查看: 7359|回复: 3
[Linux] 重新打包的ubi系统,启动时提示devtmpfs: error mounting -2
A40i\T3\T507\T527通行证i.MX6Q通行证AM335x通行证
gavin_guo 发表于 2022-11-2 18:11:41 | 显示全部楼层 |阅读模式
NAND read: device 0 offset 0xc00000, size 0x500000
5242880 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
   Image Name:   Linux-3.2.0-00020-g817881b-dirty
   Data Size:    3912584 Bytes = 3.7 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 3.2.0-00020-g817881b-dirty (lijianbin@developer-RH2485-V2) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Thu Mar 17 14:02:12 CST 2022
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,4096 rootfstype=ubifs rootwait=1 screentype=R screensize=800x480-7 calibrate=Y laohua=N
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 511620k/511620k available, 12668k reserved, 0K highmem
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0702000   (7144 kB)
[    0.000000]       .init : 0xc0702000 - 0xc0745000   ( 268 kB)
[    0.000000]       .data : 0xc0746000 - 0xc07bdc08   ( 480 kB)
[    0.000000]        .bss : 0xc07bdc2c - 0xc07f09a8   ( 204 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000194] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.057159] pid_max: default: 32768 minimum: 301
[    0.057288] Security Framework initialized
[    0.057393] Mount-cache hash table entries: 512
[    0.057787] CPU: Testing write buffer coherency: ok
[    0.058553] devtmpfs: initialized
[    0.078571] omap_hwmod: pruss: failed to hardreset
[    0.079684] print_constraints: dummy:
[    0.080049] NET: Registered protocol family 16
[    0.082180] OMAP GPIO hardware version 0.1
[    0.084750] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086642]  omap_i2c.1: alias fck already exists
[    0.087842]  omap_hsmmc.0: alias fck already exists
[    0.088117]  omap_hsmmc.1: alias fck already exists
[    0.088721]  da8xx_lcdc.0: alias fck already exists
[    0.089021]  omap_i2c.2: alias fck already exists
[    0.090608]  d_can.0: alias fck already exists
[    0.090904]  davinci-mcasp.1: alias fck already exists
[    0.092168]  omap2_mcspi.1: alias fck already exists
[    0.092394]  omap2_mcspi.2: alias fck already exists
[    0.092656]  edma.0: alias fck already exists
[    0.092677]  edma.0: alias fck already exists
[    0.092696]  edma.0: alias fck already exists
[    0.127151] bio: create slab <bio-0> at 0
[    0.129457] SCSI subsystem initialized
[    0.131462] usbcore: registered new inte**ce driver usbfs
[    0.131768] usbcore: registered new inte**ce driver hub
[    0.131973] usbcore: registered new device driver usb
[    0.132289] registerd cppi-dma Intr @ IRQ 17
[    0.132305] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[    0.132315] Cppi41 Init Done
[    0.132342] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.132647] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.147226] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.148985] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[    0.151005] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[    0.153041] print_constraints: DCDC2: 900 <--> 3300 mV at 1100 mV
[    0.155020] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[    0.156991] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[    0.158999] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[    0.160982] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[    0.162972] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[    0.177228] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.178780] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.179518] Bluetooth: Core ver 2.16
[    0.179701] NET: Registered protocol family 31
[    0.179714] Bluetooth: HCI device and connection manager initialized
[    0.179730] Bluetooth: HCI socket layer initialized
[    0.179741] Bluetooth: L2CAP socket layer initialized
[    0.179769] Bluetooth: SCO socket layer initialized
[    0.180350] cfg80211: Calling CRDA to update world regulatory domain
[    0.181534] Switching to clocksource gp timer
[    0.199410] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.199619] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.199962] MUSB0 controller's USBSS revision = 4ea20800
[    0.199997] musb0: Enabled SW babble control
[    0.200938] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083e000 using DMA, IRQ 18
[    0.201102] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.201403] MUSB1 controller's USBSS revision = 4ea20800
[    0.201432] musb1: Enabled SW babble control
[    0.201943] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.202035] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.202180] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.202196] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.202210] usb usb1: Product: MUSB HDRC host driver
[    0.202220] usb usb1: Manufacturer: Linux 3.2.0-00020-g817881b-dirty musb-hcd
[    0.202233] usb usb1: SerialNumber: musb-hdrc.1
[    0.203210] hub 1-0:1.0: USB hub found
[    0.203241] hub 1-0:1.0: 1 port detected
[    0.203849] musb-hdrc musb-hdrc.1: USB Host mode controller at e084a800 using DMA, IRQ 19
[    0.204296] NET: Registered protocol family 2
[    0.204501] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.204883] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.205178] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.205353] TCP: Hash tables configured (established 16384 bind 16384)
[    0.205366] TCP reno registered
[    0.205378] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.205401] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.205592] NET: Registered protocol family 1
[    0.205866] RPC: Registered named UNIX socket transport module.
[    0.205880] RPC: Registered udp transport module.
[    0.205889] RPC: Registered tcp transport module.
[    0.205898] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.206124] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.206353] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.225906] VFS: Disk quotas dquot_6.5.2
[    0.225980] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.226568] msgmni has been set to 999
[    0.229729] alg: No test for stdrng (krng)
[    0.229804] io scheduler noop registered
[    0.229814] io scheduler deadline registered
[    0.229912] io scheduler cfq registered (default)
[    0.231470] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-7.0-ATXI#-T-1 panel
[    0.232590] LCD Clock: 300000000 Divider: 7 PixClk: 40000000
[    0.242038] Console: switching to colour frame buffer device 100x30
[    0.249192] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.988078] console [ttyO0] enabled
[    0.992463] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    1.000345] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    1.008245] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    1.016121] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    1.023976] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.042140] brd: module loaded
[    1.050581] loop: module loaded
[    1.054365] i2c-core: driver [tsl2550] using legacy suspend method
[    1.060815] i2c-core: driver [tsl2550] using legacy resume method
[    1.067558] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.078044] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.085436] omap2-nand driver initializing
[    1.089810] info->phys_base 8000000
[    1.093545] ONFI flash detected
[    1.096938] ONFI param page 0 valid
[    1.100581] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron MT29F8G08ABACAWP)
[    1.108945] omap2-nand: detected x8 NAND flash
[    1.113676] Page size 4096 Select ECC BCH16
[    1.118040] Nand ECC BCH16 HW
[    1.121498] Creating 8 MTD partitions on "omap2-nand.0":
[    1.127075] 0x000000000000-0x000000200000 : "SPL"
[    1.133728] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.140839] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.148022] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.155212] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.161950] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.169017] 0x000000c00000-0x000001400000 : "Kernel"
[    1.176428] 0x000001400000-0x000040000000 : "File System"
[    1.273787] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.282432] OneNAND driver initializing
[    1.287252] UBI: attaching mtd7 to ubi0
[    1.291273] UBI: physical eraseblock size:   262144 bytes (256 KiB)
[    1.297841] UBI: logical eraseblock size:    253952 bytes
[    1.303482] UBI: smallest flash I/O unit:    4096
[    1.308383] UBI: sub-page size:              1024
[    1.313294] UBI: VID header offset:          4096 (aligned 4096)
[    1.319556] UBI: data offset:                8192
[    1.425767] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[    1.432776] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.474160] hub 1-1:1.0: USB hub found
[    1.478151] hub 1-1:1.0: 4 ports detected
[    7.486617] UBI: max. sequence number:       0
[    7.549466] UBI: volume 0 ("rootfs") re-sized from 3717 to 3972 LEBs
[    7.557253] UBI: attached mtd7 to ubi0
[    7.561183] UBI: MTD device name:            "File System"
[    7.566935] UBI: MTD device size:            1004 MiB
[    7.572213] UBI: number of good PEBs:        4016
[    7.577116] UBI: number of bad PEBs:         0
[    7.581769] UBI: number of corrupted PEBs:   0
[    7.586403] UBI: max. allowed volumes:       128
[    7.591215] UBI: wear-leveling threshold:    4096
[    7.596129] UBI: number of internal volumes: 1
[    7.600761] UBI: number of user volumes:     1
[    7.605401] UBI: available PEBs:             0
[    7.610032] UBI: total number of reserved PEBs: 4016
[    7.615217] UBI: number of PEBs reserved for bad PEB handling: 40
[    7.621578] UBI: max/mean erase counter: 1/0
[    7.626030] UBI: image sequence number:  350749380
[    7.631117] UBI: background thread "ubi_bgt0d" started, PID 670
[    7.653086] CAN device driver inte**ce
[    7.657088] CAN bus driver for Bosch D_CAN controller 1.0
[    7.672380] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    8.701586] mcp251x spi2.0: MCP251x didn't enter in conf mode after reset
[    8.708755] mcp251x spi2.0: Probe failed
[    8.712873] mcp251x spi2.0: probe failed
[    8.782183] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    8.788641] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    8.813733] davinci_mdio.0: probed
[    8.817285] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    8.833555] PPP generic driver version 2.4.2
[    8.844323] PPP BSD Compression module registered
[    8.849231] PPP Deflate Compression module registered
[    8.863671] usbcore: registered new inte**ce driver zd1201
[    8.884337] usbcore: registered new inte**ce driver asix
[    8.890144] usbcore: registered new inte**ce driver cdc_ether
[    8.902228] usbcore: registered new inte**ce driver cdc_eem
[    8.914129] usbcore: registered new inte**ce driver dm9601
[    8.919989] cdc_ncm: 04-Aug-2011
[    8.932485] usbcore: registered new inte**ce driver cdc_ncm
[    8.944417] GobiNet: Quectel_WCDMA<E_Linux&Android_GobiNet_Driver_V1.3.0
[    8.963436] usbcore: registered new inte**ce driver GobiNet
[    8.969337] Initializing USB Mass Storage driver...
[    8.983472] usbcore: registered new inte**ce driver usb-storage
[    8.989742] USB Mass Storage support registered.
[    9.003712] usbcore: registered new inte**ce driver usbserial
[    9.024407] USB Serial support registered for generic
[    9.029855] usbcore: registered new inte**ce driver usbserial_generic
[    9.036678] usbserial: USB Serial Driver core
[    9.053263] USB Serial support registered for GSM modem (1-port)
[    9.071899] usbcore: registered new inte**ce driver option
[    9.077712] option: v0.7.2:USB Driver for GSM modems
[    9.091826] USB Serial support registered for Vizzini USB serial port
[    9.113527] usbcore: registered new inte**ce driver vizzini
[    9.119431] USB Driver for Vizzini USB serial port: v.1.1
[    9.125268]  gadget: Mass Storage Function, version: 2009/09/11
[    9.131445]  gadget: Number of LUNs=1
[    9.135287]  lun0: LUN: removable file: (no medium)
[    9.140397]  gadget: Mass Storage Gadget, version: 2009/09/11
[    9.146409]  gadget: userspace failed to provide iSerialNumber
[    9.152509]  gadget: g_mass_storage ready
[    9.156703] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    9.162309] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    9.170138] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    9.177244] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.184797] usb usb2: Product: MUSB HDRC host driver
[    9.189976] usb usb2: Manufacturer: Linux 3.2.0-00020-g817881b-dirty musb-hcd
[    9.197428] usb usb2: SerialNumber: musb-hdrc.0
[    9.223480] hub 2-0:1.0: USB hub found
[    9.227421] hub 2-0:1.0: 1 port detected
[    9.244507] mousedev: PS/2 mouse device common for all mice
[    9.262832] <<-GTP-INFO->> GTP driver installing...
[    9.274275] usbcore: registered new inte**ce driver usbtouchscreen
[    9.280963] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
[    9.302023] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    9.327888] rtc-ds1307: probe of 1-0068 failed with error -5
[    9.342828] rtc-pcf8563 1-0051: chip found, driver version 0.4.3
[    9.352090] rtc-pcf8563 1-0051: pcf8563_read_block_data: read error
[    9.358629] rtc-pcf8563 1-0051: pcf8563_probe:read error
[    9.364190] rtc-pcf8563: probe of 1-0051 failed with error -5
[    9.382131] forlinx rx8010_probe
[    9.423196] rtc-rx8010 1-0032: Update timer was detected
[    9.452596] rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
[    9.474054] i2c /dev entries driver
[    9.478397] Linux video capture inte**ce: v2.00
[    9.492533] usbcore: registered new inte**ce driver uvcvideo
[    9.498534] USB Video Class driver (1.1.1)
[    9.512533] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    9.519004] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    9.534498] usbcore: registered new inte**ce driver bcm203x
[    9.540406] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    9.564103] usbcore: registered new inte**ce driver btusb
[    9.593998] cpuidle: using governor ladder
[    9.598758] cpuidle: using governor menu
[    9.684312] usbcore: registered new inte**ce driver usbhid
[    9.690166] usbhid: USB HID core driver
[    9.694980] tiadc tiadc: attached adc driver
[    9.735599] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[    9.743412] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[    9.751096] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[    9.758782] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[    9.769339] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[   10.325332] ALSA device list:
[   10.328433]   #0: AM335X EVM
[   10.331432] oprofile: hardware counters not available
[   10.336740] oprofile: using timer interrupt.
[   10.341356] Netfilter messages via NETLINK v0.30.
[   10.346400] nf_conntrack version 0.5.0 (7994 buckets, 31976 max)
[   10.353070] ctnetlink v0.93: registering with nfnetlink.
[   10.394254] xt_time: kernel timezone is -0000
[   10.399041] ip_tables: (C) 2000-2006 Netfilter Core Team
[   10.404823] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[   10.411530] arp_tables: (C) 2002 David S. Miller
[   10.416456] TCP cubic registered
[   10.419963] NET: Registered protocol family 10
[   10.425430] Mobile IPv6
[   10.427997] IPv6 over IPv4 tunneling driver
[   10.474669] NET: Registered protocol family 17
[   10.479345] can: controller area network core (rev 20090105 abi 8)
[   10.485984] NET: Registered protocol family 29
[   10.490641] can: raw protocol (rev 20090105)
[   10.495118] can: broadcast manager protocol (rev 20090105 t)
[   10.524383] Bluetooth: RFCOMM TTY layer initialized
[   10.529484] Bluetooth: RFCOMM socket layer initialized
[   10.534858] Bluetooth: RFCOMM ver 1.11
[   10.538767] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   10.544314] Bluetooth: BNEP filters: protocol multicast
[   10.549765] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[   10.556380] Registering the dns_resolver key type
[   10.561367] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[   10.569393] ThumbEE CPU extension supported.
[   10.573924] mux: Failed to setup hwmod io irq -22
[   10.579505] Power Management for AM33XX family
[   10.584426] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[   10.591096] Copied the M3 firmware to UMEM
[   10.595468] Cortex M3 Firmware Version = 0x181
[   10.637238] clock: disabling unused clocks to save power
[   10.665477] Detected MACID=a8:e7:7d:e5:76:3
[   10.671279] cpsw: Detected MACID = a8:e7:7d:e5:76:05
[   10.702380] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[   10.727704] rtc-rx8010 1-0032: setting system clock to 2021-08-23 04:52:17 UTC (1629694337)
[   11.024689] UBIFS: start fixing up free space
[   11.406558] UBIFS: free space fixup complete
[   11.525047] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[   11.531333] UBIFS: file system size:   1004634112 bytes (981088 KiB, 958 MiB, 3956 LEBs)
[   11.539833] UBIFS: journal size:       9404416 bytes (9184 KiB, 8 MiB, 38 LEBs)
[   11.547475] UBIFS: media format:       w4/r0 (latest is w4/r0)
[   11.553566] UBIFS: default compressor: lzo
[   11.557835] UBIFS: reserved for root:  0 bytes (0 KiB)
[   11.571506] VFS: Mounted root (ubifs filesystem) on device 0:14.
[   11.577846] devtmpfs: error mounting -2
[   11.582277] Freeing init memory: 268K
ljb2019001 发表于 2022-11-7 10:03:37 | 显示全部楼层
根据报错帮您找了一个解决方法,检查一下是不是文件系统解压缩是出问题了https://blog.csdn.net/weixin_37723417/article/details/104531097
发现问题所在了,我先解压资料中的rootfs-qt.tar.bz2,然后再打包成ubi.img,烧录进去报同样的错误! sudo ./mkfs.ubifs -F -r rootfs-my -m 4096 -e 253952 -c 3966 -o ubifs.img sudo ./ubinize -v -o ubi.img -  详情 回复 发表于 2022-11-7 16:25
楼主| gavin_guo 发表于 2022-11-7 16:25:37 | 显示全部楼层
根据报错帮您找了一个解决方法,检查一下是不是文件系统解压缩是出问题了https://blog.csdn.net/weixin_377 ...
sudo ./ubinize -v -o ubi.img -p 262144 -m 4096 -s 4096 -O 4096 ubinize-1G.cfg
用这两条命令,先解压再打包那个支持硬浮点的最小文件系统,就可以正确加载文件系统,请问是哪里没有操作正确呢?
ljb2019001 发表于 2022-11-9 15:21:26 | 显示全部楼层
请问更换了开发环境后,使用我们的开发环境,问题解决了吗
