查看: 87522|回复: 1
fcu1104 网卡配置改坏后网卡不启用等问题
T153通行证FCU11xx通行证
happyouandme 发表于 2021-8-29 19:13:37 | 显示全部楼层 |阅读模式
几个问题
   1、网络配置/etc/network/inte**ces 设置ip后跟ifconfig 配置的冲突 导致 /etc/network/inte**ces 配置无效
    2、ttl连接后 点打开没反应。
    3、下载开发环境 根据文档的系统烧录 无法成功,sd卡被格式化。
   ttl连接图:
烧录系统
forlinx@ubuntu:~/fcu1104burn$ sudo ./burn.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./6ullsdburn.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
Availible Drives to write images to:
#  major   minor    size   name
1:   8       16  125042688 sdb
Enter Device Number: 1
sdb was selected
                **********WARNING**********
        Selected Device is greater then 16GB
        Continuing past this point will erase data from device
        Double check that this is the correct SD Card
Would you like to continue [y/n] : y
Checking the device is unmounted
sdb1  sdb2   sdb3
SD Card is not correctly partitioned
                Now ** 1 partitions
1+0 records in
1+0 records out
1024 bytes (1.0 kB) copied, 0.0448654 s, 22.8 kB/s
Disk /dev/sdb doesn't contain a valid partition table
DISK SIZE - 128043712512 bytes
Checking that no-one is using this disk right now ...
BLKRRPART: Inappropriate ioctl for device
OK
Disk /dev/sdb: 15567 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/sdb: unrecognized partition table type
Old situation:
No partitions found
trailing junk after number
sfdisk: bad input
                Partitioning Boot
mkfs.vfat 3.0.12 (29 Oct 2011)
/dev/sdb1: No such file or directory
Mount the partitions
mount: special device /dev/sdb1 does not exist
Emptying partitions
        Copying files now... will take minutes
Copying boot partition
copy sdrun/ target/ to SD
Buring the u-boot.imx to sdcard
129+0 records in
129+0 records out
132096 bytes (132 kB) copied, 0.0330696 s, 4.0 MB/s
379+0 records in
379+0 records out
388096 bytes (388 kB) copied, 0.668429 s, 581 kB/s
Syncing....
Un-mount the partitions
umount2: Invalid argument
umount: boot: not mounted
Remove created temp directories
Operation Finished
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有账号?注册
i.MX6Q通行证i.MX6UL通行证RK3588通行证LS1012A通行证LS1043A\46A通行证FCU11xx通行证FCU2301\FCU2302通行证
whl 发表于 2021-8-30 09:09:57 | 显示全部楼层
1、调试开发阶段最好使用串口调试,打开盒子外壳,里边有T,R,G三个引脚,为TTL电平的串口,可以使用USB转TTL的模块进行调试
2、制卡失败问题,SD卡需要格式话为fat32格式,还有就是你Ubuntu用的什么版本的
