- 28
贡献118
飞刀25 FD
注册时间2021-7-21
在线时间4 小时
烧完后系统启动报的:
U-Boot SPL 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
power_bd71837_init
DRAM PHY training for 2400MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DS2460 OK
Normal Boot
Trying to boot from MMC2
U-Boot 2018.03-dirty (Feb 25 2020 - 02:38:23 +0000)
CPU: Freescale i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU: Commercial temperature grade (0C to 95C) at 52C
Reset cause: POR
Model: FSL i.MX8MM EVK board
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
use custom mode MIPI2HDMI_CUSTOM: 60, 1024, 600, 19531, 80, 240, 25, 10, 60, 10, 00000004, 00000000
lt8912_check_dds: DDS:3b,57,1e
Display: MIPI2HDMI_CUSTOM (1024x600)
Video: 1024x600x24
sec_mipi_dsim_bridge_mode_set: bitclk 307200 pixclk 51200 p 3 m 69 s 1
360054 bytes read in 13 ms (26.4 MiB/s)
Logo:
Image size : 400 x 300
Bits per pixel: 24
Compression : 0
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF d6451cc
- U-Boot 2018.03-dirty
switch to partitions #0, OK
mmc1(part 0) is current device
flash target is MMC:1
Net: eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
19749376 bytes read in 242 ms (77.8 MiB/s)
Booting from mmc ...
43838 bytes read in 9 ms (4.6 MiB/s)
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
reserving fdt memory region: addr=7f000000 size=1000000
Using Device Tree in place at 0000000043000000, end 000000004300db3d
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.78 (root@ubuntu) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Fri Jul 30 14:38:57 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Forlinx i.MX8MM EVK board
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000056000000, s ize 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff ]
[ 0.000000] NUMA: NODE_DATA [mem 0xbffbcd80-0xbffbeb7f]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8400000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80007ff57000 s57624 r8192 d324 88 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515072
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x3 0890000,115200 root=/dev/mmcblk2p2 rootwait rw
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1368056K/2093056K available (12604K kernel code, 1174K rw data, 4696K rodata, 768K init, 425K bss, 69640K reserved, 655360K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 M B)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 G B)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008cd0000 ( 12608 K B)
[ 0.000000] .rodata : 0xffff000008cd0000 - 0xffff000009170000 ( 4736 K B)
[ 0.000000] .init : 0xffff000009170000 - 0xffff000009230000 ( 768 K B)
[ 0.000000] .data : 0xffff000009230000 - 0xffff000009355a00 ( 1175 K B)
[ 0.000000] .bss : 0xffff000009355a00 - 0xffff0000093bffb8 ( 426 K B)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 K B)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 M B)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 G B maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0002000000 ( 32 M B actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff800080000000 ( 2048 M B)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MM clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 21990 23255500ns
[ 0.008458] system counter timer init
[ 0.011770] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 21990 23255500ns
[ 0.019775] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1d8 54df40, max_idle_ns: 440795202120 ns
[ 0.030978] Console: colour dummy device 80x25
[ 0.034630] Calibrating delay loop (skipped), value calculated using timer fr equency.. 16.00 BogoMIPS (lpj=32000)
[ 0.044899] pid_max: default: 32768 minimum: 301
[ 0.049597] Security Framework initialized
[ 0.054268] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.061125] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.067930] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.074655] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.097893] ASID allocator initialised with 32768 entries
[ 0.105887] Hierarchical SRCU implementation.
[ 0.114445] Cannot find MU entry in device tree
[ 0.116256] CPU identified as i.MX8MM, silicon rev 1.0
[ 0.121378] EFI services will not be available.
[ 0.133868] smp: Bringing up secondary CPUs ...
[ 0.162005] Detected VIPT I-cache on CPU1
[ 0.162040] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.162080] CPU1: Booted secondary processor [410fd034]
[ 0.190043] Detected VIPT I-cache on CPU2
[ 0.190064] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.190081] CPU2: Booted secondary processor [410fd034]
[ 0.218096] Detected VIPT I-cache on CPU3
[ 0.218113] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.218128] CPU3: Booted secondary processor [410fd034]
[ 0.218185] smp: Brought up 1 node, 4 CPUs
[ 0.267997] SMP: Total of 4 processors activated.
[ 0.272723] CPU features: detected feature: GIC system register CPU inte**ce
[ 0.279897] CPU features: detected feature: 32-bit EL0 Support
[ 0.285760] CPU features: detected feature: Kernel page table isolation (KPTI )
[ 0.298440] CPU: All CPU(s) started at EL2
[ 0.299694] alternatives: patching kernel code
[ 0.305506] devtmpfs: initialized
[ 0.312762] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.319246] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.328414] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.354150] pinctrl core: initialized pinctrl subsystem
[ 0.357674] DMI not present or invalid.
[ 0.360719] NET: Registered protocol family 16
[ 0.368926] cpuidle: using governor menu
[ 0.370861] vdso: 2 pages (1 code @ ffff000008cd6000, 1 data @ ffff0000092340 00)
[ 0.377466] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.394323] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.398486] Serial: AMBA PL011 UART driver
[ 0.405053] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.432393] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.445132] ACPI: Interpreter disabled.
[ 0.447830] vgaarb: loaded
[ 0.449552] SCSI subsystem initialized
[ 0.453096] usbcore: registered new inte**ce driver usbfs
[ 0.458222] usbcore: registered new inte**ce driver hub
[ 0.463531] usbcore: registered new device driver usb
[ 0.469177] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, usin g dummy regulator
[ 0.477466] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, usin g dummy regulator
[ 0.490037] bd71837 0-004b: Device ID=0xA1
[ 0.491285] bd71837 0-004b: gpio_intr = 3
[ 0.495415] bd71837 0-004b: chip_irq=72
[ 0.507555] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.527723] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.547744] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.559789] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.571792] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.583817] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.595844] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.607869] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.619897] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.639939] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.647963] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.668006] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.688042] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.696062] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.716113] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.736167] i2c i2c-0: IMX I2C adapter registered
[ 0.738029] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.744226] i2c i2c-1: IMX I2C adapter registered
[ 0.748124] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.753548] BD71837:bd71837_pmic_interrupt() in.
[ 0.754045] i2c i2c-2: IMX I2C adapter registered
[ 0.754051] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.754759] i2c i2c-3: IMX I2C adapter registered
[ 0.754766] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.755225] media: Linux media inte**ce: v0.10
[ 0.755269] Linux video capture inte**ce: v2.00
[ 0.755493] pps_core: LinuxPPS API ver. 1 registered
[ 0.755496] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.755511] PTP clock support registered
[ 0.755752] EDAC MC: Ver: 3.0.0
[ 0.756059] dmi: Firmware registration failed.
[ 0.757086] MU is ready for cross core communication!
[ 0.819998] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.822405] BD71837:IRQ_WDOG
[ 0.822408] BD71837:IRQ_ON_REQ
[ 0.830110] imx rpmsg driver is registered.
[ 0.834065] Advanced Linux Sound Architecture Driver Initialized.
[ 0.840667] Bluetooth: Core ver 2.22
[ 0.843579] NET: Registered protocol family 31
[ 0.848022] Bluetooth: HCI device and connection manager initialized
[ 0.854415] Bluetooth: HCI socket layer initialized
[ 0.859309] Bluetooth: L2CAP socket layer initialized
[ 0.864400] Bluetooth: SCO socket layer initialized
[ 0.870098] clocksource: Switched to clocksource arch_sys_counter
[ 0.875575] VFS: Disk quotas dquot_6.6.0
[ 0.879392] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.886394] pnp: PnP ACPI: disabled
[ 0.895469] NET: Registered protocol family 2
[ 0.897581] TCP established hash table entries: 16384 (order: 5, 131072 bytes )
[ 0.904406] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.911241] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.917861] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.923548] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.930275] NET: Registered protocol family 1
[ 0.934877] RPC: Registered named UNIX socket transport module.
[ 0.940307] RPC: Registered udp transport module.
[ 0.945035] RPC: Registered tcp transport module.
[ 0.949751] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.957296] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 0.964425] kvm [1]: 8-bit VMID
[ 0.967987] kvm [1]: GICv3: no GICV resource entry
[ 0.971984] kvm [1]: disabling GICv2 emulation
[ 0.976467] kvm [1]: GIC system register CPU inte**ce enabled
[ 0.982372] kvm [1]: vgic interrupt IRQ1
[ 0.986334] kvm [1]: Hyp mode initialized successfully
[ 0.993825] audit: initializing netlink subsys (disabled)
[ 0.996948] audit: type=2000 audit(0.892:1): state=initialized audit_enabled= 0 res=1
[ 0.997298] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 1.003051] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.003668] NFS: Registering the id_resolver key type
[ 1.003694] Key type id_resolver registered
[ 1.003698] Key type id_legacy registered
[ 1.003708] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.003729] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.004278] 9p: Installing v9fs 9p2000 file system support
[ 1.009025] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 45)
[ 1.009033] io scheduler noop registered
[ 1.009193] io scheduler cfq registered (default)
[ 1.009200] io scheduler mq-deadline registered
[ 1.009203] io scheduler kyber registered
[ 1.016476] pwm-backlight backlight@0: backlight@0 supply power not found, us ing dummy regulator
[ 1.019937] imx-sdma 30bd0000.dma-controller: no iram assigned, using externa l mem
[ 1.024542] imx-sdma 30bd0000.dma-controller: Falling back to user helper
[ 1.028459] imx-sdma 302c0000.dma-controller: no iram assigned, using externa l mem
[ 1.033817] imx-sdma 302b0000.dma-controller: no iram assigned, using externa l mem
[ 1.040494] mxs-dma 33000000.dma-apbh: initialized
[ 1.042218] Bus freq driver module loaded
[ 1.046878] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.049643] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
[ 1.050813] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
[ 1.051585] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
[ 1.156525] console [ttymxc1] enabled
[ 1.161001] bootconsole [ec_imx6q0] disabled
[ 1.177206] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.184094] [drm] No driver support for vblank timestamp query.
[ 1.190135] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc _ops)
[ 1.197918] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.205161] imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_d sim_ops)
[ 1.216720] imx-drm display-subsystem: fb0: frame buffer device
[ 1.223108] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.238795] brd: module loaded
[ 1.247068] loop: module loaded
[ 1.253642] random: fast init done
[ 1.262488] fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
[ 1.269596] slram: not enough parameters.
[ 1.275784] spi_imx 30820000.ecspi: probed
[ 1.281080] libphy: Fixed MDIO Bus: probed
[ 1.285604] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.291628] tun: Universal TUN/TAP device driver, 1.6
[ 1.296911] CAN device driver inte**ce
[ 1.302639] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, us ing dummy regulator
[ 1.311798] pps pps0: new PPS source ptp0
[ 1.321954] libphy: fec_enet_mii_bus: probed
[ 1.327269] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.333974] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.339826] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.345812] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.352788] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.358411] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.366254] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.372339] sky2: driver version 1.30
[ 1.377590] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.384146] ehci-pci: EHCI PCI platform driver
[ 1.388655] ehci-platform: EHCI generic platform driver
[ 1.394057] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.400272] ohci-pci: OHCI PCI platform driver
[ 1.404773] ohci-platform: OHCI generic platform driver
[ 1.410557] usbcore: registered new inte**ce driver usb-storage
[ 1.416616] usbcore: registered new inte**ce driver usb_ehset_test
[ 1.423978] usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.434376] usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.451221] imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using d ummy regulator
[ 1.462578] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.467487] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.490154] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.496389] hub 1-0:1.0: USB hub found
[ 1.500185] hub 1-0:1.0: 1 port detected
[ 1.505963] input: InputEmulator as /devices/virtual/input/input0
[ 1.512693] <<-GTP-INFO->> GTP driver installing...
[ 1.518160] i2c /dev entries driver
[ 1.523524] mxc_mipi-csi 32e30000.mipi_csi: 32e30000.mipi_csi supply mipi-phy not found, using dummy regulator
[ 1.533926] mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered
[ 1.540911] CSI: Registered sensor subdevice: mxc_mipi-csi.0
[ 1.546597] mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_sett le: 2, wclk: 1, freq: 333000000
[ 1.556956] ov5640_mipi 3-003c: 3-003c supply DOVDD not found, using dummy re gulator
[ 1.564803] ov5640_mipi 3-003c: 3-003c supply DVDD not found, using dummy reg ulator
[ 1.572504] ov5640_mipi 3-003c: 3-003c supply AVDD not found, using dummy reg ulator
[ 1.650432] ov5640_mipi 3-003c: Read reg error: reg=300a
[ 1.655757] ov5640_mipi 3-003c: Camera is not found
[ 1.675375] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.682617] sdhci: Secure Digital Host Controller Inte**ce driver
[ 1.688833] sdhci: Copyright(c) Pierre Ossman
[ 1.693328] Synopsys Designware ** Card Inte**ce Driver
[ 1.699818] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.754154] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.765603] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.818254] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 1.838124] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.878141] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.892669] galcore: clk_get vg clock failed, disable vg!
[ 1.898308] Galcore version 6.2.4.163672
[ 1.972471] mmc2: new HS200 MMC card at address 0001
[ 1.978825] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[ 1.983855] mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
[ 1.990253] mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
[ 1.998702] mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
[ 1.999856] hub 1-1:1.0: USB hub found
[ 2.000016] hub 1-1:1.0: 4 ports detected
[ 2.017593] mmcblk2: p1 p2
[ 2.023350] hantrodec 0 : module inserted. Major = 240
[ 2.029875] hantrodec 1 : module inserted. Major = 240
[ 2.036836] hx280enc: module inserted. Major <239>
[ 2.043742] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.050640] caam 30900000.caam: ERA source: CCBVID.
[ 2.058340] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.065025] caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
[ 2.074631] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.079921] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.152753] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.220410] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.235022] caam algorithms registered in /proc/crypto
[ 2.243556] caam_jr 30901000.jr0: registering rng-caam
[ 2.248991] caam 30900000.caam: caam pkc algorithms registered in /proc/crypt o
[ 2.257585] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.263998] platform caam_sm: 64-bit clear key:
[ 2.268554] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.274340] platform caam_sm: 64-bit black key:
[ 2.278889] platform caam_sm: [0000] 7b 39 06 5f d5 09 e5 29
[ 2.284562] platform caam_sm: [0008] c0 42 f3 08 c9 f9 66 2c
[ 2.286121] usb 1-1.4: new high-speed USB device number 3 using ci_hdrc
[ 2.296867] platform caam_sm: 128-bit clear key:
[ 2.301497] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.307172] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.312844] platform caam_sm: 128-bit black key:
[ 2.317476] platform caam_sm: [0000] 84 40 ff 85 06 e2 25 ad
[ 2.323152] platform caam_sm: [0008] 36 c3 f7 f0 57 21 a2 12
[ 2.328824] platform caam_sm: 192-bit clear key:
[ 2.333454] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.339125] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.344797] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.350465] platform caam_sm: 192-bit black key:
[ 2.355094] platform caam_sm: [0000] 1d ae e0 05 64 73 46 6e
[ 2.360765] platform caam_sm: [0008] 8c 24 cf 45 b9 e3 6a 72
[ 2.366436] platform caam_sm: [0016] 0b 0f f4 7c 4d 32 db b3
[ 2.372106] platform caam_sm: [0024] 53 29 72 97 dd 16 ce 76
[ 2.377776] platform caam_sm: 256-bit clear key:
[ 2.382405] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.388076] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.393747] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.399417] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.405092] platform caam_sm: 256-bit black key:
[ 2.409724] platform caam_sm: [0000] bd 87 b5 69 3d e3 c0 4d
[ 2.415399] platform caam_sm: [0008] b5 89 37 63 a8 dd 83 a1
[ 2.421071] platform caam_sm: [0016] 7e e5 aa b5 b3 40 e6 b7
[ 2.426744] platform caam_sm: [0024] ce b6 63 f3 92 24 ce 3d
[ 2.432420] platform caam_sm: 64-bit unwritten blob:
[ 2.437398] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.443069] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.448740] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.454413] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.460085] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.465756] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.471427] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.477097] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.482769] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.488440] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.494110] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.499785] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.505454] platform caam_sm: 128-bit unwritten blob:
[ 2.510517] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.516195] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.521866] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.527537] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.533207] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.538878] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.544548] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.550219] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.555890] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.561560] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.567231] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.572901] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.578570] platform caam_sm: 196-bit unwritten blob:
[ 2.583632] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.589303] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.594973] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.600644] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.606315] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.611985] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.617656] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.623326] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.628997] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.634667] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.640338] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.646008] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.651676] platform caam_sm: 256-bit unwritten blob:
[ 2.656739] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.662409] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.668080] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.673750] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.679420] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.685091] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.690761] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.696432] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.702103] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.707773] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.713444] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.719114] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.727481] platform caam_sm: 64-bit black key in blob:
[ 2.732726] platform caam_sm: [0000] 94 38 e1 12 81 7c c9 09
[ 2.738398] platform caam_sm: [0008] 58 d7 56 15 4e af f7 5b
[ 2.744069] platform caam_sm: [0016] af 97 8c 9f 79 16 a4 7f
[ 2.749740] platform caam_sm: [0024] 05 9b ea a9 a3 33 d0 d7
[ 2.755415] platform caam_sm: [0032] 16 80 13 ba 68 e8 d7 e2
[ 2.761087] platform caam_sm: [0040] 23 21 70 7a 0a b3 f1 22
[ 2.766758] platform caam_sm: [0048] a5 78 c0 2c c5 51 85 60
[ 2.772429] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.778099] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.783770] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.789441] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.795111] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.800779] platform caam_sm: 128-bit black key in blob:
[ 2.806103] platform caam_sm: [0000] 9c 7d be 4d c1 4d 93 e8
[ 2.811774] platform caam_sm: [0008] 4c 67 d1 4f 9a 0e ed e6
[ 2.817445] platform caam_sm: [0016] a5 14 5c 34 a1 17 44 a8
[ 2.823116] platform caam_sm: [0024] a1 3e f6 24 70 64 ec 7c
[ 2.828787] platform caam_sm: [0032] 18 62 ed 74 5c 12 d5 e7
[ 2.834457] platform caam_sm: [0040] 6b 57 00 c1 d7 08 6e 86
[ 2.840128] platform caam_sm: [0048] ed f3 4b 4f 13 21 59 92
[ 2.845798] platform caam_sm: [0056] 7f 0a cd 17 07 da 7d 4e
[ 2.851469] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.857140] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.862810] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.868481] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.874149] platform caam_sm: 192-bit black key in blob:
[ 2.879473] platform caam_sm: [0000] 3a 50 a7 84 d7 ed 2b a5
[ 2.885143] platform caam_sm: [0008] a9 8a 99 6b 38 ed 10 79
[ 2.890814] platform caam_sm: [0016] 32 e3 20 4b 8c 62 7a 80
[ 2.896485] platform caam_sm: [0024] a9 ff c3 51 65 26 8c 05
[ 2.902156] platform caam_sm: [0032] ba a9 2d a5 dd 62 80 00
[ 2.907826] platform caam_sm: [0040] 8f 52 b9 31 6e b0 2f ec
[ 2.913497] platform caam_sm: [0048] ee ae 41 00 c3 0d 3d 26
[ 2.919196] platform caam_sm: [0056] 8b f2 5c 06 d7 8e 7c 31
[ 2.924868] platform caam_sm: [0064] 95 e8 c6 76 90 5f 5e e3
[ 2.930539] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.936210] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.941880] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.947549] platform caam_sm: 256-bit black key in blob:
[ 2.952873] platform caam_sm: [0000] ff 1e db 61 0c f2 c5 c8
[ 2.958544] platform caam_sm: [0008] 3a dc 6b 35 77 9b d5 83
[ 2.964214] platform caam_sm: [0016] 14 ae d4 a5 a1 35 89 52
[ 2.969885] platform caam_sm: [0024] 78 d9 79 eb 34 7f 9f 28
[ 2.975555] platform caam_sm: [0032] f9 c1 83 ba f3 a4 d1 e9
[ 2.981226] platform caam_sm: [0040] 48 3f ce 45 56 88 4b ee
[ 2.986896] platform caam_sm: [0048] c5 ec 81 8b 03 1a b0 ec
[ 2.992567] platform caam_sm: [0056] 7f ea 86 4c 31 70 de 83
[ 2.998238] platform caam_sm: [0064] cb ee 7b 84 91 cd ce 1c
[ 3.003909] platform caam_sm: [0072] 4e 10 3f a7 2b d1 26 fc
[ 3.009579] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.015254] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.025074] platform caam_sm: restored 64-bit black key:
[ 3.030404] platform caam_sm: [0000] 75 48 59 44 a9 09 7d 7d
[ 3.036076] platform caam_sm: [0008] fd 0e 86 c6 28 eb d0 71
[ 3.041745] platform caam_sm: restored 128-bit black key:
[ 3.047156] platform caam_sm: [0000] 84 40 ff 85 06 e2 25 ad
[ 3.052827] platform caam_sm: [0008] 36 c3 f7 f0 57 21 a2 12
[ 3.058495] platform caam_sm: restored 192-bit black key:
[ 3.063906] platform caam_sm: [0000] 1d ae e0 05 64 73 46 6e
[ 3.069576] platform caam_sm: [0008] 8c 24 cf 45 b9 e3 6a 72
[ 3.075247] platform caam_sm: [0016] 25 17 50 2a 80 c0 46 32
[ 3.080917] platform caam_sm: [0024] 9a b6 e7 69 6e 5c 79 37
[ 3.086586] platform caam_sm: restored 256-bit black key:
[ 3.091996] platform caam_sm: [0000] bd 87 b5 69 3d e3 c0 4d
[ 3.097667] platform caam_sm: [0008] b5 89 37 63 a8 dd 83 a1
[ 3.103340] platform caam_sm: [0016] 7e e5 aa b5 b3 40 e6 b7
[ 3.109011] platform caam_sm: [0024] ce b6 63 f3 92 24 ce 3d
[ 3.115423] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 3.121332] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secu re state
[ 3.129813] usbcore: registered new inte**ce driver usbhid
[ 3.135409] usbhid: USB HID core driver
[ 3.155188] fsl-micfil-dai 30080000.micfil: GET IRQ: 41
[ 3.160449] fsl-micfil-dai 30080000.micfil: GET IRQ: 42
[ 3.165735] fsl-micfil-dai 30080000.micfil: GET IRQ: 43
[ 3.170981] fsl-micfil-dai 30080000.micfil: GET IRQ: 44
[ 3.177760] imx-wm8960 sound: wm8960-hifi <-> 30020000.sai mapping ok
[ 3.184260] imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
[ 3.191328] imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> dire ct -> CPU-Playback
[ 3.200044] imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
[ 3.206848] imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
[ 3.215387] imx-wm8960 sound: ASoC: no DMI vendor name!
[ 3.333079] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30080000.micfil ma pping ok
[ 3.340950] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[ 3.348129] NET: Registered protocol family 26
[ 3.353085] NET: Registered protocol family 10
[ 3.358330] Segment Routing with IPv6
[ 3.362034] NET: Registered protocol family 17
[ 3.366501] can: controller area network core (rev 20170425 abi 9)
[ 3.372735] NET: Registered protocol family 29
[ 3.377191] can: raw protocol (rev 20170425)
[ 3.381475] can: broadcast manager protocol (rev 20170425 t)
[ 3.387147] can: netlink gateway (rev 20170425) max_hops=1
[ 3.392803] Bluetooth: RFCOMM TTY layer initialized
[ 3.397703] Bluetooth: RFCOMM socket layer initialized
[ 3.402871] Bluetooth: RFCOMM ver 1.11
[ 3.406635] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.411959] Bluetooth: BNEP filters: protocol multicast
[ 3.417198] Bluetooth: BNEP socket layer initialized
[ 3.422174] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[ 3.428106] Bluetooth: HIDP socket layer initialized
[ 3.433143] 9pnet: Installing 9P2000 support
[ 3.437487] Key type dns_resolver registered
[ 3.442454] registered taskstats version 1
[ 3.474142] cpu cpu0: registered imx8mq-cpufreq
[ 3.479595] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found , using dummy regulator
[ 3.489353] OF: PCI: host bridge /pcie@0x33800000 ranges:
[ 3.494776] OF: PCI: No bus range found for /pcie@0x33800000, using [bus 00 -ff]
[ 3.502272] OF: PCI: IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[ 3.508205] OF: PCI: MEM 0x18000000..0x1fefffff -> 0x18000000
[ 3.514699] imx6q-pcie 33800000.pcie: Initialize PHY with EXT REfCLK!.
[ 3.521543] imx6q-pcie 33800000.pcie: PHY Initialization End!.
[ 3.527705] imx6q-pcie 33800000.pcie: pcie phy pll is locked.
[ 3.778615] imx6q-pcie 33800000.pcie: phy link never came up
[ 3.784295] imx6q-pcie 33800000.pcie: failed to initialize host
[ 3.790221] imx6q-pcie 33800000.pcie: unable to add pcie port.
[ 3.796289] imx6q-pcie: probe of 33800000.pcie failed with error -110
[ 3.804979] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 3.812496] hctosys: unable to open rtc device (rtc0)
[ 3.819560] WLAN_EN: disabling
[ 3.822640] VSD_3V3: disabling
[ 3.825703] usb_otg1_vbus: disabling
[ 3.830817] ALSA device list:
[ 3.833787] #0: wm8960-audio
[ 3.836919] #1: imx-audio-micfil
[ 3.904665] EXT4-fs (mmcblk2p2): warning: mounting fs with errors, running e2 fsck is recommended
[ 3.914744] EXT4-fs (mmcblk2p2): recovery complete
[ 3.920630] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. O pts: (null)
[ 3.928773] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.935773] devtmpfs: mounted
[ 3.939074] Freeing unused kernel memory: 768K
[ 4.005644] systemd[1]: System time before build time, advancing clock.
[ 4.020942] systemd[1]: systemd 237 running in system mode. (+PAM -AUDIT -SEL INUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL + XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybr id)
[ 4.042665] systemd[1]: Detected architecture arm64.
Welcome to NXP i.MX Release Distro 4.14-sumo (sumo)!
[ 4.066630] systemd[1]: Set hostname to <okmx8mm>.
[ 4.133227] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not sup port BPF/cgroup based firewalling.
[ 4.150314] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni ng is only shown for the first loaded unit using IP firewalling.)
[ 4.251772] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.258887] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.282250] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.290656] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.310205] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.316886] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.334213] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 4.355205] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Journal Socket.
Starting Setup Virtual Console...
Mounting Kernel Debug File System...
Mounting Temporary Directory (/tmp)...
Starting Create list of required st…ce nodes for the current kernel...
[ OK ] Reached target Slices.
Starting Load Kernel Modules...
Mounting POSIX Message Queue File System...
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
Starting udev Coldplug all Devices...
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice system-getty.slice.
Mounting Huge Pages File System...
[ OK ] Listening on Network Service Netlink Socket.
Starting Remount Root and Kernel File Systems...
[ 4.760897] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
[ OK ] Started Journal Service.
[ OK ] Started Setup Virtual Console.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ 4.919779] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43509: comm systemd: deleted inode referenced: 45689
Starting Create System Users...
[ 4.948740] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43509: comm systemd-sysuser: deleted inode referenced: 45686
[ 4.963085] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43801: comm systemd: deleted inode referenced: 45694
[ 4.977051] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43509: comm systemd: deleted inode referenced: 45689
Starting Rebuild Hardware Database...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create System Users.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
[ 5.147765] systemd-journald[1897]: Received request to flush runtime journal from PID 1
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
[ OK ] Reached target Containers.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ 5.289299] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43509: comm systemd-tmpfile: deleted inode referenced: 45686
[ 5.301997] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #43509: comm systemd-tmpfile: deleted inode referenced: 45686
[ 5.316845] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm systemd-tmpfile: deleted inode referenced: 65538
[ 5.329646] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm systemd-tmpfile: deleted inode referenced: 65538
[ 5.334401] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44510: comm systemd: deleted inode referenced: 45695
Starting Rebuild Journal[ 5.354300] EXT4-fs error (device mmcblk2p2) : ext4_lookup:1586: inode #44558: comm systemd-tmpfile: deleted inode referenced : 65539
Catalog...
Starting Rebuild Dynamic Linker Cache...
[ OK ] Started Load/Save Random Seed.
[FAILED] Failed to start Create Volatile Files and Directories.
See 'systemctl status systemd-tmpfiles-setup.service' for details.
[FAILED] Failed to start Rebuild Journal Catalog.
See 'systemctl status systemd-journal-catalog-update.service' for details.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Time Synchronized.
[ 6.098056] JBD2: Spotted dirty metadata buffer (dev = mmcblk2p2, blocknr = 0 ). There's a risk of filesystem corruption in case of system crash.
[ 6.126333] JBD2: Spotted dirty metadata buffer (dev = mmcblk2p2, blocknr = 0 ). There's a risk of filesystem corruption in case of system crash.
[FAILED] Failed to start Rebuild Hardware Database.
See 'systemctl status systemd-hwdb-update.service' for details.
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
Starting Start Psplash Boot Screen...
Starting Network Service...
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Started Network Service.
[FAILED] Failed to start Rebuild Dynamic Linker Cache.
See 'systemctl status ldconfig.service' for details.
Starting Update is Completed...
[FAILED] Failed to start Update is Completed.
[ 6.548198] imx-sdma 302b0000.dma-controller: loaded firmware 4.4
[ 6.555690] imx-sdma 302c0000.dma-controller: loaded firmware 4.4
See 'systemctl status systemd-upd[ 6.565705] imx-sdma 30bd0000.dma-controller : loaded firmware 4.4
ate-done.service' for details.
[ 6.572552] edt_ft5x06 3-0038: touchscreen probe failed
[ 6.584854] rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
[ OK ] Found device /dev/ttymxc1.
[ OK ] Reached target System Initialization.
[ OK ] Listening on dropbear.socket.
Starting Console System Startup Logging...
[ OK ] Started Daily rotation of log files.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started Job spooling tools.
[ OK ] Started D-Bus System Message Bus.
Starting Telephony service...
Starting Network Time Service (one-shot ntpdate mode)...
[ OK ] Started Configuration for i.MX GPU (Former rc_gpu.S).
Starting System Logging Service...
syslogd: /dev/xconsole: No such file or directory
[ OK ] Started Updates psplash to basic.
Starting LSB: run bluez5-obex daemon...
Starting LSB: Set system clock...
[ OK ] Started TEE Supplicant.
Starting Connection service...
Starting Avahi mDNS/DNS-SD Stack...
Starting Login Service...
Starting RPC Bind Service...
[ OK ] Started Console System Startup Logging.
[ OK ] Started Network Time Service (one-shot ntpdate mode).
[ OK ] Started System Logging Service.
[ 7.254013] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.abb7701.20181012- 134852
[ 7.261903] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 7.267054] rtk_btcoex: create workqueue
[ 7.271291] rtk_btcoex: Coex over UDP
[ 7.275385] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ OK ] Started LSB: run bluez5-obex daemon.
[ OK ] Started LSB: Set system clock.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
See 'systemctl status avahi-daemon.service' for details.
[ OK ] Started RPC Bind Service.
[ 7.454871] Atheros 8031 ethernet 30be0000.ethernet-1:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=30be0000.ethernet-1:01, irq=POLL)
[ 7.469016] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] [ 7.476306] usbcore: registered new inte**ce driver rtl8723bu
Started Telephony service.
[ 7.476358] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInte**ceNumbe r 0
[ 7.476364] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 7.476366] rtk_btusb: patch_add
[ 7.476369] rtk_btusb: auto suspend is disabled
[ 7.476372] rtk_btusb: pid = 0xb720
[ 7.476377] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 7.476396] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 7.480938] rtk_btusb: btusb_probe: done
[ 7.481053] usbcore: registered new inte**ce driver rtk_btusb
[ 7.482054] rtk_btusb: btusb_open start pm_usage_cnt(0x1)
[ 7.482060] rtk_btusb: btusb_open hdev->promisc ==0
[ 7.482063] rtk_btusb: download_patch start
[ 7.482066] rtk_btusb: chip type value: 0x00
[ 7.482071] rtk_btusb: HCI reset.
[ 7.550915] rtk_btusb: read_ver_rsp->lmp_subver = 0x8723
[ 7.550918] rtk_btusb: read_ver_rsp->hci_rev = 0xb
[ 7.550920] rtk_btusb: patch_entry->lmp_sub = 0x8723
[ 7.550923] rtk_btusb: load_firmware start
[ 7.550925] rtk_btusb: lmp_version = 0x8723
[ 7.550928] rtk_btusb: config filename rtl8723bu_config
[ 7.560261] rtk_btusb: no bdaddr file /opt/bdaddr
[ 7.560269] rtk_btusb: config offset 00f4,length 08
[ 7.560279] rtk_btusb: config offset 01e3,length 01
[ 7.560281] rtk_btusb: config offset 00db,length 01
[ 7.560284] rtk_btusb: 55 ab 23 87 13 00 f4 00 08 01 00 00 00 05 50 00
[ 7.560287] rtk_btusb: 00 e3 01 01 04 db 00 01 42
[ 7.560305] rtk_btusb: Config file length 25, new length 25
[ 7.560307] rtk_btusb: fw name is rtl8723b_fw
[ 7.565277] rtk_btusb: This is not 8723a, use new patch style!
[ 7.565281] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 7.574305] rtk_btusb: eversion->status = 0x0, eversion->version = 0x1
[ 7.574309] rtk_btusb: load_firmware: New gEVersion 1
[ 7.574313] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 1
[ 7.574316] rtk_btusb: lmp_version is 8723, project_id is 8723, match!
[ 7.574318] rtk_btusb: fw_version = 0x1e6ca747
[ 7.574320] rtk_btusb: number_of_total_patch = 2
[ 7.574323] rtk_btusb: chipID 2
[ 7.574325] rtk_btusb: patch_length 0x58f0
[ 7.574327] rtk_btusb: start_offset 0x000058c0
[ 7.574329] rtk_btusb: Svn version: 19897
[ 7.574331] rtk_btusb: Coexistence: BTCOEX_20171128-6d50
[ 7.574333] rtk_btusb: buf_len = 0x5909
[ 7.574373] rtk_btusb: fw: exists, config file: exists
[ 7.574375] rtk_btusb: load_firmware done
[ 7.574394] rtk_btusb: download_data start
[ OK ] Started Login Service.
[ OK ] Started Connection service.
Starting Hostname Service...
Starting WPA supplicant...
Starting Bluetooth service...
Starting Save/Restore Sound Card State...
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…htness of backlight:backlight@0...
Starting Rotate log files...
Starting Kernel Logging Service...
[ OK ] Started Save/Restore Sound Card State.
[FAILED] Failed to start Load/Save Screen Ba…ightness of backlight:backlight@0.
See 'systemctl status systemd-backlight…light:backlight@0.service' for details.
[FAILED] Failed to start Rotate log files.
See 'systemctl status logrotate.service' for details.
[ OK ] Started WPA supplicant.
[ OK ] Started Bluetooth service.
[ OK ] Started Hostname Service.
[ OK ] Reached target Bluetooth.
[ OK ] Reached target Network.
Starting Permit User Sessions...
Starting Lightning Fast Webserver With Light System Requirements...
Starting telnetd...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Update psplash to network.
Starting Terminate Pspla[ 8.148368] rtk_btusb: download_data done
sh Boot Screen...
[ 8.153519] rtk_btusb: HCI reset.
Starting /etc/rc.local Compatibility...
[ OK ] Started Vsftpd ftp daemon.
[ OK ] Reached target Sound Card.
[ OK ] Started Kernel[ 8.218276] rtk_btusb: read_ver_rsp->lmp_subver = 0xa7 47
Logging Service.
[ 8.226764] rtk_btusb: read_ver_rsp->hci_rev = 0x1e6c
[ 8.233410] rtk_btusb: patch_entry->lmp_sub = 0x8723
[ 8.238522] rtk_btusb: Rtk patch end 0
[ 8.242479] rtk_btusb: btusb_open set HCI_RUNNING
[ 8.247386] rtk_btcoex: Open BTCOEX
[ 8.250906] rtk_btcoex: create_udpsocket: connect_port: 30001
[ 8.256720] rtk_btcoex: send msg INVITE_REQ with len:11
[ 8.262173] rtk_btusb: btusb_open end pm_usage_cnt(0x0)
[ OK ] Started Permit User Sessions.
[ 8.270318] rtk_btcoex: BTCOEX hci_rev 0x1e6c
[ 8.277174] rtk_btcoex: BTCOEX lmp_subver 0xa747
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ 8.300293] rtk_btusb: btusb_notify: hci0 evt 3
[ OK ] Started telnetd.
[ OK ] Started Terminate Psplash Boot Screen.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Getty on tty1.
Starting Weston Wayland Compositor (on tty7)...
[ OK ] Started Serial Getty on ttymxc1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Weston Wayland Compositor (on tty7).
Starting weston-touch-calibrator...
Starting Matrix GUI...
[ OK ] Created slice User Slice of root.
Starting User Manager for UID 0...
[ 8.537297] audit: type=1006 audit(1627899474.368:2): pid=3389 uid=0 old-auid =4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ OK ] Started Session c1 of user root.
[ OK ] Started User Manager for UID 0.
[ OK ] Started Matrix GUI.
[ OK ] Started weston-touch-calibrator.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 10.338167] rtk_btusb: btusb_flush add delay
[ 10.352568] rtk_btusb: btusb_close
[ 10.374269] rtk_btcoex: Close BTCOEX
[ 10.377846] rtk_btcoex: release udp socket
[ 10.382015] rtk_btcoex: -x
[ 10.564887] fec 30be0000.ethernet eth0: Link is Up - 1Gbps/Full - flow contro l rx/tx
[ 10.572685] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.589461] 8021q: 802.1Q VLAN Support v1.8
[ 10.595085] EXT4-fs error: 78 callbacks suppressed
[ 10.595096] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 10.611989] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 10.623966] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
NXP i.MX Release Distro 4.14-sumo okmx8mm ttymxc1
okmx8mm login: root
Last login: Mon Aug 2 10:17:54 UTC 2021 on tty7
root@okmx8mm:~# ls
root@okmx8mm:~# [ 50.105657] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.121163] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.133158] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.145133] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.157021] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.169306] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.181408] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
[ 50.193267] EXT4-fs error (device mmcblk2p2): ext4_lookup:1586: inode #44539: comm connmand: deleted inode referenced: 65544
