查看: 33671|回复: 2
[Linux] 飞凌 imx6ul Qt5.6.2 + linux 4.1.15开发环境搭建说明
LS1028A通行证LS1012A通行证LS1043A\46A通行证i.MX6Q通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证i.MX9352\i.MX9131通行证i.MX RT通行证RK3568通行证RK3588通行证RK3399通行证RK3576通行证RK3562通行证AM5718通行证AM335x通行证AM62x通行证A40i\T3\T507\T527通行证T113i通行证T153通行证XX18通行证2K0300\2K0500通行证JH7110通行证D9360通行证Hi3519A通行证G2L通行证TCU通行证FDU产品通行证FDU070K02\FDU101K02通行证5G转接卡通行证FCU11xx通行证FCU1201通行证FCU1301通行证FCU1303通行证FCU1401通行证FCU2201通行证FCU2301\FCU2302通行证FCU2401通行证FCU2601通行证FCU3001通行证
Qiankun.G 发表于 2021-11-4 09:22:50 | 显示全部楼层 |阅读模式
1.安装x86 Qt5.6.2程序(使用root)
2.安装 arm-qt5.6.2
    root@ubuntu:/opt# /home/test/Desktop/fsl-imx-x11-glibc-x86_64-meta-toolchain-qt5-cortexa7hf-neon-toolchain-4.1.15-2.0.0.sh
    Freescale i.MX Release Distro SDK installer version 4.1.15-2.0.0
    Enter target directory for SDK (default: /opt/fsl-imx-x11/4.1.15-2.0.0):
    The directory "/opt/fsl-imx-x11/4.1.15-2.0.0" already contains a SDK for this architecture.
    If you continue, existing files will be overwritten! Proceed[y/N]? y
    Extracting SDK...............................................................................................................................................................done
    Setting it up...done
    SDK has been successfully set up and is ready to be used.
    Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
     $ . /opt/fsl-imx-x11/4.1.15-2.0.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabi
     设置环境
    root@ubuntu:/opt# . /opt/fsl-imx-x11/4.1.15-2.0.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabi
    启动qt 程序 用root 用户
    root@ubuntu:/opt# Qt5.6.2/Tools/QtCreator/bin/qtcreator
3.注意:如果编译报错    fatal error: GLES3/gl3.h: No such file or directory则,修改
    root@ubuntu:/opt/fsl-imx-x11# gedit  /opt/fsl-imx-x11/4.1.15-2.0.0/sysroots/cortexa7hf-neon-poky-linux-gnueabi/usr/include/qt5/QtCore/qconfig.h
        注释掉
        //#if defined(QT_OPENGL_ES_3) && defined(QT_NO_OPENGL_ES_3)
        //# undef QT_OPENGL_ES_3
        //#elif !defined(QT_OPENGL_ES_3) && !defined(QT_NO_OPENGL_ES_3)
        //# define QT_OPENGL_ES_3
        //#endif
A40i\T3\T507\T527通行证i.MX6UL通行证RK3568通行证
xlinkbox 发表于 2022-8-6 08:32:10 | 显示全部楼层
QT5.6.2哪里能找到呢?
xlinkbox 发表于 2022-8-6 09:09:23 | 显示全部楼层
您好,能否提供QT5.6.2的下载链接?我找不到这个
