查看: 3669|回复: 2
[Linux] a40i启动报错
A40i\T3\T507\T527通行证
Carry5959 发表于 2023-8-17 09:33:15 | 显示全部楼层 |阅读模式
oka40i启动后报错,是什么原因?
[220]HELLO! BOOT0 is starting!
[223]BOOT0 commit : c04b9e99ee
[227]board init start
[529]set pll start
[533]set pll end
[534][pmu]: axpxp_init
[538][pmu]:
pmuu_type = 6
[541]PMU: AXP221
[542]pmu_chip_id = 6
[544]board init ok
[546]enable_jtag
[548]DRAMC IS FOUR
[550]DRAM BOOT DRIVE INFO: V1.2
[553]the chip id is 0x3
[555]the chip id is 0x3
[557]the chip id is 0x3
[559]the chip id is 0x3
[562]the chip id is 0x3
[564]DRAM CLK =576 MHZ
[566]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[571]DRAM zq value: 0x3b3bfb
[576]DRAM SIZE =1024 M
[578]DRAM ** test OK.
[581]dram size =1024
[583]rtc standby flag is 0x0, super standby flag is 0x0
[589]card no is 2
[590]sdcard 2 line count 8
[593][mmc]: mmc driver ver 2022-08-26 15:04
[602][mmc]: Wrong media type 0x0
[605][mmc]: ***Try SD card 2***
[609][mmc]: mmc 2 cmd 8 timeout, err 100
[612][mmc]: mmc 2 cmd 8 err 100
[615][mmc]: mmc 2 send if cond failed
[619][mmc]: mmc 2 cmd 55 timeout, err 100
[623][mmc]: mmc 2 cmd 55 err 100
[626][mmc]: mmc 2 send app cmd failed
[629][mmc]: ***Try MMC card 2***
[652][mmc]: RMCA OK!
[654][mmc]: mmc 2 bias 0
[658][mmc]: MMC 5.1
[659][mmc]: HSSDR52/SDR25 8 bit
[662][mmc]: 50000000 Hz
[664][mmc]: 7456 MB
[666][mmc]: ***SD/MMC 2 init OK!!!***
[734]Loading boot-pkg Succeed(index=0).
[738]Entry_name        = u-boot
[746]Entry_name        = dtb
[749]Entry_name        = optee
[753]tunning data addr:0x4a0003e8
[756]Jump to second Boot.
MESSAGE: [0x0] TEE-CORE: OP-TEE version: 8d296159-dirty #1 Fri 21 Oct 2022 02:40:38 AM UTC arm
ERROR:   [0x0] TEE-CORE:check_hardware_info:149: data: 1 1 0 0
ERROR:   [0x0] TEE-CORE:check_hardware_info:150: hardware error 3
ERROR:   [0x0] TEE-CORE: Panic at core/arch/arm/plat-sun8iw11p1/main.c:261 <plat_init>
ERROR:   [0x0] TEE-CORE: Call stack:
ERROR:   [0x0] TEE-CORE:  0x4860b7d9
ERROR:   [0x0] TEE-CORE:  0x4861157b
ERROR:   [0x0] TEE-CORE:  0x4861001f
ERROR:   [0x0] TEE-CORE:  0x486020e8
楼主| Carry5959 发表于 2023-8-17 09:36:05 | 显示全部楼层
楼主| Carry5959 发表于 2023-8-17 09:37:18 | 显示全部楼层
[529]set pll start
[533]set pll end
[538][pmu]:
pmuu_type = 6
[541]PMU: AXP221
[544]board init ok
[546]enable_jtag
[548]DRAMC IS FOUR
[589]card no is 2
[658][mmc]: MMC 5.1
[664][mmc]: 7456 MB
