- 46
贡献155
飞刀50 FD
注册时间2020-3-31
在线时间28 小时
s3c-nand: 1 bit(s) error detected, corrected successfully
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 2.6.36.2 (root@zhu-virtual-machine) (gcc version 4.2.2) #368 Wed Sep 14 21:46:07 CST 2011
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f9000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5edf9000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 233540k/233540k available, 28604k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xe0000000 ( 248 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0032000 ( 168 kB)
.text : 0xc0032000 - 0xc0689000 (6492 kB)
.data : 0xc06ea000 - 0xc0734be0 ( 299 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 456
io scheduler noop registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
FB1: map_video_memory: dma=5e980000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
FB2: map_video_memory: dma=5e9bfc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
Window[1] - FB1: map_video_memory: clear ff700000:0007f800
FB1: map_video_memory: dma=5ea00000 cpu=ff700000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff73fc00:0003fc00
FB2: map_video_memory: dma=5ea3fc00 cpu=ff73fc00 size=0003fc00
fb1: s3cfb frame buffer device
Window[2] - FB1: map_video_memory: clear ff680000:0003fc00
FB1: map_video_memory: dma=5ea80000 cpu=ff680000 size=0003fc00
fb2: s3cfb frame buffer device
Window[3] - FB1: map_video_memory: clear ff780000:0003fc00
FB1: map_video_memory: dma=5eac0000 cpu=ff780000 size=0003fc00
fb3: s3cfb frame buffer device
jkq debug VIDCON0 is 353
leds initialized
pwm initialized
my_ok6410_leds My Leds initialized
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
S3C NAND Driver, (c) 2008 Samsung Electronics
select s3c_nand_oob_mlc_128
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
PPP MPPE Compression module registered
pl2303 1-1:1.0: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB0
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
enter s3c64xx_setup_sdhci1_cfg_gpio
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
ALSA device list:
#0: SMDK (WM9713)
TCP cubic registered
s3c-rtc s3c64xx-rtc: hctosys: invalid date/time
mtd->size = 80000 blocks = 7800000
cheaking bad block...............
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................s3c-nand: ECC uncorrectable error detected
s3c-nand: 3 bit(s) error detected, corrected successfully
下面和上面一样,一堆ECC校验错误 |
