- 15
贡献100
飞刀27 FD
注册时间2021-7-16
在线时间3 小时
根据 NXP 的文档 https://www.nxp.com.cn/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
生成了 core-image-base-imx8mm-ddr4-evk.wic.bz2,并 flash 到 TF 卡上。
启动时一直打不到 Block device。请问,还有哪里需要改?
启动日志:
U-Boot SPL 2021.04-5.10.35-2.0.0+g3463140881 (Jun 08 2021 - 01:39:44 +0000)
power_bd71837_init
DDRINFO: start DRAM init
DDRINFO: DRAM rate 2400MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0: RNG instantiated
Normal Boot
Trying to boot from MMC1
NOTICE: BL31: v2.4(release):lf-5.10.35-2.0.0-rc2-0-gec35fef92
NOTICE: BL31: Built : 09:05:55, May 28 2021
U-Boot 2021.04-5.10.35-2.0.0+g3463140881 (Jun 08 2021 - 01:39:44 +0000)
CPU: i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU: Commercial temperature grade (0C to 95C) at 41C
Reset cause: POR
Model: NXP i.MX8MM DDR4 EVK with CYW43455 WIFI/BT board
DRAM: 2 GiB
tcpc_init: Can't find device id=0x52
setup_typec: tcpc port2 init failed, err=-19
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port1 init failed, err=-19
NAND: 0 MiB
MMC: FSL_SDHC: 1
Loading Environment from MMC... MMC: no card present
*** Warning - No block device, using default environment
[*]-Video Link 0adv7535_mipi2hdmi adv7535@3d: Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
mxs_video lcdif@32e00000: failed to get any video link display timings
probe video device failed, ret -22
[0] lcdif@32e00000, video
[1] mipi_dsi@32e10000, video_bridge
[2] adv7535@3d, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF ec35fef
flash target is MMC:1
MMC card init failed!
** Block device MMC 1 not supported
Net: Could not get PHY for FEC0: addr 0
No ethernet found.
Fastboot: Normal
Normal Boot
starting USB...
Bus usb@32e40000: dev_get_parent_plat: null device
"Synchronous Abort" handler, esr 0x96000004
elr: 000000004025d5a0 lr : 000000004025d594 (reloc)
elr: 00000000bcd495a0 lr : 00000000bcd49594
x0 : 0000000014000280 x1 : 0000000000000001
x2 : 00000000bcd1714c x3 : 0000000000000001
x4 : 0000000000000013 x5 : 0000000000000020
x6 : 00000000ffffffd0 x7 : 0000000000000003
x8 : 0000000000000000 x9 : 0000000000000008
x10: 000008c004000000 x11: 00000000bacdf02c
x12: 0000000000000006 x13: 000000000001869f
x14: 00000000bacdfe90 x15: 0000000000000002
x16: 00000000bcd4e074 x17: 00000000000041a0
x18: 00000000bacebdb0 x19: 0000000000000001
x20: 0000000000000000 x21: 00000000bacdf08f
x22: 0000000000000000 x23: 000000000000001d
x24: 00000000bcdec140 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000bacf9900 x29: 00000000bacdefc0
Code: 97ff5c25 aa0003e8 f9400000 f940380a (f9400140)
Resetting CPU ...
resetting ...
