查看: 2995|回复: 1
[硬件咨询] 版本启动到10s左右直接重启,反复如此
jerry2018 发表于 2024-4-8 15:59:36 | 显示全部楼层 |阅读模式
核心板自带软件版本为  SMP Thu Oct 12 16:29:26 CST 2023 ,  可以在我们自己的板卡上正常启动;
而我自己编译的版本则不能正常启动;
但是该核心板放在官方提供的开发板上却是能够启动的;  也就是说,在 我们自制板卡上,烧录是成功的,但是启动是失败的;换到飞凌开发底板则能够启动成功;
之前电话沟通,似乎说什么禁用某个pcie,已经记不清了,请继续支持一下
[    0.543272] Key type asymmetric registered
[    0.543288] Asymmetric key parser 'x509' registered
[    0.543339] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.543357] io scheduler noop registered
[    0.543370] io scheduler deadline registered
[    0.543477] io scheduler cfq registered (default)
[    0.543495] io scheduler mq-deadline registered
[    0.543508] io scheduler kyber registered
[    0.544487] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[    0.544633] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    0.547071] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[    0.548175] extcon extcon1: failed to create extcon usb2-phy link
[    0.548442] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.557549] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.3
[    0.557807] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.3
[    0.557830] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[    0.557861] rk-pcie 3c0000000.pcie: Missing *config* reg space
[    0.557881] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    0.557910] rk-pcie 3c0000000.pcie:   err 0x300000000..0x3007fffff -> 0x00000000
[    0.557932] rk-pcie 3c0000000.pcie:    IO 0x300800000..0x3008fffff -> 0x00800000
[    0.557952] rk-pcie 3c0000000.pcie:   MEM 0x300900000..0x33fffffff -> 0x00900000
[    0.558417] pwm-backlight dsi1-backlight: dsi1-backlight supply power not found, using dummy regulator
[    0.558478] pwm-backlight dsi1-backlight: Linked as a consumer to regulator.0
[    1.575532] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    2.588865] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    3.602210] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    4.615543] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    5.628875] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    6.642209] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    7.655542] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    8.668875] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[    9.682210] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   10.695542] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
[   11.708873] rk-pcie 3c0000000.pcie: PCIe Link Fail
[   11.708893] rk-pcie 3c0000000.pcie: failed to initialize host
DDR V1.15 ec2fae0c96 huan.he 22/11/08-20:06:42
In
ddrconfig:15
楼主| jerry2018 发表于 2024-4-8 16:58:15 | 显示全部楼层
注释掉OK3568-C-linux_defconfig中CONFIG_PHY_ROCKCHIP_PCIE=y 即可正常启动
