查看: 3424|回复: 1
[Linux] 写完固件,无法登录,卡死。
A40i\T3\T507\T527通行证i.MX6UL通行证i.MX RT通行证
ChineseWu 发表于 2022-3-27 17:21:48 | 显示全部楼层 |阅读模式
HELLO! BOOT0 is starting!
                          [     0.35]HELLO! BOOT0 is starting!
[     0.39]boot0 commit : b58d49ff80aa5ff8865ab68aa2463d4ee0fe1e7d
[     0.46]boot0 version : 4.0
[     0.50]set pll start
[     0.54]set pll end
[     0.89]rtc[0] value = 0x00000000
[     0.92]rtc[1] value = 0x00000000
[     0.95]rtc[2] value = 0x00000000
[     0.98]rtc[3] value = 0x00000000
[     0.102]rtc[4] value = 0x00000000
[     0.105]rtc[5] value = 0x00000000
[     0.108]DRAMC IS FOUR
[     0.111]DRAM BOOT DRIVE INFO: V1.1
[     0.114]Found A40
[     0.116]Found A40
[     0.118]Found A40
[     0.120]Found A40
[     0.122]Found A40
[     0.128]PMU: [     0.129]AXP221
[     0.131]ddr voltage = 1500 mv
[     0.134]DRAM CLK =576 MHZ
[     0.137]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[     0.142]DRAM zq value: 0x003b3bfb
[     0.147]DRAM SIZE =2048 M
[     0.150]DRAM ** test OK.
[     0.153]dram size =2048
[     0.156]rtc standby flag is 0x00000000, super standby flag is 0x00000000
[     0.163]card no is 2
[     0.166]sdcard 2 line count 8
[     0.169][mmc]: mmc driver ver 2016-07-01 15:30
[     0.173][mmc]: wrong freq 2 at spd md 2
[     0.186][mmc]: ***Try MMC card 2***
[     0.203][mmc]: MMC 5.1
[     0.205][mmc]: HSSDR52/SDR25 8 bit
[     0.209][mmc]: 50000000 Hz
[     0.211][mmc]: 7456 MB
[     0.214][mmc]: ***SD/MMC 2 init OK!!!***
[     0.287]Succeed in loading uboot from sdmmc flash.
[     0.292]Entry_name        = u-boot
[     0.307]Ready to disable icache.
[     0.311]0xffffffff 0xffffffff
[     0.313]0xffffffff 0xffffffff
[     0.317]0xffffffff 0xffffffff
[     0.320]0xffffffff 0xffffffff
[     0.323]0xffffffff 0xffffffff
[     0.326]0xffffffff 0xffffffff
[     0.329]Jump to secend Boot.
U-Boot 2014.07 (Jul 25 2019 - 05:35:06) Allwinner Technology
uboot commit : 65b7504a61af7d8b06d7afd9b75cb593144fdcc8
i2c_init: by cpux
i2c_init ok
[      0.344]pmbus:   ready
[      0.358]PMU: AXP221
[      0.358]PMU: AXP22x found
[      0.359]PMU: dcdc2 1160
[      0.360]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz  MBus=400Mhz
set power on vol to default
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1160, onoff=1
dcdc3_vol = 1200, onoff=1
dcdc4_vol = 1100, onoff=0
aldo1_vol = 3300, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dc1sw_vol = 3000, onoff=0
dc5ldo_vol = 1100, onoff=0
dldo1_vol = 3300, onoff=1
dldo2_vol = 3300, onoff=0
dldo3_vol = 3300, onoff=0
dldo4_vol = 2500, onoff=1
eldo1_vol = 2800, onoff=0
eldo2_vol = 1200, onoff=1
eldo3_vol = 2800, onoff=1
gpio0_vol = 3300, onoff=1
gpio1_vol = 3300, onoff=1
find power_sply to end
vbus exist
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr: 0xb6e8fcd8
Relocation Offset is: 75ee6000
axp: get node[charger0] error
In:    serial
Out:   serial
Err:   serial
gic: normal mode
[      0.514]start
drv_disp_init
init_clocks: finish init_clocks.
pwm_request: reg = 0x1c23400. pwm = 0.
request pwm success, pwm = 0.
tv_init:
tv_probe:000
tv0 have no type1
tv0 have no type2
tv0 have no type3
no report hpd work,you need support the switch class!
screen 0 don't support TV!
screen 1 don't support TV!
screen 0 do not support VGA TYPE!
screen 1 do not support VGA TYPE!
tv_init:
drv_disp_init finish
fetch script data boot_disp.output_disp fail
fetch script data boot_disp.output_type fail
fetch script data boot_disp.output_mode fail
fetch script data boot_disp.auto_hpd fail
disp0 device type(1) enable
disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
     clk real:pll(308571428),clk(308571428),dclk(51428571) dsi_rate(0)
enable power vcc-lcd, ret=0
[      1.277]end
workmode = 0,storage type = 2
[      1.277]MMC:        2
[mmc]: mmc_update_timing_para: error sdc_no 2
SUNXI SD/MMC: 2
[mmc]: 50 MHz...
[mmc]: sample: 63 - 158(ps)
[mmc]: ds: 63 - 158(ps)
[mmc]: 100 MHz...
[mmc]: sample: 32 - 156(ps)
[mmc]: ds: 32 - 156(ps)
[mmc]: 200 MHz...
[mmc]: sample: 16 - 156(ps)
[mmc]: ds: 16 - 156(ps)
[mmc]: media type 0x8000000
[mmc]: ************Try MMC card 2************
[mmc]: host caps: 0x6f
[mmc]: MID 0000d6 PSN 8260d1a0
[mmc]: PNM 88A398 -- 0x38-38-41-33-39
[mmc]: PRV 1.1
[mmc]: MDT m-11 y-2021
[mmc]: MMC v5.1
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 8 bit
[mmc]: user capacity  : 7456 MB
[mmc]: boot capacity  : 4096 KB
[mmc]: rpmb capacity  : 4096 KB
[mmc]: ************SD/MMC 2 init OK!!!************
[mmc]: use default speed mode: 1-HSSDR52/SDR25, ifreq: 2
[mmc]: ========best spd md: 1-HSSDR52/SDR25, freq: 2-50000000
[mmc]: already at HSSDR52_SDR25 mode
[mmc]: erase_grp_size      : 0x400WrBlk*0x200=0x80000 Byte
[mmc]: secure_feature      : 0x55
[mmc]: secure_removal_type : 0x9
[mmc]: EOL Info(Rev blks): Normal
[mmc]: Wear out(type A): 0%-10% life time used
[mmc]: Wear out(type B): Not defined
[      1.513]sunxi flash init ok
--------fastboot partitions--------
-total partitions:6-
-name-        -start-       -size-
boot-resource: 1000000       700000
env         : 1700000       400000
boot        : 1b00000       1000000
rootfs      : 2b00000       40000000
usr         : 42b00000      9fb00000
UDISK       : e2600000      0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run setargs_mmc boot_normal
update dtb dram start
update dtb dram  end
PowerBus = 2( 2:vBus 3:acBus other: not exist)
no battery, limit to dc
no battery exist
EnterNormalBootMode sunxi_bmp_display--
1152054 bytes read in 27 ms (40.7 MiB/s)
bmp file buffer: 0x40000000, bmp_info.buffer: 46400000
fetch script data boot_disp.output_full fail
screen_id =0, screen_width =1024, screen_height =600
frame buffer address 46400036
[      1.772]inter uboot shell
Read addr=40 eeprom addrlen=1 ok!!
The test ok!
secret ok
read partition: boot or recovery
[      3.102]sunxi flash read :offset 1b00000, 14324561 bytes OK
Android's image name: sun8i_arm
Kernel load addr 0x40008000 size 11613 KiB
RAM disk load addr 0x41000000 size 1353 KiB
[      3.168]ready to boot
prepare for kernel
[mmc]: mmc exit start
[mmc]: 50 MHz...
[mmc]: sample: 62 - 161(ps)
[mmc]: ds: 62 - 161(ps)
[mmc]: 100 MHz...
[mmc]: sample: 31 - 161(ps)
[mmc]: ds: 31 - 161(ps)
[mmc]: 200 MHz...
[mmc]: sample: 15 - 166(ps)
[mmc]: mmc 2 exit ok
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (bluesky@a97aa656d1ab) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #39 SMP PREEMPT Mon Jul 29 03:45:11 UTC 2019
[    0.000000] Machine: sun8iw11p1, model: sun8iw11p1
[    0.000000] bootconsole [earlycon0] enabled
[/init]: RootDevice is "/dev/mmcblk0p7"
[/init]: Try to load EMMC ...
e2fsck 1.41.14 (22-Dec-2010)
/dev/mmcblk0p7: recovering journal
/dev/mmcblk0p7: clean, 8436/9648 files, 484381/546296 blocks
mount: proc is already mounted or /proc busy
       proc is already mounted on /proc
mount: devtmpfs is already mounted or /dev busy
init asteroid  env##
init qt env########################
Starting sshd: OK
Starting telnetd: OK
Starting vsftpd: OK
================Usrage================
/fbinit           means:clean /dev/fb0
/fbinit 0         means:clean /dev/fb0
/fbinit 1         means:clean /dev/fb1
/fbinit 2         means:clean /dev/fb2
================usrage================
cleanning /dev/fb0 ...
clean /dev/fb0 finish
find qt5 installed
D-Bus per-session daemon address is: unix:abstract=/tmp/dbus-JGVHYqurvE,guid=79a711694ed727684d2ceed45e1fda78
Unknown username "pulse" in message bus configuration file
xres = 1024, yres = 600
▒[     0.0]set pll start
[     0.3]set pll end
[     0.5]beign to init dram
[     0.7]DRAMC IS FOUR
[     0.10]DRAM BOOT DRIVE INFO: V1.1
[     0.13]Found A40
[     0.15]Found A40
[     0.17]Found A40
[     0.19]Found A40
[     0.21]Found A40
[     0.27]PMU: [     0.28]AXP221
[     0.30]ddr voltage = 1250 mv
[     0.37]PMU: [     0.38]AXP221
[     0.40]ddr voltage = 1250 mv
[     0.51]PMU: [     0.52]AXP221
[     0.54]ddr voltage = 1500 mv
[     0.64]DRAM CLK =576 MHZ
[     0.67]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[     0.72]DRAM zq value: 0x003b3bfb
[     0.78]DRAM SIZE =2048 M
[     0.81]DRAM ** test OK.
[     0.84]init dram ok
i2c_init: by cpux
i2c_init ok
[      4.468]pmbus:   ready
[      4.487]PMU: AXP221
[      4.487]PMU: AXP22x found
[      4.488]PMU: dcdc2 1160
[      4.489]PMU: cpux 1008 Mhz,AXI=336 Mhz
vbus exist
DRAM:  512 MiB
fdt addr: 0x56e8fcd8
Relocation Offset is: 15ee6000
In:    serial
Out:   serial
Err:   serial
gic: normal mode
workmode = 16,storage type = 0
[      4.620]NAND_UbootProbe start
[      4.623]NB1 : enter phy init
[      4.626]nand_physic_init
[      4.742]Reset NDFC start 0  0
[      4.742]Reset NDFC end 0  0
[      4.743]nand not support! channel 0 chip 0: 00 00 00 00 00 00 00 00
[      4.749]nand not support! channel 0 chip 1: 00 00 00 00 00 00 00 00
[      4.755]nand not support! channel 0 chip 2: 00 00 00 00 00 00 00 00
[      4.762]nand not support! channel 0 chip 3: 00 00 00 00 00 00 00 00
[      4.768] no nand found !
[      4.771]nand_physic_init nand_build_nsi error
[      4.775]nand_physic_init error -1
[      4.779]NB1 : nand phy init fail
[      4.782]NB1 : enter phy Exit
[      4.785]nand_physic_exit
[      4.788]NAND_UbootProbe end: 0xffffffff
try nand fail
try nand fail
try card 2
SUNXI SD/MMC: 2
[mmc]: 50 MHz...
[mmc]: 100 MHz...
[mmc]: sample: 33 - 151(ps)
[mmc]: 200 MHz...
[mmc]: ************Try SD card 2************
[mmc]: mmc 2 cmd 8 timeout, err 100
[mmc]: smc 2 err, cmd 8,  RTO
[mmc]: mmc 2 close bus gating and reset
[mmc]: mmc 2 mmc cmd 8 err 0x00000100
[mmc]: mmc send if cond failed
[mmc]: mmc 2 cmd 55 timeout, err 100
[mmc]: smc 2 err, cmd 55,  RTO
[mmc]: mmc 2 mmc cmd 55 err 0x00000100
[mmc]: send app cmd failed
[mmc]: PRV 1.1
[mmc]: MMC v5.1
read flash error
[      5.047]inter uboot shell
work mode=0x10
run usb efex
buf queue page size = 65536
delay time 2500
usb init ok
set address 0x31
set address 0x31 ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 6
part[0] name      :boot-resource
part[0] classname :DISK
part[0] addrlo    :0x8000
part[0] lenlo     :0x3800
part[0] user_type :32768
part[0] keydata   :0
part[0] ro        :0
part[1] name      :env
part[1] classname :DISK
part[1] addrlo    :0xb800
part[1] lenlo     :0x2000
part[1] user_type :32768
part[1] keydata   :0
part[1] ro        :0
part[2] name      :boot
part[2] classname :DISK
part[2] addrlo    :0xd800
part[2] lenlo     :0x8000
part[2] user_type :32768
part[2] keydata   :0
part[2] ro        :0
part[3] name      :rootfs
part[3] classname :DISK
part[3] addrlo    :0x15800
part[3] lenlo     :0x200000
part[3] user_type :32768
part[3] keydata   :0
part[3] ro        :0
part[4] name      :usr
part[4] classname :DISK
part[4] addrlo    :0x215800
part[4] lenlo     :0xcfd800
part[4] user_type :32768
part[4] keydata   :0
part[4] ro        :0
part[5] name      :UDISK
part[5] classname :DISK
part[5] addrlo    :0xf13000
part[5] lenlo     :0x0
part[5] user_type :0
part[5] keydata   :0
part[5] ro        :0
total part: 7
mbr 0, 8000, 8000
boot-resource 1, 3800, 8000
env 2, 2000, 8000
boot 3, 8000, 8000
rootfs 4, 200000, 8000
usr 5, cfd800, 8000
UDISK 6, 0, 0
do need erase flash
no part need to protect user data
card2 download boot0
erase boot0, size:32k, write 0x00
erase env part
[mmc]: erase from: 88064, to: 96255, cnt: 8192, erase_group: 1024
[mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0xd17 us
erase boot part
[mmc]: erase from: 96256, to: 129023, cnt: 32768, erase_group: 1024
[mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1568 us
erase rootfs part
[mmc]: erase from: 129024, to: 2226175, cnt: 2097152, erase_group: 1024
[mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x2f847 us
erase usr part
[mmc]: mmc_mmc_erase: input lenght error!!!
[mmc]: mmc_mmc_erase: after clip, from: 2226176, nr: 13043712
[mmc]: erase from: 2226176, to: 15269887, cnt: 13043712, erase_group: 1024
[mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x3f77 us
erase UDISK part
sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
[mmc]: erase from: 15847424, to: 15268863, cnt: -578560, erase_group: 1024
[mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1 us
[mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[mmc]: --0: from15268864  nr1023
write zeros-0: from 0xe8fc00 to 0xe8fffe
card erase all
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
begin to write standard mbr
successed to write standard mbr
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x530400
FEX_CMD_fes_verify_value 0xbaf04d13
FEX_CMD_fes_verify_value, start 0xb800, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0x83a5ca83
FEX_CMD_fes_verify_value, start 0xd800, size high 0x0:low 0xcaa800
FEX_CMD_fes_verify_value 0x67d3d238
FEX_CMD_fes_verify_value, start 0x15800, size high 0x0:low 0x2157e000
FEX_CMD_fes_verify_value 0x100282b
FEX_CMD_fes_verify_value, start 0x215800, size high 0x0:low 0x501600
FEX_CMD_fes_verify_value 0xfa562d1a
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0x10c000
uboot_pkg magic 0x89119800
uboot size = 0x10c000
storage type = 2
mmc down uboot
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0x8000
[mmc]: write mmc info ok
dram para[0] = 240
dram para[1] = 3
dram para[2] = 3b3bfb
dram para[3] = 31
dram para[4] = 10e410f4
dram para[5] = 8001000
dram para[6] = 1c70
dram para[7] = 40
dram para[8] = 18
dram para[9] = 0
dram para[10] = 479950
dram para[11] = 1b1a94b
dram para[12] = 65046
dram para[13] = b47d7d96
dram para[14] = 0
dram para[15] = 198
dram para[16] = 21000000
dram para[17] = 2406c1e0
dram para[18] = 0
dram para[19] = 0
dram para[20] = 3
dram para[21] = 33330000
dram para[22] = 7777
dram para[23] = c4096953
dram para[24] = 0
dram para[25] = 0
dram para[26] = 0
dram para[27] = 0
dram para[28] = 0
dram para[29] = 0
dram para[30] = 0
dram para[31] = 0
storage type = 2
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
set next mode 14
disp_ioctl, display not init yet
drv_disp_exit
[     0.54]set pll end
[     0.109]DRAMC IS FOUR
[     0.115]Found A40
[     0.117]Found A40
[     0.119]Found A40
[     0.121]Found A40
[     0.123]Found A40
[     0.129]PMU: [     0.130]AXP221
[     0.132]ddr voltage = 1500 mv
[     0.135]DRAM CLK =576 MHZ
[     0.138]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[     0.143]DRAM zq value: 0x003b3bfb
[     0.149]DRAM SIZE =2048 M
[     0.152]DRAM ** test OK.
[     0.155]dram size =2048
[     0.157]rtc standby flag is 0x00000000, super standby flag is 0x00000000
[     0.165]card no is 2
[     0.167]sdcard 2 line count 8
[     0.170][mmc]: mmc driver ver 2016-07-01 15:30
[     0.175][mmc]: wrong freq 2 at spd md 2
[     0.188][mmc]: ***Try MMC card 2***
[     0.205][mmc]: MMC 5.1
[     0.207][mmc]: HSSDR52/SDR25 8 bit
[     0.211][mmc]: 50000000 Hz
[     0.213][mmc]: 7456 MB
[     0.216][mmc]: ***SD/MMC 2 init OK!!!***
[     0.289]Succeed in loading uboot from sdmmc flash.
[     0.293]Entry_name        = u-boot
[     0.309]Ready to disable icache.
[     0.312]0xffffffff 0xffffffff
[     0.315]0xffffffff 0xffffffff
[     0.318]0xffffffff 0xffffffff
[     0.322]0xffffffff 0xffffffff
[     0.325]0xffffffff 0xffffffff
[     0.328]0xffffffff 0xffffffff
[     0.331]Jump to secend Boot.
i2c_init: by cpux
i2c_init ok
[      0.346]pmbus:   ready
[      0.360]PMU: AXP221
[      0.360]PMU: AXP22x found
[      0.361]PMU: dcdc2 1160
[      0.362]PMU: cpux 1008 Mhz,AXI=336 Mhz
vbus exist
run key detect
no key found
no uart input
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
gic: normal mode
[      0.516]start
drv_disp_init
tv_init:
tv_probe:000
tv0 have no type1
tv0 have no type2
tv0 have no type3
tv_init:
[      1.279]end
[      1.279]MMC:        2
SUNXI SD/MMC: 2
[mmc]: 50 MHz...
[mmc]: 100 MHz...
[mmc]: ds: 33 - 151(ps)
[mmc]: 200 MHz...
[mmc]: PRV 1.1
[mmc]: MMC v5.1
[      1.515]sunxi flash init ok
UDISK       : e2600000      0
key 0
update dtb dram  end
no battery exist
1152054 bytes read in 29 ms (37.9 MiB/s)
[      1.774]inter uboot shell
The test ok!
secret ok
[      3.106]sunxi flash read :offset 1b00000, 14324561 bytes OK
[      3.172]ready to boot
prepare for kernel
[mmc]: 50 MHz...
[mmc]: 100 MHz...
[mmc]: 200 MHz...
/dev/mmcblk0p7: clean, 8420/9648 files, 484368/546296 blocks
init asteroid  env##
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Starting sshd: OK
Starting vsftpd: OK
find qt5 installed
D-Bus per-session daemon address is: unix:abstract=/tmp/dbus-CpWXjMg9gl,guid=6f88816b7085eb5221c9379b5e1fdb44
create /dev/mmcblk1p1
create /dev/mmcblk1
zhichao 发表于 2022-3-28 09:28:45 | 显示全部楼层
您的资料太旧了哦,2019年资料只适用于V1.1核心板,您下载最新资料就可以了
