查看: 6363|回复: 8
[硬件咨询] 14.6寸屏不显示
A40i\T3\T507\T527通行证
TYW123123 发表于 2023-9-25 16:42:01 | 显示全部楼层 |阅读模式
我在驱动另一款屏幕14.6,按照屏参,进行了配置,但什么也不显示,我把我配置的设备树,屏幕说明书,以及如何接线我提供出来。
屏参:
Diagonal Size 14.6 inch
Resolution 1920(RGB) x 1080
Active Area(mm) 323.136x181.764
Parameter Symbol Min Typ. Max Unit
DCLK frequency FDCLK 66.05 68.18 70.18 MHz
Horizontal valid data thd 960 DCLK
Hsync pulse Width thpw - 20 - DCLK
Hsync back porch thbp - 20 - DCLK
Hsync front porch thfp - 20 - DCLK
1 horizontal line th - 1020 - H
Vertical valid data tvd 1080 H
Vsync pulse width tvpw - 2 - H
Vsync back porch tvbp - 8 - H
Vsync front porch tvfp - 24 - H
1 vertical field tv - 1114 - H
Frame rate FR - 60 - HZ
我配置的设备树:OKT507-C-Common.dtsi
lcd0: lcd0@01c0c000 {
        lcd_used            = <1>;
        lcd_driver_name     = "forlinx_gt911";
        lcd_backlight       = <250>;  // 根据屏幕资料调整
        lcd_if              = <3>;
        lcd_x               = <1920>;
        lcd_y               = <1080>;
        lcd_width             = <323>;  // 调整为屏幕的实际宽度 14inch
        lcd_height            = <181>;    // 调整为屏幕的实际高度 14inch
        lcd_dclk_freq       = <68>;   // 根据屏幕资料的中值调整14inch
        lcd_pwm_used        = <0>;
        lcd_pwm_ch          = <0>;
        lcd_pwm_freq        = <50000>;
        lcd_pwm_pol         = <1>;
        lcd_pwm_max_limit   = <255>;
        /* hsync back porch(pixel) + hsync plus width(pixel)  */
        14inch
        20+20 = 40
        lcd_hbp                           = <40>;
        /* HBP + HFP + HSPW +   Horizontal Resolution */
           40  + 20  +  20   + 1920 = 2000
        lcd_ht                                   = <2000>;  //14inch
        /* Horizontal Sync Pluse Width */
        lcd_hspw                           = <20>;   //14inch
        /* vsync back porch(line) + vysnc plus width(line) */
        2 + 8 =10
        lcd_vbp                           = <10>;    //14inch
        /* VBP + VFP + VSPW + Vertical Resolution */
        10  +  24 +  2   +   1080  = 1116
        lcd_vt                                   = <1116>;   //14inch
        /* Vertical Sync Pluse Width  */
        lcd_vspw                           = <2>;    //14inch
        lcd_lvds_if         = <1>;
        lcd_lvds_colordepth = <0>;
        lcd_lvds_mode       = <0>;
        lcd_frm             = <0>;
        lcd_hv_clk_phase    = <0>;
        lcd_hv_sync_polarity= <0>;
        lcd_gamma_en        = <0>;
        lcd_bright_curve_en = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        lcd_fsync_act_time  = <1000>;
        lcd_fsync_dis_time  = <1000>;
        lcd_fsync_pol       = <0>;
        deu_mode            = <0>;
        lcdgamma4iep        = <22>;
        smart_color         = <90>;
        lcd_pin_power = "bldo1";
        lcd_power = "dc1sw";
        lcd_bl_en        = <&pio PE 22 1 0 3 1>;
        pinctrl-0 = <&lvds2link_pins_a>;
        pinctrl-1 = <&lvds2link_pins_b>;
楼主| TYW123123 发表于 2023-9-25 16:43:10 | 显示全部楼层
背光灯正常点亮
楼主| TYW123123 发表于 2023-9-25 16:59:51 | 显示全部楼层
我任职的公司在用飞凌T507在做产品样机,我一共遇到两个问题,随时等回复
shuishui 发表于 2023-9-26 08:48:42 | 显示全部楼层
您这个屏幕是什么类型的?mipi,还是lcd、lvds,电容还是电阻呢?
这是我的QQ号:86742187,我可以把21寸与14寸屏幕说明书说明给你。 电容屏幕,lvds 是这具体参数 1. Features This is a 14.6inch LTPS-TFT-LCD (Low Temperature Poly-silicon Liquid Crystal Display) module  详情 回复 发表于 2023-9-26 10:04
楼主| TYW123123 发表于 2023-9-26 10:04:29 | 显示全部楼层
电容屏幕,lvds
是这具体参数
1. Features
This is a 14.6inch LTPS-TFT-LCD (Low Temperature Poly-silicon Liquid Crystal Display) module with
normal-black technology. It is composed of a TFT-LCD panel, LCD Driver IC with T-con integrated and a PCB
unit. This product is designed for automotive and other high reliability electronic products and complies with
RoHS Directive.
2. General Specification
Feature Specification Remark
Pixel Pitch (mm) 0.1683x0.1683
Pixel Configuration R.G.B. Vertical Stripe
Technology Type LTPS incell
Display Mode Normally Black
Landscape or Portrait Landscape
Su**ce Treatment (Top Polarizer) HC
Inte**ce 2Port LVDS
Color Depth 16.7M
Dimension (H x V x D) (mm) 327.736(H) x 191.224(V) x 1.23(D) Note1
Weight (g) TBD Note2
shuishui 发表于 2023-9-26 10:51:42 | 显示全部楼层
不好意思,我们这边不能通过私人方式加您,您可以联系我们公司和您对接的销售和他沟通一下,您还可以拨打我们的技术支持电话,以及您可以把您的问题发送至我们的邮箱,您可以在邮件中加入您的相关资料。
楼主| TYW123123 发表于 2023-9-26 11:37:14 | 显示全部楼层
不好意思,我们这边不能通过私人方式加您,您可以联系我们公司和您对接的销售和他沟通一下,您还可以拨打我 ...
好,keep touch
frankluo 发表于 2023-11-2 14:51:01 | 显示全部楼层
双通道LVDS的DCLK  是不是得双倍?
A40i\T3\T507\T527通行证i.MX6Q通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3588通行证RK3399通行证LS1028A通行证G2L通行证LS1012A通行证LS1043A\46A通行证TCU通行证FDU产品通行证FCU1401通行证FCU1301通行证FCU11xx通行证FCU1201通行证FCU2201通行证FCU2301\FCU2302通行证FCU2401通行证5G转接卡通行证FCU3001通行证AM5718通行证Hi3519A通行证AM335x通行证i.MX RT通行证XX18通行证AM62x通行证FDU070K02\FDU101K02通行证i.MX9352\i.MX9131通行证2K0300\2K0500通行证
小康康 发表于 2023-11-4 14:13:01 | 显示全部楼层
可以看下您接线吗?还有屏幕手册,方便的话,可以放到我们邮箱。
