查看: 4928|回复: 1
[Linux] OKMX6UL-C 1G Nand烧写成功后启动失败
i.MX6UL通行证RK3568通行证AM5718通行证RK3576通行证
crsculianghao 发表于 2022-6-29 11:38:07 | 显示全部楼层 |阅读模式
用SD卡烧写成功后,换成nand启动,卡住了,打印如下:
NAND read: device 0 offset 0xe00000, size 0x800000
8388608 bytes read: OK
NAND read: device 0 offset 0xb00000, size 0x40000
262144 bytes read: OK
Kernel image @ 0x80800000 [ 0x000000 - 0x622528 ]
   Using Device Tree in place at 83000000, end 8300c841
Starting kernel ...
[    0.000000] Linux version 3.14.38-6UL_ga-00003-g9b1d9f6 (liyue@developer-RH2485-V2) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Mon Feb 12 11:31:44 CST 2018
[    0.000000] Clicy: Data cache writealloc
[  bility grouping on.  Total pages: 60928
[    0.000000] Kernel c: 60928
[    0.000000] Kernel command line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115ommand line: console=ttymxc0,115200 cma=64M root=/dev/mtdblock7 rootfstype=yaffs2,calibrate=y
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 165632K/245760K available (7922K kernel code, 481K rwdata, 2792K rodata, 396K init, 433K bss, 80128K reserved, 0K highmem)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 : 0x90800000 - 0xff000000   (1768 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a7ecf8   (10716 kB)
[    0.000000]       .init : 0x80a7f000 - 0x80ae2280   ( 397 kB)
[    0.000000]       .data : 0x80ae4000 - 0x80b5c760   ( 482 kB)
[    0.000000]        .bss : 0x80b5c76c - 0x80bc8cf4   ( 434 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000020] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002640] clocksource_of_init: no matching clocksources found
[    0.003002] Console: colour dummy device 80x30
[    0.003050] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003081] pid_max: default: 32768 minimum: 301
[    0.003467] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003495] Mountpoint-cache hash 096 bytes)
[    0.005035] Initializing cgroup subsys net_cls
[    0.005121] CPU: Testing write buffer coherency: ok
[    0.005618] /cpus/cpu@0 missing clock-frequency property
[    0.005659] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005719] Setting up static identity map for 0x807855f8 - 0x80785650
[    0.040752] Brought up 1 CPUs
[    0.040786] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040803] CPU: All CPU(s) started in SVC mode.
[    0.042105] devtmpfs: initialized
[    0.052710] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.053484] pinctrl core: initialized pinctrl subsystem
[    0.054368] regulator-dummy: no parameters
[    0.059669] NET: Registered protocol family 16
[    0.076321] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.077915] cpuidle: using governor ladder
[    0.077943] cpuidle: using governor menu
[    0.078308] Use WDOG1 as reset source
[    0.096648] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.097351] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.098230] cpu: 725 <--> 1450 mV at 1150 mV
[    0.099072] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.104417] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.111047] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.112612] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.119889] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.119919] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.123981] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.126849] 20dc000.gpc supply pu not found, using dummy regulator
[    0.162009] bio: create slab <bio-0> at 0
[    0.168606] mxs-dma 1804000.dma-apbh: initialized
[    0.169554] can-3v3: 3300 mV
[    0.170099] VSD_3V3: 3300 mV
[    0.170874] usb_otg1_vbus: 5000 mV
[    0.171450] vref-3v3: 3300 mV
[    0.173034] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.174336] i2c-core: driver [max17135] using legacy suspend method
[    0.174362] i2c-core: driver [max17135] using legacy resume method
[    0.175610] SCSI subsystem initialized
[    0.176820] usbcore: registered new inte**ce driver usbfs
[    0.176990] usbcore: registered new inte**ce driver hub
[    0.177306] usbcore: registered new device driver usb
[    0.183031] i2c i2c-0: IMX I2C adapter registered
[    0.185506] i2c i2c-1: IMX I2C adapter registered
[    0.185802] Linux video capture inte**ce: v2.00
[    0.186006] pps_core: LinuxPPS API ver. 1 registered
[    0.186026] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.186090] PTP clock support registered
[    0.188700] MIPI CSI2 driver module loaded
[    0.189300] Advanced Linux Sound Archite0.191368] Bluetooth: Core ver 2.18
[    0.191502] NET: Registered protocol family 31
[    0.191524] Bluetooth: HCI device and connection manager initialized
[    0.191564] Bluetooth: HCI socket layer initialized
[    0.191596] Bluetooth: L2CAP socket layer initialized
[    0.191707] Bluetooth: SCO socket layer initialized
[    0.193663] Switched to clocksource mxc_timer1
[    0.195512] cfg80211: Calling CRmain
[    0.219222] NET: Registered protocol family 2
[    0.221226] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.221317] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.221407] TCP: Hash tables configured (established 2048 bind 2048)
[    0.221523] TCP: reno registered
[    0.221557] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.221616] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.222181] NET: Registered protocol family 1
[    0.222922] RPC: Registered named UNIX socket transport module.
[    0.222953] RPC: Registered udp transport module.
[    0.222971] RPC: Registered tcp transport module.
[    0.222988] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.226034] imx rpmsg driver is registered.
[    0.227641] Bus freq driver module loaded
[    0.229609] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.249215] VFS: Disk quotas dquot_6.5.2
[    0.249919] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.255994] NFS: Registering the id_resolver key type
[    0.256100] Key type id_resolver registered
[    0.256121] Key type id_legacy registered
[    0.256207] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    0.258082] fuse init (API version 7.22)
[    0.259369] msgmni has been set to 451
[    0.267631] io scheduler noop registered
[    0.267663] io scheduler deadline registered
[    0.268170] io scheduler cfq registered (default)
[    0.269213] imx-weim 21b8000.weim: Driver registered.
[    0.275019] backlight.9 supply power not found, using dummy regulator
[    0.278276] MIPI DSI driver module loaded
[    0.282589] 21c8000.lcdif supply lcd not found, using dummy regulator
[    0.282979] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    0.283892] mxsfb 21c8000.lcdif: initialized
[    0.291054] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.291262] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    0.299888] imx-sdma 20ec000.sdma: initialized
[    0.301342] Serial: IMX terial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    1.045242] console [ttymxc0] enabled
[    1.050661] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.060524] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    1.070220] serial: Freescale lpuart driver
[    1.078302] imx sema4 driver is registered.
[    1.082669] [drm] Initialized drm 1.1.0 20060810
[    1.088510] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.116197] brd: module loaded
[    1.130880] loop: module loaded
[    1.137695] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
[    1.149765] CAN device driver inte**ce
[    1.157147] flexcan 2090000.can: device registered (reg_base=90968000, irq=142)
[    1.167235] flexcan 2094000.can: device registered (reg_base=90970000, irq=143)
[    1.176892] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.185020] pps pps0: new PPS source ptp0
[    1.189525] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.198689] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: 96:7a:cb:e6:fd:ce
[    1.208865] libphy: fec_enet_mii_bus: probed
[    1.217003] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.224645] 2188000.ethernt (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.246341] fec 2188000.ethernet (unregistered net_device): Using random MAC address: c6:d4:cd:89:75:52
[    1.257804] fec 2188000.ethernet eth1: registered PHC device 1
[    1.265468] PPP generic driver version 2.4.2
[    1.270299] PPP BSD Compression module registered
[    1.275179] PPP Deflate Compression module registered
[    1.280477] usbcore: registered new inte**ce driver asix
[    1.286122] usbcore: registered new inte**ce driver cdc_ether
[    1.292102] usbcore: registered new inte**ce driver cdc_eem
[    1.298076] usbcore: registered new inte**ce driver cdc_ncm
[    1.303816] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.310372] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.316200] usbcore: registered new inte**ce driver usb-storage
[    1.322555] usbcore: registered new inte**ce driver usbserial
[    1.328624] usbcore: registered new inte**ce driver usbserial_generic
[    1.335346] usbserial: USB Serial support registered for generic
[    1.341489] usbcore: registered new inte**ce driver ftdi_sio
[    1.347407] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.354899] usbcore: registered new inte**ce driver option
[    1.360597] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.367732] usbcore: registered new inte**ce driver pl2303
[    1.373425] usbserial: USB Serial support registered for pl2303
[    1.379571] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    1.386172] xr_usb_serial_common: Exar USB UART (serial port) driver
[    1.392688] usbcore: registered new inte**ce driver usb_ehset_test
[    1.401281] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.417461] 2184200.usb supply vbus not found, using dummy re32716] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    1.453757] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.461219] hub 1-0:1.0: USB hub found
[    1.465199] hub 1-0:1.0: 1 port detected
[    1.471403] mousedev: PS/2 mouse device common for all mice
[    1.479130] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    1.490015] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    1.783755] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    1.945780] hub 1-1:1.0: USB hub found
[    1.951891] hub 1-1:1.0: 4 ports detected
[    2.003699] edt_ft5x06 0-0038: touchscreen probe failed
[    2.009012] edt_ft5x06: probe of 0-0038 failed with error -110
[    2.017066] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input2
[    2.026619] <<-GTP-INFO->> GTP driver installing...
[    2.031970] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    2.038067] 11:31:15, Feb 12 2018
[    2.044297] <<-GTP-INFO->> GTP I2C Address: 0x14
[    4.593680] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[    4.600768] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    7.173671] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[    7.180749] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    9.753670] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[    9.760745] <<-GTP-ERROR->> GTP i2c test failed time 3.
[   12.333670] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   12.340746] <<-GTP-ERROR->> GTP i2c test failed time 4.
[   14.913668] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   14.920743] <<-GTP-ERROR->> GTP i2c test failed time 5.
[   14.943697] <<-GTP-ERROR->> I2C read failed.
[   14.948162] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[   14.954165] <<-GTP-INFO->> GTP Driver Built@11:31:15, Feb 12 2018
[   14.960288] <<-GTP-INFO->> GTP I2C Address: 0x5d
[   17.513674] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   17.520752] <<-GTP-ERROR->> GTP i2c test failed time 1.
[   20.093670] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   20.100748] <<-GTP-ERROR->> GTP i2c test failed time 2.
[   22.673668] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   22.680743] <<-GTP-ERROR->> GTP i2c test failed time 3.
[   25.253673] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   25.260748] <<-GTP-ERROR->> GTP i2c test failed time 4.
[   27.833671] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -110!
[   27.840746] <<-GTP-ERROR->> GTP i2c test failed time 5.
874728] i2c-core: driver [isl29023] using legacy resume method
23] using legacy resume method23] using legacy resume method
[   28.383690] rtc-rx8010 0-0032: Unable to write register #23
[   28.389312] i2c i2c-0: probing for rx8010 failed
[   28.394022] rtc-rx8010: probe of 0-0032 failed with error -110
[   28.401263] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[   28.40   28.414817] IR NEC protocol handler initialized
[   28.419389] IR RC5(x) protocol handler ini.  28.428836] IR JVC protocol handler initialized
[   28.433390]rotocol handler initialized
[  rotocol handler initialized
[   28.448422] IR MCE Keyboard/mous 28.448422] IR MCE Keyboard/mouse protocol handler initialized
[   28.457231] pxp-v4l2 pxp_v4l2.10: initialized
[   28.462011] usbcore: registered new inte**ce driver uvcvideo
[   28.467876] USB Video Class driver (1.1.1er [mag3110] using legacy suspend method
[   28.479322] i2c-core: driver [mag3110] using legacy
                                                      [   28.499685] Bluetooth: HCI H
        [   28.499685] Bluetooth: HCI H4 protocol initialized
[   28.504553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP proto04553] Bluetooth: HCI BCSP protocol initialized
[   28.509545] Bluetooth: HCIATH3K protocol initialized
[   28.514787] usbcore: registered new inte**ce driver ath3k
[   28.532144] usbcore: registered new inte**ce driver rtk_btusb
[   28.538642] sdhci: Secure Digital Host Controller Inte**ce driver
[   28.544917] sdhci: Copyright(c) Pierre Ossman
[   28.549304] sdhci-pltfm: SDHCI platform and OF driver helper
[   28.558523] mmc0: no vqmmc regulator found
[   28.603739] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[   28.658608] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xd3
[   28.665094] nand: Micron MT29F8G08ABACAWP
[   28.669142] nand: 1024MiB, SLC, page size: 4096, OOB size: 224
[   28.675754] gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
[   28.682771] Scanning device for bad blocks
[   28.955463] random: nonblocking pool is initialized
[   29.199145] 8 ofpart partitions found on MTD device gpmi-nand
[   29.204978] Creating 8 MTD partitions on "gpmi-nand":
[   29.210073] 0x000000000000-0x000000800000 : "boot"
[   29.217614] 0x000000800000-0x000000a00000 : "logo"
[   29.225012] 0x000000a00000-0x000000b00000 : "ENV"
[   29.232236] 0x000000b00000-0x000000e00000 : "DTB"
[   29.239837] 0x000000e00000-0x000001600000 : "kernel"
[   29.247622] 0x000001600000-0x000001700000 : "DTBbak"
[   29.255321] 0x000001700000-0x000001f00000 : "kernelbak"
[   29.263202] 0x000001f00000-0x000040000000 : "rootfs"
[   29.271470] gpmi-nand 1806000ed new inte**ce driver usbhid
[   29.287056] usbhid: USB HID core driver
[   29.304465] fsl-asrc 2034000.asrc: driver registered
[   29.318633] snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
[   29.328115] imx-wm8960 sound.1  29.343997] imx-wm8960 sound.14  29.343997] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
[   29.361383] NET: Registered protocol family 26
[   29.365988] Netfilter messages via NETLINK v0.30.
[   29.370776] nfnl_acct: registering with nfnetlink.
[   29.375771] nf_conntrack version 0.5.0 (3612 buckets, 14448 max)
[   29.382991] ctnetlink v0.93: registering with nfnetlink.
[   29.388688] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[   29.395324] nf_tm[   29.403063] xt_time: kernel t.8 loaded successfully
[   29.420409] arp_tables: (C) 2002 David S. Miller
[   29.425241] TCP: cubic registered
[   29.429873] NET: Registered protocol family 10
[   29.436677] sit: IPv6 over IPv4 tunneling driver
[   29.442932] NET: Registered protocol family 17
[   29.447675] can: controller area network core (rev 20120528 abi 9)
[   29.454182] NET: Registered protocol family 29
[   29.458720] can: raw rotocol (rev 20120528 t)
[   29.468800] can: netlink gateway (rev 20130117) max_hops=1
[   29.474991] Bluetooth: RFCOMM TTY la9158] Bluetooth: BNEP (Ethernet 9158] Bluetooth: BNEP (Ethernet 9158] Bluetooth: BNEP (Ethernet ialized
[   29.504880] Bluetootialized
[   29.504880] Bluetooth: HIDP (Human Inte**ce Emulatih: HIDP (Human Inte**ce Emulatih: HIDP (Human Inte**ce Emulatih: HIDP (Human Inte**ce Emulatih: HIDP (Human Inte**ce Emulatih: HIDP (Human Inte**ce Emulation) ver 1.2
[   29.510848] Bluetooth: HIDP socket layer initialized
[   29.515972] 8021q: 802.1Q VLAN Support v1.8
[   29.520310] Key type dns_resolver registered
[   29.526220] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[   29.557947] gpio_dvfs: disabling
[   29.561229] vref-3v3: disabling
[   29.564512] usb_otg1 VSD_3V3: disabling
[   29.5711vs_rtc 20cc034.snvs-rtc-lp: settvs_rtc 20cc034.snvs-rtc-lp: settvs_rtc 20cc034.snvs-rtc-lp: settvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:08:08 UTC (488)
0:08:08 UTC (488)
[   29.611532] ALSA device list:
[   29.614654]   #0: wm8960-audio
[   29.618700] yaffs: dev is 32505863 name is "mtdblock7" ro
[   29.624327] yaffs: passed flags ""
[   29.703271] VFS: Mounted root (yaffs2 filesystem) readonly on device 31:7.
[   29.711420] devtmpfs: mounted
[   29.715294] Freeing unused kernel memory: 396K (80a7f000 - 80ae2000)
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug even[   30.100356] udevd (99): /proc/99/oom_adj is deprecated, please use /proc/99/oom_score_adj instead.
ts
[   41.321667] 1-0030 supply DOVDD not found, using dummy regulator
[   41.349543] 1-0030 supply DVDD not found, using dummy regulator
[   41.383969] 1-0030 supply AVDD not found, using dummy regulator
[   41.514053] ov9650_read_reg:write reg error:reg=1c
[   41.518875] camera ov9650 is not found
Mounting filesystems
Starting inetd:
Starting syslogd and klogd
[   42.421866] flexcan 2090000.can can0: writing ctrl=0x0e312085
[   42.448687] flexcan 2094000.can can1: writing ctrl=0x0e312085
Reconfiguring network inte**ces... ifdown: inte**ce eth1 not configured
[   42.764560] fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
[   42.814324] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   42.974884] fec 2188000.ethernet eth1: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:02, irq=-1)
[   43.014385] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
RTNETLINK answers: File exists
done.
alsactl: parse:1655: Unable to open file '/data0/imx6_linux/alsa/tmp/share/alsa/init/00main': No such file or directory
alsactl: set_control:1267: failed to obtain info for control #55 (No such file or directory)
[   43.210328] Trying to free nonexistent resource <0000000087b00000-0000000087c76fff>
xres = 800, yres = 480
forqs 发表于 2022-6-29 13:34:38 | 显示全部楼层
这是卡在屏幕校准了,开机uboot阶段按空格进入uboot菜单,然后选2Change The Calibrate,再按2选择Not Calibrate关闭校准,再重启就好了。
