查看: 2738|回复: 1
[Linux] iMX8MM烧录最新固件编译的rootfs.sdcard后启动不了
苏工 发表于 2024-6-12 11:35:23 | 显示全部楼层 |阅读模式
iMX8MM烧录最新固件编译的rootfs.sdcard后启动不了,始终卡在下面串口打印信息的这个位置。下载的是这个固件,没做任何修改就直接./build.sh full,求解
forlinx eep: 2022-06-20 ver 1
eep: now update emmc pins for bootrom
using eep parameter
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
image offset 0x0, pagesize 0x200, ivt offset 0x0
NOTICE:  BL31: v2.2(release):rel_imx_5.4.70_2.3.0-0-gf1d7187f2
NOTICE:  BL31: Built : 03:31:00, Apr  8 2021
Forlinx
U-Boot 2020.04-00016-gc934c03999 (Apr 10 2023 - 05:59:11 +0000)
CPU:   i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 44C
Reset cause: POR
Model: Forlinx OK8MPlus LPDDR4 EVK board
DRAM:  4 GiB
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
try kernel dtb
Error binding driver 'gpio_led': -22
Some drivers failed to bind
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
lvds0_panel enable
mipi_panel_uboot enable
eth0 enable
eth1 enable
Loading Environment from MMC... *** Warning - bad CRC, using default environment
video link is full
  • -Video Link 0 (1024 x 600)
            [0] lcd-controller@32e80000, video
            [1] mipi_dsi@32e60000, video_bridge
            [2] mipi_panel_uboot, panel
  • -Video Link 1 (1280 x 800)
            [0] lcd-controller@32e90000, video
            [1] ldb@32ec005c, video_bridge
            [2] lvds0_panel, panel
    [ ]-Video Link 2
    In:    serial
    Out:   serial
    Err:   serial
    BuildInfo:
      - ATF f1d7187
      - U-Boot 2020.04-00016-gc934c03999
    switch to partitions #0, OK
    mmc2(part 0) is current device
    secure check passed
    board_late_init: Can't find device id=0x1a, on bus 2
    flash target is MMC:2
    Net:   config yt8521
    eth0: ethernet@30be0000
    Fastboot: Normal
    Normal Boot
    Autoboot in 1 seconds
    Booting from net ...
    ethernet@30be0000 Waiting for PHY auto negotiation to complete... done
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    BOOTP broadcast 6
    BOOTP broadcast 7
    BOOTP broadcast 8
    BOOTP broadcast 9
    BOOTP broadcast 10
    BOOTP broadcast 11
    BOOTP broadcast 12
    BOOTP broadcast 13
    BOOTP broadcast 14
    BOOTP broadcast 15
    BOOTP broadcast 16
    BOOTP broadcast 17
    Retry time exceeded; starting again
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    BOOTP broadcast 6
    BOOTP broadcast 7
    BOOTP broadcast 8
    BOOTP broadcast 9
    BOOTP broadcast 10
    BOOTP broadcast 11
    BOOTP broadcast 12
    BOOTP broadcast 13
    BOOTP broadcast 14
    BOOTP broadcast 15
    BOOTP broadcast 16
    BOOTP broadcast 17
    WARN: Cannot load the DT
    1: shell
    2: boot linux
    3: Display select
    0: reboot uboot
  • 回复
    楼主| 苏工 发表于 2024-6-12 11:37:27 | 显示全部楼层
    选择1了以后,输入这个
    forlinx=> bootm
    ## Loading kernel from FIT Image at 43000000 ...
    Bad FIT kernel image format!
    ERROR: can't get kernel image!
    forlinx=>
