- 95
贡献524
飞刀143 FD
注册时间2020-4-27
在线时间12 小时
我的开发环境是全志A40i,用的配套的底板和核心板,按照手册录音放音没有问题。
之后我想实现的功能是读取录音的数据,并将其转换为指定格式文件输出,同时将数据显示在屏幕上,以波形图的形式,就像录音实时跟踪那种效果
在已经搭建好源码和交叉编译环境下,我编译一个文件在终端提示找不到#include <alsa/asoundlib.h>文件,是因为这句话没有识别,但是系统实际是已经安装了ALSA库的
我的源码如下
- #define ALSA_PCM_NEW_HW_PARAMS_API
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <fcntl.h>
- #include <sys/ioctl.h>
- #include <sys/stat.h>
- #include <sys/types.h>
- #include <unistd.h>
- #include <alsa/asoundlib.h>
- int main() {
- long loops;
- int rc;
- int size;
- unsigned int val;
- int dir;
- char *buffer;
- snd_pcm_t *handle;
- snd_pcm_hw_params_t *params;
- snd_pcm_uframes_t frames;
- /*以录制模式打开*/
- /* Open PCM device for recording (capture). */
- rc = snd_pcm_open( &handle, "default", SND_PCM_STREAM_CAPTURE, 0);
- if (rc < 0) {
- fprintf(stderr, "unable to open pcm device");
- exit(EXIT_FAILURE);
- /*分配一个参数对象*/
- /* Allocate a hardware parameters object. */
- snd_pcm_hw_params_alloca(¶ms);
- /*初始化参数对象*/
- /* Fill it in with default values. */
- rc = snd_pcm_hw_params_any(handle, params);
- if (rc < 0) {
- printf("Err\n");
- /* Set the desired hardware parameters. */
- /*交错模式*/
- /* Interleaved mode */
- rc = snd_pcm_hw_params_set_access(handle, params,
- SND_PCM_ACCESS_RW_INTERLEAVED);
- if (rc < 0) {
- printf("Err\n");
- /*PCM格式*/
- /* Signed 16-bit little-endian format */
- rc = snd_pcm_hw_params_set_format(handle, params,
- SND_PCM_FORMAT_S16_LE);
- if (rc < 0) {
- printf("Err\n");
- /*设置通道数*/
- /* Two channels (stereo) */
- rc = snd_pcm_hw_params_set_channels(handle, params, 2);
- if (rc < 0) {
- printf("Err\n");
- /*设置采样率*/
- /* 44100 bits/second sampling rate (CD quality) */
- val = 44100;
- rc = snd_pcm_hw_params_set_rate_near(handle, params,
- &val, &dir);
- if (rc < 0) {
- printf("Err\n");
- /*没周期的帧数*/
- /* Set period size to 32 frames. */
- frames = 32;
- rc = snd_pcm_hw_params_set_period_size_near(handle,
- params, &frames, &dir);
- if (rc < 0) {
- printf("Err\n");
- /* Write the parameters to the driver */
- rc = snd_pcm_hw_params(handle, params);
- if (rc < 0) {
- fprintf(stderr,
- "unable to set hw parameters: %s/n",
- snd_strerror(rc));
- exit(1);
- /* Use a buffer large enough to hold one period */
- rc = snd_pcm_hw_params_get_period_size(params,
- &frames, &dir);
- if (rc < 0) {
- printf("Err\n");
- size = frames * 4; /* 2 bytes/sample, 2 channels */
- buffer = (char *) malloc(size);
- /* We want to loop for 5 seconds */
- rc = snd_pcm_hw_params_get_period_time(params, &val, &dir);
- loops = 5000000 / val;
- while (loops > 0) {
- loops--;
- rc = snd_pcm_readi(handle, buffer, frames);
- if (rc == -EPIPE) {
- /* EPIPE means overrun */
- fprintf(stderr, "overrun occurred/n");
- //把PCM流置于PREPARED状态,这样下次我们向该PCM流中数据时,它就能重新开始处理数据。
- snd_pcm_prepare(handle);
- } else if (rc < 0) {
- fprintf(stderr,
- "error from read: %s/n",
- } else if (rc != (int)frames) {
- fprintf(stderr, "short read, read %d frames/n", rc);
- rc = write(1, buffer, size);
- if (rc != size)
- fprintf(stderr,
- "short write: wrote %d bytes/n", rc);
- //调用snd_pcm_drain把所有挂起没有传输完的声音样本传输完全
- rc = snd_pcm_drain(handle);
- //关闭该音频流,释放之前动态分配的缓冲区,退出
- rc = snd_pcm_close(handle);
- free(buffer);
- return 0;
复制代码 测试文件引用代码如下
复制代码 测试程序说明都没有执行,只是单纯的引用alsa库,都无法编译通过,报错信息如下
这里想请问一下大佬,如何正确的识别ALSA库
