查看: 5801|回复: 4
[硬件咨询] 核心板一直重启
i.MX6UL通行证RK3568通行证LS1012A通行证
maxwelllv 发表于 2024-3-22 18:26:05 | 显示全部楼层 |阅读模式
楼主| maxwelllv 发表于 2024-3-22 18:28:29 | 显示全部楼层
第一次发帖,怎么没有文字和图片显示
楼主| maxwelllv 发表于 2024-3-22 18:31:02 | 显示全部楼层
[    0.549358] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0 核心板跑到这里就重启
楼主| maxwelllv 发表于 2024-3-22 18:32:38 | 显示全部楼层
[18:19:20.203]收←◆DDR V1.15 ec2fae0c96 huan.he 22/11/08-20:06:42
In
ddrconfig:15
DDR4, 324MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 192ps, dqs1: 168ps, dqs2: 96ps, dqs3: 120ps,
change to: 324MHz
clk skew:0x84
PHY drv:clk:37,ca:37,DQ:37,odt:0
vrefinner:50%, vrefout:50%
dram drv:34,odt:0
change to: 528MHz
clk skew:0x84
dram drv:34,odt:0
change to: 780MHz
clk skew:0x84
PHY drv:clk:37,ca:37,DQ:37,odt:139
vrefinner:50%, vrefout:61%
dram drv:34,odt:120
change to: 1560MHz(final freq)
clk skew:0x84
dram drv:34,odt:120
cs 0:
the read training result:
DQS0:0x38, DQS1:0x33, DQS2:0x30, DQS3:0x33,
min  : 0xd  0xb  0xa  0xc  0x3  0x3  0x4  0x1 , 0x8  0x8  0x3  0x7  0x4  0xc  0x8  0xa ,
       0x5  0x8  0x9  0x6  0x4  0x4  0x4  0x1 , 0xa  0x2  0x5  0x2  0x6  0x8  0x6  0x6 ,
mid  :0x27 0x25 0x26 0x25 0x1e 0x1e 0x1e 0x1c ,0x23 0x21 0x1c 0x22 0x1f 0x24 0x23 0x24 ,
      0x20 0x23 0x23 0x21 0x1f 0x1f 0x1f 0x1d ,0x24 0x1d 0x1f 0x1d 0x21 0x24 0x20 0x21 ,
max  :0x42 0x40 0x43 0x3f 0x3a 0x3a 0x39 0x38 ,0x3e 0x3a 0x35 0x3e 0x3b 0x3d 0x3e 0x3e ,
      0x3b 0x3e 0x3e 0x3d 0x3b 0x3a 0x3b 0x3a ,0x3f 0x39 0x3a 0x39 0x3d 0x40 0x3a 0x3d ,
range:0x35 0x35 0x39 0x33 0x37 0x37 0x35 0x37 ,0x36 0x32 0x32 0x37 0x37 0x31 0x36 0x34 ,
      0x36 0x36 0x35 0x37 0x37 0x36 0x37 0x39 ,0x35 0x37 0x35 0x37 0x37 0x38 0x34 0x37 ,
the write training result:
DQS0:0xaa, DQS1:0xa5, DQS2:0x97, DQS3:0x9b,
min  :0x93 0x90 0x93 0x93 0x89 0x88 0x8a 0x89 0x8f ,0x8d 0x8e 0x8b 0x8e 0x8d 0x8f 0x91 0x91 0x8a ,
      0x83 0x83 0x86 0x86 0x83 0x80 0x7e 0x82 0x81 ,0x82 0x82 0x82 0x80 0x86 0x84 0x82 0x84 0x83 ,
mid  :0xab 0xaa 0xad 0xab 0x9f 0xa0 0xa0 0xa0 0xa8 ,0xa5 0xa7 0xa0 0xa4 0xa4 0xa8 0xa6 0xaa 0x9f ,
      0x9b 0x9d 0x9e 0x9d 0x9b 0x97 0x96 0x9a 0x99 ,0x99 0x98 0x99 0x96 0x9a 0x9b 0x99 0x9a 0x9b ,
max  :0xc4 0xc4 0xc7 0xc3 0xb6 0xb8 0xb6 0xb8 0xc1 ,0xbe 0xc1 0xb5 0xba 0xbc 0xc1 0xbc 0xc3 0xb4 ,
      0xb3 0xb8 0xb6 0xb5 0xb3 0xaf 0xae 0xb2 0xb2 ,0xb0 0xaf 0xb1 0xad 0xaf 0xb3 0xb0 0xb0 0xb4 ,
range:0x31 0x34 0x34 0x30 0x2d 0x30 0x2c 0x2f 0x32 ,0x31 0x33 0x2a 0x2c 0x2f 0x32 0x2b 0x32 0x2a ,
      0x30 0x35 0x30 0x2f 0x30 0x2f 0x30 0x30 0x31 ,0x2e 0x2d 0x2f 0x2d 0x29 0x2f 0x2e 0x2c 0x31 ,
out
U-Boot SPL board init
[18:19:20.480]收←◆
U-Boot SPL 2017.09-gaaca6ffec1-211203 #zzz (Dec 03 2021 - 18:42:16)
[18:19:20.527]收←◆unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 16
spl: mmc init failed with error: -95
Trying to boot from MMC1
[18:19:20.652]收←◆SPL: A/B-slot: _a, successful: 0, tries-remain: 7
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(df3dd620f7...) + OK
## Checking uboot 0x00a00000 ... sha256(d81d090c69...) + OK
## Checking fdt 0x00b32b80 ... sha256(e00fe4da74...) + OK
## Checking atf-2 0xfdcc1000 ... sha256(455304ad25...) + OK
## Checking atf-3 0x0006a000 ... sha256(919db4e965...) + OK
## Checking atf-4 0xfdcd0000 ... sha256(d4e8257343...) + OK
## Checking atf-5 0xfdcce000 ... sha256(cb025e3a5b...) + OK
## Checking atf-6 0x00068000 ... sha256(6e9d32ba23...) + OK
## Checking optee 0x08400000 ... sha256(af414b9c9f...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 316.635 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-460-g2c8be93f9:huan.he
NOTICE:  BL31: Built : 19:45:17, Nov  8 2022
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
[18:19:20.892]收←◆I/TC:
I/TC: OP-TEE version: 3.13.0-651-gd84087907 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 Fri Sep 16 15:39:33 CST 2022 aarch64
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
[18:19:20.998]收←◆
U-Boot 2017.09-g4e881c6-dirty #jifu (Mar 18 2023 - 07:13:37 +0000)
Model: Forlinx OK3568-C
[18:19:21.039]收←◆PreSerial: 2, raw, 0xfe660000
DRAM:  4 GiB
Sysmem: init
Relocation Offset: ed346000
Relocation fdt: eb9f8870 - eb9fecf0
[18:19:21.090]收←◆CR: M/C/I
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
[18:19:21.203]收←◆Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
[18:19:21.267]收←◆I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
[18:19:21.317]收←◆io-domain: OK
emmc ps same version
[18:19:21.904]收←◆Auth Success!
Could not find baseparameter partition
Model: Forlinx OK3568-C Board
Rockchip UBOOT DRM driver version: v1.0.1
VOP have 3 active VP
vp0 have layer nr:2[1 5 ], primary plane: 5
vp1 have layer nr:3[0 2 4 ], primary plane: 4
vp2 have layer nr:1[3 ], primary plane: 3
Using display timing dts
dsi@fe070000:  detailed mode clock 45000 kHz, flags[8000000a]
    H: 1024 1064 1112 1160
    V: 0600 0640 0644 0692
bus_format: 100e
VOP update mode to: 1024x600p0, type: MIPI1 for VP1
VOP VP1 enable Smart0[400x300->400x300@312x150] fmt[1] addr[0xedf00036]
final DSI-Link bandwidth: 300 Mbps x 4
[18:19:22.189]收←◆hdmi@fe0a0000 disconnected
lvds:  detailed mode clock 71000 kHz, flags[6]
    H: 1280 1420 1430 1440
    V: 0800 0802 0822 0823
bus_format: 1011
VOP update mode to: 1280x800p0, type: LVDS0 for VP2
VOP VP2 enable Esmart1[400x300->400x300@440x250] fmt[1] addr[0xedf00036]
[18:19:22.265]收←◆CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 1416000 KHz
  dpll 780000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 630000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 1416000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 500000 KHz
  aclk_top_low 400000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Rockchip watchdog timeout: 15 sec
Net:   eth0: ethernet@fe2a0000, eth1: ethernet@fe010000
Hit key to stop autoboot('Spacebar'):  1
[18:19:23.329]收←◆ 0
## Booting FIT Image
[18:19:23.467]收←◆at 0xea27c840 with size 0x0157b000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at ea27c840 ...
   Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0xea29de40
     Data Size:    22386696 Bytes = 21.3 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00280000
     Entry Point:  0x00280000
     Hash algo:    sha256
     Hash value:   8bd520d697f1e8ac052ee6e27f698d03c4ba2fda0bcbb0f1f611b8ae9c26257a
   Verifying Hash Integrity ... sha256
[18:19:23.688]收←◆+ OK
## Loading fdt from FIT Image at ea27c840 ...
   Trying 'fdt' fdt subimage
     Type:         Flat Device Tree
     Data Start:   0xea27d040
     Data Size:    134226 Bytes = 131.1 KiB
     Load Address: 0x0a100000
     Hash algo:    sha256
     Hash value:   e9477b9a821edd4447810ef1d44e29b77d3b8a08a7a3a34e79ff56ed51fbfc45
   Verifying Hash Integrity ... sha256+ OK
   Loading fdt from 0x0a100000 to 0x0a100000
   Booting using the fdt blob at 0x0a100000
   Loading Kernel Image from 0xea29de40 to 0x00280000 ... OK
   kernel loaded at 0x00280000, end = 0x017d9808
  'reserved-memory' ramoops@110000: addr=110000 size=f0000
   Using Device Tree in place at 000000000a100000, end 000000000a123c51
vp1 adjust cursor plane from 0 to 1
vp0, plane_mask:0x22, primary-id:5, curser-id:1
vp1 adjust cursor plane from 1 to 0
vp1, plane_mask:0x15, primary-id:4, curser-id:0
vp2, plane_mask:0x8, primary-id:3, curser-id:-1
[18:19:23.826]收←◆Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000)
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 2918.69 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 4.19.206 (forlinx@forlinx) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #1 SMP Sat Oct 14 21:56:38 CST 2023
[    0.000000] Machine model: Forlinx OK3568-C Board
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] cma: Reserved 16 MiB at 0x00000000eec00000
[18:19:24.054]收←◆[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
[    0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rw rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[18:19:24.226]收←◆[    0.000000] Memory: 3980384K/4175872K available (13566K kernel code, 1958K rwdata, 4772K rodata, 1536K init, 534K bss, 179104K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 49868 entries in 195 pages
[18:19:24.334]收←◆[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:         RCU event tracing is enabled.
[    0.000000] rcu:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0xfd440000-0xfd45ffff]
[    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x0000000000230000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] CPU0: using LPI pending table @0x0000000000240000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[18:19:24.492]收←◆[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.009712] Console: colour dummy device 80x25
[    0.014620] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.025889] pid_max: default: 32768 minimum: 301
[    0.031062] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.038430] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.047376] ASID allocator initialised with 32768 entries
[    0.053430] rcu: Hierarchical SRCU implementation.
[    0.060576] Platform MSI: interrupt-controller@fd440000 domain created
[    0.068114] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    0.078286] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.091524] Detected VIPT I-cache on CPU1
[    0.091551] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.091589] CPU1: using LPI pending table @0x0000000000250000
[    0.091629] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.099928] Detected VIPT I-cache on CPU2
[    0.099950] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.099987] CPU2: using LPI pending table @0x0000000000260000
[    0.100019] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.108286] Detected VIPT I-cache on CPU3
[    0.108306] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.108347] CPU3: using LPI pending table @0x0000000000270000
[    0.108376] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.108474] smp: Brought up 1 node, 4 CPUs
[    0.189747] SMP: Total of 4 processors activated.
[    0.194912] CPU features: detected: GIC system register CPU inte**ce
[    0.201982] CPU features: detected: Privileged Access Never
[    0.208097] CPU features: detected: LSE atomic instructions
[    0.214214] CPU features: detected: User Access Override
[    0.220044] CPU features: detected: 32-bit EL0 Support
[    0.225682] CPU features: detected: RAS Extension Support
[    0.231720] CPU: All CPU(s) started at EL2
[    0.236241] alternatives: patching kernel code
[    0.245426] devtmpfs: initialized
[    0.265739] Registered cp15_barrier emulation handler
[    0.271324] Registered setend emulation handler
[    0.276527] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.287236] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.294506] pinctrl core: initialized pinctrl subsystem
[    0.300986] NET: Registered protocol family 16
[    0.308663] cpuidle: using governor menu
[    0.312983] Registered FIQ tty driver
[    0.317347] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.325597] DMA: preallocated 256 KiB pool for atomic allocations
[    0.335241] console [pstore-1] enabled
[    0.339382] pstore: Registered ramoops as persistent store backend
[    0.346170] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[18:19:24.887]收←◆[    0.376411] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[    0.383935] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[    0.391434] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[    0.398922] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[    0.406410] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[    0.413562] rockchip-pinctrl pinctrl: probed pinctrl
[    0.427935] cryptd: max_cpu_qlen set to 1000
[[    0.433916] console [ttyFIQ0] enabled
[    0.441601] bootconsole [uart8250] disabled
[    0.446385] Registered fiq debugger ttyFIQ0
[    0.447094] vcc5v0_sys: supplied by vcc12v
[    0.447384] vcc3v3_sys: supplied by vcc5v0_sys
[    0.447664] vcc3v3: supplied by vcc5v0_sys
[    0.447930] vcc1v8: supplied by vcc3v3
[    0.448212] vcc1v2: supplied by vcc3v3
[    0.448494] vcc2v8: supplied by vcc3v3
[    0.448807] vcc3v3_lcd2_n: supplied by vcc3v3_sys
[    0.449092] vcc2v5-sys: supplied by vcc3v3_sys
[    0.450713] rk_iommu fde4b000.iommu: version = 2
[    0.451223] rk_iommu fdea0800.iommu: version = 2
[    0.451544] rk_iommu fded0480.iommu: version = 2
[    0.451770] rk_iommu fdee0800.iommu: version = 2
[    0.451989] rk_iommu fdef0800.iommu: version = 2
[    0.452204] rk_iommu fdf40f00.iommu: version = 2
[    0.452461] rk_iommu fdf80800.iommu: version = 2
[    0.452675] rk_iommu fdff1a00.iommu: version = 2
[    0.452871] rk_iommu fe043e00.iommu: version = 2
[    0.453592] SCSI subsystem initialized
[    0.453808] usbcore: registered new inte**ce driver usbfs
[    0.453859] usbcore: registered new inte**ce driver hub
[    0.453912] usbcore: registered new device driver usb
[    0.453992] media: Linux media inte**ce: v0.10
[    0.454034] videodev: Linux video capture inte**ce: v2.00
[    0.454109] pps_core: LinuxPPS API ver. 1 registered
[    0.454124] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.454149] PTP clock support registered
[    0.454410] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.456400] Advanced Linux Sound Architecture Driver Initialized.
[    0.456796] Bluetooth: Core ver 2.22
[    0.456842] NET: Registered protocol family 31
[    0.456857] Bluetooth: HCI device and connection manager initialized
[    0.456877] Bluetooth: HCI socket layer initialized
[    0.456893] Bluetooth: L2CAP socket layer initialized
[    0.456927] Bluetooth: SCO socket layer initialized
[    0.457389] rockchip-cpuinfo cpuinfo: SoC                : 35682000
[    0.457407] rockchip-cpuinfo cpuinfo: Serial                : 2783bd5af391780f
[    0.458129] clocksource: Switched to clocksource arch_sys_counter
[    0.519547] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.519828] NET: Registered protocol family 2
[    0.520035] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.521316] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[    0.521395] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.521630] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.522342] TCP: Hash tables configured (established 32768 bind 32768)
[    0.522477] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.522656] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.522939] NET: Registered protocol family 1
[    0.523345] RPC: Registered named UNIX socket transport module.
[    0.523361] RPC: Registered udp transport module.
[    0.523373] RPC: Registered tcp transport module.
[    0.523385] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.525410] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.527104] Initialise system trusted keyrings
[    0.527271] workingset: timestamp_bits=61 max_order=20 bucket_order=0
[    0.532273] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.532933] NFS: Registering the id_resolver key type
[    0.532971] Key type id_resolver registered
[    0.532984] Key type id_legacy registered
[    0.533018] ntfs: driver 2.1.32 [Flags: R/O].
[    0.533183] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[    0.533357] fuse init (API version 7.27)
[    0.533716] SGI XFS with security attributes, no debug enabled
[    0.535738] NET: Registered protocol family 38
[    0.535771] Key type asymmetric registered
[    0.535786] Asymmetric key parser 'x509' registered
[    0.535835] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.535853] io scheduler noop registered
[    0.535866] io scheduler deadline registered
[    0.535967] io scheduler cfq registered (default)
[    0.535983] io scheduler mq-deadline registered
[    0.535997] io scheduler kyber registered
[    0.536959] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[    0.537102] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    0.539408] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[    0.540710] extcon extcon1: failed to create extcon usb2-phy link
[    0.540957] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.549655] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.3
[    0.550074] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
[    0.550145] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0
[18:19:46.232]收←◆DDR V1.15 ec2fae0c96 huan.he 22/11/08-20:06:42
In
ddrconfig:15
DDR4, 324MHz
change to: 324MHz
clk skew:0x84
dram drv:34,odt:0
change to: 528MHz
clk skew:0x84
dram drv:34,odt:0
change to: 780MHz
clk skew:0x84
dram drv:34,odt:120
clk skew:0x84
dram drv:34,odt:120
cs 0:
DQS0:0x36, DQS1:0x31, DQS2:0x30, DQS3:0x33,
min  : 0xc  0xa  0xa  0xc  0x3  0x3  0x4  0x2 , 0x8  0x6  0x2  0x6  0x4  0xc  0x8  0xa ,
       0x5  0x8  0x9  0x6  0x4  0x4  0x4  0x2 , 0xa  0x2  0x5  0x2  0x6  0x8  0x7  0x6 ,
mid  :0x26 0x24 0x25 0x25 0x1e 0x1e 0x1e 0x1c ,0x22 0x1f 0x1a 0x21 0x1f 0x23 0x22 0x24 ,
      0x20 0x23 0x23 0x21 0x1f 0x1f 0x1f 0x1e ,0x24 0x1d 0x1f 0x1d 0x21 0x24 0x20 0x21 ,
max  :0x41 0x3f 0x41 0x3e 0x39 0x39 0x39 0x36 ,0x3c 0x38 0x32 0x3c 0x3a 0x3a 0x3c 0x3e ,
      0x3b 0x3e 0x3e 0x3c 0x3b 0x3a 0x3b 0x3a ,0x3f 0x39 0x3a 0x38 0x3d 0x40 0x3a 0x3d ,
range:0x35 0x35 0x37 0x32 0x36 0x36 0x35 0x34 ,0x34 0x32 0x30 0x36 0x36 0x2e 0x34 0x34 ,
      0x36 0x36 0x35 0x36 0x37 0x36 0x37 0x38 ,0x35 0x37 0x35 0x36 0x37 0x38 0x33 0x37 ,
      0x83 0x83 0x86 0x86 0x84 0x80 0x7f 0x82 0x81 ,0x82 0x82 0x82 0x80 0x86 0x84 0x82 0x84 0x83 ,
mid  :0xab 0xaa 0xad 0xab 0x9f 0xa0 0xa0 0xa0 0xa8 ,0xa5 0xa7 0xa0 0xa4 0xa5 0xa8 0xa6 0xaa 0x9f ,
      0x9b 0x9d 0x9d 0x9d 0x9b 0x97 0x96 0x9a 0x99 ,0x99 0x98 0x99 0x96 0x9a 0x9b 0x99 0x9a 0x9b ,
max  :0xc4 0xc4 0xc7 0xc3 0xb6 0xb8 0xb6 0xb8 0xc1 ,0xbd 0xc0 0xb5 0xba 0xbd 0xc1 0xbc 0xc3 0xb4 ,
      0xb3 0xb7 0xb5 0xb5 0xb3 0xaf 0xae 0xb2 0xb2 ,0xb0 0xaf 0xb0 0xad 0xaf 0xb3 0xb0 0xb1 0xb4 ,
range:0x31 0x34 0x34 0x30 0x2d 0x30 0x2c 0x2f 0x32 ,0x30 0x32 0x2a 0x2c 0x30 0x32 0x2b 0x32 0x2a ,
      0x30 0x34 0x2f 0x2f 0x2f 0x2f 0x2f 0x30 0x31 ,0x2e 0x2d 0x2e 0x2d 0x29 0x2f 0x2e 0x2d 0x31 ,
out
[18:19:46.510]收←◆
[18:19:46.557]收←◆unknown raw ID phN
[18:19:46.681]收←◆SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
Total: 316.609 ms
[18:19:46.922]收←◆I/TC:
INFO:    SPSR = 0x3c9
[18:19:47.028]收←◆
[18:19:47.069]收←◆PreSerial: 2, raw, 0xfe660000
DRAM:  4 GiB
Sysmem: init
[18:19:47.120]收←◆CR: M/C/I
[18:19:47.233]收←◆Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
[18:19:47.297]收←◆I2c0 speed: 100000Hz
[18:19:47.347]收←◆io-domain: OK
[18:19:47.933]收←◆Auth Success!
bus_format: 100e
[18:19:48.221]收←◆hdmi@fe0a0000 disconnected
bus_format: 1011
[18:19:48.298]收←◆CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 1416000 KHz
  dpll 780000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 630000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 1416000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  pclk_pmu 100000 KHz
[18:19:49.361]收←◆ 0
[18:19:49.500]收←◆at 0xea27c840 with size 0x0157b000
## Verified-boot: 0
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha256
[18:19:49.720]收←◆+ OK
     Hash algo:    sha256
[18:19:49.858]收←◆Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Total: 2920.624 ms
Starting kernel ...
[18:19:50.086]收←◆[    0.000000] psci: probing for conduit method from DT.
[18:19:50.259]收←◆[    0.000000] Memory: 3980384K/4175872K available (13566K kernel code, 1958K rwdata, 4772K rodata, 1536K init, 534K bss, 179104K reserved, 16384K cma-reserved)
[18:19:50.367]收←◆[    0.000000] rcu: Hierarchical RCU implementation.
[18:19:50.525]收←◆[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.009702] Console: colour dummy device 80x25
[    0.014613] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.025883] pid_max: default: 32768 minimum: 301
[    0.031059] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.038427] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.047369] ASID allocator initialised with 32768 entries
[    0.053419] rcu: Hierarchical SRCU implementation.
[    0.060545] Platform MSI: interrupt-controller@fd440000 domain created
[    0.068099] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    0.078290] smp: Bringing up secondary CPUs ...
[    0.091534] Detected VIPT I-cache on CPU1
[    0.091562] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.091598] CPU1: using LPI pending table @0x0000000000250000
[    0.091639] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.099924] Detected VIPT I-cache on CPU2
[    0.099945] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.099986] CPU2: using LPI pending table @0x0000000000260000
[    0.100018] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.108291] Detected VIPT I-cache on CPU3
[    0.108311] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.108352] CPU3: using LPI pending table @0x0000000000270000
[    0.108384] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.108465] smp: Brought up 1 node, 4 CPUs
[    0.189725] SMP: Total of 4 processors activated.
[    0.194889] CPU features: detected: GIC system register CPU inte**ce
[    0.201958] CPU features: detected: Privileged Access Never
[    0.208073] CPU features: detected: LSE atomic instructions
[    0.214189] CPU features: detected: User Access Override
[    0.220019] CPU features: detected: 32-bit EL0 Support
[    0.225658] CPU features: detected: RAS Extension Support
[    0.231693] CPU: All CPU(s) started at EL2
[    0.236212] alternatives: patching kernel code
[    0.245422] devtmpfs: initialized
[    0.265728] Registered cp15_barrier emulation handler
[    0.271314] Registered setend emulation handler
[    0.276517] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.287226] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.294490] pinctrl core: initialized pinctrl subsystem
[    0.300963] NET: Registered protocol family 16
[    0.308636] cpuidle: using governor menu
[    0.312956] Registered FIQ tty driver
[    0.317318] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.325568] DMA: preallocated 256 KiB pool for atomic allocations
[    0.334921] console [pstore-1] enabled
[    0.339062] pstore: Registered ramoops as persistent store backend
[    0.345848] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[18:19:50.919]收←◆[    0.376026] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[    0.383553] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[    0.391048] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[    0.398536] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[    0.406019] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[    0.413170] rockchip-pinctrl pinctrl: probed pinctrl
[    0.427527] cryptd: max_cpu_qlen set to 1000
[[    0.433499] console [ttyFIQ0] enabled
[    0.441186] bootconsole [uart8250] disabled
[    0.445968] Registered fiq debugger ttyFIQ0
[    0.446676] vcc5v0_sys: supplied by vcc12v
[    0.446967] vcc3v3_sys: supplied by vcc5v0_sys
[    0.447248] vcc3v3: supplied by vcc5v0_sys
[    0.447518] vcc1v8: supplied by vcc3v3
[    0.447799] vcc1v2: supplied by vcc3v3
[    0.448084] vcc2v8: supplied by vcc3v3
[    0.448396] vcc3v3_lcd2_n: supplied by vcc3v3_sys
[    0.448676] vcc2v5-sys: supplied by vcc3v3_sys
[    0.450307] rk_iommu fde4b000.iommu: version = 2
[    0.450820] rk_iommu fdea0800.iommu: version = 2
[    0.451142] rk_iommu fded0480.iommu: version = 2
[    0.451370] rk_iommu fdee0800.iommu: version = 2
[    0.451592] rk_iommu fdef0800.iommu: version = 2
[    0.451803] rk_iommu fdf40f00.iommu: version = 2
[    0.452058] rk_iommu fdf80800.iommu: version = 2
[    0.452275] rk_iommu fdff1a00.iommu: version = 2
[    0.452487] rk_iommu fe043e00.iommu: version = 2
[    0.453196] SCSI subsystem initialized
[    0.453406] usbcore: registered new inte**ce driver usbfs
[    0.453458] usbcore: registered new inte**ce driver hub
[    0.453510] usbcore: registered new device driver usb
[    0.453592] media: Linux media inte**ce: v0.10
[    0.453633] videodev: Linux video capture inte**ce: v2.00
[    0.453709] pps_core: LinuxPPS API ver. 1 registered
[    0.453724] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.453749] PTP clock support registered
[    0.454010] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.456019] Advanced Linux Sound Architecture Driver Initialized.
[    0.456411] Bluetooth: Core ver 2.22
[    0.456456] NET: Registered protocol family 31
[    0.456472] Bluetooth: HCI device and connection manager initialized
[    0.456493] Bluetooth: HCI socket layer initialized
[    0.456508] Bluetooth: L2CAP socket layer initialized
[    0.456542] Bluetooth: SCO socket layer initialized
[    0.456999] rockchip-cpuinfo cpuinfo: SoC                : 35682000
[    0.457017] rockchip-cpuinfo cpuinfo: Serial                : 2783bd5af391780f
[    0.457739] clocksource: Switched to clocksource arch_sys_counter
[    0.519201] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.519485] NET: Registered protocol family 2
[    0.519685] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.520971] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[    0.521049] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.521283] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.522001] TCP: Hash tables configured (established 32768 bind 32768)
[    0.522137] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.522316] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.522599] NET: Registered protocol family 1
[    0.523019] RPC: Registered named UNIX socket transport module.
[    0.523035] RPC: Registered udp transport module.
[    0.523047] RPC: Registered tcp transport module.
[    0.523058] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.525090] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.526793] Initialise system trusted keyrings
[    0.526964] workingset: timestamp_bits=61 max_order=20 bucket_order=0
[    0.531995] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.532662] NFS: Registering the id_resolver key type
[    0.532698] Key type id_resolver registered
[    0.532713] Key type id_legacy registered
[    0.532747] ntfs: driver 2.1.32 [Flags: R/O].
[    0.532912] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[    0.533089] fuse init (API version 7.27)
[    0.533446] SGI XFS with security attributes, no debug enabled
[    0.535456] NET: Registered protocol family 38
[    0.535488] Key type asymmetric registered
[    0.535504] Asymmetric key parser 'x509' registered
[    0.535551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.535567] io scheduler noop registered
[    0.535580] io scheduler deadline registered
[    0.535678] io scheduler cfq registered (default)
[    0.535694] io scheduler mq-deadline registered
[    0.535707] io scheduler kyber registered
[    0.536671] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[    0.536813] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    0.539118] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[    0.540196] extcon extcon1: failed to create extcon usb2-phy link
[    0.540448] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.548863] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.3
[    0.549296] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
RK3568通行证
yuchangdian 发表于 2025-11-4 16:26:00 | 显示全部楼层
根楼主一样的问题
