查看: 3423|回复: 1
[Linux] EC20模块开机启动不起来
A40i\T3\T507\T527通行证i.MX6Q通行证i.MX6UL通行证
q2782743310 发表于 2022-12-20 17:20:02 | 显示全部楼层 |阅读模式
插上EC20模块,死机。拔下EC20可正常启动。下面是插上EC20的启动时串口打印信息
U-Boot 2016.03-00001-gb0f94c6 (Apr 22 2020 - 09:30:01 +0800)
CPU:   Freescale i.MX6DL rev1.3 996 MHz (running at 792 MHz)
CPU:   Extended Commercial temperature grade (-20C to 105C) at 48C
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  2 GiB
PMIC:  PFUZE100 ID=0x10
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Display: CLAA-WVGA (800x480)
1152054 bytes read in 44 ms (25 MiB/s)
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc2(part 0) is current device
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  3  2  1  0
reading boot.scr
reading zImage
6856624 bytes read in 187 ms (35 MiB/s)
Booting from mmc ...
reading imx6dl-c-sabresd.dtb
51946 bytes read in 18 ms (2.8 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x689fb0 ]
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800fae9
switch to ldo_bypass mode!
Starting kernel ...
[    0.000000] Linux version 4.1.15-dirty (lixinguo@developer-RH2485-V2) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Wed Apr 22 09:14:33 CST 2020
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] Machine model: Freescale i.MX6 DualLite SABRE Smart Device Board
[    0.000000] Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
[    0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 12 pages/cpu @ee713000 s17420 r8192 d23540 u49152
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520720
[    0.000000] Kernel command line: console=ttymxc0,115200 video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB24,bpp=16,int_clk video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=16 ldb=sin0 root=/dev/mmcblk3p2 rootwait rw fec.macaddr=EE:31:50:AE:81:33
[    0.000000] Booting kernel: `EE:31:50:AE:81:33' invalid for parameter `fec.macaddr'
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Memory: 1737468K/2097152K available (8553K kernel code, 500K rwdata, 3092K rodata, 440K init, 458K bss, 32004K reserved, 327680K cma-reserved, 270336K highmem)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xef800000   (1784 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80b678b8   (11647 kB)
[    0.000000]       .init : 0x80b68000 - 0x80bd6000   ( 440 kB)
[    0.000000]       .data : 0x80bd6000 - 0x80c533e0   ( 501 kB)
[    0.000000]        .bss : 0x80c56000 - 0x80cc8828   ( 459 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000]         Additional per-CPU info printed with stalls.
[    0.000000]         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 512 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
[    0.000000] mxc_clocksource_init 3000000
[    0.000000] Switching to timer-based delay loop, resolution 333ns
[    0.000006] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[    0.000023] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[    0.001235] Console: colour dummy device 80x30
[    0.001256] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.001270] pid_max: default: 32768 minimum: 301
[    0.001368] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.001380] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.002040] CPU: Testing write buffer coherency: ok
[    0.002340] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002439] Setting up static identity map for 0x10008280 - 0x100082d8
[    0.060163] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.060235] Brought up 2 CPUs
[    0.060255] SMP: Total of 2 processors activated (12.00 BogoMIPS).
[    0.060263] CPU: All CPU(s) started in SVC mode.
[    0.060735] devtmpfs: initialized
[    0.073602] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.074005] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.091231] pinctrl core: initialized pinctrl subsystem
[    0.092363] NET: Registered protocol family 16
[    0.100797] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.129670] cpuidle: using governor ladder
[    0.159667] cpuidle: using governor menu
[    0.159885] CPU identified as i.MX6DL, silicon rev 1.3
[    0.171859] anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid default voltage selector.
[    0.171885] anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with error -22
[    0.172551] anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid default voltage selector.
[    0.172575] anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with error -22
[    0.186202] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.186216] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.187736] imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.232451] mxs-dma 110000.dma-apbh: initialized
[    0.237174] SCSI subsystem initialized
[    0.237712] usbcore: registered new inte**ce driver usbfs
[    0.237796] usbcore: registered new inte**ce driver hub
[    0.237893] usbcore: registered new device driver usb
[    0.238103] 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[    0.238242] 2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
[    0.239145] i2c-gpio i2c-ft5326: using pins 35 (SDA) and 169 (SCL)
[    0.240252] i2c i2c-0: IMX I2C adapter registered
[    0.240271] i2c i2c-0: can't use DMA
[    0.240815] i2c i2c-1: IMX I2C adapter registered
[    0.240831] i2c i2c-1: can't use DMA
[    0.242130] i2c i2c-2: IMX I2C adapter registered
[    0.242148] i2c i2c-2: can't use DMA
[    0.242312] Linux video capture inte**ce: v2.00
[    0.242415] pps_core: LinuxPPS API ver. 1 registered
[    0.242425] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.242459] PTP clock support registered
[    0.259718] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[    0.261460] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
[    0.261477] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[    0.261573] MIPI CSI2 driver module loaded
[    0.261859] Advanced Linux Sound Architecture Driver Initialized.
[    0.264039] Switched to clocksource mxc_timer1
[    0.275736] NET: Registered protocol family 2
[    0.276412] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[    0.276568] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.276829] TCP: Hash tables configured (established 16384 bind 16384)
[    0.276975] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.277041] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.277282] NET: Registered protocol family 1
[    0.277644] RPC: Registered named UNIX socket transport module.
[    0.277656] RPC: Registered udp transport module.
[    0.277664] RPC: Registered tcp transport module.
[    0.277673] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.278342] CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
[    0.278393] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.279732] imx rpmsg driver is registered.
[    0.280779] Bus freq driver module loaded
[    0.281807] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.288742] VFS: Disk quotas dquot_6.6.0
[    0.288954] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.291115] NFS: Registering the id_resolver key type
[    0.291155] Key type id_resolver registered
[    0.291164] Key type id_legacy registered
[    0.291264] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    0.292010] fuse init (API version 7.23)
[    0.296270] bounce: pool size: 64 pages
[    0.296292] io scheduler noop registered
[    0.296309] io scheduler deadline registered
[    0.296498] io scheduler cfq registered (default)
[    0.297084] imx-weim 21b8000.weim: Driver registered.
[    0.299410] mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
[    0.299526] MIPI DSI driver module loaded
[    0.299791] MIPI DSI driver module loaded
[    0.302653] mxc_sdc_fb fb@0: registered mxc display driver lcd
[    0.378119] Console: switching to colour frame buffer device 100x30
[    0.415138] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
[    0.415166] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[    0.415284] mxc_sdc_fb fb@1: registered mxc display driver hdmi
[    0.436425] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[    0.436858] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.437130] imx-sdma 20ec000.sdma: loaded firmware 3.3
[    0.439991] imx-sdma 20ec000.sdma: initialized
[    0.441813] pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
[    0.442429] pfuze100-regulator 1-0008: FAB: 0, FIN: 0
[    0.442444] pfuze100-regulator 1-0008: pfuze100 found.
[    0.458298] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 25, base_baud = 5000000) is a IMX
[    1.307524] console [ttymxc0] enabled
[    1.312070] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 303, base_baud = 5000000) is a IMX
[    1.321384] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 304, base_baud = 5000000) is a IMX
[    1.330693] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 305, base_baud = 5000000) is a IMX
[    1.340302] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    1.346876] xr_usb_serial_common: Exar USB UART (serial port) driver
[    1.355332] imx sema4 driver is registered.
[    1.359610] [drm] Initialized drm 1.1.0 20060810
[    1.364798] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.380764] brd: module loaded
[    1.389801] loop: module loaded
[    1.398413] spi_imx 200c000.ecspi: probed
[    1.403471] CAN device driver inte**ce
[    1.408880] flexcan 2090000.flexcan: device registered (reg_base=f0250000, irq=32)
[    1.418617] 2188000.ethernet supply phy not found, using dummy regulator
[    1.444519] pps pps0: new PPS source ptp0
[    1.453453] libphy: fec_enet_mii_bus: probed
[    1.458413] fec 2188000.ethernet eth0: registered PHC device 0
[    1.465217] PPP generic driver version 2.4.2
[    1.469747] PPP BSD Compression module registered
[    1.474494] PPP Deflate Compression module registered
[    1.479576] PPP MPPE Compression module registered
[    1.484403] NET: Registered protocol family 24
[    1.488974] usbcore: registered new inte**ce driver asix
[    1.494488] usbcore: registered new inte**ce driver cdc_ether
[    1.500401] usbcore: registered new inte**ce driver cdc_subset
[    1.506453] usbcore: registered new inte**ce driver cdc_ncm
[    1.512153] GobiNet: Quectel_WCDMA&LTE_Linux&Android_GobiNet_Driver_V1.3.0
[    1.519125] usbcore: registered new inte**ce driver GobiNet
[    1.524860] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.531404] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.536970] usbcore: registered new inte**ce driver usb-storage
[    1.543164] usbcore: registered new inte**ce driver usbserial
[    1.549098] usbcore: registered new inte**ce driver option
[    1.554747] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.561771] usbcore: registered new inte**ce driver pl2303
[    1.567419] usbserial: USB Serial support registered for pl2303
[    1.573411] usbcore: registered new inte**ce driver usb_ehset_test
[    1.581096] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.589500] usb_otg_vbus: supplied by SWBST
[    1.597814] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    1.602722] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    1.624081] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    1.630436] hub 1-0:1.0: USB hub found
[    1.634296] hub 1-0:1.0: 1 port detected
[    1.639140] usb_h1_vbus: supplied by SWBST
[    1.646678] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    1.651594] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    1.674078] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.680375] hub 2-0:1.0: USB hub found
[    1.684231] hub 2-0:1.0: 1 port detected
[    1.689312] mousedev: PS/2 mouse device common for all mice
[    1.695911] edt_ft5x06 2-0038: touchscreen probe failed
[    1.701169] edt_ft5x06: probe of 2-0038 failed with error -5
[    1.707654] edt_ft5x06-mipi 3-0038: touchscreen probe failed
[    1.713407] <<-GTP-INFO->> GTP driver installing...
[    1.718630] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    1.724632] <<-GTP-INFO->> GTP I2C Address: 0x14
[    1.730040] 2-0014 supply vdd_ana not found, using dummy regulator
[    1.736314] 2-0014 supply vcc_i2c not found, using dummy regulator
[    1.742565] <<-GTP-INFO->> Guitar reset
[    1.876680] <<-GTP-INFO->> IC Version: 911_1060
[    1.910757] <<-GTP-INFO->> X_MAX: 800, Y_MAX: 480, TRIGGER: 0x01
[    1.934064] <<-GTP-INFO->> create proc entry gt911_config success
[    1.940189] <<-GTP-INFO->> Esd started
[    1.943955] ix 800, y 480
[    1.943955]
[    1.948352] input: goodix-gt911 as /devices/virtual/input/input2
[    1.954798] <<-GTP-INFO->> GTP works in interrupt mode.
[    1.960112] <<-GTP-INFO->> GTP driver installing...
[    1.965041] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    1.971941] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    1.977952] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    1.987428] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
[    1.994420] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    2.004074] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[    2.015095] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
[    2.021998] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    2.045107] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
[    2.051992] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    2.075078] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
[    2.081962] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    2.105078] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
[    2.111975] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    2.134060] <<-GTP-ERROR->> I2C read failed.
[    2.138552] usbcore: registered new inte**ce driver usbtouchscreen
[    2.145500] input: TSC2007 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a8000.i2c/i2c-2/2-0048/input/input3
[    2.157983] hub 2-1:1.0: USB hub found
[    2.161906] hub 2-1:1.0: 4 ports detected
[    2.166861] rtc-rx8010 2-0032: rtc core: registered rx8010 as rtc0
[    2.173094] rtc-rx8010 2-0032: IRQ 74 supplied
[    2.178597] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[    2.187526] i2c /dev entries driver
[    2.192545] IR NEC protocol handler initialized
[    2.197183] IR RC5(x/sz) protocol handler initialized
[    2.202252] IR RC6 protocol handler initialized
[    2.206821] IR JVC protocol handler initialized
[    2.211375] IR Sony protocol handler initialized
[    2.216027] IR SANYO protocol handler initialized
[    2.220746] IR Sharp protocol handler initialized
[    2.225482] IR MCE Keyboard/mouse protocol handler initialized
[    2.231328] IR XMP protocol handler initialized
[    2.334276] ov5640_read_reg:write reg error:reg=300a
[    2.339285] camera ov5640 is not found
[    2.454065] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[    2.524308] ov5640_read_reg:write reg error:reg=300a
[    2.529283] camera ov5640_mipi is not found
[    2.534996] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[    2.541795] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[    2.548637] mxc_v4l2_output v4l2_out: V4L2 device registered as video18
[    2.555835] uvcvideo: Found UVC 1.00 device USB HD Camera audio (058f:0806)
[    2.572054] input: USB HD Camera audio as /devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/input/input4
[    2.584090] usbcore: registered new inte**ce driver uvcvideo
[    2.589880] USB Video Class driver (1.1.1)
[    2.595867] mma8451 0-001c: read chip ID 0x1 is not equal to 0x1a or 0x2a!
[    2.602867] mma8451: probe of 0-001c failed with error -22
[    2.609419] imx2-wdt 20c0000.wdog: use WDOG_B to reboot.
[    2.615222] imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
[    2.621722] sdhci: Secure Digital Host Controller Inte**ce driver
[    2.627997] sdhci: Copyright(c) Pierre Ossman
[    2.632372] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.639054] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
[    2.646261] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[    2.652782] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
[    2.659048] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
[    2.704225] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    2.714136] /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
[    2.721306] sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
[    2.726530] sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
[    2.732993] sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
[    2.739224] sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
[    2.784218] mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[    2.794283] /soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
[    2.801815] sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
[    2.808079] sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
[    2.817677] uvcvideo: Found UVC 1.00 device USB HD Camera audio (058f:0806)
[    2.834292] input: USB HD Camera audio as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input5
[    2.855123] mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
[    2.880574] mxc_vpu 2040000.vpu_fsl: VPU initialized
[    2.892498] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[    2.905072] mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
[    2.915544] galcore: clk_get vg clock failed, disable vg!
[    2.921187] Galcore version 5.0.11.41671
[    2.948778] mmc3: MAN_BKOPS_EN bit is not set
[    2.964120] usb 2-1.3: new high-speed USB device number 4 using ci_hdrc
[    2.973461] mmc3: new DDR MMC card at address 0001
[    2.979206] mmcblk3: mmc3:0001 SEM08G 7.28 GiB
[    2.984277] mmcblk3boot0: mmc3:0001 SEM08G partition 1 2.00 MiB
[    2.990634] mmcblk3boot1: mmc3:0001 SEM08G partition 2 2.00 MiB
[    2.997123] mmcblk3rpmb: mmc3:0001 SEM08G partition 3 2.00 MiB
[    3.004646]  mmcblk3: p1 p2
[    3.400464] caam 2100000.caam: Entropy delay = 3200
[    3.466187] caam 2100000.caam: Instantiated RNG4 SH0
[    3.526948] caam 2100000.caam: Instantiated RNG4 SH1
[    3.531930] caam 2100000.caam: device ID = 0x0a16010000000100 (Era -524)
[    3.538660] caam 2100000.caam: job rings = 2, qi = 0
[    3.610030] caam algorithms registered in /proc/crypto
[    3.619302] caam_jr 2101000.jr0: registering rng-caam
[    3.625421] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[    3.631411] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[    3.640644] usbcore: registered new inte**ce driver usbhid
[    3.646298] usbhid: USB HID core driver
[    3.659678] fsl-asrc 2034000.asrc: driver registered
[    3.674591] imx-wm8960 sound: wm8960-hifi <-> 202c000.ssi mapping ok
[    3.685916] imx-wm8960 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
[    3.693007] imx-wm8960 sound: wm8960-hifi <-> 202c000.ssi mapping ok
[    3.812104] imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
[    3.821131] NET: Registered protocol family 26
[    3.825655] Netfilter messages via NETLINK v0.30.
[    3.830443] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.837244] ctnetlink v0.93: registering with nfnetlink.
[    3.843294] xt_time: kernel timezone is -0000
[    3.848134] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.853641] arp_tables: (C) 2002 David S. Miller
[    3.858986] NET: Registered protocol family 10
[    3.864612] sit: IPv6 over IPv4 tunneling driver
[    3.869950] NET: Registered protocol family 17
[    3.874484] NET: Registered protocol family 15
[    3.878949] can: controller area network core (rev 20120528 abi 9)
[    3.885240] NET: Registered protocol family 29
[    3.889739] can: raw protocol (rev 20120528)
[    3.894053] can: broadcast manager protocol (rev 20120528 t)
[    3.899738] can: netlink gateway (rev 20130117) max_hops=1
[    3.905491] 8021q: 802.1Q VLAN Support v1.8
[    3.909736] Key type dns_resolver registered
[    3.918051] pwm-backlight supply power not found, using dummy regulator
[    3.926088] backlight supply power not found, using dummy regulator
[    3.935953] dhd_module_init in
[    3.940080] input: gpio-keys as /devices/soc0/gpio-keys/input/input8
[    3.948113] rtc-rx8010 2-0032: setting system clock to 2022-12-13 09:47:54 UTC (1670924874)
[    3.966807] SW4: disabling
[    3.969538] SATA_EN: disabling
[    3.972600] CAN XCVR: disabling
[    3.976050] ALSA device list:
[    3.979028]   #0: wm8960-audio
[    3.982088]   #1: imx-hdmi-soc
[    4.718124] EXT3-fs (mmcblk3p2): warning: mounting fs with errors, running e2fsck is recommended
[    4.727015] kjournald starting.  Commit interval 5 seconds
[    4.733625] EXT3-fs (mmcblk3p2): using internal journal
[    4.739904] EXT3-fs (mmcblk3p2): recovery complete
[    4.744756] EXT3-fs (mmcblk3p2): mounted filesystem with ordered data mode
[    4.751705] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    4.758630] devtmpfs: mounted
[    4.762927] Freeing unused kernel memory: 440K (80b68000 - 80bd6000)
INIT: version 2.88 booting
mount: mount point /mnt/.psplash does not exist
Starting udev
[    5.203288] udevd[194]: starting version 3.1.5
[    5.215593] random: udevd urandom read with 42 bits of entropy available
[    5.628829] tsc2007 2-0048: i2c io error: -5
[    5.749688] ERROR: v4l2 capture: slave not found!
[    5.782401] ERROR: v4l2 capture: slave not found!
[    5.961352] usbcore: registered new inte**ce driver snd-usb-audio
[    6.340610] usbcore: registered new inte**ce driver rtl8723bu
[    6.444700] FAT-fs (mmcblk3p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
bootlogd: cannot allocate pseudo tty: No such file or directory
urandom start: failed.
ALSA: Restoring mixer settings...
INIT: Entering runlevel: 5
Configuring network inte**ces... [    7.934851] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
[    7.974241] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Error resolving time.pool.aliyun.com: Name or service not known (-2)
13 Dec 17:47:58 ntpdate[616]: Can't find host time.pool.aliyun.com: Name or service not known (-2)
13 Dec 17:47:58 ntpdate[616]: no servers can be used, exiting
Starting system message bus: Starting Xserver
13 Dec 17:47:58 ntpdate[623]: Can't find host time.pool.aliyun.com: Name or service not known (-2)
13 Dec 17:47:58 ntpdate[623]: no servers can be used, exiting
dbus.
Starting Connection Manager
Starting rpcbind daemon...done.
starting statd: done
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting atd: OK
NFS daemon support not enabled in kernel
Starting system log daemon...0
Starting kernel log daemon...[    9.055913] tsc2007 2-0048: i2c io error: -5
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Telephony daemon
Starting Linux NFC daemon
Starting crond: OK
Starting autohdmi:
Running local boot scripts (/etc/rc.local)[    9.834119] usb 2-1.4: new high-speed USB device number 5 using ci_hdrc
[    9.984356] GobiNet 2-1.4:1.4 eth1: register 'GobiNet' at usb-ci_hdrc.1-1.4, GobiNet Ethernet Device, c2:5c:51:4a:57:cd
[    9.995739] Unable to handle kernel NULL pointer dereference at virtual address 00000009
[   10.003847] pgd = d9028000
[   10.006626] [00000009] *pgd=69165831, *pte=00000000, *ppte=00000000
[   10.012991] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[   10.018401] Modules linked in: wlan snd_usb_audio snd_hwdep snd_usbmidi_lib snd_rawmidi mxc_dcic
[   10.027378] CPU: 0 PID: 648 Comm: connmand Not tainted 4.1.15-dirty #1
[   10.033925] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[   10.040474] task: d878af80 ti: d8fc2000 task.ti: d8fc2000
[   10.045899] PC is at GobiNetDriverRxFixup+0x4/0x170
[   10.050804] LR is at usbnet_bh+0xd0/0x208
[   10.054843] pc : [<804ca2f8>]    lr : [<804c69b0>]    psr: a0000013
[   10.054843] sp : d8fc3de8  ip : 00000000  fp : 40000006
[   10.066333] r10: 80bd8080  r9 : 80bd8080  r8 : 00000101
[   10.071573] r7 : 00000005  r6 : d93924c0  r5 : d939259c  r4 : d94b6480
[   10.078114] r3 : 00000000  r2 : 804ca2f4  r1 : d94b6480  r0 : d93924c0
[   10.084653] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   10.091804] Control: 10c53c7d  Table: 6902804a  DAC: 00000015
[   10.097566] Process connmand (pid: 648, stack limit = 0xd8fc2210)
[   10.103677] Stack: (0xd8fc3de8 to 0xd8fc4000)
[   10.108050] 3de0:                   d93925fc d9392600 00000000 80bd1254 00000101 800387dc
[   10.116235] 3e00: 00000000 00000006 80bd8098 d8fc2000 00000101 80038a1c d94d5c00 d9392610
[   10.124418] 3e20: d8fc3e18 80c59040 00000007 ffff8eb8 80bd8100 00404140 d9392610 60000013
[   10.132601] 3e40: 00000201 80896d14 d9392030 00000000 00000000 00008914 d94d5c00 80038ba8
[   10.140783] 3e60: d9392000 80038cac d9392000 00000000 80896d14 8069c864 00000201 d9392000
[   10.148965] 3e80: d94d5c00 d9392000 00000001 ffff9003 00001002 8069cacc d9392000 d9392138
[   10.157146] 3ea0: 00001002 7eb0f960 00000000 8069cb94 00000000 00000000 d94d5c0c 7eb0f960
[   10.165327] 3ec0: 00000000 8072201c 7eb0f960 00000000 d8fc3ef0 d9392000 00000014 d94d5c0c
[   10.173509] 3ee0: 31687465 00000000 00000000 00000000 00009003 00000000 00000000 00000000
[   10.181690] 3f00: 00001002 00008914 d6322da0 7eb0f960 00000011 7eb0f960 d8fc2000 00000000
[   10.189872] 3f20: ffffffff 8068380c 7eb0f960 d6322da0 d94b63c0 800fac04 808e1580 800ebe58
[   10.198054] 3f40: 80bda6e8 00080000 d9176640 00000011 ffffffff 8082b3f8 d9176600 801048f8
[   10.206236] 3f60: 00000000 00000011 ffffffff 8082b67c d94b63c0 00000011 d94b63c0 00008914
[   10.214417] 3f80: 7eb0f960 d8fc2000 00000000 800fae58 00000000 00000011 00000002 00000036
[   10.222599] 3fa0: 8000f604 8000f480 00000000 00000011 00000011 00008914 7eb0f960 00001002
[   10.230782] 3fc0: 00000000 00000011 00000002 00000036 01123da0 000be978 00000001 ffffffff
[   10.238965] 3fe0: 000b9698 7eb0f95c 00062034 76bff2bc 600f0010 00000011 00000000 00000000
[   10.247161] [<804ca2f8>] (GobiNetDriverRxFixup) from [<80bd1254>] (tasklet_vec+0x4/0x8)
[   10.255171] Code: eb0d6041 eafffff5 808972e8 e590307c (e5d33009)
[   10.261336] ---[ end trace 375670531d76472a ]---
[   10.265996] Kernel panic - not syncing: Fatal exception in interrupt
[   10.272367] CPU1: stopping
[   10.275090] CPU: 1 PID: 697 Comm: syslogd Tainted: G      D         4.1.15-dirty #1
[   10.282749] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[   10.289306] [<80015d78>] (unwind_backtrace) from [<8001271c>] (show_stack+0x10/0x14)
[   10.297065] [<8001271c>] (show_stack) from [<80824490>] (dump_stack+0x84/0xc4)
[   10.304297] [<80824490>] (dump_stack) from [<80014c80>] (handle_IPI+0x178/0x18c)
[   10.311699] [<80014c80>] (handle_IPI) from [<80009480>] (gic_handle_irq+0x58/0x5c)
[   10.319276] [<80009480>] (gic_handle_irq) from [<80013200>] (__irq_svc+0x40/0x74)
[   10.326760] Exception stack(0xd8f69ce8 to 0xd8f69d30)
[   10.331817] 9ce0:                   d95da430 00000bc0 00000000 00000000 ef282b60 00000001
[   10.340001] 9d00: d95da000 80a3c8d0 ef282b40 80a3c8bc 00000001 00000001 00000000 d8f69d34
[   10.348181] 9d20: 00000000 802ad990 200f0013 ffffffff
[   10.353244] [<80013200>] (__irq_svc) from [<802ad990>] (__memzero+0x30/0x7c)
[   10.360304] [<802ad990>] (__memzero) from [<800b4cd0>] (get_page_from_freelist+0x3dc/0x6b0)
[   10.368663] [<800b4cd0>] (get_page_from_freelist) from [<800b5208>] (__alloc_pages_nodemask+0xfc/0x894)
[   10.378068] [<800b5208>] (__alloc_pages_nodemask) from [<800cda28>] (__pte_alloc+0x24/0x164)
[   10.386514] [<800cda28>] (__pte_alloc) from [<800cf418>] (copy_page_range+0x4e4/0x61c)
[   10.394442] [<800cf418>] (copy_page_range) from [<80034298>] (copy_process.part.3+0xaec/0x1398)
[   10.403149] [<80034298>] (copy_process.part.3) from [<80034c8c>] (do_fork+0xac/0x364)
[   10.410990] [<80034c8c>] (do_fork) from [<8000f480>] (ret_fast_syscall+0x0/0x3c)
[   10.418392] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
金色田野的灿烂 发表于 2022-12-22 17:39:47 | 显示全部楼层
您的问题解决没有呀,上午的时候您是不是电话咨询跟工程师沟通过了呢,如果不是您的话,您可以电话咨询或者邮箱咨询与工程师详细沟通下问题,方便帮您解决问题
