查看: 7508|回复: 2
[Linux] 用支持硬件浮点的编译器,编译内核的时候,脚本报错了
A40i\T3\T507\T527通行证i.MX6Q通行证AM335x通行证
gavin_guo 发表于 2022-11-7 15:58:43 | 显示全部楼层 |阅读模式
从资料中获取的4.7.3版本的带硬件浮点的编译器
ad8@ad8-virtual-machine:~/kernel-3.2$ make  ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- uImage -j4
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: 'include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  TIMEC   kernel/timeconst.h
Can't use 'defined(@array)' (Maybe you should just omit the defined()?) at kernel/timeconst.pl line 373.
/home/ad8/kernel-3.2/kernel/Makefile:141: recipe for target 'kernel/timeconst.h' failed
make[1]: *** [kernel/timeconst.h] Error 255
Makefile:945: recipe for target 'kernel' failed
make: *** [kernel] Error 2
make: *** Waiting for unfinished jobs....
ljb2019001 发表于 2022-11-15 08:58:23 | 显示全部楼层
根据报错把kernel/timeconst.pl 的 373行的 defined(@array)改成@array就好了
kaiden999 发表于 2023-1-27 12:12:07 | 显示全部楼层
