- 22
贡献121
飞刀32 FD
注册时间2023-4-24
在线时间4 小时
Windows Media Foundation ............... no
Qt WebEngine:
Embedded build ......................... yes
Pepper Plugins ......................... no
Printing and PDF ....................... no
Proprietary Codecs ..................... no
Spellchecker ........................... yes
WebRTC ................................. no
Using system ninja ..................... no
ALSA ................................... yes
PulseAudio ............................. no
System libraries:
re2 .................................. no
ICU .................................. no
libwebp and libwebpdemux ............. no
Opus ................................. no
ffmpeg ............................... no
Note: Also available for Linux: linux-clang linux-icc
Note: PKG_CONFIG_LIBDIR automatically set to /home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/pkgconfig:/home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/pkgconfig:/home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/pkgconfig
Note: PKG_CONFIG_SYSROOT_DIR automatically set to /home/yanglei/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.9/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot
Note: -optimized-tools is not useful in -release mode.
Note: No wayland-egl support detected. Cross-toolkit compatibility disabled.
WARNING: Feature qqnx_pps is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature lgmon is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature qqnx_imf is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature xcb-xlib is insignificant in this configuration, ignoring related command line option(s).
WARNING: Feature xinput2 is insignificant in this configuration, ignoring related command line option(s).
ERROR: Feature 'eglfs' was enabled, but the pre-condition '!config.android && !config.darwin && !config.win32 && features.egl' failed.
5.9.9 编译 Qt WebEngine 报错 |
