- 22
贡献94
飞刀24 FD
注册时间2023-9-11
在线时间3 小时
2.1 Display Characteristics
The following items are characteristics summary on the table under 25oC condition:
ITEMS Unit SPECIFICATIONS
Screen Diagonal [mm] 21.5”
Active Area [mm] 476.064 (H) x 267.786 (V)
Pixels H x V 1920(x3) x 1080
Pixel Pitch [um] 247.95 (per one triad) ×247.95
Pixel Arrangement R.G.B. Vertical Stripe
Display Mode AHVA Mode, Normally Black
White Luminance ( Center ) [cd/m2
] 250 cd/m2 (Typ.)
Contrast Ratio 1000 (Typ.)
Optical Response Time [msec] 22
Nominal Input Voltage VDD [Volt] 5 V (Typ)
Power Consumption
(VDD line + LED line) [Watt]
11.1W (Typ.)
LCD module : PDD (Typ.)= 2.3 @ White
pattern,Fv=60Hz
Backlight unit : PBLU (Typ.) =8.8W
Weight [Grams] 1740 (Typ)
Physical Size [mm] 497.6(H) x 292.2(V) x 10.5 (D)Typ
Electrical Inte**ce Dual LVDS
Support Color 16.7M colors
Su**ce Treatment Anti-Glare, 3H
RoHS Compliance RoHS Compliance |
