查看: 6714|回复: 5
[硬件咨询] OK6254开发板网络频繁掉线是怎么回事
XX18通行证AM62x通行证
FuZhenYu163 发表于 2023-7-30 06:54:45 | 显示全部楼层 |阅读模式
刚购买的OK6254开发板,无论是连在路由器还是连在计算机上,网络都是频繁的掉线。
同时对比测试的,也是用的飞凌公司的S5P6818做核心板的板子,网卡PHY用的RTL8211的芯片就没问题。
附上超级终端监测到的掉线信息
[ 1339.344379] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 1340.368621] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 1548.240455] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 1549.264659] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 2706.384607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 2707.408608] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 3404.752376] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 3405.776603] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 3718.096371] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 3719.120606] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 4824.016374] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 4825.040607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 4939.728388] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 4940.752662] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 5334.992370] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 5336.016668] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 6330.320373] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 6331.344605] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 6370.256422] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 6371.280649] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 6858.704381] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 6859.728608] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 7924.688375] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 7925.712614] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 8865.744404] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 8866.768609] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 9721.808373] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 9722.832607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[10899.408379] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[10900.432604] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[12754.896376] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[12755.920627] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[12916.688382] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[12917.712607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[13791.184384] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[13792.208608] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[14695.376370] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[14696.400602] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[14774.224644] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[14775.248603] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[15701.968374] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[15702.992655] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[16071.632383] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[16072.656611] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[16210.896404] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[16211.920607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[17292.240412] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[17293.264631] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[18975.696376] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[18976.720616] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[19726.288405] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[19727.312644] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[21631.952371] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[21632.976606] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[22284.240403] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[22285.264636] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[22552.528685] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[22553.552698] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[23860.176374] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[23861.200627] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24301.520398] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24302.544613] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24643.536401] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24644.560643] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24664.016658] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24665.040603] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24782.800382] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24783.824602] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24818.640682] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24819.664609] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[24866.768683] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[24867.792630] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[25029.584395] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[25030.608612] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[25056.208633] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[25057.232607] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[25161.680411] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[25162.704647] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[27126.736349] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[27127.760721] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[27284.432379] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[27285.456609] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[27949.008382] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[27950.032651] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[28112.848419] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[28113.872638] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[28159.952911] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[28160.976672] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[28214.224445] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[28215.248633] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[28584.912378] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[28585.936612] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[29114.320374] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[29115.344601] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[29739.984371] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[29741.008597] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Q_Y_X 发表于 2023-7-31 15:10:08 | 显示全部楼层
请问您是在进行哪部分测试的时候出现的该现象?还是上电就是这样?能稳定复现该问题吗?
今天又测试了一天,上午连路由器,下午连主机,没再出现掉线问题,我打算连点30天再看看。  详情 回复 发表于 2023-7-31 16:31
XX18通行证AM62x通行证
楼主| FuZhenYu163 发表于 2023-7-31 16:31:48 | 显示全部楼层
XX18通行证AM62x通行证
楼主| FuZhenYu163 发表于 2023-8-6 12:31:14 | 显示全部楼层
7.31开始测试,8.06又掉线,8.07早上查看掉线两次。
我这边了解了一下,Ti的勘误表上确实提到过这个问题,我们这边最新的镜像上已经解决了此问题,您使用的是最新资料中的镜像吗?  详情 回复 发表于 2023-8-7 10:09
Q_Y_X 发表于 2023-8-7 10:09:40 | 显示全部楼层
换上新的镜像,两个网口各运行了15天,正常了。  详情 回复 发表于 2023-9-14 12:54
XX18通行证AM62x通行证
楼主| FuZhenYu163 发表于 2023-9-14 12:54:33 | 显示全部楼层
我这边了解了一下,Ti的勘误表上确实提到过这个问题,我们这边最新的镜像上已经解决了此问题,您使用的是 ...
