.401240] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.428217] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.441178] ACPI: Interpreter disabled.
[ 0.443951] vgaarb: loaded
[ 0.445646] SCSI subsystem initialized
[ 0.449178] usbcore: registered new inte**ce driver usbfs
[ 0.454318] usbcore: registered new inte**ce driver hub
[ 0.459587] usbcore: registered new device driver usb
[ 0.465127] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.473489] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.486081] bd71837 0-004b: Device ID=0xA1
[ 0.487330] bd71837 0-004b: gpio_intr = 3
[ 0.491461] bd71837 0-004b: chip_irq=73
[ 0.503598] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.523767] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.543780] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.555831] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.567828] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.579863] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.591890] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.603916] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.615937] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.635989] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.644004] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.664044] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.684093] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.692105] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.712145] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.732209] i2c i2c-0: IMX I2C adapter registered
[ 0.734074] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.740276] i2c i2c-1: IMX I2C adapter registered
[ 0.744176] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.749594] BD71837:bd71837_pmic_interrupt() in.
[ 0.750039] i2c i2c-2: IMX I2C adapter registered
[ 0.750047] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.750738] i2c i2c-3: IMX I2C adapter registered
[ 0.750746] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.751182] media: Linux media inte**ce: v0.10
[ 0.751258] Linux video capture inte**ce: v2.00
[ 0.751432] pps_core: LinuxPPS API ver. 1 registered
[ 0.751436] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.751459] PTP clock support registered
[ 0.751712] EDAC MC: Ver: 3.0.0
[ 0.752078] dmi: Firmware registration failed.
[ 0.752996] MU is ready for cross core communication!
[ 0.815987] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.820214] imx rpmsg driver is registered.
[ 0.824202] Advanced Linux Sound Architecture Driver Initialized.
[ 0.830186] BD71837:IRQ_WDOG
[ 0.830807] Bluetooth: Core ver 2.22
[ 0.830842] NET: Registered protocol family 31
[ 0.830845] Bluetooth: HCI device and connection manager initialized
[ 0.830855] Bluetooth: HCI socket layer initialized
[ 0.830861] Bluetooth: L2CAP socket layer initialized
[ 0.830883] Bluetooth: SCO socket layer initialized
[ 0.832994] clocksource: Switched to clocksource arch_sys_counter
[ 0.833144] VFS: Disk quotas dquot_6.6.0
[ 0.833206] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.833337] pnp: PnP ACPI: disabled
[ 0.839162] NET: Registered protocol family 2
[ 0.839731] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.839880] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.840229] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.840338] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.840393] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.840542] NET: Registered protocol family 1
[ 0.840908] RPC: Registered named UNIX socket transport module.
[ 0.840910] RPC: Registered udp transport module.
[ 0.840913] RPC: Registered tcp transport module.
[ 0.840916] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.946349] BD71837:IRQ_ON_REQ
[ 0.950156] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.957670] kvm [1]: 8-bit VMID
[ 0.961169] kvm [1]: GICv3: no GICV resource entry
[ 0.965162] kvm [1]: disabling GICv2 emulation
[ 0.969647] kvm [1]: GIC system register CPU inte**ce enabled
[ 0.975558] kvm [1]: vgic interrupt IRQ1
[ 0.979520] kvm [1]: Hyp mode initialized successfully
[ 0.987185] audit: initializing netlink subsys (disabled)
[ 0.990149] audit: type=2000 audit(0.880:1): state=initialized audit_enabled=0 res=1
[ 0.990535] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 0.996265] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.996856] NFS: Registering the id_resolver key type
[ 0.996885] Key type id_resolver registered
[ 0.996889] Key type id_legacy registered
[ 0.996898] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.996923] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.997512] 9p: Installing v9fs 9p2000 file system support
[ 1.002058] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.002068] io scheduler noop registered
[ 1.002225] io scheduler cfq registered (default)
[ 1.002230] io scheduler mq-deadline registered
[ 1.002233] io scheduler kyber registered
[ 1.008797] pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
[ 1.011708] imx-sdma 30bd0000.dma-controller: no iram assigned, using external mem
[ 1.022723] imx-sdma 30bd0000.dma-controller: Falling back to user helper
[ 1.025701] imx-sdma 302c0000.dma-controller: no iram assigned, using external mem
[ 1.031201] imx-sdma 302b0000.dma-controller: no iram assigned, using external mem
[ 1.038329] mxs-dma 33000000.dma-apbh: initialized
[ 1.039981] Bus freq driver module loaded
[ 1.044057] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.047346] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
[ 1.048365] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
[ 1.049271] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
[ 1.149712] console [ttymxc1] enabled
[ 1.154185] bootconsole [ec_imx6q0] disabled
[ 1.170709] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.177365] [drm] No driver support for vblank timestamp query.
[ 1.183469] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.191193] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.198441] imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 1.209963] imx-drm display-subsystem: fb0: frame buffer device
[ 1.216335] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.231942] brd: module loaded
[ 1.240308] loop: module loaded
[ 1.247090] random: fast init done
[ 1.256000] fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
[ 1.263026] slram: not enough parameters.
[ 1.269049] spi_imx 30820000.ecspi: probed
[ 1.274377] spi_imx 30830000.ecspi: probed
[ 1.279557] libphy: Fixed MDIO Bus: probed
[ 1.284123] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.290138] tun: Universal TUN/TAP device driver, 1.6
[ 1.295443] CAN device driver inte**ce
[ 1.309633] mcp251x spi1.0: Cannot initialize MCP2515. Wrong wiring?
[ 1.316007] mcp251x spi1.0: Probe failed, err=19
[ 1.322512] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 1.331651] pps pps0: new PPS source ptp0
[ 1.341850] libphy: fec_enet_mii_bus: probed
[ 1.347086] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.353814] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.359666] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.365649] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.372622] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.378240] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.386080] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.392196] sky2: driver version 1.30
[ 1.397554] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.404106] ehci-pci: EHCI PCI platform driver
[ 1.408613] ehci-platform: EHCI generic platform driver
[ 1.414026] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.420266] ohci-pci: OHCI PCI platform driver
[ 1.424765] ohci-platform: OHCI generic platform driver
[ 1.430549] usbcore: registered new inte**ce driver usb-storage
[ 1.436609] usbcore: registered new inte**ce driver usb_ehset_test
[ 1.444001] usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.454403] usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.471493] imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using dummy regulator
[ 1.482897] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.487808] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.513047] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.519297] hub 1-0:1.0: USB hub found
[ 1.523100] hub 1-0:1.0: 1 port detected
[ 1.528877] input: InputEmulator as /devices/virtual/input/input0
[ 1.535686] <<-GTP-INFO->> GTP driver installing...
[ 1.541216] i2c /dev entries driver
[ 1.546661] mxc_mipi-csi 32e30000.mipi_csi: 32e30000.mipi_csi supply mipi-phy not found, using dummy regulator
[ 1.557106] mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered
[ 1.564086] CSI: Registered sensor subdevice: mxc_mipi-csi.0
[ 1.569780] mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 333000000
[ 1.580141] ov5640_mipi 3-003c: 3-003c supply DOVDD not found, using dummy regulator
[ 1.587968] ov5640_mipi 3-003c: 3-003c supply DVDD not found, using dummy regulator
[ 1.595668] ov5640_mipi 3-003c: 3-003c supply AVDD not found, using dummy regulator
[ 1.673325] ov5640_mipi 3-003c: Read reg error: reg=300a
[ 1.678650] ov5640_mipi 3-003c: Camera is not found
[ 1.698300] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.705574] sdhci: Secure Digital Host Controller Inte**ce driver
[ 1.711791] sdhci: Copyright(c) Pierre Ossman
[ 1.716305] Synopsys Designware ** Card Inte**ce Driver
[ 1.722788] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.777048] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.785080] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.842181] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 1.861045] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.905031] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.915226] galcore: clk_get vg clock failed, disable vg!
[ 1.920874] Galcore version 6.2.4.163672
[ 2.008205] mmc2: new HS200 MMC card at address 0001
[ 2.013970] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[ 2.014889] hantrodec 0 : module inserted. Major = 240
[ 2.016126] hantrodec 1 : module inserted. Major = 240
[ 2.017704] hx280enc: module inserted. Major <239>
[ 2.024074] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.024164] hub 1-1:1.0: USB hub found
[ 2.024349] hub 1-1:1.0: 4 ports detected
[ 2.025094] caam 30900000.caam: ERA source: CCBVID.
[ 2.027416] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.027426] caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
[ 2.039773] mmc1: host does not support reading read-only switch, assuming write-enable
[ 2.073597] mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
[ 2.079985] mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
[ 2.086371] mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
[ 2.098076] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.100408] mmcblk2: p1 p2
[ 2.106204] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.167994] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.175378] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 2.179048] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.189888] mmcblk1: p1
[ 2.246703] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.264096] caam algorithms registered in /proc/crypto
[ 2.272628] caam_jr 30901000.jr0: registering rng-caam
[ 2.277998] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.286617] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.293192] platform caam_sm: 64-bit clear key:
[ 2.297741] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.303413] platform caam_sm: 64-bit black key:
[ 2.307956] platform caam_sm: [0000] a3 ae 0d e1 fd a9 91 ee
[ 2.313627] platform caam_sm: [0008] d7 ee db e8 a6 f7 0a 4c
[ 2.319300] platform caam_sm: 128-bit clear key:
[ 2.321014] usb 1-1.2: new full-speed USB device number 3 using ci_hdrc
[ 2.330562] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.336239] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.341912] platform caam_sm: 128-bit black key:
[ 2.346540] platform caam_sm: [0000] 85 d6 e7 54 e2 b2 4c f6
[ 2.352212] platform caam_sm: [0008] 8d 5f 77 fd bb 2d 66 f9
[ 2.357880] platform caam_sm: 192-bit clear key:
[ 2.362512] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.368182] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.373854] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.379524] platform caam_sm: 192-bit black key:
[ 2.384153] platform caam_sm: [0000] e4 72 06 8e e2 59 e3 29
[ 2.389824] platform caam_sm: [0008] bc 41 67 61 6d 2a 3c 8d
[ 2.395495] platform caam_sm: [0016] e7 2a d8 23 33 95 eb 5f
[ 2.401165] platform caam_sm: [0024] 47 12 91 56 79 73 05 c4
[ 2.406833] platform caam_sm: 256-bit clear key:
[ 2.411463] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.417134] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.422805] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.428476] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.434143] platform caam_sm: 256-bit black key:
[ 2.438776] platform caam_sm: [0000] 6e 09 0b c5 59 75 32 9f
[ 2.444449] platform caam_sm: [0008] b0 9d 65 b3 cb c4 d9 48
[ 2.450120] platform caam_sm: [0016] 15 80 d7 b3 ce f2 f6 2a
[ 2.455795] platform caam_sm: [0024] 3e 4e a4 09 a0 69 0c 15
[ 2.461464] platform caam_sm: 64-bit unwritten blob:
[ 2.466443] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.472114] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.477786] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.483463] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.489135] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.494805] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.500476] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.506146] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.511817] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.513006] usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
[ 2.524117] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.529788] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.535459] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.541128] platform caam_sm: 128-bit unwritten blob:
[ 2.546193] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.551867] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.557540] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.563212] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.568882] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.574553] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.580223] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.585894] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.591564] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.597236] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.602906] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.608577] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.614247] platform caam_sm: 196-bit unwritten blob:
[ 2.619310] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.624997] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.630672] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.636350] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.642025] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.647700] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.653373] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.659050] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.664722] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.670396] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.676068] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.681739] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.687408] platform caam_sm: 256-bit unwritten blob:
[ 2.692471] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.698141] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.703812] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.709482] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.715153] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.720823] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.726494] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.732164] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.737834] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.743505] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.749176] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.754846] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.762201] platform caam_sm: 64-bit black key in blob:
[ 2.767445] platform caam_sm: [0000] d4 68 41 5f 6b 2a 28 1a
[ 2.773116] platform caam_sm: [0008] 1c 90 47 92 7e 38 e0 8d
[ 2.778787] platform caam_sm: [0016] 0d f1 55 55 84 bc e9 0d
[ 2.784459] platform caam_sm: [0024] 27 b6 07 58 b2 9b 3f cc
[ 2.790130] platform caam_sm: [0032] 0f dd 72 b6 6a 0e d5 c6
[ 2.795800] platform caam_sm: [0040] 17 a5 ea ee 40 34 cb bc
[ 2.801471] platform caam_sm: [0048] 69 62 43 24 7d b7 e9 e9
[ 2.807145] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.812816] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.818487] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.824157] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.829828] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.835496] platform caam_sm: 128-bit black key in blob:
[ 2.840820] platform caam_sm: [0000] d6 0f c2 36 e4 8a 3e 18
[ 2.846491] platform caam_sm: [0008] 5c e8 b2 4f 59 89 80 bd
[ 2.852162] platform caam_sm: [0016] 7e 29 a8 54 9b 98 9d b5
[ 2.857833] platform caam_sm: [0024] 21 5b 95 3c 3a 32 33 46
[ 2.863503] platform caam_sm: [0032] e9 40 14 2b 0e fe 2b 15
[ 2.869174] platform caam_sm: [0040] 43 32 1d fa 5a 01 0d c9
[ 2.874845] platform caam_sm: [0048] 28 72 4b 98 48 d3 92 99
[ 2.880515] platform caam_sm: [0056] 01 8e e5 95 19 b5 bf b3
[ 2.886186] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.891857] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.897527] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.903197] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.908866] platform caam_sm: 192-bit black key in blob:
[ 2.914190] platform caam_sm: [0000] 4e 73 44 c3 dd 6d e3 d0
[ 2.919860] platform caam_sm: [0008] a4 c9 a5 cd a8 4d 43 2a
[ 2.925559] platform caam_sm: [0016] f4 f0 ea 63 8b da 38 14
[ 2.931231] platform caam_sm: [0024] 3c b8 9b b0 4b 71 65 6f
[ 2.936901] platform caam_sm: [0032] 00 a8 4c d0 7b 62 3d cf
[ 2.942572] platform caam_sm: [0040] dd 1e 4c b8 20 c4 85 09
[ 2.948242] platform caam_sm: [0048] ce 57 1c 99 ce 26 cb c3
[ 2.953913] platform caam_sm: [0056] 17 93 c0 c7 1e 54 21 78
[ 2.959584] platform caam_sm: [0064] 46 17 02 95 82 3e 70 64
[ 2.965254] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.970925] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.976595] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.982264] platform caam_sm: 256-bit black key in blob:
[ 2.987588] platform caam_sm: [0000] 8d 92 e4 ef ac 58 8e 13
[ 2.993258] platform caam_sm: [0008] f3 0c 88 5c 64 8f c8 61
[ 2.998929] platform caam_sm: [0016] a7 aa 42 83 63 14 94 ca
[ 3.004599] platform caam_sm: [0024] 38 90 e2 24 cc 56 9b c8
[ 3.010270] platform caam_sm: [0032] a9 1e f4 b1 0a e9 40 c4
[ 3.015941] platform caam_sm: [0040] e6 f3 35 a4 76 8e 0e 60
[ 3.021612] platform caam_sm: [0048] ed d2 b6 66 cb fc df f9
[ 3.027283] platform caam_sm: [0056] 7b 6c f3 73 d8 2b 64 ee
[ 3.032953] platform caam_sm: [0064] c8 08 ce 25 3a a1 e8 29
[ 3.038624] platform caam_sm: [0072] 99 4e 9f b4 0a 61 c1 e1
[ 3.044294] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.049965] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.059789] platform caam_sm: restored 64-bit black key:
[ 3.065122] platform caam_sm: [0000] 03 ce df 65 c3 6b 18 7a
[ 3.070794] platform caam_sm: [0008] ea af ad d7 f9 1a c6 05
[ 3.076463] platform caam_sm: restored 128-bit black key:
[ 3.081874] platform caam_sm: [0000] 85 d6 e7 54 e2 b2 4c f6
[ 3.087545] platform caam_sm: [0008] 8d 5f 77 fd bb 2d 66 f9
[ 3.093214] platform caam_sm: restored 192-bit black key:
[ 3.098624] platform caam_sm: [0000] e4 72 06 8e e2 59 e3 29
[ 3.104295] platform caam_sm: [0008] bc 41 67 61 6d 2a 3c 8d
[ 3.109968] platform caam_sm: [0016] 7b a0 6d e7 86 ed fa de
[ 3.115639] platform caam_sm: [0024] 63 92 21 d6 35 f8 d4 48
[ 3.121308] platform caam_sm: restored 256-bit black key:
[ 3.126718] platform caam_sm: [0000] 6e 09 0b c5 59 75 32 9f
[ 3.132389] platform caam_sm: [0008] b0 9d 65 b3 cb c4 d9 48
[ 3.138060] platform caam_sm: [0016] 15 80 d7 b3 ce f2 f6 2a
[ 3.143731] platform caam_sm: [0024] 3e 4e a4 09 a0 69 0c 15
[ 3.150159] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 3.156054] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 3.172293] input: eGalax Inc. eGalaxTouch P80H46 1592 vT1_M00 k4.10.142 as /devices/platform/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:C002.0001/input/input1
[ 3.188074] hid-multitouch 0003:0EEF:C002.0001: input: USB HID v1.11 Pointer [eGalax Inc. eGalaxTouch P80H46 1592 vT1_M00 k4.10.142] on usb-ci_hdrc.1-1.2/input0
[ 3.202656] usbcore: registered new inte**ce driver usbhid
[ 3.208245] usbhid: USB HID core driver
[ 3.227758] fsl-micfil-dai 30080000.micfil: GET IRQ: 41
[ 3.233074] fsl-micfil-dai 30080000.micfil: GET IRQ: 42
[ 3.238322] fsl-micfil-dai 30080000.micfil: GET IRQ: 43
[ 3.243572] fsl-micfil-dai 30080000.micfil: GET IRQ: 44
[ 3.250659] imx-wm8960 sound: wm8960-hifi <-> 30020000.sai mapping ok
[ 3.257159] imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
[ 3.264227] imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
[ 3.272941] imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
[ 3.279743] imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
[ 3.288281] imx-wm8960 sound: ASoC: no DMI vendor name!
[ 3.406040] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30080000.micfil mapping ok
[ 3.413910] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[ 3.422143] NET: Registered protocol family 26
[ 3.427115] NET: Registered protocol family 10
[ 3.432332] Segment Routing with IPv6
[ 3.436058] NET: Registered protocol family 17
[ 3.440522] can: controller area network core (rev 20170425 abi 9)
[ 3.446759] NET: Registered protocol family 29
[ 3.451216] can: raw protocol (rev 20170425)
[ 3.455497] can: broadcast manager protocol (rev 20170425 t)
[ 3.461170] can: netlink gateway (rev 20170425) max_hops=1
[ 3.466842] Bluetooth: RFCOMM TTY layer initialized
[ 3.471740] Bluetooth: RFCOMM socket layer initialized
[ 3.476908] Bluetooth: RFCOMM ver 1.11
[ 3.480673] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.485999] Bluetooth: BNEP filters: protocol multicast
[ 3.491239] Bluetooth: BNEP socket layer initialized
[ 3.496217] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[ 3.502148] Bluetooth: HIDP socket layer initialized
[ 3.507195] 9pnet: Installing 9P2000 support
[ 3.511540] Key type dns_resolver registered
[ 3.518551] registered taskstats version 1
[ 3.549048] cpu cpu0: registered imx8mq-cpufreq
[ 3.554595] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
[ 3.564328] OF: PCI: host bridge /pcie@0x33800000 ranges:
[ 3.569752] OF: PCI: No bus range found for /pcie@0x33800000, using [bus 00-ff]
[ 3.577248] OF: PCI: IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[ 3.583181] OF: PCI: MEM 0x18000000..0x1fefffff -> 0x18000000
[ 3.589607] imx6q-pcie 33800000.pcie: Initialize PHY with EXT REfCLK!.
[ 3.596449] imx6q-pcie 33800000.pcie: PHY Initialization End!.
[ 3.602610] imx6q-pcie 33800000.pcie: pcie phy pll is locked.
[ 3.853519] imx6q-pcie 33800000.pcie: phy link never came up
[ 3.859198] imx6q-pcie 33800000.pcie: failed to initialize host
[ 3.865123] imx6q-pcie 33800000.pcie: unable to add pcie port.
[ 3.871690] imx6q-pcie: probe of 33800000.pcie failed with error -110
[ 3.881077] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 3.888054] hctosys: unable to open rtc device (rtc0)
[ 3.895016] WLAN_EN: disabling
[ 3.898133] usb_otg1_vbus: disabling
[ 3.902791] ALSA device list:
[ 3.905792] #0: wm8960-audio
[ 3.908847] #1: imx-audio-micfil
[ 3.920467] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.928622] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.935067] devtmpfs: mounted
[ 3.938353] Freeing unused kernel memory: 768K
[ 4.017345] systemd[1]: System time before build time, advancing clock.
[ 4.032714] systemd[1]: systemd 237 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCR default-hierarchy=hybrid)
[ 4.054460] systemd[1]: Detected architecture arm64.
Welcome to NXP i.MX Release Distro 4.14-sumo (sumo)!
[ 4.081532] systemd[1]: Set hostname to <okmx8mm>.
[ 4.088194] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.094857] systemd[1]: Initializing machine ID from random generator.
[ 4.178383] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.195573] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.298600] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.305493] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 4.329229] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.337619] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.357594] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.377410] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Swap.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Listening on Journal Socket.
Mounting Temporary Directory (/tmp)...
Mounting Kernel Debug File System...
Mounting POSIX Message Queue File System...
Mounting Huge Pages File System...
Starting Remount Root and Kernel File Systems...
Starting Create list of [ 4.605187] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
required st…ce nodes for the current kernel...
Starting Load Kernel Modules...
Starting Setup Virtual Console...
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Audit Socket.
Starting Journal Service...
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on udev Kernel Socket.
Starting udev Coldplug all Devices...
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Create System Users...
Starting Rebuild Hardware Database...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create System Users.
[ 5.062824] systemd-journald[1920]: Received request to flush runtime journal from PID 1
Starting Create Static Device Nodes in /dev...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Containers.
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Rebuild Dynamic Linker Cache...
Starting Rebuild Journal Catalog...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Rebuild Journal Catalog.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Rebuild Dynamic Linker Cache.
Starting Update is Completed...
Starting Start Psplash Boot Screen...
Starting Network Service...
[ OK ] Started Update is Completed.
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
Starting Console System Startup Logging...
[ 6.500511] edt_ft5x06 3-0038: touchscreen probe failed
[ OK ] Listening on RPCbind Server Activation Socket.
[ 6.521363] rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
[ 6.532204] imx-sdma 302c0000.dma-controller: loaded firmware 4.4
[ 6.539928] imx-sdma 302b0000.dma-controller: loaded firmware 4.4
[ 6.547642] imx-sdma 30bd0000.dma-controller: loaded firmware 4.4
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Periodic Command Scheduler.
Starting LSB: Set system clock...
[ OK ] Started Configuration for i.MX GPU (Former rc_gpu.S).
[ OK ] Started TEE Supplicant.
Starting Telephony service...
Starting RPC Bind Service...
Starting Login Service...
Starting System Logging Service...
Starting Resize root filesystem to fit available disk space...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Login Service.
Starting Connection service...
[ OK ] Started Job spooling tools.
Starting Network Time Service (one-shot ntpdate mode)...
[ OK ] Started Updates psplash to basic.
Starting LSB: run bluez5-obex daemon...
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Started Network Service.
[ OK ] Started Console System Startup Logging.
[ OK ] Started LSB: Set system clock.
[ OK ] Started RPC Bind Service.
[ OK ] Started System Logging Service.
[ OK ] Started Network Time Service (one-shot ntpdate mode).
[ OK ] Started LSB: run bluez5-obex daemon.
[ OK ] Found device /dev/ttymxc1.
[ 7.256638] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.abb7701.20181012-134852
[ 7.276821] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 7.305232] rtk_btcoex: create workqueue
[ 7.323450] rtk_btcoex: Coex over UDP
[ 7.330004] Atheros 8031 ethernet 30be0000.ethernet-1:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=30be0000.ethernet-1:01, irq=POLL)
[ 7.330319] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started Telephony service.
[ 7.379615] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Connection service.
[ 7.462817] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting Hostname Service...
Starting WPA supplicant...
Starting Save/Restore Sound Card State...
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…htness of backlight:backlight@0...
Starting Kernel Logging Service...
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Load/Save Screen Backlight …ightness of backlight:backlight@0.
[ OK ] Started WPA supplicant.
[ 7.640847] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInte**ceNumber 0
[ 7.647921] usbcore: registered new inte**ce driver rtl8723bu
[ 7.654691] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 7.660585] rtk_btusb: patch_add
[ 7.664036] rtk_btusb: auto suspend is disabled
[ 7.668922] rtk_btusb: pid = 0xb720
[ 7.672779] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 7.678443] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 7.690024] rtk_btusb: btusb_probe: done
[ 7.695202] usbcore: registered new inte**ce driver rtk_btusb
[ OK [ 7.704830] rtk_btusb: btusb_open start pm_usage_cnt(0x1)
] Reached target Network.
[ 7.711728] rtk_btusb: btusb_open hdev->promisc ==0
[ 7.719201] rtk_btusb: download_patch start
[ 7.723653] rtk_btusb: chip type value: 0x00
[ 7.728149] rtk_btusb: HCI reset.
Starting /etc/rc.local Compatibility...
Starting Lightning Fast Webserver With Light System Requirements...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ 7.788144] rtk_btusb: read_ver_rsp->lmp_subver = 0x8723
[ 7.794217] rtk_btusb: read_ver_rsp->hci_rev = 0xb
[ 7.794220] rtk_btusb: patch_entry->lmp_sub = 0x8723
[ 7.794223] rtk_btusb: load_firmware start
[ 7.794225] rtk_btusb: lmp_version = 0x8723
[ 7.794229] rtk_btusb: config filename rtl8723bu_config
[ 7.794879] rtk_btusb: no bdaddr file /opt/bdaddr
[ 7.794904] rtk_btusb: config offset 00f4,length 08
[ 7.794907] rtk_btusb: config offset 01e3,length 01
[ 7.794909] rtk_btusb: config offset 00db,length 01
[ 7.794912] rtk_btusb: 55 ab 23 87 13 00 f4 00 08 01 00 00 00 05 50 00
[ 7.794914] rtk_btusb: 00 e3 01 01 04 db 00 01 42
[ 7.794931] rtk_btusb: Config file length 25, new length 25
[ 7.794933] rtk_btusb: fw name is rtl8723b_fw
[ 7.796984] rtk_btusb: This is not 8723a, use new patch style!
[ 7.797050] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 7.798146] rtk_btusb: eversion->status = 0x0, eversion->version = 0x1
[ 7.798153] rtk_btusb: load_firmware: New gEVersion 1
[ 7.798158] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 1
[ 7.798161] rtk_btusb: lmp_version is 8723, project_id is 8723, match!
[ 7.798162] rtk_btusb: fw_version = 0x1e6ca747
[ 7.798164] rtk_btusb: number_of_total_patch = 2
[ 7.798167] rtk_btusb: chipID 2
[ 7.798170] rtk_btusb: patch_length 0x58f0
[ 7.798171] rtk_btusb: start_offset 0x000058c0
[ 7.798174] rtk_btusb: Svn version: 19897
[ 7.798177] rtk_btusb: Coexistence: BTCOEX_20171128-6d50
[ 7.798178] rtk_btusb: buf_len = 0x5909
[ 7.798222] rtk_btusb: fw: exists, config file: exists
[ 7.798224] rtk_btusb: load_firmware done
[ 7.798260] rtk_btusb: download_data start
Starting telnetd...
[ OK ] Started Vsftpd ftp daemon.
Starting Permit User Sessions...
[ OK ] Started Update psplash to network.
Starting Terminate Psplash Boot Screen...
[ OK ] Reached target Sound Card.
[ OK ] Started Kernel Logging Service.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started telnetd.
[ OK ] Started Permit User Sessions.
[ OK ] Started Terminate Psplash Boot Screen.
[ OK ] Started Hostname Service.
Starting Bluetooth service...
Starting Weston Wayland Compositor (on tty7)...
[ OK ] Started Serial Getty on ttymxc1.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Weston Wayland Compositor (on tty7).
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth.
Starting weston-touch-calibrator...
Starting Matrix GUI...
[ 8.338143] rtk_btusb: download_data done
[ 8.342243] rtk_btusb: HCI reset.
[ OK ] Created slice User Slice of root.
Starting User Manager for UID 0...
[ 8.400774] audit: type=1006 audit(1627611652.724:2): pid=3441 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 8.414132] rtk_btusb: read_ver_rsp->lmp_subver = 0xa747
[ 8.419600] rtk_btusb: read_ver_rsp->hci_rev = 0x1e6c
[ 8.424751] rtk_btusb: patch_entry->lmp_sub = 0x8723
[ 8.429866] rtk_btusb: Rtk patch end 0
[ 8.429871] rtk_btusb: btusb_open set HCI_RUNNING
[ 8.430056] rtk_btcoex: Open BTCOEX
[ 8.430060] rtk_btcoex: create_udpsocket: connect_port: 30001
[ 8.430100] rtk_btcoex: send msg INVITE_REQ with len:11
[ 8.430239] rtk_btusb: btusb_open end pm_usage_cnt(0x0)
[ 8.439105] rtk_btcoex: BTCOEX hci_rev 0x1e6c
[ 8.439108] rtk_btcoex: BTCOEX lmp_subver 0xa747
[ OK ] Started Session c1 of user root.
[ 8.483169] rtk_btusb: btusb_notify: hci0 evt 3
[ OK ] Started Matrix GUI.
[ OK ] Started User Manager for UID 0.
[ 10.541077] rtk_btusb: btusb_flush add delay
[ 10.555497] rtk_btusb: btusb_close
[ 10.577076] rtk_btcoex: Close BTCOEX
[ 10.580669] rtk_btcoex: release udp socket
[ 10.584897] rtk_btcoex: -x
[ 11.352531] EXT4-fs (mmcblk2p2): resizing filesystem from 786432 to 1890768 blocks
[ 11.418812] EXT4-fs (mmcblk2p2): resized filesystem to 1890768
[ 11.438829] fec 30be0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.446641] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.493968] 8021q: 802.1Q VLAN Support v1.8
[ OK ] Started Resize root filesystem to fit available disk space.
NXP i.MX Release Distro 4.14-sumo okmx8mm ttymxc1
okmx8mm login: root
Last login: Fri Jul 30 02:20:52 UTC 2021 on tty7
root@okmx8mm:~# ls
root@okmx8mm:~# [ 106.959384] random: crng init done
[ 106.962802] random: 7 urandom warning(s) missed due to ratelimiting
[ 557.645655] audit: type=1006 audit(1627612201.968:3): pid=3537 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
root@okmx8mm:~# mount -f nfs 192.168.0.99:/nfsroot /mnt/nfs -o nolock
mount: bad usage
Try 'mount --help' for more information.
root@okmx8mm:~# ls /mnt/
root@okmx8mm:~# mkdir /mnt/nfs
mount: bad usage
root@okmx8mm:~# mount -t nfs 192.168.0.99:/nfsroot /mnt/nfs -o nolock
root@okmx8mm:~# ls
root@okmx8mm:~# cd /mnt/nfs/
root@okmx8mm:/mnt/nfs# ls
backlight env.ini gpio.ko gpio_test keypad libgpiod.a linux qtt1
root@okmx8mm:/mnt/nfs# ./qtt1
swvalve init open export file error:: Permission denied
root@okmx8mm:/mnt/nfs# cd /sys/kernel/debug/
root@okmx8mm:/sys/kernel/debug# ls
30900000.caam ctl ieee80211 opp split_huge_pages
asoc debug_enabled iio pinctrl suspend_stats
bdi dma_buf ion pm_genpd ubi
block dri kvm pm_qos ubifs
bluetooth extfrag memblock pwm usb
cec fault_around_bytes mmc0 ras virtio-ports
ci_hdrc.0 gc mmc1 regmap wakeup_sources
ci_hdrc.1 gpio mmc2 regulator
clk hid mtd sleep_time
root@okmx8mm:/sys/kernel/debug# cat gpio
gpiochip0: GPIOs 0-31, parent: platform/30200000.gpio, 30200000.gpio:
gpiochip1: GPIOs 32-63, parent: platform/30210000.gpio, 30210000.gpio:
gpio-38 ( |? ) out hi
gpio-44 ( |cd ) in lo IRQ
gpio-51 ( |VSD_3V3 ) out hi
gpiochip2: GPIOs 64-95, parent: platform/30220000.gpio, 30220000.gpio:
gpio-80 ( |status ) out hi
gpio-83 ( |usb_otg1_vbus ) out lo
gpio-89 ( |WLAN_EN ) out lo
gpiochip3: GPIOs 96-127, parent: platform/30230000.gpio, 30230000.gpio:
gpio-118 ( |headphone detect ) in lo IRQ
gpio-124 ( |GPIO Key HOME ) in hi IRQ
gpio-127 ( |GPIO Key UP ) in hi IRQ
gpiochip4: GPIOs 128-159, parent: platform/30240000.gpio, 30240000.gpio:
gpio-130 ( |GPIO Key DOWN ) in hi IRQ
gpio-137 ( |spi_imx ) out hi
gpio-141 ( |spi_imx ) out hi
root@okmx8mm:/sys/kernel/debug# cd /mnt/nfs/
swvalve init write file operation error:: Device or resource busy
root@okmx8mm:/mnt/nfs# [ 4156.737959] audit: type=1006 audit(1627615801.064:4): pid=3596 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
U-Boot SPL 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
power_bd71837_init
DRAM PHY training for 2400MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DS2460 OK
Normal Boot
Trying to boot from MMC1
U-Boot 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
CPU: Freescale i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU: Commercial temperature grade (0C to 95C) at 52C
Reset cause: POR
Model: FSL i.MX8MM EVK board
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
OK
Display: MIPI7 (1024x600)
Video: 1024x600x24
** Unable to read file logo.bmp **
Logo:
There is no valid bmp file at the given address
Error: no valid bmp image at 40480000
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF d6451cc
- U-Boot 2018.03-dirty
switch to partitions #0, OK
mmc0 is current device
flash target is MMC:0
Net:
Warning: ethernet@30be0000 (eth0) using random MAC address - 3e:80:82:a2:7b:81
Saving Environment to MMC... Writing to MMC(0)... OK
eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
17215124 bytes read in 741 ms (22.2 MiB/s)
## Loading kernel from FIT Image at 4a000000 ...
Using 'okmx8mm' configuration
Trying 'kernel' kernel subimage
Description: ARM64 Kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x4a0000d0
Data Size: 8940586 Bytes = 8.5 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x40480000
Entry Point: 0x40480000
Hash algo: crc32
Hash value: b2455a52
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 4a000000 ...
Trying 'initrd' ramdisk subimage
Description: initrd for arm64
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x4a886ddc
Data Size: 8229541 Bytes = 7.8 MiB
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 805c150e
## Loading fdt from FIT Image at 4a000000 ...
Trying 'okmx8mm-evk-dtb' fdt subimage
Description: ok8mm-evk-dtb
Type: Flat Device Tree
Data Start: 0x4b060168
Data Size: 42972 Bytes = 42 KiB
Load Address: 0x43000000
Hash algo: crc32
Hash value: 96a916de
Loading fdt from 0x4b060168 to 0x43000000
Booting using the fdt blob at 0x43000000
Uncompressing Kernel Image ... OK
reserving fdt memory region: addr=7f000000 size=1000000
Using Device Tree in place at 0000000043000000, end 000000004300d7db
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.78-g19c3169-dirty (forlinx@forlinx-Shangqi-N4610) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Tue Aug 13 10:43:28 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Forlinx i.MX8MM EVK board
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000056000000, size 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xbffbed00-0xbffc0aff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8400000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80007ff59000 s57624 r8192 d32488 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515072
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 root=/dev/ram0 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1360008K/2093056K available (12604K kernel code, 1172K rwdata, 4700K rodata, 768K init, 435K bss, 77688K reserved, 655360K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008cd0000 ( 12608 KB)
[ 0.000000] .rodata : 0xffff000008cd0000 - 0xffff000009170000 ( 4736 KB)
[ 0.000000] .data : 0xffff000009230000 - 0xffff000009355200 ( 1173 KB)
[ 0.000000] .bss : 0xffff000009355200 - 0xffff0000093c1fb8 ( 436 KB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MM clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.008482] system counter timer init
[ 0.011766] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.031017] Console: colour dummy device 80x25
[ 0.034631] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.044898] pid_max: default: 32768 minimum: 301
[ 0.049601] Security Framework initialized
[ 0.054271] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.061128] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.067928] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.074655] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.097891] ASID allocator initialised with 32768 entries
[ 0.105887] Hierarchical SRCU implementation.
[ 0.114464] Cannot find MU entry in device tree
[ 0.116276] CPU identified as i.MX8MM, silicon rev 1.0
[ 0.121396] EFI services will not be available.
[ 0.133886] smp: Bringing up secondary CPUs ...
[ 0.162025] Detected VIPT I-cache on CPU1
[ 0.162061] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.162102] CPU1: Booted secondary processor [410fd034]
[ 0.190060] Detected VIPT I-cache on CPU2
[ 0.190079] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.190097] CPU2: Booted secondary processor [410fd034]
[ 0.218116] Detected VIPT I-cache on CPU3
[ 0.218132] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.218147] CPU3: Booted secondary processor [410fd034]
[ 0.218204] smp: Brought up 1 node, 4 CPUs
[ 0.268018] SMP: Total of 4 processors activated.
[ 0.272744] CPU features: detected feature: GIC system register CPU inte**ce
[ 0.279918] CPU features: detected feature: 32-bit EL0 Support
[ 0.285780] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.298504] CPU: All CPU(s) started at EL2
[ 0.299758] alternatives: patching kernel code
[ 0.305591] devtmpfs: initialized
[ 0.312602] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.319092] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.328250] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.354080] pinctrl core: initialized pinctrl subsystem
[ 0.357608] DMI not present or invalid.
[ 0.360659] NET: Registered protocol family 16
[ 0.366236] cpuidle: using governor menu
[ 0.369600] vdso: 2 pages (1 code @ ffff000008cd6000, 1 data @ ffff000009234000)
[ 0.376195] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.388992] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.393057] Serial: AMBA PL011 UART driver
[ 0.399470] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.424658] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.437966] ACPI: Interpreter disabled.
[ 0.440692] vgaarb: loaded
[ 0.441961] SCSI subsystem initialized
[ 0.446119] usbcore: registered new inte**ce driver usbfs
[ 0.451004] usbcore: registered new inte**ce driver hub
[ 0.456373] usbcore: registered new device driver usb
[ 0.461866] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.470298] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.482863] bd71837 0-004b: Device ID=0xA1
[ 0.484111] bd71837 0-004b: gpio_intr = 3
[ 0.488244] bd71837 0-004b: chip_irq=54
[ 0.504375] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.528538] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.552557] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.568582] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.584609] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.600668] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.616666] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.632695] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.648727] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.672774] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.684761] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.708852] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.732884] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.744887] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.768934] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.792999] i2c i2c-0: IMX I2C adapter registered
[ 0.794862] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.796487] BD71837:bd71837_pmic_interrupt() in.
[ 0.800487] BD71837:IRQ_WDOG
[ 0.800489] BD71837:IRQ_ON_REQ
[ 0.811559] i2c i2c-1: IMX I2C adapter registered
[ 0.815528] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.821243] media: Linux media inte**ce: v0.10
[ 0.825436] Linux video capture inte**ce: v2.00
[ 0.830180] pps_core: LinuxPPS API ver. 1 registered
[ 0.835029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.844231] PTP clock support registered
[ 0.848394] EDAC MC: Ver: 3.0.0
[ 0.851544] dmi: Firmware registration failed.
[ 0.856668] MU is ready for cross core communication!
[ 0.863278] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.866799] imx rpmsg driver is registered.
[ 0.870792] Advanced Linux Sound Architecture Driver Initialized.
[ 0.877342] Bluetooth: Core ver 2.22
[ 0.880285] NET: Registered protocol family 31
[ 0.884733] Bluetooth: HCI device and connection manager initialized
[ 0.891121] Bluetooth: HCI socket layer initialized
[ 0.896018] Bluetooth: L2CAP socket layer initialized
[ 0.901104] Bluetooth: SCO socket layer initialized
[ 0.906843] clocksource: Switched to clocksource arch_sys_counter
[ 0.912278] VFS: Disk quotas dquot_6.6.0
[ 0.916105] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.923098] pnp: PnP ACPI: disabled
[ 0.932135] NET: Registered protocol family 2
[ 0.934249] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.941084] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.947905] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.954256] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.960448] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.966813] NET: Registered protocol family 1
[ 0.971384] RPC: Registered named UNIX socket transport module.
[ 0.976975] RPC: Registered udp transport module.
[ 0.981697] RPC: Registered tcp transport module.
[ 0.986422] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.993108] Trying to unpack rootfs image as initramfs...
[ 0.998685] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 1.025930] Freeing initrd memory: 8036K
[ 1.028121] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.035279] kvm [1]: 8-bit VMID
[ 1.038749] kvm [1]: GICv3: no GICV resource entry
[ 1.042769] kvm [1]: disabling GICv2 emulation
[ 1.047252] kvm [1]: GIC system register CPU inte**ce enabled
[ 1.053161] kvm [1]: vgic interrupt IRQ1
[ 1.057126] kvm [1]: Hyp mode initialized successfully
[ 1.064699] audit: initializing netlink subsys (disabled)
[ 1.067752] audit: type=2000 audit(0.972:1): state=initialized audit_enabled=0 res=1
[ 1.068111] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 1.073871] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.074473] NFS: Registering the id_resolver key type
[ 1.074502] Key type id_resolver registered
[ 1.074506] Key type id_legacy registered
[ 1.074515] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.074538] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.075230] 9p: Installing v9fs 9p2000 file system support
[ 1.088750] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.088758] io scheduler noop registered
[ 1.088907] io scheduler cfq registered (default)
[ 1.088911] io scheduler mq-deadline registered
[ 1.088915] io scheduler kyber registered
[ 1.096971] pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
[ 1.099716] imx-sdma 30bd0000.dma-controller: no iram assigned, using external mem
[ 1.103737] imx-sdma 30bd0000.dma-controller: Falling back to user helper
[ 1.106367] imx-sdma 302c0000.dma-controller: no iram assigned, using external mem
[ 1.111817] imx-sdma 302b0000.dma-controller: no iram assigned, using external mem
[ 1.122076] mxs-dma 33000000.dma-apbh: initialized
[ 1.123703] Bus freq driver module loaded
[ 1.127733] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.130258] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 25, base_baud = 1500000) is a IMX
[ 1.209838] console [ttymxc1] enabled
[ 1.214306] bootconsole [ec_imx6q0] disabled
[ 1.230118] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.236788] [drm] No driver support for vblank timestamp query.
[ 1.242842] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.250569] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.257786] panel-**-dsi 32e10000.mipi_dsi.0: 32e10000.mipi_dsi.0 supply power not found, using dummy regulator
[ 1.268383] imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 1.320008] Console: switching to colour frame buffer device 128x37
[ 1.343528] imx-drm display-subsystem: fb0: frame buffer device
[ 1.349880] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.365189] brd: module loaded
[ 1.373405] loop: module loaded
[ 1.379892] random: fast init done
[ 1.392331] fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
[ 1.399370] slram: not enough parameters.
[ 1.405032] libphy: Fixed MDIO Bus: probed
[ 1.409502] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.415507] tun: Universal TUN/TAP device driver, 1.6
[ 1.420814] CAN device driver inte**ce
[ 1.426054] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.431908] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.437900] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.444876] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.450497] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.458384] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.464501] sky2: driver version 1.30
[ 1.469682] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.476241] ehci-pci: EHCI PCI platform driver
[ 1.480752] ehci-platform: EHCI generic platform driver
[ 1.486162] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.492379] ohci-pci: OHCI PCI platform driver
[ 1.496881] ohci-platform: OHCI generic platform driver
[ 1.502616] usbcore: registered new inte**ce driver usb-storage
[ 1.508679] usbcore: registered new inte**ce driver usb_ehset_test
[ 1.515956] usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.526399] usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.543459] imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using dummy regulator
[ 1.554773] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.559682] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.582905] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.589147] hub 1-0:1.0: USB hub found
[ 1.592949] hub 1-0:1.0: 1 port detected
[ 1.598697] input: InputEmulator as /devices/virtual/input/input0
[ 1.605635] i2c /dev entries driver
[ 1.624105] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.631306] sdhci: Secure Digital Host Controller Inte**ce driver
[ 1.637533] sdhci: Copyright(c) Pierre Ossman
[ 1.641996] Synopsys Designware ** Card Inte**ce Driver
[ 1.648454] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.702899] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.715850] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.766988] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 1.822885] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.833644] galcore: clk_get vg clock failed, disable vg!
[ 1.839302] Galcore version 6.2.4.163672
[ 1.842122] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.930904] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.948481] hantrodec 0 : module inserted. Major = 240
[ 1.954690] hantrodec 1 : module inserted. Major = 240
[ 1.961285] hx280enc: module inserted. Major <239>
[ 1.969795] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.976473] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.977214] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 1.981857] mmcblk1: p1
[ 1.990537] caam 30900000.caam: ERA source: CCBVID.
[ 1.997839] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.004407] caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
[ 2.013633] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.018931] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.075975] mmc2: new HS200 MMC card at address 0001
[ 2.081712] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[ 2.086707] mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
[ 2.091768] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.091941] hub 1-1:1.0: USB hub found
[ 2.092097] hub 1-1:1.0: 4 ports detected
[ 2.106238] mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
[ 2.112622] mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
[ 2.119743] mmcblk2: p1 p2
[ 2.159432] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.174059] caam algorithms registered in /proc/crypto
[ 2.182510] caam_jr 30901000.jr0: registering rng-caam
[ 2.187855] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.196630] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.203036] platform caam_sm: 64-bit clear key:
[ 2.207725] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.213426] platform caam_sm: 64-bit black key:
[ 2.217972] platform caam_sm: [0000] 75 4c fc 59 0d 11 84 14
[ 2.223648] platform caam_sm: [0008] 82 56 8d b1 df 56 41 b7
[ 2.229336] platform caam_sm: 128-bit clear key:
[ 2.233966] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.239637] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.245313] platform caam_sm: 128-bit black key:
[ 2.249942] platform caam_sm: [0000] 94 9e b2 f9 7a b9 11 bd
[ 2.255618] platform caam_sm: [0008] 90 a3 97 40 b0 49 31 f5
[ 2.261288] platform caam_sm: 192-bit clear key:
[ 2.265923] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.271594] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.277265] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.282938] platform caam_sm: 192-bit black key:
[ 2.287567] platform caam_sm: [0000] 30 13 39 cc 19 bb af c7
[ 2.293238] platform caam_sm: [0008] ec 2d 63 af 55 d6 dd 2f
[ 2.298913] platform caam_sm: [0016] 9a e5 58 66 2b 65 2d 13
[ 2.304634] platform caam_sm: [0024] 2d c7 71 eb c2 b4 85 43
[ 2.304639] platform caam_sm: 256-bit clear key:
[ 2.304645] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.304651] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.304658] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.304664] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.304667] platform caam_sm: 256-bit black key:
[ 2.304673] platform caam_sm: [0000] e1 3b ce f7 71 83 18 c6
[ 2.304678] platform caam_sm: [0008] 80 83 3a 09 32 04 86 a0
[ 2.304684] platform caam_sm: [0016] f5 87 94 74 ea 10 68 8e
[ 2.304689] platform caam_sm: [0024] e8 c5 83 0e 56 3c 67 9a
[ 2.304693] platform caam_sm: 64-bit unwritten blob:
[ 2.304715] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.304720] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.304726] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.304731] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.304737] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.304742] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.304748] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.304753] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.304759] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.304764] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.304770] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.304775] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.304779] platform caam_sm: 128-bit unwritten blob:
[ 2.304784] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.304790] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.304795] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.304801] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.304806] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.304812] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.304817] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.304823] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.304829] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.304834] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.304840] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.304845] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.304849] platform caam_sm: 196-bit unwritten blob:
[ 2.304855] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.304860] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.304866] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.304871] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.304877] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.304882] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.304888] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.304893] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.304899] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.304904] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.304909] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.304915] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.304918] platform caam_sm: 256-bit unwritten blob:
[ 2.304924] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.304929] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.304935] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.304940] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.304945] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.304951] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.304957] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.304962] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.304968] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.304973] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.304979] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.304984] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.305105] platform caam_sm: 64-bit black key in blob:
[ 2.305112] platform caam_sm: [0000] 20 b5 90 63 7d 26 02 76
[ 2.305117] platform caam_sm: [0008] 30 9e a8 71 0d 79 e2 ec
[ 2.305123] platform caam_sm: [0016] 5e c7 6a 96 47 ac 2c 7c
[ 2.305128] platform caam_sm: [0024] f8 2b d3 da 27 c0 f4 5e
[ 2.305134] platform caam_sm: [0032] e6 7a 16 6b a8 6d 13 3b
[ 2.305140] platform caam_sm: [0040] 94 17 03 6d 7c 41 d4 3e
[ 2.305145] platform caam_sm: [0048] 22 eb b0 b1 e4 b9 64 63
[ 2.305151] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.305156] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.305162] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.305167] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.305173] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.305176] platform caam_sm: 128-bit black key in blob:
[ 2.305182] platform caam_sm: [0000] 6c 39 94 f5 e2 3d 7c 1e
[ 2.305188] platform caam_sm: [0008] 18 02 4c ae 5f e5 0d 3b
[ 2.305193] platform caam_sm: [0016] 3f b0 2b 54 2f e5 24 f7
[ 2.305199] platform caam_sm: [0024] e6 3f 1b 8c a0 f6 fe 23
[ 2.305204] platform caam_sm: [0032] 05 c3 23 76 f2 11 54 05
[ 2.305210] platform caam_sm: [0040] 32 73 48 bc 9b 89 1c 46
[ 2.305216] platform caam_sm: [0048] e2 11 34 29 46 df b6 6b
[ 2.305221] platform caam_sm: [0056] 2d 25 e1 cb 45 e3 8c a4
[ 2.305227] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.305232] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.305238] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.305243] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.305247] platform caam_sm: 192-bit black key in blob:
[ 2.305252] platform caam_sm: [0000] 8f ad 69 08 7b 0a d0 51
[ 2.305258] platform caam_sm: [0008] 8b ba 6a 73 6a 11 f9 23
[ 2.305263] platform caam_sm: [0016] bb 59 58 45 35 ce 10 95
[ 2.305269] platform caam_sm: [0024] 35 c7 48 ab 86 b9 88 19
[ 2.305275] platform caam_sm: [0032] 2d 25 35 e0 bb e4 ce a9
[ 2.305280] platform caam_sm: [0040] 8f b7 50 92 ea cd ae 32
[ 2.305286] platform caam_sm: [0048] 8b 28 d3 53 86 8a f3 0b
[ 2.305292] platform caam_sm: [0056] 7d 78 05 12 9f 3b 89 db
[ 2.305297] platform caam_sm: [0064] d2 7f 83 dd bf 19 72 16
[ 2.305303] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.305308] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.305314] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.305317] platform caam_sm: 256-bit black key in blob:
[ 2.305323] platform caam_sm: [0000] 61 35 92 45 58 1f 04 2d
[ 2.305329] platform caam_sm: [0008] b5 16 f6 39 26 c7 a7 f3
[ 2.305334] platform caam_sm: [0016] de c4 a3 b6 ac 61 d0 38
[ 2.305340] platform caam_sm: [0024] 35 bd a5 a2 42 f8 20 00
[ 2.305345] platform caam_sm: [0032] ca 2d 28 09 cc 32 7d 84
[ 2.305351] platform caam_sm: [0040] 52 7f 65 fa 92 41 63 d7
[ 2.305357] platform caam_sm: [0048] 78 c8 60 c2 d1 1b 96 cd
[ 2.305362] platform caam_sm: [0056] 06 c0 ce e6 37 fd c9 43
[ 2.305368] platform caam_sm: [0064] ec 3d f0 03 79 d1 1c 3b
[ 2.305374] platform caam_sm: [0072] 94 77 17 43 08 b0 43 3a
[ 2.305379] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.305385] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.305497] platform caam_sm: restored 64-bit black key:
[ 2.305504] platform caam_sm: [0000] d8 d2 44 f3 e8 26 a2 2e
[ 2.305509] platform caam_sm: [0008] f8 49 90 67 b2 3f f9 f0
[ 2.305513] platform caam_sm: restored 128-bit black key:
[ 2.305518] platform caam_sm: [0000] 94 9e b2 f9 7a b9 11 bd
[ 2.305524] platform caam_sm: [0008] 90 a3 97 40 b0 49 31 f5
[ 2.305527] platform caam_sm: restored 192-bit black key:
[ 2.305533] platform caam_sm: [0000] 30 13 39 cc 19 bb af c7
[ 2.305538] platform caam_sm: [0008] ec 2d 63 af 55 d6 dd 2f
[ 2.305544] platform caam_sm: [0016] a7 9b a0 48 15 29 5e 72
[ 2.305550] platform caam_sm: [0024] 69 f5 5b 93 9d 43 d6 59
[ 2.305553] platform caam_sm: restored 256-bit black key:
[ 2.305559] platform caam_sm: [0000] e1 3b ce f7 71 83 18 c6
[ 2.305564] platform caam_sm: [0008] 80 83 3a 09 32 04 86 a0
[ 2.305570] platform caam_sm: [0016] f5 87 94 74 ea 10 68 8e
[ 2.305576] platform caam_sm: [0024] e8 c5 83 0e 56 3c 67 9a
[ 2.306095] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 2.306145] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 2.306753] usbcore: registered new inte**ce driver usbhid
[ 2.306756] usbhid: USB HID core driver
[ 2.316421] imx-micfil sound-micfil: failed to find MICFIL platform device
[ 2.316444] imx-micfil: probe of sound-micfil failed with error -22
[ 2.317057] NET: Registered protocol family 26
[ 2.317549] NET: Registered protocol family 10
[ 2.318313] Segment Routing with IPv6
[ 2.318357] NET: Registered protocol family 17
[ 2.318365] can: controller area network core (rev 20170425 abi 9)
[ 2.318408] NET: Registered protocol family 29
[ 2.318412] can: raw protocol (rev 20170425)
[ 2.318416] can: broadcast manager protocol (rev 20170425 t)
[ 2.318423] can: netlink gateway (rev 20170425) max_hops=1
[ 2.318592] Bluetooth: RFCOMM TTY layer initialized
[ 2.318600] Bluetooth: RFCOMM socket layer initialized
[ 2.318619] Bluetooth: RFCOMM ver 1.11
[ 2.318626] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.318628] Bluetooth: BNEP filters: protocol multicast
[ 2.318635] Bluetooth: BNEP socket layer initialized
[ 2.318639] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[ 2.318643] Bluetooth: HIDP socket layer initialized
[ 2.318717] 9pnet: Installing 9P2000 support
[ 2.318796] Key type dns_resolver registered
[ 2.319507] registered taskstats version 1
[ 2.346890] cpu cpu0: registered imx8mq-cpufreq
[ 2.348566] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 2.349147] hctosys: unable to open rtc device (rtc0)
[ 2.353608] WLAN_EN: disabling
[ 2.353612] usb_otg1_vbus: disabling
[ 2.354241] ALSA device list:
[ 2.354244] No soundcards found.
[ 2.382863] usb 1-1.2: new full-speed USB device number 3 using ci_hdrc
[ 2.502091] input: eGalax Inc. eGalaxTouch P80H46 1592 vT1_M00 k4.10.142 as /devices/platform/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:C002.0001/input/input2
[ 2.502283] hid-multitouch 0003:0EEF:C002.0001: input: USB HID v1.11 Pointer [eGalax Inc. eGalaxTouch P80H46 1592 vT1_M00 k4.10.142] on usb-ci_hdrc.1-1.2/input0
[ 2.578851] usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
[ 3.245772] RAMDISK: gzip image found at block 0
[ 3.611977] EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
[ 3.619698] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 3.625846] devtmpfs: mounted
[ 3.629138] Freeing unused kernel memory: 768K
[ 4.483798] random: crng init done
[ 62.523486] imx-sdma 302b0000.dma-controller: external firmware not found, using ROM firmware
[ 62.523488] imx-sdma 302c0000.dma-controller: external firmware not found, using ROM firmware
[ 62.523594] imx-sdma 30bd0000.dma-controller: external firmware not found, using ROM firmware
