查看: 3833|回复: 2
[Linux] emmc pin check error -1 20400
A40i\T3\T507\T527通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3399通行证
kk2008 发表于 2023-11-7 11:28:55 | 显示全部楼层 |阅读模式
新做的一个底板debug终端输出 如然后不停的重启进不了系统,可能是什么原因?将核心板放到开发板上启动正常。
[    0.550463] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
[    0.550526] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0
[    1.566060] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    2.579389] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    3.592722] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    4.606055] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    5.619388] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    6.632721] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    7.646056] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    8.659387] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    9.672720] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   10.686052] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   11.699386] rk-pcie 3c0000000.pcie: PCIe Link Fail
[   11.699404] rk-pcie 3c0000000.pcie: failed to initialize host
forqs 发表于 2023-11-7 14:59:29 | 显示全部楼层
可以看下用户资料/手册/常见问题手册 pcie章节,自制底板没有pcie3.0导致反复重启,如果没有i2c2也一并disabled
楼主| kk2008 发表于 2023-11-8 09:38:37 | 显示全部楼层
可以看下用户资料/手册/常见问题手册 pcie章节,自制底板没有pcie3.0导致反复重启,如果没有i2c2也一并disa ...
感谢,问题解决了。
