- 95
贡献495
飞刀167 FD
注册时间2021-3-29
在线时间14 小时
单板:imx8mp
单板是从emmc 启动的,我想要查看u-boot 信息
下面是u-boot 的打印:
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
image offset 0x0, pagesize 0x200, ivt offset 0x0
NOTICE: BL31: v2.2(release):rel_imx_5.4.70_2.3.0-0-gf1d7187f2
NOTICE: BL31: Built : 03:31:00, Apr 8 2021
Forlinx
U-Boot 2020.04-00005-g23b6e181f8-dirty (Jan 21 2022 - 08:24:05 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 38C
Reset cause: POR
Model: Forlinx OK8MPlus LPDDR4 EVK board
DRAM: 4 GiB
MMC: FSL_SDHC: 1, FSL_SDHC: 2
try kernel dtb
Error binding driver 'gpio_led': -22
Some drivers failed to bind
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
lvds0_panel enable
mipi_panel_uboot enable
eth0 enable
eth1 enable
Loading Environment from MMC... *** Warning - bad CRC, using default environment
video link is full-Video Link 0 (1024 x 600)
[0] lcd-controller@32e80000, video
[1] mipi_dsi@32e60000, video_bridge
[2] mipi_panel_uboot, panel-Video Link 1 (1280 x 800)
[0] lcd-controller@32e90000, video
[1] ldb@32ec005c, video_bridge
[2] lvds0_panel, panel
[ ]-Video Link 2
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF f1d7187
- U-Boot 2020.04-00005-g23b6e181f8-dirty
switch to partitions #0, OK
mmc2(part 0) is current device
a1007 auth ok!
flash target is MMC:2
Net: config yt8521
eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
Autoboot in 1 seconds 单板能在这里停住吗?
28215808 bytes read in 637 ms (42.2 MiB/s)
Booting from mmc ...
67111 bytes read in 16 ms (4 MiB/s)
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Using Device Tree in place at 0000000043000000, end 0000000043013626
