查看: 4969|回复: 1
[Ubuntu] 关于LS1028内核编译
LS1028A通行证
lpcarm 发表于 2023-8-25 06:34:21 | 显示全部楼层 |阅读模式
您好,今日调试1028开发板,按照手册配置好相关环境后进行内核编译,出现如下错误,有没有解决方案 LD       drivers/net/built-in.o  LD      cmd/built-in.o
make[2]: Leaving directory '/home/forlinx/work/OK1028-linux-fs/build/firmware/u-boot/ls1028ardb/output/ls1028ardb_tfa_SECURE_BOOT_defconfig'
Makefile:148: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory '/home/forlinx/work/OK1028-linux-fs/packages/firmware/OK1028-linux-uboot'
cp: -r not specified; omitting directory '/home/forlinx/work/OK1028-linux-fs/build/firmware/u-boot/ls1028ardb/output/ls1028ardb_tfa_SECURE_BOOT_defconfig/'
/home/forlinx/work/OK1028-linux-fs/packages/firmware/u-boot.mk:14: recipe for target 'uboot' failed
make: *** [uboot] Error 1
make: Leaving directory '/home/forlinx/work/OK1028-linux-fs/packages/firmware'
root@ubuntu:/home/forlinx/work#
A40i\T3\T507\T527通行证i.MX6Q通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3588通行证RK3399通行证LS1028A通行证G2L通行证LS1012A通行证LS1043A\46A通行证TCU通行证FDU产品通行证FCU1401通行证FCU1301通行证FCU11xx通行证FCU1201通行证FCU2201通行证FCU2301\FCU2302通行证FCU2401通行证5G转接卡通行证FCU3001通行证AM5718通行证Hi3519A通行证AM335x通行证i.MX RT通行证XX18通行证AM62x通行证FDU070K02\FDU101K02通行证i.MX9352\i.MX9131通行证2K0300\2K0500通行证JH7110通行证T113i通行证D9360通行证FCU2601通行证FCU1303通行证RK3576通行证RK3562通行证
gggfff 发表于 2023-9-5 14:02:09 | 显示全部楼层
请问您可否提供一下您所使用的1028版本的系统是哪个?还有您用户资料里文件夹名称后面的版本日期是多少?
