查看: 5765|回复: 2
[Linux] OK8MP板子从TF卡启动显示"context forlinx"
i.MX8MP通行证
qingfengjuechen 发表于 2022-8-10 11:16:45 | 显示全部楼层 |阅读模式
U-Boot SPL 2020.04-00001-g1aaf466989-dirty (Aug 25 2021 - 15:02:44 +0800)
using static parameter
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
image offset 0x8000, pagesize 0x200, ivt offset 0x0
NOTICE:  BL31: v2.2(release):rel_imx_5.4.70_2.3.0-0-gf1d7187f2
NOTICE:  BL31: Built : 03:31:00, Apr  8 2021
Forlinx
U-Boot 2020.04-00001-g1aaf466989-dirty (Aug 25 2021 - 15:02:44 +0800)
CPU:   i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
Model: Forlinx OK8MPlus LPDDR4 EVK board
DRAM:  4 GiB
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
boot dev is not emmc, using static dtb
mipi_panel enable
lvds0_panel enable
eth0 enable
eth1 enable
Loading Environment from MMC... *** Warning - bad CRC, using default environment
  • -Video Link 0 (1024 x 600)
            [0] lcd-controller@32e80000, video
            [1] mipi_dsi@32e60000, video_bridge
            [2] mipi_panel, panel
  • -Video Link 1 (1280 x 800)
            [0] lcd-controller@32e90000, video
            [1] ldb@32ec005c, video_bridge
            [2] lvds0_panel, panel
    [ ]-Video Link 2
    ** Unrecognized filesystem type **
    In:    serial
    Out:   serial
    Err:   serial
    BuildInfo:
      - ATF f1d7187
      - U-Boot 2020.04-00001-g1aaf466989-dirty
    switch to partitions #0, OK
    mmc1 is current device
    normal mode
    please contact forlinx
  • 回复
    i.MX8MP通行证
    楼主| qingfengjuechen 发表于 2022-8-10 11:25:18 | 显示全部楼层
    补充一下: TF卡已经是fat32格式了
    您好,这应该是镜像的原因,由于新的底板更换了加密芯片,需要烧写22年以后的镜像,您的镜像版本有些旧,下载一下最新的镜像重新烧写即可。  详情 回复 发表于 2022-8-11 07:54
    Q_Y_X 发表于 2022-8-11 07:54:55 | 显示全部楼层
