查看: 5367|回复: 4
[Ubuntu] ls1046A下获取网口PHY的寄存器值
LS1043A\46A通行证
elephant4216 发表于 2022-10-10 14:18:16 | 显示全部楼层 |阅读模式
你好:
     请问在ls1046A下,怎样获取网口PHY各个寄存器的值?
     谢谢!
LS1043A\46A通行证
楼主| elephant4216 发表于 2022-10-12 18:50:01 | 显示全部楼层
hai 发表于 2022-10-12 10:20
您好,我们这边是直接使用的ethtool fm1-amc3这个命令,这个能看到网口的协商结果还有是否处于link状态等 ...
嗯,是的,我实现了,分享如下:
修改文件:drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.c
修改接口:dpa_ioctl
修改的地方:在接口dpa_ioctl的最后一个return之前加入如下的代码:
       if( cmd >= SIOCGMIIPHY && cmd <= SIOCSMIIREG)
                struct dpa_priv_s *priv = netdev_priv(dev);
                if( priv && priv->mac_dev && priv->mac_dev->phy_dev )
                        return phy_mii_ioctl(priv->mac_dev->phy_dev, rq, cmd);
                else
                        netdev_warn(dev, "No phy device\n");
                        ret = -ENODEV;
上层使用如下工具就可以读取到网络接口的PHY寄存器了:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <linux/mii.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <sys/ioctl.h>
#include <net/if.h>
#include <linux/sockios.h>
#include <linux/types.h>
#include <netinet/in.h>
#include <errno.h>
#include <fcntl.h>
#include <getopt.h>
#include <unistd.h>
#define reteck(ret)     \
        if(ret < 0){    \
            printf("%m! \"%s\" : line: %d\n", __func__, __LINE__);   \
            goto lab;   \
#define help() \
    printf("mdio:\n");                  \
    printf("read all regs: mdio if\n");          \
    printf("write regAddr to value : mdio if regAddr value\n");    \
    printf("For example:\n");            \
    printf("mdio fm1-mac5 \n");             \
    printf("mdio fm1-mac5 0 0x1234\n\n");      \
    exit(0);
int sockfd;
int main(int argc, char *argv[])
        uint16_t data[32] = {0};
    struct mii_ioctl_data *mii = NULL;
    struct ifreq ifr;
    int ret;
        uint16_t i;
    if(argc == 1 || !strcmp(argv[1], "-h"))
        help();
        if((argc != 2) && (argc != 4))
        help();
    memset(&ifr, 0, sizeof(ifr));
    strncpy(ifr.ifr_name, argv[1], IFNAMSIZ - 1);
    sockfd = socket(PF_LOCAL, SOCK_DGRAM, 0);
    reteck(sockfd);
    //get phy address in smi bus
    ret = ioctl(sockfd, SIOCGMIIPHY, &ifr);
    reteck(ret);
    mii = (struct mii_ioctl_data*)&ifr.ifr_data;
    if(argc == 2)
                for( i =0 ;i < 32;i++)
                        mii->reg_num  = i;
                        //printf("mii->reg_num = %d\n",mii->reg_num);
                        ret = ioctl(sockfd, SIOCGMIIREG, &ifr);
                        reteck(ret);
                        data = mii->val_out;
                printf("%s\'s phyAddr = %d\n",ifr.ifr_name,mii->phy_id);
                printf("All Phy Reg as follows:\n");
                printf("--------------------------------------\n");
                for(i = 0 ;i < 32; i++)
                        printf("regAddr = %2d,Val = 0x%04X   ",i,data);
                        if( ((i+1) %2) == 0)
                                printf("\n");
                printf("\n");
        else if(argc == 4)
        mii->reg_num  = (uint16_t)strtoul(argv[2], NULL, 0);
        mii->val_in   = (uint16_t)strtoul(argv[3], NULL, 0);
        ret = ioctl(sockfd, SIOCSMIIREG, &ifr);
        reteck(ret);
        printf("write phy addr: 0x%x  reg: 0x%x  value : 0x%x\n\n", mii->phy_id, mii->reg_num, mii->val_in);
lab:
    close(sockfd);
    return 0;
点评回复 支持 1 反对 0
hai 发表于 2022-10-10 14:48:38 | 显示全部楼层
可以在uboot阶段使用如下命令读取,详细的参数还是用看芯片手册。
例:
列举PHY:mdio list
读取寄存器0: mdio read 1 0x00
读取寄存器1:mdio read 1 0x01
在uboot阶段验证OK,感谢! 另外,请教一下,在Linux下有什么工具可用吗? 使用ethtool提示如下,不知什么原因? root@localhost:~# root@localhost:~# ethtool -i fm1-mac5 driver: fsl_dpa version: 5.10  详情 回复 发表于 2022-10-10 16:18
LS1043A\46A通行证
楼主| elephant4216 发表于 2022-10-10 16:18:55 | 显示全部楼层
例:
列举PHY:mdio list
在uboot阶段验证OK,感谢!
root@localhost:~#
driver: fsl_dpa
version: 5.10.35-rt39-svn80
firmware-version: 0
expansion-rom-version:
bus-info: soc:fsl,dpaa
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no     【提示no】
supports-priv-flags: no
root@localhost:~#
root@localhost:~#
root@localhost:~# ethtool -d fm1-mac5
Cannot get register dump: Operation not supported
root@localhost:~#
hai
您好,我们这边是直接使用的ethtool fm1-amc3这个命令,这个能看到网口的协商结果还有是否处于link状态等等信息。但是ls系列的是不支持在ubuntu系统中读取phy寄存器状态的。如果想读取需要您自己改驱动。 root@loca  详情 回复 发表于 2022-10-12 10:20
hai 发表于 2022-10-12 10:20:04 | 显示全部楼层
在uboot阶段验证OK,感谢!
root@localhost:~# ethtool fm1-mac3
Settings for fm1-mac3:
        Supported ports: [ MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Speed: 10Mb/s
        Duplex: Half
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0xffffffff (-1)
                               drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol 0xffff8000
        Link detected: no
嗯,是的,我实现了,分享如下: 修改文件:drivers/net/ethernet/freescale/sdk_dpaa/dpaa_eth_common.c 修改接口:dpa_ioctl 修改的地方:在接口dpa_ioctl的最后一个return之前加入如下的代码: if( cm  详情 回复 发表于 2022-10-12 18:50
