查看: 20872|回复: 15
[Linux] 求大佬告知,如何连接wifi
A40i\T3\T507\T527通行证
wjh498877269 发表于 2022-2-17 13:02:44 | 显示全部楼层 |阅读模式
# insmod /lib/modules/$(uname -r)/8723du.ko
# lsmod
8723du 1927153 0 - Live 0xbf06d000
mali 279073 15 - Live 0xbf010000 (O)
gt9xxnew_ts 44468 0 - Live 0xbf000000
# wifi.sh -i 8723du -s HATI_411 -p tof56832897
wifi 8723du
ssid HATI_411
pasw tof56832897
ifconfig: SIOCGIFFLAGS: No such device
Successfully initialized wpa_supplicant
Could not read inte**ce wlan0 flags: No such device
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: Failed to initialize driver inte**ce
udhcpc: SIOCGIFINDEX: No such device
Finshed!
楼主| wjh498877269 发表于 2022-2-17 13:04:03 | 显示全部楼层
# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 36:C9:E3:F1:B8:05
          inet addr:192.168.0.232  Bcast:192.168.0.255  Mask:255.255.255.0
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:40 errors:0 dropped:12 overruns:0 frame:0
          TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5682 (5.5 KiB)  TX bytes:468 (468.0 B)
          Interrupt:87 Base address:0xb000
lo        Link encap:Local Loopback
          LOOPBACK  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
tunl0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          NOARP  MTU:0  Metric:1
usb0      Link encap:Ethernet  HWaddr FE:0E:08:21:BD:86
          BROADCAST NOARP MULTICAST  MTU:1500  Metric:1
tanglu 发表于 2022-2-17 13:46:09 | 显示全部楼层
您在测试的过程中,有连接好天线吗?
楼主| wjh498877269 发表于 2022-2-17 14:33:08 | 显示全部楼层
您在测试的过程中,有连接好天线吗?
大佬您好,连接了。
tanglu 发表于 2022-2-17 15:00:24 | 显示全部楼层
您板子上是否已经焊接8723du的模块?焊接的是否是8723du模块?
有的,有手册上图片所示模块。我烧录的镜像是sun8iw11p1_linux_OKA40i_C_uart0-1024x600.img,天线也接了。  详情 回复 发表于 2022-2-17 15:19
楼主| wjh498877269 发表于 2022-2-17 15:19:10 | 显示全部楼层
tanglu 发表于 2022-2-17 15:27:40 | 显示全部楼层
您方便说一下,您板子上的WiFi模块的颜色是蓝色还是绿色吗?我们中途换过一次模块。
蓝色, rtl8723bu k7d58h1 gk32 芯片上面的文字  详情 回复 发表于 2022-2-17 15:35
楼主| wjh498877269 发表于 2022-2-17 15:35:56 | 显示全部楼层
tanglu 发表于 2022-2-17 15:40:55 | 显示全部楼层
您应该加载8723bu的驱动。
指令:开发板上电,启动 Linux 系统。手动加载模块:
#insmod /lib/modules/$(uname -r)/8723bu.ko
查看模块是否加载:
#lsmod
然后您再按手册步骤三进行自动发配ip试试。
按您说的做了。串口调试如下: # insmod /lib/modules/$(uname -r)/8723bu.ko # lsmod 8723bu 1920908 0 - Live 0xbf06d000 mali 279073 15 - Live 0xbf010000 (O) gt9xxnew_ts 44468 0 - Live 0xbf000000 # w  详情 回复 发表于 2022-2-17 15:49
楼主| wjh498877269 发表于 2022-2-17 15:49:53 | 显示全部楼层
您应该加载8723bu的驱动。
#insmod /lib/modules/$( ...
按您说的做了。串口调试如下:
# lsmod
wifi 8723du
ssid HATI_411
pasw tof56832897
Finshed!
