查看: 6087|回复: 4
[Linux] ok3588c v1.2,官方最新的 linux 镜像启动出错
RK3588通行证
xiaguangbo 发表于 2023-6-4 17:54:17 | 显示全部楼层 |阅读模式
# 描述
镜像名:官方的 OK3588-linuxfs-img.tar.bz2
自己使用 BoardConfig-linuxfs-ok3588.mk 编译的也是,出的问题一摸一样
# 信息
OK3588-linuxfs-img.tar.bz2 的 md5 值:
  1. $ md5sum OK3588-linuxfs-img.tar.bz2
  2. 0d99e0975d51abbbcb2141d88e7280b1  OK3588-linuxfs-img.tar.bz2
复制代码
烧录:
  1. $ sudo upgrade_tool uf update.img
  2. Loading firmware...
  3. Support Type:3588        FW Ver:1.0.00        FW Time:2023-03-23 16:16:16
  4. Loader ver:1.0b        Loader Time:2023-03-23 15:26:51
  5. Start to upgrade firmware...
  6. Test Device Start
  7. Test Device Success
  8. Check Chip Start
  9. Check Chip Success
  10. Get FlashInfo Start
  11. Get FlashInfo Success
  12. Prepare IDB Start
  13. Prepare IDB Success
  14. Download IDB Start
  15. Download IDB Success
  16. Download Firmware Start
  17. Download Image... (100%)
  18. Download Firmware Success
  19. Upgrade firmware ok.
复制代码
日志:
  1. DDR Version V1.07 20220412
  2. LPDDR4X, 2112MHz
  3. ...
  4. ## Checking optee 0x08400000 ... sha256(fde0860845...) + OK
  5. Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
  6. Total: 174.493 ms
  7.
  8. INFO:    Preloader serial: 2
  9. NOTICE:  BL31: v2.3():v2.3-481-g17b41886e:derrick.huang
  10. NOTICE:  BL31: Built : 16:20:07, Dec  7 2022
  11. INFO:    spec: 0x1
  12. INFO:    ext 32k is not valid
  13. INFO:    ddr: stride-en 4CH
  14. INFO:    GICv3 without legacy support detected.
  15. ...
  16. U-Boot 2017.09 (Mar 23 2023 - 15:26:41 +0800)
  17.
  18. Model: Forlinx OK3588-C Board
  19. PreSerial: 2, raw, 0xfeb50000
  20. ...
  21. Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
  22. Total: 2304.841 ms
  23.
  24. Starting kernel ...
  25.
  26. I/TC: Secondary CPU 1 initializing
  27. I/TC: Secondary CPU 1 switching to normal world boot
  28. ...
  29. I/TC: Secondary CPU 7 initializing
  30. I/TC: Secondary CPU 7 switching to normal world boot
  31. [ddr_m0]E: waiting_vop_line_flag-1894: vop_post=0 unsupported!
  32. [ddr_m0]E: waiting_vop_line_flag-1894: vop_post=0 unsupported!
  33. mount: mounting /dev/mmcblk1p1 on /mnt/sdcard failed: No such file or directory
  34. mount: mounting PARTLABEL=oem on /oem failed: No such file or directory
  35. mount: mounting PARTLABEL=userdata on /userdata failed: No such file or directoy
  36. Starting syslogd: OK
  37. Starting klogd: OK
  38. Running sysctl: OK
  39. Populating /dev using udev: DDR Version V1.07 20220412
  40. LPDDR4X, 2112MHz
复制代码
等级纪念章·正式会员i.MX6Q通行证i.MX6UL通行证RK3588通行证LS1012A通行证LS1043A\46A通行证FCU11xx通行证FCU2301\FCU2302通行证
whl 发表于 2023-6-5 11:39:32 | 显示全部楼层
这是用的什么烧录方式进行烧录的,我看Log日志中有挂载失败的打印信息
好像是供电不足。。。。。。。。。我用的是给路由器用的 usb 5v转12v。。。。。换成正经电源就好了  详情 回复 发表于 2023-6-5 16:37
sudo upgrade_tool uf update.img 上面有,开发板的 typec0 连接电脑,使用 upgrade_tool 工具直接烧录到 emmc 里  详情 回复 发表于 2023-6-5 16:28
RK3588通行证
楼主| xiaguangbo 发表于 2023-6-5 16:28:07 | 显示全部楼层
mount: mounting /dev/mmcblk1p1 on ...
开发板刚拿到手上电也是这样,核心板和底板上的灯就是亮一会就会灭,然后再亮,就是不断重启
RK3588通行证
楼主| xiaguangbo 发表于 2023-6-5 16:37:57 | 显示全部楼层
RK3588通行证
楼主| xiaguangbo 发表于 2023-6-5 16:42:07 | 显示全部楼层
记录一下换电源之后的日志
  1. ...
  2. I/TC: Secondary CPU 7 initializing
  3. I/TC: Secondary CPU 7 switching to normal world boot
  4. [ddr_m0]E: waiting_vop_line_flag-1894: vop_post=0 unsupported!
  5. [ddr_m0]E: waiting_vop_line_flag-1894: vop_post=0 unsupported!
  6. mount: mounting PARTLABEL=oem on /oem failed: No such file or directory
  7. mount: mounting PARTLABEL=userdata on /userdata failed: No such file or directoy
  8. Starting syslogd: OK
  9. Starting klogd: OK
  10. Running sysctl: OK
  11. /usr/bin/modetest
  12. Populating /dev using udev: done
  13. Initializing random number generator: OK
  14. Saving random seed: OK
  15. Will now mount all partitions in /etc/fstab
  16. Note: Will skip fsck, remove /.skip_fsck to enable
  17. Handling rootfs: /dev/mmcblk0p6 / ext4 rw,noauto 1
  18. ...
复制代码
