查看: 7048|回复: 3
[硬件咨询] 中断函数GPIO1_Combined_16_31_IRQHandler不会进入
i.MX RT通行证
zhanchi 发表于 2023-1-10 16:13:48 | 显示全部楼层 |阅读模式
我选取GPIO1.24(H13)和GPIO1.25(M13)来进行测试,不会进入中断,帮我看看是哪里的问题。我用GPIO1.3(G11)也都没问题的。我是在GPIO口的中断例程中更改的。
配置:
  IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B0_03_GPIO1_IO03, 0U);
// IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B1_08_GPIO1_IO24, 0U);  /* GPIO_AD_B1_08(H13) is configured as 输入中断 */
IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B1_09_GPIO1_IO25, 0U);
main.c文件中:
这个0-15的中断可以进入
void GPIO1_Combined_0_15_IRQHandler(void)
    /* clear the interrupt status */
    GPIO_PortClearInterruptFlags(GPIO1, 1U << 3);
    /* Change state of switch. */
    g_InputSignal = true;
    /* Add for ARM errata 838869, affects Cortex-M4, Cortex-M4F Store immediate overlapping
      exception return operation might vector to incorrect interrupt */
#if defined __CORTEX_M && (__CORTEX_M == 4U)
    __DSB();
#endif
这个中断一直不会进来
void GPIO1_Combined_16_31_IRQHandler(void)
    GPIO_PortClearInterruptFlags(GPIO1, 1U << 25);
    __DSB();
#endif
主函数中的初始化:
/* Define the init structure for the input switch pin */
    gpio_pin_config_t sw_config = {
        kGPIO_DigitalInput,
        0,
        kGPIO_IntRisingEdge,
    /* Init input switch GPIO. */
    EnableIRQ(EXAMPLE_SW_IRQ);
    GPIO_PinInit(EXAMPLE_SW_GPIO, EXAMPLE_SW_GPIO_PIN, &sw_config);
    /* Enable GPIO pin interrupt */
    GPIO_PortEnableInterrupts(EXAMPLE_SW_GPIO, 1U << EXAMPLE_SW_GPIO_PIN);//这里是GPIO1.3
    EnableIRQ(GPIO1_Combined_0_15_IRQn);
    GPIO_PinInit(GPIO1, 3U, &sw_config);
    GPIO_PortEnableInterrupts(GPIO1, 1U << 3);
    EnableIRQ(GPIO1_Combined_16_31_IRQn);
    GPIO_PinInit(GPIO1, 25U, &sw_config);
    GPIO_PortEnableInterrupts(GPIO1, 1U << 25);
有人用过这个GPIO1的16-31中断的吗?帮我看看问题出在哪里,我用相同的方式GPIO1的0-15的可以触发
