查看: 7527|回复: 3
[已解决] [Linux] Yocto/Poky 开发环境
RK3568通行证i.MX RT通行证AM62x通行证
kunyi 发表于 2022-10-25 13:04:16 | 显示全部楼层 |阅读模式
提供一个 Yocto/Poky 的开发环境给 OK6254-C DDR4 2GB的版本
目前驗證 core-image-minimal 開機正常
代码放在Github上
https://github.com/UWINGS-KUNYI/meta-ok6254c
开机讯息如下
  1. U-Boot SPL 2021.01-gede58cb32c (Oct 20 2022 - 11:12:44 +0000)
  2. SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.2--v08.04.02 (Jolly Jellyfi')
  3. Trying to boot from MMC2
  4. Loading Environment from MMC... *** Warning - No MMC card found, using default environment
  5. Starting ATF on ARM64 core...
  6. NOTICE:  BL31: v2.6(release):v2.7-rc0-dirty
  7. NOTICE:  BL31: Built : 19:33:32, May 19 2022
  8. I/TC:
  9. I/TC: OP-TEE version: 3.17.0-125-g15a746d28-dev (gcc version 11.3.0 (GCC)) #1 Thu 16 Jun 2022 03:57:51 PM UTC aarch64
  10. I/TC: WARNING: This OP-TEE configuration might be insecure!
  11. I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
  12. I/TC: Primary CPU initializing
  13. I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.2--v08.04.02 (Jolly Jellyfi')
  14. I/TC: HUK Initialized
  15. I/TC: Primary CPU switching to normal world boot
  16. U-Boot SPL 2021.01-gede58cb32c (Oct 20 2022 - 11:12:44 +0000)
  17. SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.2--v08.04.02 (Jolly Jellyfi')
  18. Trying to boot from MMC2
  19. U-Boot 2021.01-gede58cb32c (Oct 20 2022 - 11:12:44 +0000)
  20. SoC:   AM62X SR1.0 GP
  21. Model: Forlinx OK6254-C
  22. DRAM:  2 GiB
  23. MMC:   mmc@fa10000: 0, mmc@fa00000: 1
  24. Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000)
  25. *** Warning - !read failed, using default environment
  26. In:    serial@2800000
  27. Out:   serial@2800000
  28. Err:   serial@2800000
  29. Net:   eth0: ethernet@8000000port@1
  30. Hit any key to stop autoboot:  0
  31. switch to partitions #0, OK
  32. mmc1 is current device
  33. SD/MMC found on device 1
  34. Failed to load 'boot.scr'
  35. Failed to load 'uEnv.txt'
  36. 18670080 bytes read in 789 ms (22.6 MiB/s)
  37. 52555 bytes read in 6 ms (8.4 MiB/s)
  38. ## Flattened Device Tree blob at 88000000
  39.    Booting using the fdt blob at 0x88000000
  40.    Loading Device Tree to 000000008fef0000, end 000000008fffffff ... OK
  41. Starting kernel ...
  42. [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  43. [    0.000000] Linux version 5.10.140-gc3b343850c (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Oct 21 10:51:07 UTC 2022
  44. [    0.000000] Machine model: Forlinx AM6254-C Dev. Board
  45. [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
  46. [    0.000000] printk: bootconsole [ns16550a0] enabled
  47. [    0.000000] efi: UEFI not found.
  48. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
  49. [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
  50. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
  51. [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
  52. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 13 MiB
  53. [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
  54. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009d900000, size 1 MiB
  55. [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9d900000, compatible id shared-dma-pool
  56. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 13 MiB
  57. [    0.000000] OF: reserved mem: initialized node r5f-memory@9da00000, compatible id shared-dma-pool
  58. [    0.000000] Zone ranges:
  59. [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
  60. [    0.000000]   DMA32    empty
  61. [    0.000000]   Normal   empty
  62. [    0.000000] Movable zone start for each node
  63. [    0.000000] Early memory node ranges
  64. [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
  65. [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
  66. [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
  67. [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
  68. [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
  69. [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
  70. [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
  71. [    0.000000] psci: probing for conduit method from DT.
  72. [    0.000000] psci: PSCIv1.1 detected in firmware.
  73. [    0.000000] psci: Using standard PSCI v0.2 function IDs
  74. [    0.000000] psci: Trusted OS migration not required
  75. [    0.000000] psci: SMC Calling Convention v1.2
  76. [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
  77. [    0.000000] Detected VIPT I-cache on CPU0
  78. [    0.000000] CPU features: detected: ARM erratum 845719
  79. [    0.000000] CPU features: detected: GIC system register CPU inte**ce
  80. [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
  81. [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=6ed93013-02 rw rootfstype=ext4 rootwait
  82. [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  83. [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  84. [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  85. [    0.000000] Memory: 1456372K/2097152K available (11008K kernel code, 1144K rwdata, 4152K rodata, 1792K init, 432K bss, 116492K reserved, 524288K cma-reserved)
  86. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  87. [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  88. [    0.000000] rcu:     RCU event tracing is enabled.
  89. [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  90. [    0.000000]  Trampoline variant of Tasks RCU enabled.
  91. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  92. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  93. [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  94. [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
  95. [    0.000000] GICv3: 256 SPIs implemented
  96. [    0.000000] GICv3: 0 Extended SPIs implemented
  97. [    0.000000] GICv3: Distributor has no Range Selector support
  98. [    0.000000] GICv3: 16 PPIs implemented
  99. [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
  100. [    0.000000] ITS [mem 0x01820000-0x0182ffff]
  101. [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
  102. [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
  103. [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
  104. [    0.000000] ITS: using cache flushing for cmd queue
  105. [    0.000000] GICv3: using LPI property table @0x0000000080030000
  106. [    0.000000] GIC: using cache flushing for LPI property table
  107. [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
  108. [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
  109. [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
  110. [    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
  111. [    0.008505] Console: colour dummy device 80x25
  112. [    0.013096] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
  113. [    0.023778] pid_max: default: 32768 minimum: 301
  114. [    0.028580] LSM: Security Framework initializing
  115. [    0.033363] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  116. [    0.040943] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  117. [    0.050701] rcu: Hierarchical SRCU implementation.
  118. [    0.055889] Platform MSI: msi-controller@1820000 domain created
  119. [    0.062181] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
  120. [    0.071421] EFI services will not be available.
  121. [    0.076336] smp: Bringing up secondary CPUs ...
  122. I/TC: Secondary CPU 1 initializing
  123. I/TC: Secondary CPU 1 switching to normal world boot
  124. I/TC: Secondary CPU 2 initializing
  125. I/TC: Secondary CPU 2 switching to normal world boot
  126. I/TC: Secondary CPU 3 initializing
  127. I/TC: Secondary CPU 3 switching to normal world boot
  128. [    0.100285] Detected VIPT I-cache on CPU1
  129. [    0.100322] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
  130. [    0.100337] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
  131. [    0.100397] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  132. [    0.119651] Detected VIPT I-cache on CPU2
  133. [    0.119677] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
  134. [    0.119687] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
  135. [    0.119725] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  136. [    0.138922] Detected VIPT I-cache on CPU3
  137. [    0.138944] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
  138. [    0.138954] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
  139. [    0.138987] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  140. [    0.139058] smp: Brought up 1 node, 4 CPUs
  141. [    0.218765] SMP: Total of 4 processors activated.
  142. [    0.223576] CPU features: detected: 32-bit EL0 Support
  143. [    0.228845] CPU features: detected: CRC32 instructions
  144. [    0.241276] CPU: All CPU(s) started at EL2
  145. [    0.245484] alternatives: patching kernel code
  146. [    0.251164] devtmpfs: initialized
  147. [    0.261269] KASLR disabled due to lack of seed
  148. [    0.266025] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  149. [    0.276003] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  150. [    0.297503] pinctrl core: initialized pinctrl subsystem
  151. [    0.303536] DMI not present or invalid.
  152. [    0.308121] NET: Registered protocol family 16
  153. [    0.314297] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  154. [    0.321643] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  155. [    0.329716] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  156. [    0.338421] thermal_sys: Registered thermal governor 'step_wise'
  157. [    0.338426] thermal_sys: Registered thermal governor 'power_allocator'
  158. [    0.345076] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  159. [    0.358790] ASID allocator initialised with 65536 entries
  160. [    0.388033] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  161. [    0.394912] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  162. [    0.401764] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  163. [    0.408614] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  164. [    0.416533] cryptd: max_cpu_qlen set to 1000
  165. [    0.423775] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
  166. [    0.432825] vcc_5v0: supplied by vcc_12v0
  167. [    0.437369] vcc_3v3: supplied by vcc_5v0
  168. [    0.441750] vdd_mmc1: supplied by vcc_3v3
  169. [    0.446814] iommu: Default domain type: Translated
  170. [    0.452152] SCSI subsystem initialized
  171. [    0.456468] mc: Linux media inte**ce: v0.10
  172. [    0.460858] videodev: Linux video capture inte**ce: v2.00
  173. [    0.466539] pps_core: LinuxPPS API ver. 1 registered
  174. [    0.471614] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  175. [    0.480962] PTP clock support registered
  176. [    0.484999] EDAC MC: Ver: 3.0.0
  177. [    0.488814] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
  178. [    0.495975] FPGA manager framework
  179. [    0.499545] Advanced Linux Sound Architecture Driver Initialized.
  180. [    0.506613] clocksource: Switched to clocksource arch_sys_counter
  181. [    0.513074] VFS: Disk quotas dquot_6.6.0
  182. [    0.517141] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  183. [    0.529459] NET: Registered protocol family 2
  184. [    0.534209] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  185. [    0.542938] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  186. [    0.551711] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  187. [    0.559919] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  188. [    0.567646] TCP: Hash tables configured (established 16384 bind 16384)
  189. [    0.574533] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  190. [    0.581426] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  191. [    0.588904] NET: Registered protocol family 1
  192. [    0.593835] RPC: Registered named UNIX socket transport module.
  193. [    0.599908] RPC: Registered udp transport module.
  194. [    0.604745] RPC: Registered tcp transport module.
  195. [    0.609557] RPC: Registered tcp NFSv4.1 backchannel transport module.
  196. [    0.616152] PCI: CLS 0 bytes, default 64
  197. [    0.620930] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  198. [    0.633073] Initialise system trusted keyrings
  199. [    0.637840] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  200. [    0.648080] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  201. [    0.654649] NFS: Registering the id_resolver key type
  202. [    0.659865] Key type id_resolver registered
  203. [    0.664141] Key type id_legacy registered
  204. [    0.668293] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  205. [    0.675147] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
  206. [    0.682901] 9p: Installing v9fs 9p2000 file system support
  207. [    0.723400] Key type asymmetric registered
  208. [    0.727597] Asymmetric key parser 'x509' registered
  209. [    0.732621] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
  210. [    0.740186] io scheduler mq-deadline registered
  211. [    0.744815] io scheduler kyber registered
  212. [    0.750952] pinctrl-single 4084000.pinctrl: 34 pins, size 136
  213. [    0.757300] pinctrl-single f4000.pinctrl: 171 pins, size 684
  214. [    0.770433] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
  215. [    0.790176] brd: module loaded
  216. [    0.800353] loop: module loaded
  217. [    0.804559] megasas: 07.714.04.00-rc1
  218. [    0.811947] tun: Universal TUN/TAP device driver, 1.6
  219. [    0.817663] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  220. [    0.824079] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  221. [    0.830205] sky2: driver version 1.30
  222. [    0.834884] VFIO - User Level meta-driver version: 0.3
  223. [    0.841079] i2c /dev entries driver
  224. [    0.846295] sdhci: Secure Digital Host Controller Inte**ce driver
  225. [    0.852627] sdhci: Copyright(c) Pierre Ossman
  226. [    0.857395] sdhci-pltfm: SDHCI platform and OF driver helper
  227. [    0.864283] ledtrig-cpu: registered to indicate activity on CPUs
  228. [    0.870793] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  229. [    0.878447] optee: probing for conduit method.
  230. [    0.883040] optee: revision 3.17 (15a746d2)
  231. [    0.883312] optee: dynamic shared memory is enabled
  232. [    0.892831] optee: initialized driver
  233. [    0.898545] NET: Registered protocol family 17
  234. [    0.903267] 9pnet: Installing 9P2000 support
  235. [    0.907711] Key type dns_resolver registered
  236. [    0.912236] Loading compiled-in X.509 certificates
  237. [    0.928692] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.2--v08.04.02 (Jolly Jellyfi')
  238. [    1.700850] davinci-mcasp 2b00000.mcasp: IRQ common not found
  239. [    1.751061] omap_i2c 4900000.i2c: bus 0 rev0.12 at 100 kHz
  240. [    1.761378] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 100 kHz
  241. [    1.769076] omap_i2c 20010000.i2c: bus 2 rev0.12 at 400 kHz
  242. [    1.776636] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
  243. [    1.783581] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
  244. [    1.789636] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
  245. [    1.797960] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
  246. [    1.807193] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
  247. [    1.854119] ti-bcdma 485c0100.dma-controller: Number of rings: 82
  248. [    1.872518] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
  249. [    1.883674] ti-pktdma 485c0000.dma-controller: Number of rings: 150
  250. [    1.893649] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
  251. [    1.903734] omap8250 4a00000.serial: failed to get alias
  252. [    1.910110] omap8250 2b300000.serial: failed to get alias
  253. [    1.921712] printk: console [ttyS2] disabled
  254. [    1.926155] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
  255. [    1.934947] printk: console [ttyS2] enabled
  256. [    1.934947] printk: console [ttyS2] enabled
  257. [    1.943398] printk: bootconsole [ns16550a0] disabled
  258. [    1.943398] printk: bootconsole [ns16550a0] disabled
  259. [    1.954511] omap8250 2810000.serial: failed to get alias
  260. [    1.960650] omap8250 2850000.serial: failed to get alias
  261. [    2.003731] spi spi0.0: setup: ignoring unsupported mode bits 200
  262. [    2.010119] spi-nor spi0.0: w25q128 (16384 Kbytes)
  263. [    2.048622] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
  264. [    2.094638] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
  265. [    2.104834] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver unknown
  266. [    2.112680] davinci_mdio 8000f00.mdio: phy[2]: device 8000f00.mdio:02, driver unknown
  267. [    2.120638] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
  268. [    2.133554] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
  269. [    2.139822] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
  270. [    2.146944] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
  271. [    2.158924] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
  272. [    2.271595] cpufreq: cpufreq_online: ->get() failed
  273. [    2.277152] cpufreq: cpufreq_online: ->get() failed
  274. [    2.282658] cpufreq: cpufreq_online: ->get() failed
  275. [    2.288100] cpufreq: cpufreq_online: ->get() failed
  276. [    2.357657] davinci-mcasp 2b00000.mcasp: IRQ common not found
  277. [    2.363142] mmc0: CQHCI version 5.10
  278. [    2.408145] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
  279. [    2.482410] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
  280. [    2.509871] mmc0: Command Queue Engine enabled
  281. [    2.514350] mmc0: new HS200 MMC card at address 0001
  282. [    2.519983] mmcblk0: mmc0:0001 88A398 7.28 GiB
  283. [    2.524714] mmcblk0boot0: mmc0:0001 88A398 partition 1 4.00 MiB
  284. [    2.530811] mmcblk0boot1: mmc0:0001 88A398 partition 2 4.00 MiB
  285. [    2.536905] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (237:0)
  286. [    2.545282]  mmcblk0: p1 p2
  287. [    2.795389] ALSA device list:
  288. [    2.798363]   No soundcards found.
  289. [    2.801344] mmc2: CQHCI version 5.10
  290. [    2.841114] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
  291. [    2.848743] mmc1: CQHCI version 5.10
  292. [    2.893623] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
  293. [    2.896287] mmc2: new ultra high speed SDR104 SDIO card at address 0001
  294. [    2.901824] Waiting for root device PARTUUID=6ed93013-02...
  295. [    2.942455] mmc1: error -110 whilst initialising SD card
  296. [    3.111806] mmc1: new high speed SDHC card at address 0001
  297. [    3.117999] mmcblk1: mmc1:0001 SD16G 14.9 GiB
  298. [    3.124061]  mmcblk1: p1 p2
  299. [    3.270911] EXT4-fs (mmcblk1p2): recovery complete
  300. [    3.277002] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
  301. [    3.285163] VFS: Mounted root (ext4 filesystem) on device 179:98.
  302. [    3.291391] devtmpfs: mounted
  303. [    3.295600] Freeing unused kernel memory: 1792K
  304. [    3.300221] Run /sbin/init as init process
  305. INIT: version 3.01 booting
  306. Starting udev
  307. [    3.796231] udevd[198]: starting version 3.2.10
  308. [    3.809565] random: udevd: uninitialized urandom read (16 bytes read)
  309. [    3.816715] random: udevd: uninitialized urandom read (16 bytes read)
  310. [    3.823949] random: udevd: uninitialized urandom read (16 bytes read)
  311. [    3.859661] udevd[199]: starting eudev-3.2.10
  312. [    4.193212] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
  313. hwclock: can't open '/dev/misc/rtc': No such file or directory
  314. Fri Mar  9 12:34:56 UTC 2018
  315. hwclock: can't open '/dev/misc/rtc': No such file or directory
  316. INIT: Entering runlevel: 5
  317. Configuring network inte**ces... [    4.554914] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
  318. [    4.565978] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
  319. [    4.576500] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:01] driver [Generic PHY] (irq=POLL)
  320. [    4.585940] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
  321. udhcpc: started, v1.35.0
  322. udhcpc: broadcasting discover
  323. udhcpc: broadcasting discover
  324. udhcpc: broadcasting discover
  325. udhcpc: no lease, forking to background
  326. done.
  327. hwclock: can't open '/dev/misc/rtc': No such file or directory
  328. Starting syslogd/klogd: done
  329. Poky (Yocto Project Reference Distro) 4.0.4 ok6254c /dev/ttyS2
  330. ok6254c login: root
  331. root@ok6254c:~#
复制代码
楼主| kunyi 发表于 2022-11-9 17:12:12 | 显示全部楼层
增加 WIFI 与 YT8521 Gbits PHY 支援
  1. U-Boot SPL 2021.01-g6c60769028 (Nov 09 2022 - 06:43:59 +0000)
  8. I/TC:
  16. U-Boot SPL 2021.01-g6c60769028 (Nov 09 2022 - 06:43:59 +0000)
  18. U-Boot 2021.01-g6c60769028 (Nov 09 2022 - 06:43:59 +0000)
  19. SoC:   AM62X SR1.0 GP
  20. Model: Forlinx OK6254-C
  21. DRAM:  2 GiB
  22. MMC:   mmc@fa10000: 0, mmc@fa00000: 1
  23. Loading Environment from EXT4... Loading Environment from FAT... OK
  24. Net:   eth0: ethernet@8000000port@1
  25. Hit any key to stop autoboot:  0
  26. switch to partitions #0, OK
  27. mmc1 is current device
  28. SD/MMC found on device 1
  29. Failed to load 'boot.scr'
  30. Failed to load 'uEnv.txt'
  31. 18364928 bytes read in 771 ms (22.7 MiB/s)
  32. 52813 bytes read in 7 ms (7.2 MiB/s)
  33. ## Flattened Device Tree blob at 88000000
  34.    Booting using the fdt blob at 0x88000000
  35.    Loading Device Tree to 000000008fef0000, end 000000008fffffff ... OK
  36. Starting kernel ...
  37. [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  38. [    0.000000] Linux version 5.10.140-g9345e71d46 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Nov 9 08:17:45 UTC 2022
  39. [    0.000000] Machine model: Forlinx OK6254-C Dev. Board
  40. [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
  41. [    0.000000] printk: bootconsole [ns16550a0] enabled
  42. [    0.000000] efi: UEFI not found.
  43. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
  44. [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
  45. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
  46. [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
  47. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 13 MiB
  48. [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
  49. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009d900000, size 1 MiB
  50. [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9d900000, compatible id shared-dma-pool
  51. [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 13 MiB
  52. [    0.000000] OF: reserved mem: initialized node r5f-memory@9da00000, compatible id shared-dma-pool
  53. [    0.000000] Zone ranges:
  54. [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
  55. [    0.000000]   DMA32    empty
  56. [    0.000000]   Normal   empty
  57. [    0.000000] Movable zone start for each node
  58. [    0.000000] Early memory node ranges
  59. [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
  60. [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
  61. [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
  62. [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
  63. [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
  64. [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
  65. [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
  66. [    0.000000] psci: probing for conduit method from DT.
  67. [    0.000000] psci: PSCIv1.1 detected in firmware.
  68. [    0.000000] psci: Using standard PSCI v0.2 function IDs
  69. [    0.000000] psci: Trusted OS migration not required
  70. [    0.000000] psci: SMC Calling Convention v1.2
  71. [    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
  72. [    0.000000] Detected VIPT I-cache on CPU0
  73. [    0.000000] CPU features: detected: ARM erratum 845719
  74. [    0.000000] CPU features: detected: GIC system register CPU inte**ce
  75. [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
  76. [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=89063919-02 rw rootfstype=ext4 rootwait
  77. [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  78. [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  79. [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  80. [    0.000000] Memory: 1456632K/2097152K available (10816K kernel code, 1102K rwdata, 4096K rodata, 1792K init, 430K bss, 116232K reserved, 524288K cma-reserved)
  81. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  82. [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  83. [    0.000000] rcu:     RCU event tracing is enabled.
  84. [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
  85. [    0.000000]  Trampoline variant of Tasks RCU enabled.
  86. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  87. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  88. [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  89. [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
  90. [    0.000000] GICv3: 256 SPIs implemented
  91. [    0.000000] GICv3: 0 Extended SPIs implemented
  92. [    0.000000] GICv3: Distributor has no Range Selector support
  93. [    0.000000] GICv3: 16 PPIs implemented
  94. [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
  95. [    0.000000] ITS [mem 0x01820000-0x0182ffff]
  96. [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
  97. [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
  98. [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
  99. [    0.000000] ITS: using cache flushing for cmd queue
  100. [    0.000000] GICv3: using LPI property table @0x0000000080040000
  101. [    0.000000] GIC: using cache flushing for LPI property table
  102. [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
  103. [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
  104. [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
  105. [    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
  106. [    0.008507] Console: colour dummy device 80x25
  107. [    0.013098] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
  108. [    0.023780] pid_max: default: 32768 minimum: 301
  109. [    0.028583] LSM: Security Framework initializing
  110. [    0.033370] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  111. [    0.040950] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  112. [    0.050695] rcu: Hierarchical SRCU implementation.
  113. [    0.055880] Platform MSI: msi-controller@1820000 domain created
  114. [    0.062172] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
  115. [    0.071413] EFI services will not be available.
  116. [    0.076336] smp: Bringing up secondary CPUs ...
  117. I/TC: Secondary CPU 1 initializing
  118. I/TC: Secondary CPU 1 switching to normal world boot
  119. I/TC: Secondary CPU 2 initializing
  120. I/TC: Secondary CPU 2 switching to normal world boot
  121. I/TC: Secondary CPU 3 initializing
  122. I/TC: Secondary CPU 3 switching to normal world boot
  123. [    0.100280] Detected VIPT I-cache on CPU1
  124. [    0.100316] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
  125. [    0.100330] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
  126. [    0.100393] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  127. [    0.119651] Detected VIPT I-cache on CPU2
  128. [    0.119678] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
  129. [    0.119689] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
  130. [    0.119727] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  131. [    0.138933] Detected VIPT I-cache on CPU3
  132. [    0.138955] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
  133. [    0.138966] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
  134. [    0.139000] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  135. [    0.139074] smp: Brought up 1 node, 4 CPUs
  136. [    0.218787] SMP: Total of 4 processors activated.
  137. [    0.223598] CPU features: detected: 32-bit EL0 Support
  138. [    0.228867] CPU features: detected: CRC32 instructions
  139. [    0.241230] CPU: All CPU(s) started at EL2
  140. [    0.245438] alternatives: patching kernel code
  141. [    0.251117] devtmpfs: initialized
  142. [    0.261033] KASLR disabled due to lack of seed
  143. [    0.265783] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  144. [    0.275760] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  145. [    0.297260] pinctrl core: initialized pinctrl subsystem
  146. [    0.303284] DMI not present or invalid.
  147. [    0.307870] NET: Registered protocol family 16
  148. [    0.314032] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  149. [    0.321379] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  150. [    0.329451] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  151. [    0.338154] thermal_sys: Registered thermal governor 'step_wise'
  152. [    0.338159] thermal_sys: Registered thermal governor 'power_allocator'
  153. [    0.344796] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  154. [    0.358516] ASID allocator initialised with 65536 entries
  155. [    0.387187] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  156. [    0.394064] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  157. [    0.400916] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  158. [    0.407766] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  159. [    0.415664] cryptd: max_cpu_qlen set to 1000
  160. [    0.422907] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
  161. [    0.431985] vcc_5v0: supplied by vcc_12v0
  162. [    0.436482] vcc_3v3: supplied by vcc_5v0
  163. [    0.440861] vdd_mmc1: supplied by vcc_3v3
  164. [    0.445919] iommu: Default domain type: Translated
  165. [    0.451256] SCSI subsystem initialized
  166. [    0.455598] mc: Linux media inte**ce: v0.10
  167. [    0.459989] videodev: Linux video capture inte**ce: v2.00
  168. [    0.465664] pps_core: LinuxPPS API ver. 1 registered
  169. [    0.470739] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  170. [    0.480086] PTP clock support registered
  171. [    0.484121] EDAC MC: Ver: 3.0.0
  172. [    0.487962] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
  173. [    0.495114] FPGA manager framework
  174. [    0.498686] Advanced Linux Sound Architecture Driver Initialized.
  175. [    0.505763] clocksource: Switched to clocksource arch_sys_counter
  176. [    0.512216] VFS: Disk quotas dquot_6.6.0
  177. [    0.516284] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  178. [    0.528575] NET: Registered protocol family 2
  179. [    0.533324] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  180. [    0.542061] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  181. [    0.550837] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  182. [    0.559051] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  183. [    0.566794] TCP: Hash tables configured (established 16384 bind 16384)
  184. [    0.573687] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  185. [    0.580584] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  186. [    0.588068] NET: Registered protocol family 1
  187. [    0.592980] RPC: Registered named UNIX socket transport module.
  188. [    0.599056] RPC: Registered udp transport module.
  189. [    0.603892] RPC: Registered tcp transport module.
  190. [    0.608704] RPC: Registered tcp NFSv4.1 backchannel transport module.
  191. [    0.615300] PCI: CLS 0 bytes, default 64
  192. [    0.620071] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  193. [    0.632216] Initialise system trusted keyrings
  194. [    0.636983] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  195. [    0.647237] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  196. [    0.653779] NFS: Registering the id_resolver key type
  197. [    0.658980] Key type id_resolver registered
  198. [    0.663256] Key type id_legacy registered
  199. [    0.667416] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  200. [    0.674270] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
  201. [    0.682027] 9p: Installing v9fs 9p2000 file system support
  202. [    0.722304] Key type asymmetric registered
  203. [    0.726500] Asymmetric key parser 'x509' registered
  204. [    0.731524] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
  205. [    0.739090] io scheduler mq-deadline registered
  206. [    0.743720] io scheduler kyber registered
  207. [    0.749857] pinctrl-single 4084000.pinctrl: 34 pins, size 136
  208. [    0.756211] pinctrl-single f4000.pinctrl: 171 pins, size 684
  209. [    0.769351] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
  210. [    0.789121] brd: module loaded
  211. [    0.799275] loop: module loaded
  212. [    0.803475] megasas: 07.714.04.00-rc1
  213. [    0.809686] tun: Universal TUN/TAP device driver, 1.6
  214. [    0.816094] VFIO - User Level meta-driver version: 0.3
  215. [    0.822189] i2c /dev entries driver
  216. [    0.827379] sdhci: Secure Digital Host Controller Inte**ce driver
  217. [    0.833734] sdhci: Copyright(c) Pierre Ossman
  218. [    0.838506] sdhci-pltfm: SDHCI platform and OF driver helper
  219. [    0.845296] ledtrig-cpu: registered to indicate activity on CPUs
  220. [    0.851790] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
  221. [    0.859486] optee: probing for conduit method.
  222. [    0.864087] optee: revision 3.17 (15a746d2)
  223. [    0.864359] optee: dynamic shared memory is enabled
  224. [    0.873881] optee: initialized driver
  225. [    0.879631] NET: Registered protocol family 17
  226. [    0.884339] 9pnet: Installing 9P2000 support
  227. [    0.888786] Key type dns_resolver registered
  228. [    0.893302] Loading compiled-in X.509 certificates
  229. [    0.909971] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.2--v08.04.02 (Jolly Jellyfi')
  230. [    1.687242] davinci-mcasp 2b00000.mcasp: IRQ common not found
  231. [    1.737441] omap_i2c 4900000.i2c: bus 0 rev0.12 at 100 kHz
  232. [    1.747750] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 100 kHz
  233. [    1.754889] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
  234. [    1.761809] omap_i2c 20010000.i2c: bus 3 rev0.12 at 400 kHz
  235. [    1.791381] rtc-pcf8563 4-0051: registered as rtc0
  236. [    1.796644] rtc-pcf8563 4-0051: setting system clock to 2022-11-07T11:33:14 UTC (1667820794)
  237. [    1.805762] omap_i2c 20020000.i2c: bus 4 rev0.12 at 400 kHz
  238. [    1.812649] omap_i2c 20030000.i2c: bus 5 rev0.12 at 100 kHz
  239. [    1.818678] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
  240. [    1.827005] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
  241. [    1.836237] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
  242. [    1.883206] ti-bcdma 485c0100.dma-controller: Number of rings: 82
  243. [    1.901627] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
  244. [    1.912728] ti-pktdma 485c0000.dma-controller: Number of rings: 150
  245. [    1.922729] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
  246. [    1.932762] omap8250 4a00000.serial: failed to get alias
  247. [    1.939151] omap8250 2b300000.serial: failed to get alias
  248. [    1.950683] printk: console [ttyS2] disabled
  249. [    1.955125] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
  250. [    1.963910] printk: console [ttyS2] enabled
  251. [    1.963910] printk: console [ttyS2] enabled
  252. [    1.972358] printk: bootconsole [ns16550a0] disabled
  253. [    1.972358] printk: bootconsole [ns16550a0] disabled
  254. [    1.983448] omap8250 2810000.serial: failed to get alias
  255. [    1.989605] omap8250 2850000.serial: failed to get alias
  256. [    2.032670] spi spi0.0: setup: ignoring unsupported mode bits 200
  257. [    2.039032] spi-nor spi0.0: w25q128 (16384 Kbytes)
  258. [    2.077486] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
  259. [    2.121793] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
  260. [    2.134068] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver YT8521 Gigabit Ethernet
  261. [    2.143289] davinci_mdio 8000f00.mdio: phy[2]: device 8000f00.mdio:02, driver YT8521 Gigabit Ethernet
  262. [    2.152599] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
  263. [    2.165509] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
  264. [    2.171776] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
  265. [    2.178900] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
  266. [    2.190877] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
  267. [    2.303569] cpufreq: cpufreq_online: ->get() failed
  268. [    2.309115] cpufreq: cpufreq_online: ->get() failed
  269. [    2.314593] cpufreq: cpufreq_online: ->get() failed
  270. [    2.320041] cpufreq: cpufreq_online: ->get() failed
  271. [    2.389639] davinci-mcasp 2b00000.mcasp: IRQ common not found
  272. [    2.421309] mmc0: CQHCI version 5.10
  273. [    2.465788] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
  274. [    2.514295] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
  275. [    2.570719] mmc0: Command Queue Engine enabled
  276. [    2.575199] mmc0: new HS200 MMC card at address 0001
  277. [    2.580868] mmcblk0: mmc0:0001 88A398 7.28 GiB
  278. [    2.585612] mmcblk0boot0: mmc0:0001 88A398 partition 1 4.00 MiB
  279. [    2.591711] mmcblk0boot1: mmc0:0001 88A398 partition 2 4.00 MiB
  280. [    2.597821] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (237:0)
  281. [    2.606440]  mmcblk0: p1 p2
  282. [    2.827400] ALSA device list:
  283. [    2.830402]   No soundcards found.
  284. [    2.833340] mmc2: CQHCI version 5.10
  285. [    2.843624] mmc1: CQHCI version 5.10
  286. [    2.873180] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
  287. [    2.888385] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
  288. [    2.896444] Waiting for root device PARTUUID=89063919-02...
  289. [    2.924863] mmc2: new ultra high speed SDR104 SDIO card at address 0001
  290. [    2.935198] mmc1: error -110 whilst initialising SD card
  291. [    3.104562] mmc1: new high speed SDHC card at address 0001
  292. [    3.110763] mmcblk1: mmc1:0001 SD16G 14.9 GiB
  293. [    3.116999]  mmcblk1: p1 p2 p3
  294. [    3.140757] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
  295. [    3.149003] VFS: Mounted root (ext4 filesystem) on device 179:98.
  296. [    3.158790] devtmpfs: mounted
  297. [    3.163040] Freeing unused kernel memory: 1792K
  298. [    3.167703] Run /sbin/init as init process
  299. INIT: version 3.01 booting
  300. Starting udev
  301. [    3.575384] udevd[198]: starting version 3.2.10
  302. [    3.610120] random: udevd: uninitialized urandom read (16 bytes read)
  303. [    3.617293] random: udevd: uninitialized urandom read (16 bytes read)
  304. [    3.624556] random: udevd: uninitialized urandom read (16 bytes read)
  305. [    3.660900] udevd[199]: starting eudev-3.2.10
  306. [    3.778203] CAN device driver inte**ce
  307. [    3.832759] at24 2-0051: supply vcc not found, using dummy regulator
  308. [    3.839767] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
  309. [    3.860651] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
  310. [    3.870264] at24 2-0051: 8192 byte 24c64 EEPROM, writable, 32 bytes/write
  311. [    3.898921] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
  312. [    3.899774] platform 78000000.r5f: could not request atcm region for resource
  313. [    3.913240] platform 78000000.r5f: failed to get internal memories, ret = -16
  314. [    3.920678] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_core_of_init failed, ret = -16
  315. [    3.929684] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_of_init failed, ret = -16
  316. [    3.933571] remoteproc remoteproc0: 5000000.m4fss is available
  317. [    3.939067] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -16
  318. [    3.939364] m_can_platform 20701000.can: m_can device registered (irq=39, version=32)
  319. [    3.948237] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
  320. [    3.970364] remoteproc remoteproc0: powering up 5000000.m4fss
  321. [    3.976473] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
  322. [    3.986288] remoteproc remoteproc0: request_firmware failed: -2
  323. [    4.194261] remoteproc remoteproc1: 30074000.pru is available
  324. [    4.201422] remoteproc remoteproc2: 30078000.pru is available
  325. [    4.231932] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
  326. [    4.311016] usbcore: registered new inte**ce driver usbfs
  327. [    4.316630] usbcore: registered new inte**ce driver hub
  328. [    4.322043] usbcore: registered new device driver usb
  329. [    4.347445] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  330. [    4.352982] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  331. [    4.360861] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
  332. [    4.370308] xhci-hcd xhci-hcd.0.auto: irq 477, io mem 0x31100000
  333. [    4.376609] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  334. [    4.384875] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  335. [    4.392151] usb usb1: Product: xHCI Host Controller
  336. [    4.397030] usb usb1: Manufacturer: Linux 5.10.140-g9345e71d46 xhci-hcd
  337. [    4.403638] usb usb1: SerialNumber: xhci-hcd.0.auto
  338. [    4.409097] hub 1-0:1.0: USB hub found
  339. [    4.412901] hub 1-0:1.0: 1 port detected
  340. [    4.417871] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  341. [    4.424366] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  342. [    4.432110] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  343. [    4.438732] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  344. [    4.446914] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  345. [    4.455168] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  346. [    4.462386] usb usb2: Product: xHCI Host Controller
  347. [    4.467257] usb usb2: Manufacturer: Linux 5.10.140-g9345e71d46 xhci-hcd
  348. [    4.473863] usb usb2: SerialNumber: xhci-hcd.0.auto
  349. [    4.479281] hub 2-0:1.0: USB hub found
  350. [    4.483077] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  351. [    4.516066] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
  352. [    4.614653] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  353. [    4.663918] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  354. [    4.673849] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  355. [    4.707359] mlan: loading out-of-tree module taints kernel.
  356. [    4.784301] wlan: Loading MWLAN driver
  357. [    4.788572] wlan: Register to Bus Driver...
  358. [    4.826043] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
  359. [    4.834231] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  360. [    4.841364] usb 1-1: Product: USB 2.0 Hub
  361. [    4.885691] vendor=0x02DF device=0x9149 class=0 function=1
  362. [    4.887327] hub 1-1:1.0: USB hub found
  363. [    4.895035] Attach moal handle ops, card inte**ce type: 0x105
  364. [    4.895070] hub 1-1:1.0: 4 ports detected
  365. [    4.905967] SD8987: init module param from usr cfg
  366. [    4.910839] card_type: SD8987, config block: 0
  367. [    4.915298] cfg80211_wext=0xf
  368. [    4.918266] max_vir_bss=1
  369. [    4.920880] cal_data_cfg=none
  370. [    4.923845] ps_mode = 1
  371. [    4.926290] auto_ds = 1
  372. [    4.928733] host_mlme=enable
  373. [    4.931611] fw_name=nxp/sdiouart8987_combo_v0.bin
  374. [    4.936321] sta_name=wlan
  375. [    4.938940] uap_name=uap
  376. [    4.941462] wfd_name=p2p
  377. [    4.944020] SDIO: max_segs=128 max_seg_size=65536
  378. [    4.948719] rx_work=1 cpu_num=4
  379. [    4.951890] Attach mlan adapter operations.card_type is 0x105.
  380. [    4.958158] wlan: Enable TX SG mode
  381. [    4.961637] wlan: Enable RX SG mode
  382. [    4.965851] Request firmware: nxp/sdiouart8987_combo_v0.bin
  383. [    5.330319] Wlan: FW download over, firmwarelen=595196 downloaded 595196
  384. [    6.197812] WLAN FW is active
  385. [    6.200776] on_time is 6091032655
  386. [    6.267875] fw_cap_info=0x181d7f03, dev_cap_mask=0xffffffff
  387. [    6.273465] max_p2p_conn = 8, max_sta_conn = 8
  388. [    6.278252] SDIO rx aggr: 1 block_size=512
  389. [    6.282386] wlan: Enable RX SG mode
  390. [    6.285869] mpa_rx_buf_size=65280
  391. [    6.307307] wlan: version = SD8987----16.92.21.p41.3-MM5X16322.p3-(FP92)
  392. [    6.315811] wlan: Register to Bus Driver Done
  393. [    6.320230] wlan: Driver loaded successfully
  394. [    6.852792] random: dd: uninitialized urandom read (512 bytes read)
  395. Configuring packages on first boot....
  396. (This may take several minutes. Please do not power off the machine.)
  397. Running postinst /etc/ipk-postinsts/000-sysvinit-inittab...
  398. update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
  399. Removing any system startup links for run-postinsts ...
  400.   /etc/rcS.d/S99run-postinsts
  401. INIT: Entering runlevel: 5
  402. Configuring network inte**ces... [    7.058855] am65-cpsw-nuss 8000000.ethernet: down msc_sl e0000000 tmo 0
  403. [    7.070242] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
  404. [    7.083868] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:01] driver [YT8521 Gigabit Ethernet] (irq=POLL)
  405. [    7.094324] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
  406. udhcpc: started, v1.35.0
  407. udhcpc: broadcasting discover
  408. udhcpc: broadcasting discover
  409. [   11.178653] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
  410. udhcpc: broadcasting discover
  411. udhcpc: broadcasting select for 10.42.0.93, server 10.42.0.1
  412. udhcpc: lease of 10.42.0.93 obtained from 10.42.0.1, lease time 3600
  413. /etc/udhcpc.d/50default: Adding DNS 10.42.0.1
  414. done.
  415. [   13.562894] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
  416. [   13.570059] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
  417. Starting system message bus: [   13.623671] random: dbus-daemon: uninitialized urandom read (12 bytes read)
  418. dbus.
  419. Starting HOSTAP Daemon: [   13.847635] wlan: Starting AP
  420. [   13.851658] fw doesn't support 11ax
  421. [   13.866238] wlan: AP started
  422. [   13.869919] wlan: HostMlme uap0 send deauth/disassoc
  423. [   13.875009] Set AC=3, txop=47 cwmin=3, cwmax=7 aifs=1
  424. [   13.882085] Set AC=2, txop=94 cwmin=7, cwmax=15 aifs=1
  425. [   13.889233] Set AC=0, txop=0 cwmin=15, cwmax=63 aifs=3
  426. [   13.896377] Set AC=1, txop=0 cwmin=15, cwmax=1023 aifs=7
  427. uap0: inte**ce state UNINITIALIZED->ENABLED
  428. uap0: AP-ENABLED
  429. hostapd.
  430. Starting syslogd/klogd: done
  431. Poky (Yocto Project Reference Distro) 4.0.5 ok6254c /dev/ttyS2
  432. ok6254c login: [  102.076265] random: crng init done
  433. [  102.079713] random: 10 urandom warning(s) missed due to ratelimiting
复制代码
头像被屏蔽
zuanlin 发表于 2023-4-12 11:01:57 | 显示全部楼层
AM62x通行证
KyleChen9999 发表于 2025-1-7 08:58:16 | 显示全部楼层
:handshake
牛人,感谢分享。
