查看: 3940|回复: 7
为什么烧写CE一直停在这里
ArmWinLinux 发表于 2011-8-12 10:03:07 | 显示全部楼层 |阅读模式
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x800420B8
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x1E
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0xfff].
Erasing flash block(s) [0x3, 0xfff] (please wait): EraseBlocks: found a bad block (0x6ee) - skipping...
Done.
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x2362D83
飞凌-fatfish 发表于 2011-8-12 11:24:34 | 显示全部楼层
请问楼主什么板子?多大内存?多大flash?烧写映像的来源?烧写系统时打印信息?
楼主| ArmWinLinux 发表于 2011-8-12 11:39:15 | 显示全部楼层
我是从官网上下载的256M+2G的映像,打印信息如下:
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x800668C4
INFO: (unsigned)ASM_IsrHandler : 0x80069F80
INFO: (unsigned)pISR : 0xEA01A7D8
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
CardSize: 1977614336
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : PAGES_PER_BLOCK = 128
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 2 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x1C813
g_pDownPt = 0xA301C813
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x1d86c
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x1D86C, LaunchAddr = 0x800420B8
Completed file(s):
[0]: Address=0x80030000  Length=0x1D86C  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x1d86c
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
Done.
Done.
BinFS format done.
IsCardInserted
一直停在这里,请问为什么?
飞凌-alexlee 发表于 2011-8-12 17:01:52 | 显示全部楼层
提示有坏块,用linux的uboot,使用scrub 命令擦一下呢?
楼主| ArmWinLinux 发表于 2011-8-13 14:09:00 | 显示全部楼层
谢谢版主,我烧写完后linux2.6.36.2,代码是从官网上的。执行了scrub后,然后重新烧写了linux2.6.36.2后,出现问题,请问是那个硬件出现问题了么?打印信息如下:
U-Boot 1.1.6 (May 27 2011 - 17:42:40) for SMDK6410
**    Updated for TE6410 Board        **
**    Version 1.0 (10-01-15)          **
CPU:     S3C6410 @532MHz
         Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    select s3c_nand_oob_mlc_128
2048 MB
In:      serial
Out:     serial
Err:     serial
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 2.6.36.2 (root@czj) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-7
2) ) #2 Mon May 30 17:29:16 CST 2011
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f9000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5edf9000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,11520
Memory: 256MB = 256MB total
Memory: 233452k/233452k available, 28692k reserved, 0K highmem
Virtual kernel memory layout:
    DMA     : 0xff600000 - 0xffe00000   (   8 MB)
    vmalloc : 0xd0800000 - 0xe0000000   ( 248 MB)
      .init : 0xc0008000 - 0xc0044000   ( 240 kB)
      .text : 0xc0044000 - 0xc06a4000   (6528 kB)
      .data : 0xc0700000 - 0xc074ab80   ( 299 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1]
last sysfs file:
Modules linked in:
CPU: 0    Not tainted  (2.6.36.2 #2)
PC is at find_inode_fast+0x18/0x74
LR is at ifind_fast+0x10/0x54
pc : [<c00fed24>]    lr : [<c00fed90>]    psr: 60000153
sp : c0701e00  ip : c0701e20  fp : c0701e1c
r10: 00000b1a  r9 : c07a7d38  r8 : c09ef8c0
r7 : c09f2528  r6 : 00000000  r5 : 00000000  r4 : 00000001
r3 : 00002c68  r2 : 00000001  r1 : 00000000  r0 : 00000000
Flags: nZCv  IRQs on  FIQs off  Mode SVC_32  ISA ARM  Segment kernel
Control: 00c5387f  Table: 50004008  DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc0700268)
Stack: (0xc0701e00 to 0xc0702000)
1e00: 00000001 ce8003e0 c09f2528 c09f2528 c0701e34 c0701e20 c00fed90 c00fed18
1e20: 00000001 ce8003e0 c0701e54 c0701e38 c00fed90 c00fed8c 00000001 ce8003e0
1e40: ce802200 c09f2528 c0701e6c c0701e58 c00fed90 c00fed18 00000001 ce8003e0
1e60: c0701ea4 c0701e70 c00ffcb4 c00fed8c 00000000 ce802200 ce802200 ce802200
1e80: ce8003e0 c0713e90 c04d4154 c013bc04 00400000 c0713e70 c0701ecc c0701ea8
1ea0: c0138f4c c00ffc80 c0701ecc c0701eb8 c04c17cc ce802200 ce8003e0 c0713e90
1ec0: c0701f04 c0701ed0 c013bd50 c0138f3c c0701f04 c0701ee0 c0103bb8 ce805000
1ee0: c06193a8 00400000 00000000 c0713e70 410fb766 5002b218 c0701f34 c0701f08
1f00: c00ec520 c013bc10 ce805000 c0713e70 c07a903c 00000000 00000000 c07a903c
1f20: 0000e3e7 5002b2bc c0701f44 c0701f38 c00ec5fc c00ec4c8 c0701f6c c0701f48
1f40: c0017b60 c00ec5ec 00000000 c0701f64 c0701f94 00000000 c07a7e78 00000000
1f60: c0701f94 c0701f70 c0016a84 c0017ae8 00000000 c00168e0 00000000 0000e3fb
1f80: c07a7d20 0000e3fb c0701fc4 c0701f98 c00165c4 c0016a08 00000000 c07a397c
1fa0: c074ac6c c002c200 c07a397c c074ac6c c002c200 c0704c64 c0701ff4 c0701fc8
1fc0: c0008bb0 c0016530 c00086bc 00000000 271beb38 c002d018 00000000 00c5387d
1fe0: c074ad50 c002d014 00000000 c0701ff8 50008034 c000896c 00000000 00000000
[<c00fed24>] (find_inode_fast+0x18/0x74) from [<c00fed90>] (ifind_fast+0x10/0x54
Code: e24cb004 e1a05000 e1a06001 e1a04002 (e5960000)
---[ end trace da227214a82491b7 ]---
Kernel panic - not syncing: Attempted to kill the idle task!
[<c004aa8c>] (unwind_backtrace+0x0/0xfc) from [<c04c00c0>] (dump_stack+0x18/0x1c
[<c04c00c0>] (dump_stack+0x18/0x1c) from [<c04c0124>] (panic+0x60/0x1a8)
[<c04c0124>] (panic+0x60/0x1a8) from [<c0062fb0>] (do_exit+0x64c/0x694)
[<c0062fb0>] (do_exit+0x64c/0x694) from [<c0048a30>] (die+0x2f0/0x340)
[<c0048a30>] (die+0x2f0/0x340) from [<c004dd98>] (__do_kernel_fault+0x6c/0x8c)
[<c004dd98>] (__do_kernel_fault+0x6c/0x8c) from [<c04c4708>] (do_page_fault+0x94
/0x330)
[<c04c4708>] (do_page_fault+0x94/0x330) from [<c04c4a18>] (do_translation_fault+
0x74/0xb0)
[<c04c4a18>] (do_translation_fault+0x74/0xb0) from [<c00442d8>] (do_DataAbort+0x
40/0xa4)
[<c00442d8>] (do_DataAbort+0x40/0xa4) from [<c04c290c>] (__dabt_svc+0x4c/0x80)
Exception stack(0xc0701db8 to 0xc0701e00)
1da0:                                                       00000000 00000000
1dc0: 00000001 00002c68 00000001 00000000 00000000 c09f2528 c09ef8c0 c07a7d38
1de0: 00000b1a c0701e1c c0701e20 c0701e00 c00fed90 c00fed24 60000153 ffffffff
[<c04c290c>] (__dabt_svc+0x4c/0x80) from [<c00fed24>] (find_inode_fast+0x18/0x74
飞凌-alexlee 发表于 2011-8-15 08:03:40 | 显示全部楼层
电话联系客服吧~
楼主| ArmWinLinux 发表于 2011-8-15 09:01:48 | 显示全部楼层
很郁闷,客服电话也一直打不进去的。
楼主| ArmWinLinux 发表于 2011-8-15 10:46:14 | 显示全部楼层
而且我试过了CE,一键烧写一直停在一个地方,打印输出如下:
+OALArgsInit()
SocID:0x36410101
-OALArgsInit()
HSMMC init
BP_Init
[FMD] --FMD_Init()
Initiating image launch in 0 seconds.
System ready!
IsCardInserted
Stepldr image
Completed file(s):
[FMD] --FMD_Init()
dwNumBlocks = 0x1
IsCardInserted
BL_IMAGE_TYPE_BIN
Eboot image
rom_offset=0x0.
Completed file(s):
[FMD] --FMD_Init()
dwNumBlocks = 0x1
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
Done.
Done.
BinFS format done.
IsCardInserted
g_pDownPt = 0xA5362D83
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80150000  Length=0x24026b8
RAM image
一直停在这个地方,不知道怎么回事?然后断电从nandfalsh启动后,又一直停在一个地方,打印如下:
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Nov 22 2010 08:44:45
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Dec  7 2010
+OALArgsInit()
SocID:0x36410101
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8003FEB8
INFO: (unsigned)ASM_IsrHandler : 0x800424A0
INFO: (unsigned)pISR : 0xEA010920
BP_Init
[FMD] --FMD_Init()
TOC_Read
-TOC_Read
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
Stepldr image
Stepldr image
ReadOSImageFromBootMedia: ERROR_INVALID_ADDRESS: (address=0x0, sectors=0x0, launch address=0x0)...
OEMPlatformInit ERROR: Failed to load kernel region into RAM.
请问这个是什么原因,是硬件故障么,软件我根本没有更改的?
