查看: 54631|回复: 1
[Linux] 飞凌IMX6Q L3.0.35 rt path 吐核
A40i\T3\T507\T527通行证i.MX6Q通行证
ChenXu3500 发表于 2021-9-22 12:46:59 | 显示全部楼层 |阅读模式
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
Internal error: Oops: 80000007 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35-2666-gbdde708-rt*56 #8)
PC is at 0x0
LR is at activate_task+0x54/0x64
pc : [<00000000>]    lr : [<8006d7bc>]    psr: 80000093
sp : bff87eb8  ip : 00000000  fp : bff87ecc
r10: 20000013  r9 : 8003c240  r8 : bff92cb8
r7 : 00000008  r6 : 00000001  r5 : bff92920  r4 : 8c017240
r3 : 00000000  r2 : 00000001  r1 : bff92920  r0 : 8c017240
Flags: Nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 4a5e804a  DAC: 00000015
Process ksoftirqd/0 (pid: 3, stack limit = 0xbff862f0)
Stack: (0xbff87eb8 to 0xbff88000)
7ea0:                                                       00000001 bff92920
7ec0: 8c017240 00000001 bff87efc 80072cfc 00000003 8003c240 00000000 80b3e520
7ee0: 80b3e520 80ac6200 bff86000 00200200 00000000 00000000 803b59e0 8055855c
7f00: bff87f10 80083514 00000000 bff86000 bff87f10 bff87f10 80b3e380 00000101
7f20: 80ac6184 bff86000 80adfff8 80ac6180 00000000 80b3e380 00000001 8007c28c
7f40: bffdf290 00000000 00000001 00000000 00000000 bff86000 8c00e2b8 00000000
7f60: 80adfff8 8003b2b8 00000000 00000000 00000000 8007c448 bff86000 00000000
7f80: 00000001 bff87f94 80b3e380 8007c55c 00000013 00000001 00000000 bff81f1c
7fa0: 00000000 8007c4a0 00000013 00000000 00000000 800915b4 00000000 00000000
7fc0: 00000000 00000000 00000000 bff87fcc bff87fcc 00000000 00000000 00000000
7fe0: bff87fe0 bff87fe0 bff81f1c 80091534 80043a98 80043a98 02c10200 00510201
[<8006d7bc>] (activate_task+0x54/0x64) from [<80072cfc>] (try_to_wake_up+0x26c/0x2f4)
[<80072cfc>] (try_to_wake_up+0x26c/0x2f4) from [<8055855c>] (rt_spin_lock_slowunlock+0x24/0x54)
[<8055855c>] (rt_spin_lock_slowunlock+0x24/0x54) from [<80083514>] (run_timer_softirq+0x170/0x240)
[<80083514>] (run_timer_softirq+0x170/0x240) from [<8007c28c>] (__do_softirq_common+0xc4/0x178)
[<8007c28c>] (__do_softirq_common+0xc4/0x178) from [<8007c448>] (__thread_do_softirq+0x108/0x160)
[<8007c448>] (__thread_do_softirq+0x108/0x160) from [<8007c55c>] (run_ksoftirqd+0xbc/0x180)
[<8007c55c>] (run_ksoftirqd+0xbc/0x180) from [<800915b4>] (kthread+0x80/0x88)
[<800915b4>] (kthread+0x80/0x88) from [<80043a98>] (kernel_thread_exit+0x0/0x8)
Code: bad PC value
飞凌的IMX6Q V1.3的底板,给Linux3.0.35打上实时补丁后,运行吐核,请问有遇到的么,或者解决思路
Forlinx-Wangjy 发表于 2021-9-26 15:02:38 | 显示全部楼层
抱歉我们目前没有打实时补丁的方法,我们自己也没有这么操作过。
您可以看论坛里有没有其他用户尝试过,帮您解答一下。
