查看: 7299|回复: 3
[Linux] OKT507能不能打实时补丁
A40i\T3\T507\T527通行证i.MX8MM通行证
zloves2199 发表于 2022-11-12 12:35:12 | 显示全部楼层 |阅读模式
如题用的是patch-4.9.170-rt129.patch
打RT补丁的时候碰到问题
patch -p1 < ../patch-4.9.170-rt129.patch
patching file Documentation/sysrq.txt
patching file Documentation/trace/histograms.txt
patching file MAINTAINERS
patching file arch/Kconfig
patching file arch/arm/Kconfig
Hunk #1 succeeded at 37 (offset 1 line).
Hunk #2 succeeded at 76 (offset 1 line).
Hunk #3 succeeded at 2230 (offset 72 lines).
patching file arch/arm/include/asm/irq.h
patching file arch/arm/include/asm/switch_to.h
patching file arch/arm/include/asm/thread_info.h
patching file arch/arm/kernel/asm-offsets.c
patching file arch/arm/kernel/entry-armv.S
patching file arch/arm/kernel/entry-common.S
Hunk #1 succeeded at 41 with fuzz 2 (offset 4 lines).
Hunk #2 succeeded at 71 with fuzz 2 (offset 7 lines).
patching file arch/arm/kernel/process.c
Hunk #1 succeeded at 324 (offset 2 lines).
patching file arch/arm/kernel/signal.c
Hunk #1 succeeded at 582 (offset 1 line).
patching file arch/arm/kernel/smp.c
patching file arch/arm/kvm/arm.c
patching file arch/arm/mach-exynos/platsmp.c
patching file arch/arm/mach-hisi/platmcpm.c
patching file arch/arm/mach-omap2/omap-smp.c
patching file arch/arm/mach-prima2/platsmp.c
patching file arch/arm/mach-qcom/platsmp.c
patching file arch/arm/mach-spear/platsmp.c
patching file arch/arm/mach-sti/platsmp.c
patching file arch/arm/mm/fault.c
patching file arch/arm/mm/highmem.c
patching file arch/arm/plat-versatile/platsmp.c
patching file arch/arm64/Kconfig
Hunk #1 succeeded at 92 (offset 1 line).
Hunk #2 succeeded at 720 (offset 2 lines).
patching file arch/arm64/crypto/Kconfig
patching file arch/arm64/include/asm/thread_info.h
Hunk #1 FAILED at 49.
Hunk #2 FAILED at 113.
Hunk #3 succeeded at 102 (offset -28 lines).
Hunk #4 FAILED at 138.
后边还有很多失败的地方,不知道你们有没有碰到过
A40i\T3\T507\T527通行证i.MX6Q通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3588通行证RK3399通行证LS1028A通行证G2L通行证LS1012A通行证LS1043A\46A通行证TCU通行证FDU产品通行证FCU1401通行证FCU1301通行证FCU11xx通行证FCU1201通行证FCU2201通行证FCU1106通行证FCU2301\FCU2302通行证FCU2401通行证5G转接卡通行证FCU3001通行证AM5718通行证Hi3519A通行证AM335x通行证i.MX RT通行证XX18通行证AM62x通行证FDU070K02\FDU101K02通行证i.MX9352\i.MX9131通行证2K0300\2K0500通行证JH7110通行证T113i通行证D9360通行证FCU2601通行证FCU1303通行证RK3576通行证RK3562通行证MA35通行证RK3506通行证T536通行证i.MX8MPx-SMARC通行证FCU3011通行证FCU3501通行证
香飘飘~~~ 发表于 2022-11-22 16:55:30 | 显示全部楼层
很抱歉,没有打过实时补丁
wangyangyangdz 发表于 2022-12-29 10:00:50 | 显示全部楼层
能不能打实时补丁? 关注后续
Linux本身就不是实时操作系统,应该是可以打的,但没有实际测试过  详情 回复 发表于 2023-1-5 11:44
香飘飘~~~ 发表于 2023-1-5 11:44:58 | 显示全部楼层
能不能打实时补丁? 关注后续
