查看: 3698|回复: 2
[Linux] LCD屏幕的显示位置,靠下 如何设置?
A40i\T3\T507\T527通行证
方鸿开发2023 发表于 2023-5-15 17:11:44 | 显示全部楼层 |阅读模式
如下所示,根据屏幕厂家的设置 计算如下参数并刷机,目前看来图片的位置显示靠下,请问 是需要调整哪些参数?
[lcd0]
lcd_used            = 1
lcd_driver_name     = "default_lcd"
lcd_backlight       = 255
lcd_if              = 0
lcd_x               = 800
lcd_y               = 480
lcd_width           =
lcd_height          =
lcd_dclk_freq       = 26
lcd_pwm_used        = 0
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 0
lcd_pwm_max_limit   = 255
lcd_hbp             = 20
lcd_ht              = 842
lcd_hspw            = 2
lcd_vbp             = 10
lcd_vt              = 502
lcd_vspw            = 2
lcd_lvds_if         = 0
lcd_lvds_colordepth = 1
lcd_lvds_mode       = 0
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 0
lcd_cmap_en         = 0
Q_Y_X 发表于 2023-5-16 09:24:48 | 显示全部楼层
https://www.cnblogs.com/linhaostudy/p/10413089.html
可以参考这个链接中的图示调整一下参数
楼主| 方鸿开发2023 发表于 2023-5-16 09:25:21 | 显示全部楼层
可以参考这个链接中的图示调整一下参数
好的,感谢
