- 18
贡献147
飞刀6 FD
注册时间2021-9-1
在线时间0 小时
CC drivers/gpu/drm/i915/i915_perf.o
CC drivers/gpu/drm/i915/i915_oa_hsw.o
CC drivers/gpu/drm/i915/i915_oa_bdw.o
CC drivers/gpu/drm/i915/i915_oa_chv.o
CC drivers/gpu/drm/i915/i915_oa_sklgt2.o
CC drivers/gpu/drm/i915/i915_oa_sklgt3.o
CC drivers/gpu/drm/i915/i915_oa_sklgt4.o
CC drivers/gpu/drm/i915/i915_oa_bxt.o
CC drivers/gpu/drm/i915/i915_oa_kblgt2.o
CC drivers/gpu/drm/i915/i915_oa_kblgt3.o
CC drivers/gpu/drm/i915/i915_oa_glk.o
CC drivers/gpu/drm/i915/intel_lpe_audio.o
AR drivers/gpu/drm/i915/i915.o
AR drivers/gpu/drm/i915/built-in.o
AR drivers/gpu/drm/built-in.o
AR drivers/gpu/built-in.o
AR drivers/built-in.o
GEN .version
make[2]: Entering directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
make[2]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule.
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
AR init/built-in.o
make[2]: Leaving directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
AR built-in.o
LD vmlinux.o
ld: drivers/gpu/drm/bridge/lt8912.lo: Relocations in generic ELF (EM: 183)
drivers/gpu/drm/bridge/lt8912.lo: error adding symbols: File in wrong format
Makefile:1020: recipe for target 'vmlinux' failed
make[1]: *** [vmlinux] Error 1
make[1]: Leaving directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
Makefile:11: recipe for target 'linux' failed
make: *** [linux] Error 2
